    4. Test Adapter fb-checkpresence v1.0.x
    • rschwartz
      rschwartz @afuerhoff last edited by
      @afuerhoff
      Danke - Fritzbox (mal wieder) neu gestartet, dann war der User weg... Neu angelegt.
      Jetzt neue Fehlermeldungen, aber die Instanz beendet sich immerhin nicht mehr von selber.
      Die Familienmitglieder finde ich in den Objekten, Anwesenheit/Zeiten werden aber nicht aktualisiert
      fb-checkpresence.0	2020-04-22 19:59:12.618	debug	(32142) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.611	debug	(32142) checkPresence first run
      fb-checkpresence.0	2020-04-22 19:59:12.609	error	(32142) soapAction status 500
      fb-checkpresence.0	2020-04-22 19:59:12.600	error	(32142) soapAction mesg<?xml version="1.0"?> <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <s:Fault> <faultcode>
      fb-checkpresence.0	2020-04-22 19:59:12.579	debug	(32142) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.575	debug	(32142) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.568	debug	(32142) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.534	debug	(32142) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.533	debug	(32142) createMemberObjects Ruth
      fb-checkpresence.0	2020-04-22 19:59:12.530	debug	(32142) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.528	debug	(32142) createMemberObjects Anne
      fb-checkpresence.0	2020-04-22 19:59:12.525	debug	(32142) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.522	debug	(32142) createMemberObjects Katharina
      fb-checkpresence.0	2020-04-22 19:59:12.519	debug	(32142) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-04-22 19:59:12.516	debug	(32142) createMemberObjects Rüdiger
      fb-checkpresence.0	2020-04-22 19:59:12.514	debug	(32142) function fb-devices false
      fb-checkpresence.0	2020-04-22 19:59:12.513	debug	(32142) createGlobalObjects
      fb-checkpresence.0	2020-04-22 19:59:12.509	debug	(32142) sslPort 49443
      fb-checkpresence.0	2020-04-22 19:59:12.489	debug	(32142) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:GetSecurity
      fb-checkpresence.0	2020-04-22 19:59:12.467	info	(32142) service GetSecurityPort is supported
      fb-checkpresence.0	2020-04-22 19:59:12.448	info	(32142) service X_AVM-DE_GetSpecificHostEntryByIP is supported
      fb-checkpresence.0	2020-04-22 19:59:12.412	info	(32142) service GetSpecificHostEntry is supported
      fb-checkpresence.0	2020-04-22 19:59:12.367	info	(32142) service X_AVM-DE_GetHostListPath is supported
      fb-checkpresence.0	2020-04-22 19:59:12.210	debug	(32142) configuration familymembers: [{"familymember":"Rüdiger","macaddress":"xx-xx:xx:xx:xx:xx","ipaddress":"","useip":false,"comment":"","enabled":true},{"familymember":"Katharina","macaddress":"48:
      fb-checkpresence.0	2020-04-22 19:59:12.200	debug	(32142) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
      fb-checkpresence.0	2020-04-22 19:59:12.197	debug	(32142) configuration history: <history.0>
      fb-checkpresence.0	2020-04-22 19:59:12.193	debug	(32142) configuration user: <fb-presence>
      fb-checkpresence.0	2020-04-22 19:59:12.191	info	(32142) start fb-checkpresence: ip-address: fritz.box polling interval: 1 Min.
      fb-checkpresence.0	2020-04-22 19:59:12.070	info	(32142) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.16.1, js-controller: 3.0.14
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @rschwartz last edited by
        @rschwartz
        Die Fehlermeldung ist leider nicht kpl. abgebildet. Der entscheidende Teil fehlt.
        rschwartz 1 Reply Last reply Reply Quote 0
        • rschwartz
          @afuerhoff Danke für die Geduld...
          fb-checkpresence.0	2020-04-22 20:47:23.183	error	(13056) soapAction status 500
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	</s:Envelope>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	</s:Body>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	</s:Fault>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	</detail>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	</UPnPError>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<errorDescription>Invalid Args</errorDescription>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<errorCode>402</errorCode>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<detail>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<faultstring>UPnPError</faultstring>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<faultcode>s:Client</faultcode>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<s:Fault>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<s:Body>
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
          fb-checkpresence.0	2020-04-22 20:47:23.182	error	(13056) soapAction mesg<?xml version="1.0"?>
          fb-checkpresence.0	2020-04-22 20:46:23.188	error	(13056) soapAction status 500
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	</s:Envelope>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	</s:Body>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	</s:Fault>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	</detail>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	</UPnPError>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<errorDescription>Invalid Args</errorDescription>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<errorCode>402</errorCode>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<detail>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<faultstring>UPnPError</faultstring>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<faultcode>s:Client</faultcode>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<s:Fault>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<s:Body>
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
          fb-checkpresence.0	2020-04-22 20:46:23.186	error	(13056) soapAction mesg<?xml version="1.0"?>
          • afuerhoff
            afuerhoff Developer @rschwartz last edited by afuerhoff
            @rschwartz sagte in Test Adapter fb-checkpresence v1.0.x:
            Invalid Args
            Bitte Mac-Adressen kontrollieren. Hier scheint ein Fehler zu sein. Hattest du vorher IP-Adressen angegeben? Hierfür gibt es jetzt ja ein eigenes Feld und den Schalter diese zu nutzen.
            • rschwartz
              @afuerhoff
              Die Familiengeräte waren über MAC definiert (alles via copy/paste direkt aus der Box). Ich habe jetzt jeweils die IP eingetragen und das entsprechende Häkchen gesetzt.
              Keine Fehlermeldungen mehr ...
              • afuerhoff
                @rschwartz
                Dann muss aber in der Mac noch ein Fehler gewesen sein. Warum per Copy/Paste. Du kannst doch den Dialog aufrufen und das Device anhaken.
                rschwartz Garfonso 2 Replies Last reply Reply Quote 0
                • rschwartz
                  @afuerhoff
                  grrh - ich habe auf "+" gedrückt und nicht auf den beschrifteten Button ...
                  • Garfonso
                    Garfonso Developer @afuerhoff last edited by
                    @afuerhoff
                    Das mit dem Anhanken ist ziemlich cool. 🙂 Das muss ich mir mal abgucken flöt
                    • JB_Sullivan
                      JB_Sullivan last edited by
                      Wieso bekomme ich diese Warnungen? Man sollte berücksichtigen, das die Fritzbox zwei IP & MAC Adressen speichert - je nachdem, ob ich mit dem Gerät via LAN oder Wlan ins Netzwerk gehe.
                      Alle Geräte die hier angemeckert werden sind solche LAN/Wlan Geräte
                      fb-checkpresence.0	2020-04-22 21:45:39.374	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> octopi B8:27:EB:5D:9E:8F
                      fb-checkpresence.0	2020-04-22 21:45:39.373	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> octopi B8:27:EB:08:CB:DA
                      fb-checkpresence.0	2020-04-22 21:45:39.372	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Samsung 68:27:37:0C:AB:C8
                      fb-checkpresence.0	2020-04-22 21:45:39.372	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Samsung 4C:ED:DE:EB:2F:50
                      fb-checkpresence.0	2020-04-22 21:45:39.366	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Nintendo-3DS B8:AE:6E:F8:CA:FB
                      fb-checkpresence.0	2020-04-22 21:45:39.365	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Nintendo-3DS B8:AE:6E:F5:CE:9D
                      fb-checkpresence.0	2020-04-22 21:45:39.365	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> MotionEyeOS B8:27:EB:6B:77:66
                      fb-checkpresence.0	2020-04-22 21:45:39.365	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> MotionEyeOS B8:27:EB:3E:22:33
                      fb-checkpresence.0	2020-04-22 21:45:39.364	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> IconiaTab 38:60:77:FF:1F:60
                      fb-checkpresence.0	2020-04-22 21:45:39.363	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> IconiaTab CC:AF:78:6E:7E:7F
                      fb-checkpresence.0	2020-04-22 21:45:39.362	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Fernseher-Kueche A8:A6:48:1D:82:CD
                      fb-checkpresence.0	2020-04-22 21:45:39.362	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Fernseher-Kueche C8:3D:D4:18:A5:EC
                      fb-checkpresence.0	2020-04-22 21:45:39.362	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> DESKTOP-DKHNV7B E4:BE:ED:4F:0A:4D
                      fb-checkpresence.0	2020-04-22 21:45:39.357	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> DESKTOP-DKHNV7B 60:45:CB:6D:23:35
                      • afuerhoff
                        afuerhoff Developer @Garfonso last edited by
                        @Garfonso
                        Gerne. Hat mich einiges an Zeit gekostet. Bin da nicht unbedingt der Spezialist.
                        • afuerhoff
                          afuerhoff Developer @JB_Sullivan last edited by afuerhoff
                          @JB_Sullivan
                          Die Fb-devices werden über den Namen als Objekt angelegt. Damit ist das ganze nicht eindeutig.
                          Kommt der Name zweimal vor, wird das Objekt aber nur einmal angelegt. Damit können die Werte nur für eine Mac-Adresse ermittelt werden. Die Warnung wird angezeigt, damit das auffällt und ggfs. korrigiert werden kann. Ich habe bei mir jeder Mac einen eindeutigen Namen gegeben.
                          • JB_Sullivan
                            Warum kommen diesen Meldungen überhaupt. Ich habe kein einziges Gerät aus der Liste in den Objekten. In den Objekten sind nur die Samrtphones der Familienmitglieder enthalten - keine sonstigen Netzwerk Geräte.
                            • afuerhoff
                              @JB_Sullivan
                              Es geht hier ja nicht um die Familienmitglieder, sondern um die FB-devices. Die Meldung könnte man ausblenden, wenn die Funktion nicht benutz wird.
                              • JB_Sullivan
                                Ach, ich habe es schon gefunden - Harken bei FB-Geräte erstellen war drin.
                                Der Datenpunkt fb-devices kann dann sicher auch gelöscht werden oder? Ist in meinem Fall ja eine Monster Liste.
                                • afuerhoff
                                  @JB_Sullivan
                                  Den kann man löschen.
                                  • Garfonso
                                    @afuerhoff
                                    Warum machst du es denn mit den Objekten so?
                                    Besser wäre es die MAC als objekt_id zu nehmen und den Namen dann gerne als Namen zu setzen. Das Problem mit dem Namen ist zum einen, dass er doppelt vorkommen kann und zum anderen, das er sich beliebig ändern kann. Beides ist bei der MAC ausgeschlossen und damit eignet sie sich besser als ID. (Das hatte ich auch letztens erst bei einer Diskussion mit einer Gruppe devs gelernt. Seitdem ist es in den best practices auch mit aufgenommen, da es nicht so ganz klar war -> aber aus ioBroker-Sicht sollte sich eine ObjektId nie ändern).
                                    • afuerhoff
                                      @Garfonso
                                      Aus meiner damaligen Sicht wollte ich sprechende Namen haben. Das Problem mit den Namen war bei mir auch nicht existent, da ich eindeutige Namen vergeben hatte. Heute würde ich auch eher die Mac verwenden. Hab schon überlegt, ob man das mit einem Schalter zum umstellen gestaltet. Aus Kompatibilitäts Gründen.
                                        e-s @afuerhoff last edited by
                                        @afuerhoff
                                        Wenn man mal seine fritte neu startet oder ein Update fährt, dann gibt es viele errors. Kannst du das eventuell abfangen?
                                        fb-checkpresence.1	2020-04-23 07:35:23.178	error	(2709) soapAction status 500
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Envelope>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Body>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Fault>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	</detail>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	</UPnPError>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<errorDescription>Action Failed</errorDescription>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<errorCode>501</errorCode>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<detail>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<faultstring>UPnPError</faultstring>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<faultcode>s:Client</faultcode>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Fault>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Body>
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                                        fb-checkpresence.1	2020-04-23 07:35:23.177	error	(2709) soapAction mesg<?xml version="1.0"?>
                                          sigi234 Forum Testing Most Active @afuerhoff last edited by sigi234
                                          @afuerhoff
                                          V 1.0.1
                                          Bei mir kommt das:
                                          fb-checkpresence.0	2020-04-23 09:17:30.216	error	(18168) Fb.getDeviceList Error: timeout of 2000ms exceeded
                                          fb-checkpresence.0	2020-04-23 09:15:41.560	error	(18168) soapAction [object Object]
                                          fb-checkpresence.0	2020-04-23 09:13:38.032	error	(18168) soapAction [object Object]
                                          Neuschwansteini afuerhoff 2 Replies Last reply Reply Quote 0
                                          • Neuschwansteini
                                            Neuschwansteini @sigi234 last edited by
                                            @sigi234 @afuerhoff
                                            Seit FritzBeta vorgestern und js-controller 3.0.14 läuft er bei mir auch nicht mehr sauber.
                                            Admin 4.0.9
                                            Bin gerade am löschen und mal komplett neu installieren...
                                            sigi234 E afuerhoff 3 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.9k
                                            avm fritzbox soap tr-064
                                            23
                                            248
                                            25468
