    4. js-controller 3.0/3.1 jetzt im Latest!
      Jan1 @e-s last edited by
      @e-s
      Das ist richtig, nur eben nicht böse.
      • dirk1962
        dirk1962 @dslraser last edited by
        @dslraser
        Das war aber schon bei der 3.0.14 so, danach hat aber auch alles funktioniert.
        • foxriver76
          foxriver76 Developer @dslraser last edited by
          @dslraser Danke, sehe das Problem.. fixen wir.
          dslraser 1 Reply Last reply Reply Quote 2
            crunchip Forum Testing Most Active last edited by crunchip
            habe gerade auch mal den Versuch gestartet über iobroker upgrade self auf v3.0.14.
            Es verlief fehlerfrei, bis auf ble.0 error im log(reiche ich nach), da iobroker aktuell gestoppt.
            Anschließend habe ich dann ein npm install auf v3.0.16 nachgelegt und stehe aktuell hier.
            root@IoBroker:/opt/iobroker# npm install iobroker.js-controller@3.0.16
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            > iobroker.js-controller@3.0.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.4
            > iobroker.js-controller@3.0.16 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            object system.certificates updated
            The following notifications happened during sync:
            - Ignoring Directory "cloud.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "covid-19.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "fb-checkpresence.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "iobroker.admin.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "iobroker.discovery.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "mqtt-client.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "multicast.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "nightscout.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "rssfeed.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"                                    } (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin                                    ","arch":"any"} (current: {"os":"linux","arch":"x64"})
            + iobroker.js-controller@3.0.16
            updated 1 package in 104.073s
            37 packages are looking for funding
              run `npm fund` for details
            nun die Frage, was jetzt am besten zu tun wäre
            EDIT: Nachgereichte Meldungen aus dem log
            (gekürztes log)
            2020-04-22 20:57:19.661 - warn: socketio.0 (29243) Empty pattern!
            2020-04-22 20:57:38.411 - error: ble.0 (1819) uncaught exception: undefined is not a valid state value
            2020-04-22 20:57:38.414 - error: ble.0 (1819) Error: undefined is not a valid state value
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1570:39
            at Adapter.setStateChanged (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5833:21)
            at Promise (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1567:16)
            at new Promise ()
            at Adapter.setStateChangedAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1566:16)
            at Noble. (/opt/iobroker/node_modules/iobroker.ble/build/main.js:331:35)
            at Generator.next ()
            at fulfilled (/opt/iobroker/node_modules/iobroker.ble/build/main.js:5:58)
            at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-04-22 20:57:38.416 - info: ble.0 (1819) stopping scan
            2020-04-22 20:57:38.418 - error: ble.0 (1819) unhandled promise rejection: Error: undefined is not a valid state value
            2020-04-22 21:03:11.206 - error: socketio.0 (29243) uncaught exception: Cannot read property 'sockets' of null
            2020-04-22 21:03:11.207 - error: socketio.0 (29243) TypeError: Cannot read property 'sockets' of null
            2020-04-22 21:03:13.611 - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2020-04-22 21:03:13.616 - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'sockets' of null
            2020-04-22 21:03:13.616 - error: host.IoBroker Caught by controller[0]: at Timeout.updateConnectedInfo (/opt/iobroker/node_modules/iobroker.socketio/lib/socket.js:1593:25)
            2020-04-22 21:03:13.616 - error: host.IoBroker Caught by controller[0]: at ontimeout (timers.js:436:11)
            2020-04-22 21:03:13.617 - error: host.IoBroker Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
            2020-04-22 21:03:13.617 - error: host.IoBroker Caught by controller[0]: at listOnTimeout (timers.js:263:5)
            2020-04-22 21:03:13.617 - error: host.IoBroker Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
            2020-04-22 21:03:13.617 - info: host.IoBroker instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            aktuell verbleibt jetzt noch
            ble.0	2020-04-22 21:45:33.027	info	(19500) starting scan for services ["fe95"]
            ble.0	2020-04-22 21:45:32.696	info	(19500) monitored services: fe95
            ble.0	2020-04-22 21:45:32.693	info	(19500) enabled plugins: Xiaomi, mi-flora, _default
            ble.0	2020-04-22 21:45:32.690	info	(19500) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
            ble.0	2020-04-22 21:45:32.420	info	(19500) starting. Version 0.11.1 in /opt/iobroker/node_modules/iobroker.ble, node: v10.20.1, js-controller: 3.0.16
            host.IoBroker	2020-04-22 21:45:28.794	info	instance system.adapter.ble.0 started with pid 19500
            host.IoBroker	2020-04-22 21:45:27.738	info	Restart adapter system.adapter.ble.0 because enabled
            host.IoBroker	2020-04-22 21:45:27.737	info	instance system.adapter.ble.0 terminated with code 0 (NO_ERROR)
            ble.0	2020-04-22 21:45:27.152	info	(19119) Terminated (NO_ERROR): Without reason
            ble.0	2020-04-22 21:45:27.149	info	(19119) terminating
            ble.0	2020-04-22 21:45:27.095	error	(19119) unhandled promise rejection: Error: undefined is not a valid state value
            ble.0	2020-04-22 21:45:27.092	info	(19119) stopping scan
            ble.0	2020-04-22 21:45:27.090	error	(19119) Error: undefined is not a valid state value at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1581:39 at Adapter.setStateChanged (/opt/iobroker/node_modules/iobroker.js
            ble.0	2020-04-22 21:45:27.086	error	(19119) uncaught exception: undefined is not a valid state value
            ble.0	2020-04-22 21:54:38.618	info	(22603) Terminated (NO_ERROR): Without reason
            ble.0	2020-04-22 21:54:38.615	info	(22603) terminating
            ble.0	2020-04-22 21:54:38.584	error	(22603) unhandled promise rejection: Error: undefined is not a valid state value
            ble.0	2020-04-22 21:54:38.576	info	(22603) stopping scan
            ble.0	2020-04-22 21:54:38.573	error	at process._tickCallback (internal/process/next_tick.js:68:7)
            ble.0	2020-04-22 21:54:38.573	error	at fulfilled (/opt/iobroker/node_modules/iobroker.ble/build/main.js:5:58)
            ble.0	2020-04-22 21:54:38.573	error	at Generator.next (<anonymous>)
            ble.0	2020-04-22 21:54:38.573	error	at Noble.<anonymous> (/opt/iobroker/node_modules/iobroker.ble/build/main.js:331:35)
            ble.0	2020-04-22 21:54:38.573	error	at Adapter.setStateChangedAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1577:16)
            ble.0	2020-04-22 21:54:38.573	error	at new Promise (<anonymous>)
            ble.0	2020-04-22 21:54:38.573	error	at Promise (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1578:16)
            ble.0	2020-04-22 21:54:38.573	error	at Adapter.setStateChanged (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5908:21)
            ble.0	2020-04-22 21:54:38.573	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1581:39
            ble.0	2020-04-22 21:54:38.573	error	(22603) Error: undefined is not a valid state value
            ble.0	2020-04-22 21:54:38.570	error	(22603) uncaught exception: undefined is not a valid state value
            mikeal created this issue in request/request
            open Request’s Past, Present and Future #3142
            wendy2702 apollon77 AlCalzone 3 Replies Last reply Reply Quote 0
            • wendy2702
              wendy2702 @crunchip last edited by wendy2702
              @crunchip iobroker starten.
              Wegen den Directory Sachen kannst du mal uploads der einzelnen Adapter probieren. Das hatte ich auch für Z.B. den Sayit adapter.
              Wenn Fehler dann weg ist gut, sonst Issue beim Adapter.
                crunchip Forum Testing Most Active @wendy2702 last edited by
                @wendy2702 cloud, multicast, nightscout und tr-64-community sind aber eigentlich gar nicht installiert
                wendy2702 apollon77 2 Replies Last reply Reply Quote 0
                • ostseereiter
                  ostseereiter @Jan1 last edited by
                  @Jan1 das ist schon richtig aber es gibt so wie ich wo der Iobroker schon seit 3 Jahren läuft und da geht es nun mal nur mit root
                  • wendy2702
                    @crunchip gibt es die Ordner denn?
                    Waren die vielleicht mal installiert?
                      apollon77 @crunchip last edited by
                      @crunchip mal schauen bei ble ob es ein update gibt sonst issiue anlegen. Ich weiss aber das @AlCalzone dran ist
                        @crunchip Waren Sie bestimmt mal 🙂 Kannst dann ignoreren oder manuell löschen
                          crunchip Forum Testing Most Active @apollon77 last edited by
                          @apollon77 es gibt aktuell 0.11.2, bin im Moment auf 0.11.1, ich teste mal
                          ja natürlich waren die mal installiert, wo finde ich die Dateien zum manuellen löschen?
                          • wendy2702
                            @crunchip
                            EDIT: sorry wahr im falschen FILM. Werde alt...
                            Hatte es vor 2 Tagen selber noch gepostet ..sogar mit Bild.
                            Duck und weg 😥
                              @crunchip ne die Files um die es hier geht liegen bei einem File Storage in iobroker-data/files/.. im ioBroker Verzeichnis
                              crunchip 1 Reply Last reply Reply Quote 1
                              • JB_Sullivan
                                JB_Sullivan last edited by
                                @apollon77
                                Ich hänge immer noch an dieser Kack Fritzbox Geschichte seit dem letzten Update.
                                Was macht eingentlich der Admin Adapter? Irgend etwas mit Rechte Verwaltung o.ä.?
                                Ich bin beim js-controller schon wieder zurück auf 0.2.2.9 aber der Admin ist noch auf 4.0.9.
                                Alles was mit der Fritzbox zu tun hat (siehe oben) scheitert angeblich am falschen Passwort. Hier z.B. die FritzDect Geräte - ich drehe noch durch.
                                fritzdect.0	2020-04-22 22:08:57.723	error	(10676) Did not get session id- invalid username or password?
                                fritzdect.0	2020-04-22 22:08:57.722	error	(10676) fritzbox returned this "0000000000000000"
                                fritzdect.0	2020-04-22 22:08:57.234	error	(10676) Did not get session id- invalid username or password?
                                fritzdect.0	2020-04-22 22:08:57.234	error	(10676) fritzbox returned this "0000000000000000"
                                apollon77 Chaot 2 Replies Last reply Reply Quote 0
                                  apollon77 @JB_Sullivan last edited by
                                  @JB_Sullivan Ist das ne ernste Frage was der Admin Adapter tut? 🙂
                                  • AlCalzone
                                    AlCalzone Developer @crunchip last edited by AlCalzone
                                    @crunchip v0.11.2 behebt den genannten Fehler.
                                      Hey ALl, wir müssen leider nach der etwas kaputten 3.0.15 gestern nochmal nachbessern:
                                      3.0.17 ist auf dem Weg ins Latest Repository.
                                      3.0.17 (2020-04-22) Release Elena
                                      • (Apollon77) make sure system.config objects has correct type
                                      • (foxriver76) make sure that callback of extend*Object returns object as before (was broken in 3.0.15)
                                      BBTown 1 Reply Last reply Reply Quote 3
                                        @apollon77 danke, da bin ich fündig geworden
                                        wobei ich hätte da im /opt/iobroker/node_modules/...noch sowas im Angebot
                                        • JB_Sullivan
                                          JB_Sullivan @apollon77 last edited by
                                          @apollon77 Das er für die Bedienung von ioBroker zuständig ist, ist mir schon klar, aber greift er auch irgendwie in die Passwort / Rechte Verwaltung von anderen Adaptern ein?
                                            crunchip Forum Testing Most Active @AlCalzone last edited by
                                            @AlCalzone danke für die Info, funktioniert wieder
                                            js-controller
                                            127
                                            1340
                                            444451
