    4. js-controller 3.0/3.1 jetzt im Latest!
    • ostseereiter
      ostseereiter last edited by ostseereiter
      Das Update des js-controller 3.0.14 und admin 4.0.9 lief durch. Im Moment keine Auffälligkeiten.
      • wendy2702
        Update von 3.0.13 nach 3.0.14.
        @apollon77 : Sayit upload hatte ich vorher gemacht. Jetzt kommt das:
        2020-04-21 20:58:15.785  - warn: readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.1 is not an object of type "meta"
        2020-04-21 20:58:15.809  - warn: readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.1 is not an object of type "meta"
        2020-04-21 20:58:15.812  - warn: readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.1 is not an object of type "meta"
        2020-04-21 20:58:15.813  - warn: readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.1 is not an object of type "meta"
        Und das hier beim Yamaha Adapter: (Sorry falls es schon erwähnt wurde)
        2020-04-21 20:59:08.020  - warn: yamaha.0 (32612) Object yamaha.0.Commands.volumeUp is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
        2020-04-21 20:59:08.020  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
        2020-04-21 20:59:08.022  - warn: yamaha.0 (32612) Object yamaha.0.Commands.volumeDown is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
        2020-04-21 20:59:08.022  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
        2020-04-21 20:59:08.023  - warn: yamaha.0 (32612) Object yamaha.0.Commands.adjustVolume is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
        2020-04-21 20:59:08.024  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
        2020-04-21 20:59:08.027  - warn: yamaha.0 (32612) Object yamaha.0.volume is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
        2020-04-21 20:59:08.027  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
        Issue für Yamaha: https://github.com/iobroker-community-adapters/ioBroker.yamaha-community/issues/14
        wendy2702 created this issue in iobroker-community-adapters/ioBroker.yamaha-community
        closed Warnings with JS-Controller 3.0.14 #14
        • JB_Sullivan
          JB_Sullivan last edited by JB_Sullivan
          Nach dem Update auf 3.0.14 und Admin 4.0.9 habe ich jetzt einen bunten Strauß an Warn und Fehlermeldungen von verschiedenen Adaptern (vorher NULL Fehlermeldungen)
          tr-064.0	2020-04-21 21:35:37.299	error	(10884) Password error: Please re-enter the password in Admin. Stopping
          fritzbox.0	2020-04-21 21:35:41.038	warn	(6452) restartConnection: 10.IP.IP.
          fritzbox.0	2020-04-21 21:35:41.035	info	(6452) adapter connected to fritzbox: 10.IP.IP.
          innogy-smarthome.0	2020-04-21 21:37:02.227	debug	(8720) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
          innogy-smarthome.0	2020-04-21 21:37:02.202	info	(8720) Terminated (NO_ERROR): Without reason
          innogy-smarthome.0	2020-04-21 21:37:02.200	info	(8720) terminating
          innogy-smarthome.0	2020-04-21 21:37:02.192	debug	(8720) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
          innogy-smarthome.0	2020-04-21 21:37:02.188	error	at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
          innogy-smarthome.0	2020-04-21 21:37:02.188	error	(8720) Error: read ECONNRESET
          innogy-smarthome.0	2020-04-21 21:37:02.188	error	(8720) uncaught exception: read ECONNRESET
          Irgendwie hat man das Gefühl, das alles was mit FritzBox zu tun hat gerade kollabiert.
          tr-064.0	2020-04-21 21:49:03.583	warn	at process.topLevelDomainCallback (domain.js:126:23)
          tr-064.0	2020-04-21 21:49:03.583	warn	at processImmediate (timers.js:658:5)
          tr-064.0	2020-04-21 21:49:03.583	warn	at tryOnImmediate (timers.js:676:5)
          tr-064.0	2020-04-21 21:49:03.583	warn	at runCallback (timers.js:705:18)
          tr-064.0	2020-04-21 21:49:03.583	warn	at Immediate.setImmediate (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:234:41)
          tr-064.0	2020-04-21 21:49:03.583	warn	at change (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\adapter.js:5228:34)
          tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.EventEmitter.emit (domain.js:448:20)
          tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.emit (events.js:198:13)
          tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.adapter.on.obj (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:92:41)
          tr-064.0	2020-04-21 21:49:03.583	warn	at onMessage (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:255:25)
          tr-064.0	2020-04-21 21:49:03.583	warn	(3316) TypeError: Cannot read property 'forEachHostEntry' of undefined
          tr-064.0	2020-04-21 21:49:03.561	warn	(3316) States system pmessage io.messagebox.system.adapter.tr-064.0 {"command":"discovery","message":{"onlyActive":true,"reread":false},"from":"system.adapter.admin.0","callback":{"message":{"onlyAct
          tr-064.0	2020-04-21 21:48:58.819	error	(3316) Password error: Please re-enter the password in Admin. Stopping
          tr-064.0	2020-04-21 21:48:58.798	info	(3316) starting. Version 4.0.0 in C:/iobroker/GLT/node_modules/iobroker.tr-064, node: v10.17.0, js-controller: 3.0.14
          host.GLT	2020-04-21 21:48:56.999	info	instance system.adapter.tr-064.0 started with pid 3316
          host.GLT	2020-04-21 21:48:56.978	info	"system.adapter.tr-064.0" enabled
          wendy2702 apollon77 2 Replies Last reply Reply Quote 0
            Flugschüler last edited by wendy2702
            Hallo!
            bin noch neu hier im Forum
            bei mir kommt immer das und dann startet mein js adapter neu.
            Kann mir vieleicht irgend wer helfen?
            host.raspberrypi	2020-04-21 20:49:09.462	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
            host.raspberrypi	2020-04-21 20:49:09.462	error	Caught by controller[1]: Error: connect EHOSTUNREACH 192.168.1.140:22
            host.raspberrypi	2020-04-21 20:49:09.461	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
            • wendy2702
              wendy2702 @JB_Sullivan last edited by
              @JB_Sullivan bei tr064 password neu eingegeben ?
              Bei Fritzbox die IP mal kontrollieren bzw. Eingeben.
              • wendy2702
                wendy2702 @Flugschüler last edited by
                @Flugschüler was hast du denn gemacht?
                Welche Version vom Controller?
                  Version 3.0.14 ich habe keine Fritzbox.
                  • wendy2702
                    @Flugschüler Fritzbox war nicht für dich gedacht.
                    Wohl aber die Frage was du gemacht hast.
                    • JB_Sullivan
                      JB_Sullivan @wendy2702 last edited by JB_Sullivan
                      @wendy2702 Na klar, alles kontrolliert und auch nochmal eingegeben - no way.
                      FritzDect Adapter genau das gleiche - immer Passwort Fehler, aber das PW ist 100%ig richtig
                      fritzdect.0	2020-04-21 21:56:02.467	error	(11792) Did not get session id- invalid username or password?
                      fritzdect.0	2020-04-21 21:56:02.467	error	(11792) fritzbox returned this "0000000000000000"
                      fritzdect.0	2020-04-21 21:56:00.477	info	(11792) SWITCH ID: 087610244490 identified for command (state) : true
                      fritzdect.0	2020-04-21 21:55:46.252	error	(11792) Did not get session id- invalid username or password?
                      fritzdect.0	2020-04-21 21:55:46.251	error	(11792) fritzbox returned this "0000000000000000"
                      Das interessante daran ist, das alle Instanzen grün sind.
                        Flugschüler last edited by Flugschüler
                        cd /opt/iobroker
                        sudo iobroker stop
                        sudo iobroker update
                        sudo iobroker upgrade self
                        sudo iobroker start
                        Das hab ich gemacht hab jetzt js controller 3.0.14 und der startet andauernd neu.
                        Ich glaube ich hab den Fehler gefunden.
                        Habe ein Blockly das einen ssh Befehl sendet, wenn das ausgeführt wird startet der js controller neu, aber warum?
                        Beim der Version 2.2.9 hats noch funktioniert.
                        • wendy2702
                          @Flugschüler eventuell was das „sudo“ der Fehler.
                          Ich spreche aus Erfahrung, auch wenn ich andere Probleme hatte.
                          Ich würde als erstes mal den Fixer laufen lassen.
                          sudo curl -sL https://iobroker.net/fix.sh | bash -
                            Flugschüler @wendy2702 last edited by
                            @wendy2702 Nein das Blockly mit dem ssh befehl ist schuld, wenn ich das deaktiviere ist der Fehler weg.
                            • wendy2702
                              @JB_Sullivan werden denn die Objecte aktualisiert?
                              Vielleicht hat die FB den User wegen zu vielen Fehlversuchen für eine gewisse Zeit gesperrt. Ähnlich dem WEB Admin login der Fritte.
                              Darüber gibt es hier auch Berichte.
                              Instanzen stoppen. Fritte neu starten, 15 Minuten warten und dann erneut probieren hat in den fällen geholfen.
                              Admin hast du 4.0.9 ?
                              • wendy2702
                                @Flugschüler Na dann...
                                Perfekt.
                                  @wendy2702 Nicht ganz, ich brauche das Blockly um einen anderen Raspberry herunter zu fahren. Hat beim alten js ja funktioniert.
                                  • Iccube
                                    Iccube last edited by
                                    nach dem update auf 3.0.14 und Admin 4.0.9 habe ich folgende Warnmeldung
                                    2020-04-21 22:22:10.934 - warn: writeFile will not write this file (/htmlinfo.html) in future versions: iqontrol.meta is not an object of type "meta"
                                    2020-04-21 22:22:10.939 - warn: writeFile will not write this file (htmlinfo.html) in future versions: iqontrol.meta is not an object of type "meta"
                                    Kann mir einer sagen was das heißt habe den iqontrol adapter nicht installiert
                                    • JB_Sullivan
                                      @wendy2702 Neustart der Fritzbox hat nichts gebrauch - selben Fehlermeldungen. Dafür funktioniert jetzt der ALXA2.0 Adapter auch nicht mehr - Proxy Problem
                                      • spotify
                                      • iot
                                      • cloud
                                      • telegram
                                      Alle Adapter feuern jetzt Error Meldungen raus. Irgend etwas ist da Oberfaul seit dem Update.
                                      Ich Rolle wieder zurück, das hat so keinen Zweck.
                                      • BBTown
                                        BBTown @JB_Sullivan last edited by BBTown
                                        @JB_Sullivan die letzten Meldungen kamen wahrscheinlich weil/während Du die Fritzbox gestartet hast, da zu derzeit diese Adapter keine Internetverbindung hatten. Diese Meldungen sollten also zeitnah erledigt sein.
                                        • JB_Sullivan
                                          JB_Sullivan @BBTown last edited by JB_Sullivan
                                          @BBTown
                                          Ich habe jetzt den ganzen PC (win10) auf dem ioB läuft nochmal komplett neu gestartet - ich lasse mich überraschen.
                                          Gut - die Fehler oben sind jetzt weg - aber alles was FritzBox Adapter betrifft funktioniert noch immer nicht.
                                          Lt. Fritzbox log kommt in der Tat vom ioBroker PC eine (bzw. dutzenden) Anfragen mit falschem Passwort. Das PW ist aber zu 100% richtig was ich verwende, dafür lege ich meine Hand ins Feuer.
                                          Was für Passwort Anfragen sendet denn ALLE Adapter die mit etwas mit der Fritte zu tun haben wollen?
                                            miggedy last edited by
                                            Habe von nodejs 10 auf 12 geupdated (wie gewünscht) ohne rebuild. Alle Adapter funktionierten nach einem einfachen iobroker start außer der BLE adapter der folgende Fehler zeigte:
                                            ble.0	2020-04-21 22:12:58.582	error	(31045) unhandled promise rejection: TypeError: Cannot read property 'on' of undefined
                                            ble.0	2020-04-21 22:12:58.580	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                            ble.0	2020-04-21 22:12:58.580	error	at fulfilled (/opt/iobroker/node_modules/iobroker.ble/build/main.js:5:58)
                                            ble.0	2020-04-21 22:12:58.580	error	at Generator.next (<anonymous>)
                                            ble.0	2020-04-21 22:12:58.580	error	at /opt/iobroker/node_modules/iobroker.ble/build/main.js:97:19
                                            ble.0	2020-04-21 22:12:58.580	error	(31045) TypeError: Cannot read property 'on' of undefined
                                            ble.0	2020-04-21 22:12:58.579	error	(31045) uncaught exception: Cannot read property 'on' of undefined
                                            ble.0	2020-04-21 22:12:58.574	error	the module (for instance, using `npm rebuild` or `npm install`).
                                            ble.0	2020-04-21 22:12:58.574	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                            ble.0	2020-04-21 22:12:58.574	error	NODE_MODULE_VERSION 64. This version of Node.js requires
                                            ble.0	2020-04-21 22:12:58.574	error	was compiled against a different Node.js version using
                                            ble.0	2020-04-21 22:12:58.574	error	(31045) Terminating because The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
                                            iobroker rebuild ble behob das Problem nicht, iobroker rebuild ble --install tat es allerdings. Ist dies etwas was an den js-controller berichtet werden sollte (zur Verbessrung des neuen auto-rebuild) oder ein Problem im BLE Adapter?
                                            js-controller
                                            127
                                            1340
                                            441920
