    5. Anwesenheit an die CCU senden
    • BBTown
      BBTown @Torxplacid last edited by
      @Torxplacid
      Was erzählt denn das LOG?
        Torxplacid @BBTown last edited by
        @BBTown
        javascript.0 2020-04-23 01:07:33.584 info (3357) script.js.Datenpunkte.Alarmscharf_Kopieren: registered 1 subscription and 2 schedules
        javascript.0 2020-04-23 01:07:33.526 info (3357) Start javascript script.js.Datenpunkte.Alarmscharf_Kopieren
        javascript.0 2020-04-23 01:07:33.399 info (3357) Stop script script.js.Datenpunkte.Alarmscharf_Kopieren
        javascript.0 2020-04-23 01:06:15.561 info (3357) script.js.Anwesenheit.Anwesend: registered 1 subscription and 2 schedules
        javascript.0 2020-04-23 01:06:15.539 info (3357) Start javascript script.js.Anwesenheit.Anwesend
        javascript.0 2020-04-23 01:06:15.538 info (3357) script.js.Datenpunkte.IP-Cam: registered 1 subscription and 0 schedules
        javascript.0 2020-04-23 01:06:15.529 info (3357) Start javascript script.js.Datenpunkte.IP-Cam
        javascript.0 2020-04-23 01:06:15.528 info (3357) script.js.Datenpunkte.Alarmscharf_Kopieren: registered 1 subscription and 2 schedules
        javascript.0 2020-04-23 01:06:15.477 info (3357) Start javascript script.js.Datenpunkte.Alarmscharf_Kopieren
        javascript.0 2020-04-23 01:06:15.476 info (3357) script.js.Datenpunkte.Anwesenheit: registered 1 subscription and 0 schedules
        javascript.0 2020-04-23 01:06:15.467 info (3357) Start javascript script.js.Datenpunkte.Anwesenheit
        javascript.0 2020-04-23 01:06:15.465 info (3357) script.js.Toniebox_Ladung: registered 2 subscriptions and 0 schedules
        javascript.0 2020-04-23 01:06:15.455 info (3357) Start javascript script.js.Toniebox_Ladung
        javascript.0 2020-04-23 01:06:15.453 info (3357) script.js.Staubsauger: registered 1 subscription and 0 schedules
        javascript.0 2020-04-23 01:06:15.410 info (3357) Start javascript script.js.Staubsauger
        javascript.0 2020-04-23 01:06:14.319 info (3357) received all states
        javascript.0 2020-04-23 01:06:14.187 info (3357) received all objects
        javascript.0 2020-04-23 01:06:12.014 info (3357) requesting all objects
        javascript.0 2020-04-23 01:06:12.007 info (3357) requesting all states
        javascript.0 2020-04-23 01:06:11.773 info (3357) starting. Version 4.3.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.1
        • BBTown
          @Torxplacid
          LOGs und Code immer "code-Tags" setzen !!
            @BBTown sorry
            • BBTown
              @Torxplacid war denn vor dem Ablauf des Zeitplans der Alarmscharf auch wieder auf "falsch", damit er zum Zeitplan auch umschalten kann??
                @BBTown
                jupp
                BBTown 2 Replies Last reply Reply Quote 0
                • BBTown
                  @Torxplacid
                  mach doch mal ein Blockly wo nur der http-Aufruf als Baustein drinne ist und aktiviere das Script, damit er auslöst
                    Torxplacid @BBTown last edited by Torxplacid
                    @BBTown
                    scheint nicht zu funktionieren
                    das muss ich im browser eingeben
                    http://user:passwort@ip:port/web/cgi-bin/hi3510/param.cgi?cmd=setscheduleex&-ename=md&-week0=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week1=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week2=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week3=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week4=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week5=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week6=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP
                    • BBTown
                      BBTown @Torxplacid last edited by BBTown
                      @Torxplacid
                      Kommando zurück, der Fehler liegt bei mir, ich habe dir einen falschen Baustein in das Script gepackt.
                      Das ist gar nicht der URL Baustein, das ist der Exec Baustein 🤦‍♂️ .... bitte einmal austauschen!!
                      [EDIT]
                      Ich habe es im Beitrag weiter oben nun auch korrigiert
                        @BBTown
                        ahhhhh
                        jetzt funktioniert es
                        • BBTown
                          @Torxplacid
                          dann spiel doch noch einmal mit dem Zeitplan für Ein- und für Ausschalten als Abschluss
                            @BBTown
                            Super vielen Dank nochmal 👍
                            Habe ich schon 🙂
                            • BBTown
                              @Torxplacid
                              sorry, für den Fehler ... Fehler 40 .... der Fehler sitzt 40cm vor dem Bildschirm 😉
                                @BBTown 😁
                                Ich hätte alleine bestimmt 40 fehler eingebaut
                                • BBTown
                                  @Torxplacid
                                  Dann sage ich mal gute Nacht, die ist für mich nämlich um 06:00h zu Ende 😬
                                    @BBTown 🙄
                                    Ja gute nacht und vielen vielen dank
                                    • BBTown
                                      @Torxplacid
                                      sehr gern, wir haben ja fast alle ähnlich angefangen 😉
                                        @BBTown 🙂
                                        Ich habe nochmal das erste Skript was für die Anwesenheit der CCU ist bearbeitet und versucht die Datenpunkte einzubauen.
                                        Sollte das laufen oder bin ich schon wieder auf dem Holzweg?
                                        • BBTown
                                          @Torxplacid ich verstehe nicht was Du vorhast
                                            @BBTown sagte in Anwesenheit an die CCU senden:
                                            Das ersetzten?
                                            6539
