    5. Überprüfen ob Aktor Steuerbefehl erhalten hat...
      paul53 @AnamCara last edited by
      @AnamCara sagte:
      ein Beispiel block
      Versuche es mal so:
       <variables>
         <variable type="" id="V*8SecbOYtdYL9J2Van6">soll</variable>
         <variable type="undefined" id="timeout">timeout</variable>
       </variables>
       <block type="comment" id="RgU^FnFCeCG_^Y(n|v11" x="63" y="-13">
         <field name="COMMENT">Rollo-Aktor</field>
           <block type="on_ext" id="T+m`])pthE4_/)0c*(0q">
             <value name="OID0">
               <shadow type="field_oid" id="#Xdo7tmN|+t~RtIf=37P">
               <block type="controls_if" id="-$8{Ruml{`Qoi-^0g2D`">
                   <block type="on_source" id="gNOVaU5R67SYrH=kMQDy">
                     <field name="ATTR">state.ack</field>
                   <block type="controls_if" id="axAh.K[$bN8D}G:qJEk3">
                       <block type="logic_compare" id="*1Iuc|oaj(69[!}`/K_I">
                         <field name="OP">EQ</field>
                           <block type="variables_get" id="j{~6nAgws8dt;HIcCyZ0">
                             <field name="VAR" id="V*8SecbOYtdYL9J2Van6" variabletype="">soll</field>
                           <block type="on_source" id="n;uB,)b1K`MC.K$[[#0z">
                       <block type="timeouts_cleartimeout" id="#H91=^8g1qS.DR!uKi_z">
                 <statement name="ELSE">
                   <block type="controls_if" id="hx_UgF=#TXr$#.]3kZn-">
                       <block type="logic_compare" id="cqIWn@pqC}p5RE[qG@aM">
                         <field name="OP">NEQ</field>
                           <block type="on_source" id="1Js7~v99vM2NE![EK=uk">
                           <block type="on_source" id="8gh(8~j*:r!f{a);P%!n">
                             <field name="ATTR">oldState.val</field>
                       <block type="variables_set" id="JF1d5qm(@kADj.U:Y_7w">
                           <block type="on_source" id="]]O{h!-K=v+bkT[A__Tn">
                           <block type="comment" id="Igmu@H4dny_-b83dcQ,D">
                             <field name="COMMENT">Rollolaufzeit</field>
                               <block type="timeouts_settimeout" id="9,8Pim2S3B`0e{!m#wXA">
                                 <field name="DELAY">40</field>
                                   <block type="control_ex" id="BM^Z@TKLWjul@o+qBVTW" inline="true">
                                     <value name="OID">
                                       <shadow type="field_oid" id="tn5Ne#?fV0)mN2$/d{-h">
                                         <field name="oid">Object ID</field>
                                       <block type="on_source" id="F%sycofU*{erdq^cwI=a">
                                         <field name="ATTR">id</field>
                                       <shadow type="logic_boolean" id="z-vY3}.J}w/FR4QzJY5N">
                                       <block type="variables_get" id="_zC%ow0d1y./++~T:M{J">
                                     <value name="DELAY_MS">
                                       <shadow type="math_number" id="mhn]=?1`Z|KH:xj6x:%F">
                                         <field name="NUM">0</field>
      AnamCara 1 Reply Last reply Reply Quote 1
      • AnamCara
        AnamCara @paul53 last edited by
        @Homoran said in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
        dann gehe mal auf die CCU unter Systemsteuerung und devconfig und suche da nach rssi (jetzt aus dem Kopf)
        dort wird gezeigt wie gut der Empfang ist
        Mhmh, das kann ich nicht finden, Du meinst doch die WEBUI?
        @paul53 said in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
        Versuche es mal so:
        Das schau ich mir mal später an...
        Herzlichen Dank erst mal!
        • DAN78
          DAN78 last edited by DAN78
          @AnamCara Hallo,
          auch ich hatte anfangs ähnliche Probleme mit den Rolladenaktoren.
          Zwar sind bei mir diejenigen von Homematic (ohne IP) verbaut, aber möglicher Weiße können dir diese Infos weiterhelfen. Eine Lösung mittels Skript wie von dir gewünscht ist weiter unten
          1. Homematic Funkgeräte wünschen untereinander einen Mindestabstand von 20 cm.
            Wusste das beim Kauf nicht und habe diese Aktoren in einer Berker Leiste nebeneinander verbaut, versetzen wollte ich diese Beiden aus ästhetische Gründe nicht.
            Das Zeitliche versetzen der Startbefehle für mehreren Rolladen ist sinnvoll, half aber bei der Lösung des Problem nicht wirklich viel. Die Situation verbesserte sich ein wenig. Abhilfe schaffte das ausbauen und um 180 Grad wieder montieren des Aktors. Abdeckplatte passt auch umgedreht und die Internen Tasten des Aktors können in der CCU konfiguriert werden.
            Als Zeitversatz habe ich 40 Sekunden gewählt, meine Rolladen brauchen um die 30 Sekunden von Level 0-100. So stelle ich sicher dass jedes Rollo nur einzeln fährt. Funkbefehle gibt es auch während der Fahrt.
          2. Ablauf der Befehle (so weit ich mitbekommen bin)
            Eingabe eines Werts in Objekt "LEVEL"
            a) CCU erteilt Befehl an Aktor den eingegebenen Wert anzusteuern
            b) CCU erhält während- und beim Abschluss der Aktion Updtates zum Wert von Objekt bzw. Rückmeldungen.
          Läuft alles normal blinkt im iobroker der Wert dieses Objekts nach Status-Änderungen kurz auf. Bleiben die Rückmeldungen aus wird der Wert rot dargestellt. In der CCU wirst du die Fehlermeldung "Kommunikationsstörung" finden.
          Du kannst diese Tatsache beim erstellen der Skripte berücksichtigen.
          Es ist möglich den anerkannt Status eines Objekt abzufragen. Falls es mal ein "nicht anerkannt" geben sollte, Befehl wiederholen. Bei einen zweiten Versuch wird das ganze auch klappen. (Anerkannt bei Trigger: "Update" für aktualisiere Objekt ID bzw. "Befehl" für steuere Objekt ID)
          Ob's Störung gab kannst man in der CCU immer noch verfolgen. Dort wird in diesem Fall die Fehlermeldung "Kommunikation WAR gestört" gelistet sein.
          Zu HM-IP: Ich hab vier Stück Unterputz Schaltaktoren. Diese reagierten sporadisch nicht mehr. Ein Triggern von "nicht-anerkannt" nutzte bei diesen Geräten nicht weshalb durch unbegrenzte Schaltbefehlen der Duty Cylke stark anstieg. Sicherheitshalber empfehle ich dir in deinen Skripte die anzahl der Versuche zu limitieren.
          Abhilfe verschaffte letztendlich das versetzen der CCU zentraler in der Wohnung. Fehlermeldungen sind sehr sehr selten geworden.
          Testweise habe ich den umgedrehten Rolloaktor wieder gerade gestellt.
          CCU mitten in der Wohnung kein Problem; CCU an ursprünglichen Standort Probleme treten wieder auf.
          (Aktor ist nahe an einen Anderen Aktor verbaut, jedoch nicht wie bei dir entfernt von CCU)
          Homoran AnamCara 2 Replies Last reply Reply Quote 1
            Homoran Global Moderator Administrators @DAN78 last edited by
            @DAN78 sagte in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
            Das ist so nicht korrekt.
            Dieser Abstand bezieht sich auf einen Sender und einen Empfänger, die mit Direktverknüpfung verbunden sind.
            (z.B. Wandtaster mit dahinter liegendem Schaltaktor)
            wenn es nur Aktoren sind ist es kein Problem diese in einen Mehrfach-Rahmen unterzubringen.
            Allerdings weiß ich nicht wie es bei HmIP aussieht, da alle PBU getrennte Bedientaster und Aktoren haben, die nicht mehr hardwaremaäßig, sondern über eine interne DV verbunden sind.
            Da das aber so designed ist, sollte es auch keine Probleme machen
            AnamCara DAN78 2 Replies Last reply Reply Quote 1
            • AnamCara
              AnamCara @Homoran last edited by
              @Homoran @DAN78
              Die Abstände wären gegeben, denn es sind ja Rolladen-Aktoren die betroffen sind und jedes Fenster ist mehr als 20cm voneinander entfernt 🙂 (auch die Schalter/Aktoren).
              Neben der CCU sind noch zwei Steckdosen als Repeater eingebunden.
              Ich hoffe ich finde heute noch die Zeit um die Code-Schnipsel anzuschauen und aus zu probieren.
              Herzlichen Dank für Eure Hilfe!
              • DAN78
                DAN78 @Homoran last edited by
                @Homoran danke
                DAN78 1 Reply Last reply Reply Quote 0
                • DAN78
                  DAN78 @DAN78 last edited by DAN78
                  @Homoran sagte in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
                  • AnamCara
                    AnamCara @DAN78 last edited by AnamCara
                    @DAN78 said in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
                    Sicherheitshalber empfehle ich dir in deinen Skripte die Anzahl der Versuche zu limitieren.
                    Guten Morgen,
                    ich hatte erst noch ein anderes Problem zu lösen, meine Skripte liefen gar nicht mehr. Ich hatte eine einfache Steuerung mit der Astro-Funktion gebaut und darunter dann die ganzen "Steuere Objekt ID"'s liegen. Als ich aber eine CRON Zeitsteuerung darüber gesetzt hatte ging nichts mehr. Also habe ich erst mal den CRON wieder herausgenommen, da die Vierschachtelung wohl nicht funktionierte.
                    Danach habe ich mir mal Dein Skript angesehen. Schlussendlich habe ich es etwas anders umgesetzt, denn ich denke mal in Deinem Skript geht es darum individuell die Behanghöhe "Neue Zielposition" eingeben zu können und dann geht die Steuerung los...
                    Bei mir soll das ganze "erst einmal" etwas statischer von statten gehen und ich habe das nun so gesetzt:
                    Im Grunde sollte das Rollo ja den Befehl zum steuern der Behanghöhe erhalten haben wenn es danach in Bewegung ist.
                    (P.S. was macht denn "anerkannt von Objekt ID" ?)
                    Wenn das so okay ist, müsste ich das nun für 12 Rolladen machen. Ich denke mal den Block jetzt 11 mal zu kopieren und abzuändern ist aus Sicht eines Programmierers nicht das gelbe vom Ei. Ich bin zwar kein Programmierer aber ich habe genug Code gesehen um zu erahnen, dass eine Schleife oder besser wohl ein Array mit den Rolladen besser wäre?
                    Das Skript oben habe ich jetzt noch nicht richtig testen können, denn es funktioniert im Moment direkt beim ersten Lauf 🙂 ich hatte zunächst Dein Skript zu quasi 100% übernommen, aber dabei wurde nie ins Log geschrieben, das es gerade der 2.,3.,4. oder 5. Versuch ist der läuft, es kam immer die Meldung Störung, obwohl der Rolladen noch bei der Arbeit war, deshalb habe ich den Intervall nach oben korrigiert.
                    DAN78 2 Replies Last reply Reply Quote 0
                    • DAN78
                      DAN78 @AnamCara last edited by
                      @AnamCara Hallo,
                      Das "anerkannt von Objekt ID" gibt Rückmeldung ob dein Befehl ausgeführt wurde
                      In deinem Skript oben fragst du ab ob das Rollo läuft. Mit activiti up/down...
                      So was probierte ich auch mal für eine andere Anwendung, funktionierte dann nicht wirklich.
                      Mein Lösungsansatz zu deiner Frage: "Wie stellt ihr sicher, dass das Rollo auch wirklich gefahren ist." war folgender.
                      1. Die Rollade fährt.
                      2. Nach ein paar Minuten wird kontrolliert ob die aktuelle Bahnhöhe der angesteuerten entspricht, und ob diese per Rückmeldung bestätigt sei.
                      3. Falls nicht zurück zu punkt 1
                      Falls du unter "meinem Skript" hingegen das Rolladenskript meitest welches ich 2018 hochgeladen habe,
                      bitte ich dich dieses nicht zu verwenden! Das beinhaltet Astro und mehrere Spielereien.
                      Zwar funktioniert es, ist aber für den Zweck viel zu unübersichtlich, wenn nicht schlecht ausgeführt.
                      Das war damals mein erstes Programm 🙂 ich konnte es nicht besser.
                      Aktuell bin ich dabei ein neues Rolladenskript zu erstellen, werde dann den Schinken im Post ersetzen. Habe nicht die Berechtigung meine Posts zu löschen.
                        Homoran Global Moderator Administrators @DAN78 last edited by Homoran
                        aber ich 😂
                        Aber ich bin der Meinung, dass so etwas archiviert gehört.
                        Erstens zeigt es, dass man sich entwickelt, zum anderen kann man es immer wieder als Basis für anderes nutzen
                        und zum dritten zerstört das Löschen ggf. den Sinninhalt des folgenden Threads
                        • DAN78
                          @Homoran Da gebe ich dir vollkommen Recht. Es ist aber auch so, dass man den Leuten hier nur gutes weiter geben möchte 🙂
                          • DAN78
                            DAN78 @AnamCara last edited by DAN78
                            @AnamCara Probier mal das Skript. Ich glaube du wolltest das haben
                              <variables>
                                <variable type="" id="fGkS8jJx-UC*s0yHpdv*">var_neue_Behanghoehe</variable>
                                <variable type="" id="Yyk;+Ej*G^q;$$=E8S}l">var_Anzahl_Versuche</variable>
                                <variable type="undefined" id="Intervall_weiterer_Versuch">Intervall_weiterer_Versuch</variable>
                              </variables>
                              <block type="variables_set" id="e8dE+dd:bTXjxgRb9~4?" x="-438" y="37">
                                <field name="VAR" id="fGkS8jJx-UC*s0yHpdv*" variabletype="">var_neue_Behanghoehe</field>
                                  <block type="math_number" id="dj3~OilSG7CKfWwMQOk@">
                                    <field name="NUM">70</field>
                                  <block type="schedule" id="TCe,*CJa}b+Jd_3e(#;G">
                                    <field name="SCHEDULE">49 15 * * *</field>
                                      <block type="controls_if" id="L$.KI`y*kgR#nR0BX3JJ">
                                          <block type="logic_compare" id="Q3A1x?oUTFLHLZ}%{|ux">
                                              <block type="variables_get" id="X_oyMKvcM,J#8,+-.EqH">
                                              <block type="get_value" id="e6n%9(6~|$SO(B-Z#7NM">
                                                <field name="OID">hm-rpc.0.PEQ0005311.1.LEVEL</field>
                                          <block type="control" id="D|P8C=#ml5QYhj{$EMuR">
                                              <block type="variables_get" id="QahG?%RGy:~Q*qb{l,f^">
                                              <block type="debug" id="?z|?eaHf-CB^X)WwSmsq">
                                                <value name="TEXT">
                                                  <shadow type="text" id="dNW](`0}~]2aq:]KjY1(">
                                                    <field name="TEXT">1. Versuch</field>
                                                  <block type="variables_set" id="gMbk;?$z_[Af8pEA1Mpy">
                                                    <field name="VAR" id="Yyk;+Ej*G^q;$$=E8S}l" variabletype="">var_Anzahl_Versuche</field>
                                                      <block type="math_number" id="R(Hl|}rF20EbED5,:?)f">
                                                        <field name="NUM">1</field>
                                                      <block type="timeouts_setinterval" id="26zz;Qjv:Ae:EPjV)},K">
                                                        <field name="NAME">Intervall_weiterer_Versuch</field>
                                                        <field name="INTERVAL">2</field>
                                                          <block type="math_change" id="${[B@86#A~$X%^If(XZ{">
                                                            <value name="DELTA">
                                                              <shadow type="math_number" id="V,mJT1/f?=TkL*V2!62T">
                                                              <block type="controls_if" id="TNQkz1~2HtsEWy]7~gGu">
        <block type="logic_operation" id="O2yuL1;z2nk3kkw{+{.^">
        <field name="OP">AND</field>
        <block type="logic_compare" id="a?hCtQF?1_S(Fqwa*fXa">
        <field name="OP">LTE</field>
        <block type="variables_get" id="Dwq77@qs?FOIPh+]vBn#">
        <block type="math_number" id="_@,w5,-[?Hi))Vs9:?_i">
        <field name="NUM">5</field>
        <block type="logic_compare" id="K`|`?6#+WZ:]~378XENY">
        <block type="variables_get" id="eB35z2Gz-9pKG@|rRX]0">
        <block type="get_value" id="|H)xi=7Vc?]F+(}x#fWx">
        <block type="control" id="LPoX~di|oNj$[!i{rTPT">
        <block type="variables_get" id="x/4L5EMrB=Z]%g^}Eox~">
        <block type="debug" id="-o-^OGwdRTOp2[|+Wro.">
        <value name="TEXT">
        <shadow type="text" id=";xPlZCpA^7Asu6v`DK:%">
        <block type="text_join" id="+Y[_X9ky{vf]4ahC-NuS">
        <value name="ADD0">
        <block type="variables_get" id="x8(Q!|R!{:VrD6AK,@D@">
        <value name="ADD1">
        <block type="text" id="/(PHvCiQv)2Q7+XN-ImP">
        <field name="TEXT">. Versuch</field>
        <block type="timeouts_clearinterval" id="0o,:CCsd[6[VLU4E8#Uz">
        <block type="debug" id="s/5zpJ!M@jhY*ib5/g]N">
        <value name="TEXT">
        <shadow type="text" id="D|6rcCb|b@ax^xIM#/fU">
        <field name="TEXT">Rolladen Buero Joerg verzeichnet eine Störung!</field>
        <block type="debug" id="PFQeInC2-=9KZr$hCYea">
        <value name="TEXT">
        <shadow type="text" id="o,uR+N]%2dAY#0--NRZu">
        <field name="TEXT">Intervall/Skript Ende</field>
                                      <block type="on_ext" id="+.-r#/(bd(1;%iji|@OG">
                                        <field name="ACK_CONDITION">true</field>
                                        <value name="OID0">
                                          <shadow type="field_oid" id="F}2pd5:IApGH#fdP7Kea">
                                            <field name="oid">hm-rpc.0.PEQ0005311.1.WORKING</field>
                                          <block type="controls_if" id="cI$Iy0K*u5qH)k}4+}5Y">
                                              <block type="on_source" id="EY69Ml6`|vHhmrcu{g:e">
                                              <block type="debug" id="?W;z^Nfw#ojq2W+b@oID">
                                                <value name="TEXT">
                                                  <shadow type="text" id="h3arA9hGdT|2^mmI|W#N">
                                                    <field name="TEXT">Rolladen in Aktion</field>
                                            <value name="IF1">
                                              <block type="logic_operation" id="|nw:k=p~Yn6,8{1`!q9e">
                                                  <block type="logic_negate" id="g(+XF=#sOL_t5bVJ;.?A">
                                                    <value name="BOOL">
                                                      <block type="on_source" id="i;:o=-y%9gA}A-R9p7qR">
                                                  <block type="logic_compare" id="?n9YB~5~.R2i{pch#0$1">
                                                      <block type="variables_get" id="|VUq.Z5l`]Gf#V[e;3xv">
                                                      <block type="get_value" id="bc.gU,7!}/an!aG1hXFN">
                                            <statement name="DO1">
                                              <block type="debug" id="n*~m:g:BfTs0_`]=stW~">
                                                <value name="TEXT">
                                                  <shadow type="text" id="*_Y#R].#=_ek)LQ#(s%=">
                                                    <field name="TEXT">Rolladen ist auf Behanghoehe.</field>
                                                  <block type="debug" id="M4Zv{r5[qetQXav^BD;5">
                                                    <value name="TEXT">
                                                      <shadow type="text" id="5=|n{7v:BacBXfuYT%(L">
                            • AnamCara
                              Dankeschön @DAN78
                              nur eine kurze Rückfrage ich habe leider kein .WORKING objekt das ich abfragen kann in HMip oder habe ich etwas übersehen?
                              Wenn ich das Skript ausführe, dann laufen gleich alle 1-5 Versuche durch, ich habe deshalb den Intervall von 2 Sek. auf 2 Minuten geändert. Bei mir habe ich dann anstelle von WORKING den ACTIVITY__STATE gewählt. Jetzt kommt im Log dann nur noch folgendes
                              javascript.0 2020-04-24 07:57:15.215 info (878) script.js.Test.Pruefung: Rolladen in Aktion
                              javascript.0 2020-04-24 07:57:00.213 info (878) script.js.Test.Pruefung: Rolladen in Aktion
                              javascript.0 2020-04-24 07:57:00.025 info (878) script.js.Test.Pruefung: 1. Versuch
                              Sollte mich der zweite "Rolladen in Aktion" Eintrag stören? 🤔
                              • DAN78
                                @AnamCara
                                Zum zweiten Log-Eintrag:
                                Was hast du im Trigger? (Objekt ID geändert oder aktualisiert / anerkannt egal oder update)
                                Habe die von HM (ohne IP), kann oder wird sein dass die Datenpunkte nicht identisch sind.
                                Activity wird bei HMIP vermutlich dieselbe Funktion haben wie Working und Stop bei HM.
                                Du kannt das Ganze evtl auch mit Direction verknüpfen. (states: 0=NONE; 1=UP; 2=DOWN; 3=UNDEFINED)
                                Hatte die 2 Sekunden in Intervall um das Blockly zu testen.
                                AnamCara 1 Reply Last reply Reply Quote 0
                                • AnamCara
                                  Ich habe als Trigger "Falls Objekt Rolladen.Buero.Joerg:4.ACTIVITY_STATE wurde geändert".
                                    <variables>
                                    </variables>
                                          <field name="NUM">100</field>
                                          <field name="SCHEDULE">57 7 * * *</field>
                                                      <field name="OID">hm-rpc.1.00111A49A48768.4.LEVEL</field>
                                                      <value name="TEXT">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="TEXT">
        <value name="TEXT">
                                                  <value name="OID0">
                                                      <field name="oid">hm-rpc.1.00111A49A48768.4.ACTIVITY_STATE</field>
                                                          <value name="TEXT">
                                                      <value name="IF1">
                                                              <value name="BOOL">
                                                          <value name="TEXT">
                                                              <value name="TEXT">
                                  Wo kann man eigentlich mal nachlesen, welchen Kanal man wann verwendet und wofür diese gut sind? Ich finde bei eQ3 nicht wirklich eine gute Beschreibung von Aktoren und den Funktionen/Kanälen...
                                  AnamCara Homoran 2 Replies Last reply Reply Quote 0
                                  • AnamCara
                                    AnamCara @AnamCara last edited by
                                    Nachdem ich nun einfache Verzögerungen (jeweils 5 Sekunden) eingebaut habe ist das Problem nicht mehr aufgetreten.
                                    @AnamCara sagte in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
                                      Homoran Global Moderator Administrators @AnamCara last edited by
                                      bei HomeMatic gibt es ein Programmierhandbuch (Teil4 Datenpunkte) in dem alles sehr asuführlich dokumentiert ist.
                                      für IP gibt es auch so etwas, das ist schon fast ein Telefonbuch.
                                      Ansonsten auf der CCU unter Einstellungen - Geräte das entsprechende Gerät aufrufen, dann steht dort üblicherweise zu jedem Kanal zumindest der mehr oder weniger aussagekräftige Bezeichner
                                      • AnamCara
                                        AnamCara @Homoran last edited by AnamCara
                                        @Homoran wenn Du das hier meinst? https://www.eq-3.de/Downloads/eq3/download bereich/handbuecher/WebUI_Handbuch_eQ-3.pdf da steht leider nicht alles drin 😞 zum Beispiel fehlen die Rolladenaktoren...
                                          Nö - sondern das hier:
                                          https://www.eq-3.de/service/downloads.html?id=90
                                          • AnamCara
                                            Da sind leider keine HmIP Komponenten drin und die Suche gibt auch keine entsprechenden Ergebnisse. Schade.
                                            HM und HmIP haben zum Teil andere Bezeichnungen in den Namen .
                                            blockly scenes
                                            2141
