    4. [fixed] Nach Update von js-controller auf 0.8.9 kein Start von iobroker Dienst mehr möglich
      Weil ihr so herzzerreissend jammert habe ich auch den controller upgedated.
      Bei mir erscheint während des Updates (genau gesagt bein restart):
      iobroker	2016-04-23 15:38:07	error	at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      iobroker	2016-04-23 15:38:07	error	at ChildProcess.emit (events.js:172:7)
      iobroker	2016-04-23 15:38:07	error	at emitTwo (events.js:87:13)
      iobroker	2016-04-23 15:38:07	error	at ChildProcess. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:263:31)
      iobroker	2016-04-23 15:38:07	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:212:29
      iobroker	2016-04-23 15:38:07	error	at restartController (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2091:18)
      iobroker	2016-04-23 15:38:07	error	at Object.fs.openSync (fs.js:549:18)
      iobroker	2016-04-23 15:38:07	error	at Error (native)
      iobroker	2016-04-23 15:38:07	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/../log/restart.log'
      iobroker	2016-04-23 15:38:07	error	^
      iobroker	2016-04-23 15:38:07	error	fs.js:549 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      iobroker	2016-04-23 15:38:07	info	Chmod finished. Restart controller
      EDIT: nach reboot sieht es gut aus! (?)
      Rainer
      • N
        Nili last edited by
        Sry, dass ich das Logfile vergessen habe.
        Da das Logfile nicht mehr vorhanden ist, habe ich nochmals eine js-controller Installation durchgeführt.
        Hier das Log dazu.
        0 info it worked if it ends with ok
        1 verbose cli [ 'node',
        1 verbose cli '/usr/local/bin/npm',
        1 verbose cli 'install',
        1 verbose cli 'iobroker.js-controller',
        1 verbose cli '--production' ]
        2 info using npm@3.8.7
        3 info using node@v0.10.42
        4 silly loadCurrentTree Starting
        5 silly install loadCurrentTree
        6 silly install readLocalPackageData
        7 silly fetchPackageMetaData iobroker.js-controller
        8 silly fetchNamedPackageData iobroker.js-controller
        9 silly mapToRegistry name iobroker.js-controller
        10 silly mapToRegistry using default registry
        11 silly mapToRegistry registry https://registry.npmjs.org/
        12 silly mapToRegistry data { raw: 'iobroker.js-controller',
        12 silly mapToRegistry scope: null,
        12 silly mapToRegistry name: 'iobroker.js-controller',
        12 silly mapToRegistry rawSpec: '',
        12 silly mapToRegistry spec: 'latest',
        12 silly mapToRegistry type: 'tag' }
        13 silly mapToRegistry uri https://registry.npmjs.org/iobroker.js-controller
        14 verbose request uri https://registry.npmjs.org/iobroker.js-controller
        15 verbose request no auth needed
        16 info attempt registry request try #1 at 19:42:34
        17 verbose request id 15060d4ed61db4bd
        18 verbose etag "32CQW3QP5ML7RNBCAHX33ALRK"
        19 http request GET https://registry.npmjs.org/iobroker.js-controller
        20 http 304 https://registry.npmjs.org/iobroker.js-controller
        21 verbose headers { date: 'Sat, 23 Apr 2016 17:42:34 GMT',
        21 verbose headers via: '1.1 varnish',
        21 verbose headers 'cache-control': 'max-age=300',
        21 verbose headers etag: '"32CQW3QP5ML7RNBCAHX33ALRK"',
        21 verbose headers age: '172',
        21 verbose headers connection: 'keep-alive',
        21 verbose headers 'x-served-by': 'cache-fra1225-FRA',
        21 verbose headers 'x-cache': 'HIT',
        21 verbose headers 'x-cache-hits': '2',
        21 verbose headers 'x-timer': 'S1461433354.981513,VS0,VE0',
        21 verbose headers vary: 'Accept-Encoding' }
        22 silly get cb [ 304,
        22 silly get { date: 'Sat, 23 Apr 2016 17:42:34 GMT',
        22 silly get via: '1.1 varnish',
        22 silly get 'cache-control': 'max-age=300',
        22 silly get etag: '"32CQW3QP5ML7RNBCAHX33ALRK"',
        22 silly get age: '172',
        22 silly get connection: 'keep-alive',
        22 silly get 'x-served-by': 'cache-fra1225-FRA',
        22 silly get 'x-cache': 'HIT',
        22 silly get 'x-cache-hits': '2',
        22 silly get 'x-timer': 'S1461433354.981513,VS0,VE0',
        22 silly get vary: 'Accept-Encoding' } ]
        23 verbose etag https://registry.npmjs.org/iobroker.js-controller from cache
        24 verbose get saving iobroker.js-controller to /root/.npm/registry.npmjs.org/iobroker.js-controller/.cache.json
        25 verbose correctMkdir /root/.npm correctMkdir not in flight; initializing
        26 silly install normalizeTree
        27 silly loadCurrentTree Finishing
        28 silly loadIdealTree Starting
        29 silly install loadIdealTree
        30 silly cloneCurrentTree Starting
        31 silly install cloneCurrentTreeToIdealTree
        32 silly cloneCurrentTree Finishing
        33 silly loadShrinkwrap Starting
        34 silly install loadShrinkwrap
        35 silly loadShrinkwrap Finishing
        36 silly loadAllDepsIntoIdealTree Starting
        37 silly install loadAllDepsIntoIdealTree
        38 silly rollbackFailedOptional Starting
        39 silly rollbackFailedOptional Finishing
        40 silly runTopLevelLifecycles Starting
        41 silly runTopLevelLifecycles Finishing
        42 silly install printInstalled
        43 verbose stack Error: Refusing to install iobroker.js-controller as a dependency of itself
        43 verbose stack at checkSelf (/usr/local/lib/node_modules/npm/lib/install/validate-args.js:53:14)
        43 verbose stack at Array.0 (/usr/local/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
        43 verbose stack at LOOP (/usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:15:14)
        43 verbose stack at chain (/usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:20:5)
        43 verbose stack at /usr/local/lib/node_modules/npm/lib/install/validate-args.js:16:5
        43 verbose stack at /usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:35
        43 verbose stack at Array.forEach (native)
        43 verbose stack at /usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:11
        43 verbose stack at asyncMap (/usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:51:8)
        44 verbose cwd /opt/iobroker
        45 error Linux 3.19.0-58-generic
        46 error argv "node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
        47 error node v0.10.42
        48 error npm v3.8.7
        49 error code ENOSELF
        50 error Refusing to install iobroker.js-controller as a dependency of itself
        51 error If you need help, you may report this error at:
        51 error <https: github.com/npm/issues="">
        52 verbose exit [ 1, true ]</https:>
        Ich wollte dann deinen Tipp noch ausführen, doch leider existiert bei mir das Verzeichnis nicht.
        root@SrvDK-Tools2:/opt/iobroker# cd node_modules/iobroker.js-controller
        bash: cd: node_modules/iobroker.js-controller: Datei oder Verzeichnis nicht gefunden
          Solear last edited by
          @Homoran:
          Weil ihr so herzzerreissend jammert habe ich auch den controller upgedated. `
          Du Masochist! :lol:
          Kannst du Adapter installieren oder löschen?
          Also bei mir ist alles durcheinander. Muss alles neu aufsetzen. Mein Backuptool unter Linux sichert leider Dateien mit "Cache" im Namen nicht mit, deshalb fehlt da auch die Hälfte beim Backup. Zum Glück habe ich nicht sooo viel eingestellt da.
          Ich mache es jetzt erstmal so wie ruhr70 (http://forum.iobroker.net/viewtopic.php … 545#p24323) und lasse iobroker als VM laufen, da sichere ich dann einfach die ganzen Snapshots weg und fertig.
            Hast du wirklich:
            npm install iobroker.js-controller
            eingegeben, oder hast du das iobroker vergessen?
            Der Fehler, duetet darauf hin.
            Außerdem hast du ein sehr altes node.
            du solltest auf 4.x updaten
            Rainer
              @Solear:
              Kannst du Adapter installieren `
              Habe das eben getestet und mobile installiert. Und Ja, er ist jetzt drin.
              Rainer
                na so ganz läuft es wohl doch nicht 😞
                meine hm-rpc Datenpunkte sind wieder weg.
                Ich wollte deshalb nochmal den controller im Reiter hosts neu starten, da erscheint dann:
                iobroker	2016-04-23 18:27:08	info	exit 1
                iobroker	2016-04-23 18:27:08	error	at require (internal/module.js:12:17)
                iobroker	2016-04-23 18:27:08	error	at Module.require (module.js:353:17)
                iobroker	2016-04-23 18:27:08	error	at Function.Module._load (module.js:300:12)
                iobroker	2016-04-23 18:27:08	error	at Module.load (module.js:343:32)
                iobroker	2016-04-23 18:27:08	error	at Object.Module._extensions..js (module.js:416:10)
                iobroker	2016-04-23 18:27:08	error	at Module._compile (module.js:409:26)
                iobroker	2016-04-23 18:27:08	error	at Object. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:310:9)
                iobroker	2016-04-23 18:27:08	error	at restartController (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2113:18)
                iobroker	2016-04-23 18:27:08	error	at Object.fs.openSync (fs.js:549:18)
                iobroker	2016-04-23 18:27:08	error	at Error (native)
                iobroker	2016-04-23 18:27:08	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/../log/restart.log'
                iobroker	2016-04-23 18:27:08	error	^
                iobroker	2016-04-23 18:27:08	error	fs.js:549 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
                iobroker	2016-04-23 18:27:08	info	_restart
                Rainer
                • N
                  Nili last edited by
                  @Homoran
                  Ich habe es sicherheitshalber nochmals versucht zu installieren mit
                  Bzgl. der Node-Version habe ich ein "apt-get install node" im Terminal eingegeben.
                  Es wurde auch etwas installiert, doch bleibt die Version bei 0.10.42
                  Ich befürchte, dass das wohll nicht der richtige Befehl war.
                  Wie oben schon erwähnt, ist Linux halt noch nicht so mein Ding.
                  Könntet ihr mir den passenden Befehl aufzeigen?
                    @Nili:
                    Wie oben schon erwähnt, ist Linux halt noch nicht so mein Ding. `
                    Meins auch noch nicht so ganz.
                    Aber du must erst die alte version entfernen. ich denke mit:
                    apt-get purge nodejs
                    dann die neue Version aufspielen. Bei RasPi2 oder 3 und debian jessie:
                        curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
                        sudo apt-get install -y build-essential python-rpi.gpio nodejs
                        reboot
                    Rainer
                    • N
                      Nili last edited by
                      Ich habe Node jetzt auf Version 4.4.3 aktualisiert.
                      Wenn ich jetzt den js-controller installieren will bekomme ich, je nachdem aus welchem Verzeichnis heraus ich den Befehl absetze, unterschiedliche Meldungen.
                      aus "cd /opt/iobroker" kommt folgendes:
                      klueber@SrvDK-Tools2:/opt/iobroker$ sudo npm install iobroker.js-controller
                      npm WARN install Refusing to install iobroker.js-controller as a dependency of itself
                      aus meinem "home" Verzeichnis kommt allerdings das hier:
                      klueber@SrvDK-Tools2:~$ sudo npm install iobroker.js-controller
                      > iobroker.js-controller@0.8.9 install /home/klueber/node_modules/iobroker.js-controller
                      > node lib/setup.js setup first
                      iobroker.js-controller@0.8.9 node_modules/iobroker.js-controller
                      In beiden Fällen wird keine npm-debug.log Datei angelegt.
                      Danilo
                      • Bluefox
                        Bluefox last edited by
                        @Nili:
                        Danilo `
                        Ich habe jetzt probiert zu Installieren und es ging.
                        "dependency of itself" ist merkwürdig.. und mir unbekannt.
                        Kann sagen, dass vielleicht Verzeichnis /opt/iobroker/node_modules/iobroker.js-controller zu löschen und dann installieren?
                        • N
                          Nili last edited by
                          Dieses Verzeichnis "/opt/iobroker/node_modules/iobroker.js-controller" existiert bei mir leider gar nicht.
                          Also löschen nicht möglich.
                          Aber eine Installation funktioniert leider trotzdem nicht.
                          Danilo
                          • Bluefox
                            @Nili:
                            Danilo `
                            Es gibt noch einen Workaround 🙂
                            sudo apt-get update
                            sudo apt-get install git
                            cd /opt/iobroker/node_modules
                            git clone https://github.com/ioBroker/ioBroker.js-controller.git
                            mv ioBroker.js-controller iobroker.js-controller
                            cd iobroker.js-controller
                            npm install --production
                            • N
                              Nili last edited by
                              Git ist aktuell, das ist ja schonmal nicht verkehrt:
                              klueber@SrvDK-Tools2:/opt/iobroker$ sudo apt-get install git
                              git ist schon die neueste Version.
                              Das Klonen sieht auch ganz gut aus:
                              klueber@SrvDK-Tools2:/opt/iobroker/node_modules$ git clone https://github.com/ioBroker/ioBroker.js-controller.git
                              Nach »ioBroker.js-controller« wird geklont
                              remote: Counting objects: 5520, done.
                              remote: Compressing objects: 100% (24/24), done.
                              remote: Total 5520 (delta 7), reused 0 (delta 0), pack-reused 5496
                              Objekte werden empfangen: 100% (5520/5520), 68.60 MiB | 878.00 KiB/s, done.
                              Unterschiede werden aufgelöst: 100% (3596/3596), done.
                              Verbundenheit wird überprüft … Fertig.
                              Doch leider ist das Verzeichnis "iobroker.js-controller" immer noch nicht vorhanden: 😞 😞
                              klueber@SrvDK-Tools2:/opt/iobroker/node_modules$ mv iobroker.js-controller iobroker.js-controller
                              mv: der Aufruf von stat für »iobroker.js-controller“ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                              Danilo
                                Und wenn du das Verzeichnis erstellst?
                                • N
                                  Nili last edited by
                                  Wenn ich das Verzeichnis anlege, bekomme ich beim "Klonen" dann folgende Meldung:
                                  fatal: Zielpfad 'ioBroker.js-controller' existiert bereits und ist kein leeres Verzeichnis.
                                  Danilo
                                    Und deinen mv Befehl mit sudo mal probieren?
                                      Ritter last edited by
                                      ich glaub mein node ist auch schon alt. Muss ich zum updaten einfach auf die nodejs.org Seite gehen und den installer für Windows 64bit herunterladen und ausführen oder ist dann alles kaputt?
                                      • N
                                        Nili last edited by
                                        Wenn ich das Verzeichnis jetzt wieder löschen will, wird mir gesagt, dass das Verzeichnis nicht existiert. :shock:
                                        klueber@SrvDK-Tools2:/opt/iobroker/node_modules$ rmdir iobroker.js-controller
                                        rmdir: konnte »iobroker.js-controller“ nicht entfernen: Datei oder Verzeichnis nicht gefunden
                                        Allerdings über den Befehl "ll" wird es mir noch angezeigt. Hier mal ein kleiner Ausschnitt.
                                        Was mich nur verwundert ist, dass die Verzeichisse "iobroker.admin" und "iobroker.js-controller" nicht wie alle anderen grün hinterlegt sind.
                                        drwxrwxrwx   2 klueber klueber  4096 Apr 23 10:18 inherits/
                                        drwxrwxrwx   2 klueber klueber  4096 Apr 23 10:17 inline-process-browser/
                                        drwxrwxrwx   2 klueber klueber  4096 Apr 23 10:17 invert-kv/
                                        drwxr-xr-x   5 klueber klueber  4096 Apr 23 21:36 iobroker.admin/
                                        drwxrwxrwx   5 klueber klueber  4096 Mär 26 10:38 iobroker.dwd/
                                        drwxrwxrwx   5 klueber klueber  4096 Feb 26 14:16 iobroker.fritzbox/
                                        drwxrwxrwx   6 klueber klueber  4096 Apr 23 09:46 iobroker.hm-rega/
                                        drwxrwxrwx   6 klueber klueber  4096 Apr 23 09:46 iobroker.hm-rpc/
                                        drwxrwxrwx   6 klueber klueber  4096 Feb 26 14:24 iobroker.ical/
                                        drwxrwxrwx   5 klueber klueber  4096 Feb 26 16:01 iobroker.icons-addictive-flavour-png/
                                        drwxrwxrwx   5 klueber klueber  4096 Apr 23 09:45 iobroker.javascript/
                                        drwxrwxr-x   9 klueber klueber  4096 Apr 24 11:31 ioBroker.js-controller/
                                        drwxrwxrwx   8 klueber root     4096 Feb 26 21:14 iobroker.node-red/
                                        drwxrwxrwx   4 klueber klueber  4096 Apr 16 21:07 iobroker.ping/
                                        drwxrwxrwx   5 klueber klueber  4096 Mär 11 12:53 iobroker.sql/
                                        Danilo
                                        • Bluefox
                                          @Nili:
                                          Danilo `
                                          Bei linux wird casesensitiv gehandelt:
                                          Du hast ioBroker.js-controller.
                                          Eigentlich sollte das Kommando
                                          es erledigen.
                                          • N
                                            Nili last edited by
                                            Das Verzeichnis konnte ich jetzt durch die "casesensitive" Schreibweise wieder löschen.
                                            Habe dann nochmal den Workaround von Bluefox abgearbeitet.
                                            Beim letzten Befehl kam dann folgendes als Ergebnis heraus:
                                            ! klueber@SrvDK-Tools2:/opt/iobroker/node_modules/iobroker.js-controller$ sudo npm install --production npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade npm WARN deprecated graceful-fs@2.0.3: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible. npm WARN cannot run in wd iobroker.js-controller@0.8.9 node lib/setup.js setup first (wd=/opt/iobroker/node_modules/iobroker.js-controller) mime@1.3.4 node_modules/mime ! daemonize2@0.4.2 node_modules/daemonize2 ! adm-zip@0.4.7 node_modules/adm-zip ! ncp@2.0.0 node_modules/ncp ! semver@4.3.6 node_modules/semver ! node.extend@1.1.5 node_modules/node.extend └── is@3.1.0 ! node-schedule@1.0.0 node_modules/node-schedule ├── long-timeout@0.0.2 └── cron-parser@1.1.0 ! winston@2.2.0 node_modules/winston ├── cycle@1.0.3 ├── stack-trace@0.0.9 ├── eyes@0.1.8 ├── isstream@0.1.2 ├── async@1.0.0 ├── pkginfo@0.3.1 └── colors@1.0.3 ! winston-daily-rotate-file@1.0.1 node_modules/winston-daily-rotate-file └── winston@2.1.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, pkginfo@0.3.1, colors@1.0.3) ! yargs@3.32.0 node_modules/yargs ├── decamelize@1.2.0 ├── y18n@3.2.1 ├── camelcase@2.1.1 ├── window-size@0.1.4 ├── cliui@3.2.0 (wrap-ansi@2.0.0, strip-ansi@3.0.1) ├── os-locale@1.4.0 (lcid@1.0.0) └── string-width@1.0.1 (strip-ansi@3.0.1, is-fullwidth-code-point@1.0.0, code-point-at@1.0.0) ! iobroker.admin@1.0.2 node_modules/iobroker.admin ├── connect-flash@0.1.1 ├── xtend@4.0.1 ├── cookie-parser@1.4.1 (cookie-signature@1.0.6, cookie@0.2.3) ├── passport-local@1.0.0 (passport-strategy@1.0.0) ├── passport@0.2.2 (pause@0.0.1, passport-strategy@1.0.0) ├── express-session@1.13.0 (cookie-signature@1.0.6, utils-merge@1.0.0, on-headers@1.0.1, cookie@0.2.3, parseurl@1.3.1, depd@1.1.0, crc@3.4.0, uid-safe@2.0.0, debug@2.2.0) ├── body-parser@1.15.0 (content-type@1.0.1, bytes@2.2.0, depd@1.1.0, qs@6.1.0, on-finished@2.3.0, raw-body@2.1.6, http-errors@1.4.0, debug@2.2.0, iconv-lite@0.4.13, type-is@1.6.12) └── express@4.13.4 (escape-html@1.0.3, array-flatten@1.1.1, utils-merge@1.0.0, cookie-signature@1.0.6, content-type@1.0.1, methods@1.1.2, vary@1.0.1, merge-descriptors@1.0.1, fresh@0.3.0, range-parser@1.0.3, etag@1.7.0, parseurl@1.3.1, serve-static@1.10.2, path-to-regexp@0.1.7, cookie@0.1.5, content-disposition@0.5.1, depd@1.1.0, qs@4.0.0, on-finished@2.3.0, finalhandler@0.4.1, debug@2.2.0, proxy-addr@1.0.10, accepts@1.2.13, type-is@1.6.12, send@0.13.1) ! socket.io-client@1.4.5 node_modules/socket.io-client ├── to-array@0.1.4 ├── component-emitter@1.2.0 ├── indexof@0.0.1 ├── object-component@0.0.3 ├── component-bind@1.0.0 ├── backo2@1.0.2 ├── has-binary@0.1.7 (isarray@0.0.1) ├── debug@2.2.0 (ms@0.7.1) ├── socket.io-parser@2.2.6 (isarray@0.0.1, json3@3.3.2, component-emitter@1.1.2, benchmark@1.0.0) ├── parseuri@0.0.4 (better-assert@1.0.2) └── engine.io-client@1.6.8 (yeast@0.1.2, component-emitter@1.1.2, has-cors@1.1.0, component-inherit@0.0.3, xmlhttprequest-ssl@1.5.1, parsejson@0.0.1, parseqs@0.0.2, ws@1.0.1, engine.io-parser@1.2.4) ! socket.io@1.4.5 node_modules/socket.io ├── has-binary@0.1.7 (isarray@0.0.1) ├── debug@2.2.0 (ms@0.7.1) ├── socket.io-parser@2.2.6 (isarray@0.0.1, json3@3.3.2, component-emitter@1.1.2, benchmark@1.0.0) ├── socket.io-adapter@0.4.0 (socket.io-parser@2.2.2) └── engine.io@1.6.8 (base64id@0.1.0, ws@1.0.1, accepts@1.1.4, engine.io-parser@1.2.4) ! prompt@1.0.0 node_modules/prompt ├── revalidator@0.1.8 ├── pkginfo@0.4.0 ├── colors@1.1.2 ├── read@1.0.7 (mute-stream@0.0.6) ├── winston@2.1.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, pkginfo@0.3.1, colors@1.0.3) └── utile@0.3.0 (deep-equal@0.2.2, async@0.9.2, i@0.3.4, ncp@1.0.1, mkdirp@0.5.1, rimraf@2.5.2) ! tar.gz@1.0.3 node_modules/tar.gz ├── commander@2.9.0 (graceful-readlink@1.0.1) ├── bluebird@2.10.2 ├── tar@2.2.1 (inherits@2.0.1, block-stream@0.0.8) ├── chai@3.5.0 (assertion-error@1.0.1, type-detect@1.0.0, deep-eql@0.1.3) ├── fstream@1.0.8 (inherits@2.0.1, graceful-fs@4.1.3, mkdirp@0.5.1, rimraf@2.5.2) ├── mocha@2.4.5 (escape-string-regexp@1.0.2, commander@2.3.0, diff@1.4.0, growl@1.8.1, supports-color@1.2.0, debug@2.2.0, mkdirp@0.5.1, glob@3.2.3, jade@0.26.3) └── mout@0.11.1 ! request@2.72.0 node_modules/request ├── aws-sign2@0.6.0 ├── forever-agent@0.6.1 ├── tunnel-agent@0.4.2 ├── oauth-sign@0.8.1 ├── is-typedarray@1.0.0 ├── caseless@0.11.0 ├── stringstream@0.0.5 ├── isstream@0.1.2 ├── json-stringify-safe@5.0.1 ├── extend@3.0.0 ├── tough-cookie@2.2.2 ├── node-uuid@1.4.7 ├── qs@6.1.0 ├── combined-stream@1.0.5 (delayed-stream@1.0.0) ├── mime-types@2.1.10 (mime-db@1.22.0) ├── form-data@1.0.0-rc4 (async@1.5.2) ├── aws4@1.3.2 (lru-cache@4.0.1) ├── bl@1.1.2 (readable-stream@2.0.6) ├── hawk@3.1.3 (cryptiles@2.0.5, boom@2.10.1, sntp@1.0.9, hoek@2.16.3) ├── har-validator@2.0.6 (commander@2.9.0, pinkie-promise@2.0.1, chalk@1.1.3, is-my-json-valid@2.13.1) └── http-signature@1.1.1 (assert-plus@0.2.0, jsprim@1.2.2, sshpk@1.8.1) ! npm@2.15.4 node_modules/npm !
                                            Leider bleibt alles beim alten … ich kann den daemon einfach nicht starten.
                                            Es bleibt dann wohl doch nichts anderes mehr übrig, als alles neu zu installieren. 😢 😢 😢
                                            Oder hat noch jemand einen Tipp?
                                            Danilo
                                            57
                                            9669
