    5. Anwesenheit an die CCU senden
    • BBTown
      BBTown @Torxplacid last edited by BBTown
      @Torxplacid
      ja, das paßt!!
      wobei das jetzt sogar noch viel kürzer geht, ich Dusssel ... gib mir einen kurzen Moment
      So, Anwesenheit ist doch längst geklärt, also können wir das so vereinfachen:
       <block type="schedule" id="pMiOilzaDIa$-(2RzzgW" x="-288" y="-262">
         <field name="SCHEDULE">0 23 * * *</field>
           <block type="control" id="{L_]/l^ct!%WP9XYKAiT">
             <field name="OID">Test.0.alarmScharf</field>
               <block type="logic_boolean" id="[uHz!yO=K8*8]S--]qH7">
           <block type="schedule" id="$)/qtdGHD21_^s6|c!Mp">
             <field name="SCHEDULE">30 5 * * *</field>
               <block type="control" id="if{KR,gc#(a@s,V4N{}W">
                   <block type="logic_boolean" id=")~{lB*DPh,}g0|xOuYo~">
               <block type="on_ext" id="]yt;9m?.g4K+$NAvT.y@">
                 <value name="OID0">
                   <shadow type="field_oid" id="Fm:b.Kt{%wQ+B#l(hY}-">
                     <field name="oid">Test.0.Anwesenheit</field>
                   <block type="controls_if" id="/U4e{%AtThu{1:Pk2%sb">
                       <block type="logic_compare" id="_w$T[;1O3vhK5|js(Y]d">
                         <field name="OP">EQ</field>
                           <block type="get_value" id="(+~1,)^vnjMI}W=@npg.">
                             <field name="OID">Test.0.Anwesenheit</field>
                           <block type="logic_boolean" id="(3im)^[KQJ8UI$lr6k#I">
                       <block type="control" id="OS(CJ7Z.U^b9Fo$uu/tN">
                           <block type="logic_boolean" id="`wGx3;y2Lk*U$rVy*wJR">
                     <value name="IF1">
                       <block type="logic_operation" id="m7IJ(~ddE*43~NCzz@8+" inline="false">
                         <field name="OP">AND</field>
                           <block type="logic_compare" id=";IwbpLyw2$cOU8GEqFN*">
                               <block type="get_value" id="3=qEi64/k}G$NrhW7NPM">
                               <block type="logic_boolean" id="Ct{HFPP?P,%ChvnVOg}^">
                           <block type="logic_compare" id="nUH%S!DoP,tQWWHJsBgE">
                               <block type="get_value" id="1@dZw5YNZLdCIy:XZ%fM">
                               <block type="logic_boolean" id="7BCNfVAlrv,Q)O%t|11Z">
                     <statement name="DO1">
                       <block type="control" id="A#U+ceX$:mFfQRv2b~4*">
                           <block type="logic_boolean" id="#Sz+_3a_;0[_1yD%%d2d">
        Torxplacid @BBTown last edited by
        @BBTown sagte in Anwesenheit an die CCU senden:
        @Torxplacid
        Script 3 - IPcam schalten
         <block type="on_ext" id="/?ue*JxRAhJY1O{Stu3R" x="13" y="13">
           <value name="OID0">
             <shadow type="field_oid" id="s?6;VPwa#]HTRELZV?BG">
               <field name="oid">Test.0.alarmScharf</field>
             <block type="controls_if" id="0.D7D7wpSz-W]d?|38TV">
                 <block type="get_value" id="!qg!X~z98v:|WsZR)Onx">
                 <block type="exec" id="bhlo4d5yuJAJX~1d!V]O">
                   <mutation with_statement="false"></mutation>
                   <field name="WITH_STATEMENT">FALSE</field>
                   <field name="LOG"></field>
                   <value name="COMMAND">
                     <shadow type="text" id="jl`(LEX2.ihGvn)w(2mS">
                       <field name="TEXT">http-Befehl (IPcam einschalten)</field>
               <statement name="ELSE">
                 <block type="exec" id="%A-sderr8{,eia?U9D~*">
                     <shadow type="text" id="3!!DrkNY@FZ6~d!MM%K`">
                       <field name="TEXT">http-Befeh (IPcam auschalten)</field>
        Ich glaube ich verstehe es doch nicht.
        Fehlt hier nicht der Wert auf den er wartet?
        • BBTown
          @Torxplacid sagte in Anwesenheit an die CCU senden:
          Die IPcam muss ab sofort nur noch schauen ob Alarm scharf ist oder nicht.
          Genau diesen Datenpunkt, der uns das sagt beobachten wir ab sofort, mehr brauchen wir hier (bei deiner bisher formulierten Anforderung) nicht - genau das ist ja der Kniff. Wir müssen hier nicht mehr die Bedingungen prüfen wie Alarm scharf gestellt wird, sondern nur OB Alarm scharf ist.
          Das ist das gleiche mit dem Script genau vor deiner Antwort (habe ich eben noch aktualisiert)
          Auch hier müssen wir nicht mehr die "Bedingung für die Anwesenheit" prüfen - die Anwesenheit haben wir anderweitig bereits geklärt.
            @BBTown
            Ok.
            Aber irgendwie ändern sich die Datenpunkte nicht.
            • BBTown
              @Torxplacid
              war denn um 23:00h dein Script schon fertig und aktiviert, so dass das Script um 23:00h überhaupt scharf stellen konnte?
              Du könntest die Uhrzeit im Script von 23:00h testweise mal auf 01:00h stellen und 5 Minuten warten
                @BBTown
                Wahrscheinlich nicht.
                Und die Anwesenheit regiert nicht weil keine Änderung da war?
                BBTown 2 Replies Last reply Reply Quote 0
                • BBTown
                  @Torxplacid exact
                  • BBTown
                    @Torxplacid stell doch mal den Zeitplan von 23:00h auf 01:00h um
                      @BBTown
                      ist umgesprungen auf true
                      • BBTown
                        @BBTown
                        • BBTown
                          BBTown @BBTown last edited by BBTown
                          @BBTown und wenn die anderen Scripte auch schon aktiv waren, sollte die IPcam nun auch gestartet sein (sofern diese nicht bereits vorher lief).
                          Ansonsten schalte sie mal aus und stelle den Zeitplan auf 01:05h und schau was mit der IPcam passiert
                            @BBTown
                            nope
                            exec is not available. Please enable "Enable Exec" option in instance settings
                            • BBTown
                              @Torxplacid
                              das mußt Du in den Einstellungen des JavaScript Adapters aktivieren und dann erneut den Zeitplan anpassen für den nächsten Versuch 🙂
                                Torxplacid @BBTown last edited by Torxplacid
                                @BBTown
                                habe ich geändert
                                funktioniert trotzdem nicht 😞
                                wenn ich den befehl im browser eingebe funktioniert es
                                • BBTown
                                  @Torxplacid
                                  Was erzählt denn das LOG?
                                    @BBTown
                                    javascript.0 2020-04-23 01:07:33.584 info (3357) script.js.Datenpunkte.Alarmscharf_Kopieren: registered 1 subscription and 2 schedules
                                    javascript.0 2020-04-23 01:07:33.526 info (3357) Start javascript script.js.Datenpunkte.Alarmscharf_Kopieren
                                    javascript.0 2020-04-23 01:07:33.399 info (3357) Stop script script.js.Datenpunkte.Alarmscharf_Kopieren
                                    javascript.0 2020-04-23 01:06:15.561 info (3357) script.js.Anwesenheit.Anwesend: registered 1 subscription and 2 schedules
                                    javascript.0 2020-04-23 01:06:15.539 info (3357) Start javascript script.js.Anwesenheit.Anwesend
                                    javascript.0 2020-04-23 01:06:15.538 info (3357) script.js.Datenpunkte.IP-Cam: registered 1 subscription and 0 schedules
                                    javascript.0 2020-04-23 01:06:15.529 info (3357) Start javascript script.js.Datenpunkte.IP-Cam
                                    javascript.0 2020-04-23 01:06:15.528 info (3357) script.js.Datenpunkte.Alarmscharf_Kopieren: registered 1 subscription and 2 schedules
                                    javascript.0 2020-04-23 01:06:15.477 info (3357) Start javascript script.js.Datenpunkte.Alarmscharf_Kopieren
                                    javascript.0 2020-04-23 01:06:15.476 info (3357) script.js.Datenpunkte.Anwesenheit: registered 1 subscription and 0 schedules
                                    javascript.0 2020-04-23 01:06:15.467 info (3357) Start javascript script.js.Datenpunkte.Anwesenheit
                                    javascript.0 2020-04-23 01:06:15.465 info (3357) script.js.Toniebox_Ladung: registered 2 subscriptions and 0 schedules
                                    javascript.0 2020-04-23 01:06:15.455 info (3357) Start javascript script.js.Toniebox_Ladung
                                    javascript.0 2020-04-23 01:06:15.453 info (3357) script.js.Staubsauger: registered 1 subscription and 0 schedules
                                    javascript.0 2020-04-23 01:06:15.410 info (3357) Start javascript script.js.Staubsauger
                                    javascript.0 2020-04-23 01:06:14.319 info (3357) received all states
                                    javascript.0 2020-04-23 01:06:14.187 info (3357) received all objects
                                    javascript.0 2020-04-23 01:06:12.014 info (3357) requesting all objects
                                    javascript.0 2020-04-23 01:06:12.007 info (3357) requesting all states
                                    javascript.0 2020-04-23 01:06:11.773 info (3357) starting. Version 4.3.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.1
                                    • BBTown
                                      @Torxplacid
                                      LOGs und Code immer "code-Tags" setzen !!
                                        @BBTown sorry
                                        • BBTown
                                          @Torxplacid war denn vor dem Ablauf des Zeitplans der Alarmscharf auch wieder auf "falsch", damit er zum Zeitplan auch umschalten kann??
                                            @BBTown
                                            jupp
                                            6539
