    5. Anwesenheit an die CCU senden
    • BBTown
      BBTown @Torxplacid last edited by
      @Torxplacid
      LOGs und Code immer "code-Tags" setzen !!
        Torxplacid @BBTown last edited by
        @BBTown sorry
        javascript.0	2020-04-23 01:07:33.584	info	(3357) script.js.Datenpunkte.Alarmscharf_Kopieren: registered 1 subscription and 2 schedules
        javascript.0	2020-04-23 01:07:33.526	info	(3357) Start javascript script.js.Datenpunkte.Alarmscharf_Kopieren
        javascript.0	2020-04-23 01:07:33.399	info	(3357) Stop script script.js.Datenpunkte.Alarmscharf_Kopieren
        javascript.0	2020-04-23 01:06:15.561	info	(3357) script.js.Anwesenheit.Anwesend: registered 1 subscription and 2 schedules
        javascript.0	2020-04-23 01:06:15.539	info	(3357) Start javascript script.js.Anwesenheit.Anwesend
        javascript.0	2020-04-23 01:06:15.538	info	(3357) script.js.Datenpunkte.IP-Cam: registered 1 subscription and 0 schedules
        javascript.0	2020-04-23 01:06:15.529	info	(3357) Start javascript script.js.Datenpunkte.IP-Cam
        javascript.0	2020-04-23 01:06:15.528	info	(3357) script.js.Datenpunkte.Alarmscharf_Kopieren: registered 1 subscription and 2 schedules
        javascript.0	2020-04-23 01:06:15.477	info	(3357) Start javascript script.js.Datenpunkte.Alarmscharf_Kopieren
        javascript.0	2020-04-23 01:06:15.476	info	(3357) script.js.Datenpunkte.Anwesenheit: registered 1 subscription and 0 schedules
        javascript.0	2020-04-23 01:06:15.467	info	(3357) Start javascript script.js.Datenpunkte.Anwesenheit
        javascript.0	2020-04-23 01:06:15.465	info	(3357) script.js.Toniebox_Ladung: registered 2 subscriptions and 0 schedules
        javascript.0	2020-04-23 01:06:15.455	info	(3357) Start javascript script.js.Toniebox_Ladung
        javascript.0	2020-04-23 01:06:15.453	info	(3357) script.js.Staubsauger: registered 1 subscription and 0 schedules
        javascript.0	2020-04-23 01:06:15.410	info	(3357) Start javascript script.js.Staubsauger
        javascript.0	2020-04-23 01:06:14.319	info	(3357) received all states
        javascript.0	2020-04-23 01:06:14.187	info	(3357) received all objects
        javascript.0	2020-04-23 01:06:12.014	info	(3357) requesting all objects
        javascript.0	2020-04-23 01:06:12.007	info	(3357) requesting all states
        javascript.0	2020-04-23 01:06:11.773	info	(3357) starting. Version 4.3.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.1
        • BBTown
          @Torxplacid war denn vor dem Ablauf des Zeitplans der Alarmscharf auch wieder auf "falsch", damit er zum Zeitplan auch umschalten kann??
            @BBTown
            jupp
            BBTown 2 Replies Last reply Reply Quote 0
            • BBTown
              @Torxplacid
              mach doch mal ein Blockly wo nur der http-Aufruf als Baustein drinne ist und aktiviere das Script, damit er auslöst
                Torxplacid @BBTown last edited by Torxplacid
                @BBTown
                scheint nicht zu funktionieren
                das muss ich im browser eingeben
                http://user:passwort@ip:port/web/cgi-bin/hi3510/param.cgi?cmd=setscheduleex&-ename=md&-week0=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week1=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week2=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week3=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week4=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week5=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP&-week6=PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP
                • BBTown
                  BBTown @Torxplacid last edited by BBTown
                  @Torxplacid
                  Kommando zurück, der Fehler liegt bei mir, ich habe dir einen falschen Baustein in das Script gepackt.
                  Das ist gar nicht der URL Baustein, das ist der Exec Baustein 🤦‍♂️ .... bitte einmal austauschen!!
                  [EDIT]
                  Ich habe es im Beitrag weiter oben nun auch korrigiert
                    @BBTown
                    ahhhhh
                    jetzt funktioniert es
                    • BBTown
                      @Torxplacid
                      dann spiel doch noch einmal mit dem Zeitplan für Ein- und für Ausschalten als Abschluss
                        @BBTown
                        Super vielen Dank nochmal 👍
                        Habe ich schon 🙂
                        • BBTown
                          @Torxplacid
                          sorry, für den Fehler ... Fehler 40 .... der Fehler sitzt 40cm vor dem Bildschirm 😉
                            @BBTown 😁
                            Ich hätte alleine bestimmt 40 fehler eingebaut
                            • BBTown
                              @Torxplacid
                              Dann sage ich mal gute Nacht, die ist für mich nämlich um 06:00h zu Ende 😬
                                @BBTown 🙄
                                Ja gute nacht und vielen vielen dank
                                • BBTown
                                  @Torxplacid
                                  sehr gern, wir haben ja fast alle ähnlich angefangen 😉
                                    @BBTown 🙂
                                    Ich habe nochmal das erste Skript was für die Anwesenheit der CCU ist bearbeitet und versucht die Datenpunkte einzubauen.
                                    Sollte das laufen oder bin ich schon wieder auf dem Holzweg?
                                    • BBTown
                                      @Torxplacid ich verstehe nicht was Du vorhast
                                        @BBTown sagte in Anwesenheit an die CCU senden:
                                        Das ersetzten?
                                        • BBTown
                                          @Torxplacid
                                          warum und womit?
                                          .... und wo kommt plätzlich die "var_Anwesend" her bzw. was soll das?
                                          bei mir steht etwas anderes
                                            @BBTown
                                            Meine Frage ist nur ob ich das alte Script duch das neue ersetzten kann?
                                            In dem anderen habe ich die Datenpunkte von gestern berücksichtig.
                                            Nacht ist wahr zwischen 23 und 5:30
                                            Anwesend richtet sich nur den G-Tags
                                            6539
