    4. Test Adapter fb-checkpresence v1.0.x
      e-s @afuerhoff last edited by
      @afuerhoff
      Wenn man mal seine fritte neu startet oder ein Update fährt, dann gibt es viele errors. Kannst du das eventuell abfangen?
      fb-checkpresence.1	2020-04-23 07:35:23.178	error	(2709) soapAction status 500
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Envelope>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Body>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Fault>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	</detail>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	</UPnPError>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<errorDescription>Action Failed</errorDescription>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<errorCode>501</errorCode>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<detail>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<faultstring>UPnPError</faultstring>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<faultcode>s:Client</faultcode>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Fault>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Body>
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
      fb-checkpresence.1	2020-04-23 07:35:23.177	error	(2709) soapAction mesg<?xml version="1.0"?>
      afuerhoff 1 Reply Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @afuerhoff last edited by sigi234
        @afuerhoff
        V 1.0.1
        Bei mir kommt das:
        fb-checkpresence.0	2020-04-23 09:17:30.216	error	(18168) Fb.getDeviceList Error: timeout of 2000ms exceeded
        fb-checkpresence.0	2020-04-23 09:15:41.560	error	(18168) soapAction [object Object]
        fb-checkpresence.0	2020-04-23 09:13:38.032	error	(18168) soapAction [object Object]
        ? afuerhoff 2 Replies Last reply Reply Quote 0
          A Former User @sigi234 last edited by
          @sigi234 @afuerhoff
          Seit FritzBeta vorgestern und js-controller 3.0.14 läuft er bei mir auch nicht mehr sauber.
          Admin 4.0.9
          Bin gerade am löschen und mal komplett neu installieren...
          sigi234 E afuerhoff 3 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @Guest last edited by
            @ilovegym sagte in Test Adapter fb-checkpresence v1.0.x:
            Gibt schon 3.0.17
              e-s @Guest last edited by
              @ilovegym
              Habe im tr064 thread auch über Probleme mit der neuen beta geschrieben, funktioniert bei dir der externalIP dp im tr064?
              Bzw hast du ausser den Fehlermeldungen noch andere Probleme?
                A Former User @e-s last edited by
                @e-s tr-064 funktioniert einwandfrei, da gibts nix zu berichten.
                Js-controller 3.0.14 oder jetzt mit 3.0.17, admin 4.0,9 und der aktuellen 4.0 des tr-064.
                • afuerhoff
                  afuerhoff Developer @e-s last edited by
                  @e-s sagte in Test Adapter fb-checkpresence v1.0.x:
                  @afuerhoff
                  Ist eigentlich eine Fehlermeldung. Die wird nur so im Log zerlegt angezeigt.
                  • afuerhoff
                    afuerhoff Developer @Guest last edited by
                    @sigi234 @afuerhoff
                    Admin 4.0.9
                    Was läuft denn nicht?
                    • afuerhoff
                      afuerhoff Developer @sigi234 last edited by
                      @sigi234 sagte in Test Adapter fb-checkpresence v1.0.x:
                      @afuerhoff
                      V 1.0.1
                      Bei mir kommt das:
                      Die zwei unteren muss ich mal prüfen. Die obere hab ich schon geschrieben das da noch ein Timeout erhöht werden muss. Kannst du zu den unteren weitere Infos liefern -》Debug Log
                        @afuerhoff sagte in Test Adapter fb-checkpresence v1.0.x:
                        Leider nein, kommt aber nicht immer.
                          mameier1234 last edited by
                          ich habe vorhin meine Fritzbox vorhin neugestartet.. bis dahin war alles ok...
                          jetzt kommt nur noch:
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	(6784) soapAction status 500
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	</s:Envelope>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	</s:Body>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	</s:Fault>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	</detail>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	</UPnPError>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<errorDescription>NoSuchEntryInArray</errorDescription>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<errorCode>714</errorCode>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<detail>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<faultstring>UPnPError</faultstring>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<faultcode>s:Client</faultcode>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<s:Fault>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<s:Body>
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                          fb-checkpresence.0	2020-04-27 21:35:21.531	error	(6784) soapAction mesg<?xml version="1.0"?>
                          • afuerhoff
                            afuerhoff Developer @mameier1234 last edited by
                            @mameier1234 sagte in Test Adapter fb-checkpresence v1.0.x:
                            NoSuchEntryInArray
                            Da scheint eine Mac eingetragen sein, die in der Fritzbox nicht mehr existiert.
                              A Former User @afuerhoff last edited by
                              NoSuchEntryInArray
                              Hi, ich hab den Fehler seit neuestem auch, hab den Adapter und die Instanz mal komplett gelöscht, Fritzbox rebooted, dann den Adapter und die Instanz neu installiert. Version 1.0.1
                              Adapter beendet sich, kann man den Fehler nicht abfangen?
                              • afuerhoff
                                @ilovegym
                                Ich muss mal schauen. Bin sowieso am Fehlerhandling dran. Problem ist, das man die Fehler nicht unbedingt immer im eigenen Netzwerk nachstellen kann. Kann aber noch etwas dauern. Die größeren Änderungen kommen dann später mal.
                                E ? 2 Replies Last reply Reply Quote 0
                                  @afuerhoff
                                  Kannst du mir bitte einen Gefallen tun und eine Version mit Auswertung des externen IP Adresse der fritzbox basteln.
                                  Seit einigen beta firmwares wird die nicht mehr im tr064 angezeigt, am Anfang war ich alleine mit dem Fehler. Später hatte noch jemand anderes das Problem.
                                  Mich würde mal interessieren ob vielleicht doch der Adapter schuld ist oder avm mit der api.
                                  Hatte die zwar angeschrieben aber nur eine Antwort bekommen, die wollen es weiter beobachten.
                                  Oder kannst du mir sagen wie der api Befehl dafür ist?
                                    @afuerhoff Alles gut, in der Ruhe liegt die Kraft!
                                    Ich weiß, wolltest ja die Verzeichnisstruktur ändern mit den Familienmitgliedern, etc.. lass dir ruhig Zeit. Wenn du was zum ersten Testen hast, sag bescheid.
                                    • afuerhoff
                                      @e-s
                                      Im Testbetrieb habe ich das bei mir schon drin und ich kann meine externe IP auslesen. Würde ich dann mit dem Fehlerhandling demnächst auf Github hochladen.
                                      • afuerhoff
                                        afuerhoff Developer last edited by afuerhoff
                                        ich habe gerade eine neue Version 1.0.2 auf Github hochgeladen.
                                        Ich habe hauptsächlich an der Fehlerbehandlung etwas geändert. Zusätzlich frage ich noch die externe IP der Fritzbox ab (unter Info zu finden). Bitte gebt mir Rückmeldung, ob es Fehlermeldungen gibt.
                                        Änderungen:
                                        • Fehlerbehandlung
                                        • auslesen externe IP-Adresse
                                        • Timeout erhöht
                                        • Warnmeldung "duplicate fritzbox device item" entfernt
                                        • Prüfung, ob Mac oder IP in Fritzbox vorhanden
                                        ? E 3 Replies Last reply Reply Quote 1
                                          @afuerhoff Hi, super, danke!
                                          Fehler sind hier weg. Perfekt!
                                            @afuerhoff
                                            Mir ist gerade was aufgefallen, wenn ich für die Anwesenheit einer Person zwei Geräte eintrage, zum Beispiel mein Handy und meine Smartwatch, die Smartwatch aber nur im wlan ist, wenn das Handy nicht erreichbar, dann steht bei den Members, dass ich Zuhause bin, und gleichzeitig nicht. 🙂
                                            Klar, ich hab den Namen 2x eingetragen, einmal mit der Mac/IP des Handys und einmal mit den Daten der Smartwatch.
                                            Könntest du das noch abfangen?
                                            avm fritzbox soap tr-064
                                            23
                                            248
                                            27006
