      Jan1 @dslraser last edited by Jan1
      @dslraser
      Sobald ich auf 0.3.3 hoch gehe kommt das :
      host.Beelink	2020-04-22 09:49:08.192	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Beelink	2020-04-22 09:49:08.192	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:79:11)
      host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at /opt/iobroker/node_modules/socket.io/lib/socket.js:528:12
      host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:482:12)
      host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at Socket.emit (events.js:310:20)
      host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/lib/socket.js:921:30)
      host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6786:26)
      host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6693:31)
      host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at Array.map (<anonymous>)
      host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6694:24
      host.Beelink	2020-04-22 09:49:08.189	error	Caught by controller[0]: TypeError: Cannot read property 'startsWith' of null
      web.0	2020-04-22 09:49:07.836	info	(17739) Terminated (NO_ERROR): Without reason
      web.0	2020-04-22 09:49:07.834	info	(17739) terminating
      web.0	2020-04-22 09:49:07.760	info	(17739) terminated http server on port 8082
      web.0	2020-04-22 09:49:07.759	error	at processTicksAndRejections (internal/process/task_queues.js:79:11)
      web.0	2020-04-22 09:49:07.759	error	at /opt/iobroker/node_modules/socket.io/lib/socket.js:528:12
      web.0	2020-04-22 09:49:07.759	error	at Socket.EventEmitter.emit (domain.js:482:12)
      web.0	2020-04-22 09:49:07.759	error	at Socket.emit (events.js:310:20)
      web.0	2020-04-22 09:49:07.759	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/lib/socket.js:921:30)
      web.0	2020-04-22 09:49:07.759	error	at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6786:26)
      web.0	2020-04-22 09:49:07.759	error	at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6693:31)
      web.0	2020-04-22 09:49:07.759	error	at Array.map (<anonymous>)
      web.0	2020-04-22 09:49:07.759	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6694:24
      web.0	2020-04-22 09:49:07.759	error	(17739) TypeError: Cannot read property 'startsWith' of null
      web.0	2020-04-22 09:49:07.758	error	(17739) uncaught exception: Cannot read property 'startsWith' of null
      Edit:
      Also alles auf HTTP umgestellt und Version 0.3.1 läuft noch, alles darüber schießt mir den Web Adapter ins Nirwana. Somit liegts nicht am HTTPS sondern in der Tat am Sprung von 0.3.1 nach 0.3.2, da ab dieser Version bei mir die Probleme auftauchen.
      • Roberto Gresia
        Roberto Gresia @s.bormann last edited by
        @s-bormann Thank you
          ts020339 @s.bormann last edited by
          @s-bormann said in Test Adapter iqontrol v0.2.x:
          @Roberto-Gresia sagte in Test Adapter iqontrol v0.2.x:
          @ ts020339 e @s-bormann @simatec
          You could use a value given by an application like OpenWheaterMap, which gives a value that changes. Or accept that the Icons can be inserted via URL.
          It is possible to define external urls already - you can use the drop-down menu, but you can also use any url you like.
          In the next version it will be possible to add variables into these urls, that will be replaced by an ioBroker state.
          Syntax will be:
          path/to/preloadedimage.png|anotherpath/to/{iobrokerstate|fallback}.png
          iobrokerstate is sth. like javascript.0.myweather-icon-url and will be replaced by the value of this state. If the state is not present fallback will be used.
          Hey @s-bormann :
          Toll dass Du den Vorschlag mit dem variablen Pfad/Bild so schnell umsetzt! Sehr cool, vielen Dank! Echt krass, wie Du die ganzen "Wünsche" hier immer so schnell integrierst!
          • s.bormann
            s.bormann Most Active @Jan1 last edited by s.bormann
            @Jan1 Hi, bitte schicke mir mal ein Log aus der Entwicklerkonsole des Browsers:
            F12 drücken, ins Console-Fenster wechseln und dann den Fehler provozieren. Achso, und die Konfig der Lampe, bei der der Fehler auftritt. Lass mich mal raten: Es hat was mit Alternative Colorspace zu tun??? Da scheint es noch gewaltig zu haken irgendwo... Danke und VG!
              Jan1 @s.bormann last edited by
              @s-bormann
              So, habe heute noch mal ein Backup eingespielt und alle Adapter inklusive JS auf den aktuellen Stand gebracht, was soll ich sagen, der Fehler ist weg. Ich hatte gestern schon 2 mal ein Backup zurück gespielt um mir sicher zu sein, dass es am Adapter liegt und ich konnte es jedes mal reproduzieren. Heute gabs wieder ne Menge Updates und nun läuft es.
              Die Lampe war eigentlich egal, da der Fehler auftrat egal was ich geschaltet hatte. Es wurde etwas verzögert eingeschaltet und der Webadapter ging auf rot. Erst wenn der wieder grün war, konnte ich mit iQontrol wieder schalten.
              Ich beobachte das mal weiter und melde mich falls das noch mal auftaucht.
                blackeagle998 last edited by blackeagle998
                @s-bormann
                Kannst du bestätigen, dass bei einem iQontrol Adapter Update der Titel der Instanz immer wieder auf "iQontrol" geändert wird?
                siehe Screenshot letzte Spalte:
                Da ich mehrere Instanzen habe und die einzeln benannt hatte, ist mir das nach dem letzten Update aufgefallen.
                Kann man das ändern bzw. so gestalten, dass die Namen erhalten bleiben?
                E s.bormann 2 Replies Last reply Reply Quote 0
                  eMd @blackeagle998 last edited by
                  @blackeagle998
                  krass, was machst du mit so vielen instanzen?
                  • s.bormann
                    s.bormann Most Active @blackeagle998 last edited by
                    @blackeagle998 Hi, ehrlichgesagt bin ich da voll überfragt, die ganze Instanz-Verwaltung macht (glaube ich zumindest) der ioBroker selbst. Jedenfalls habe ich diesbezüglich nichts eigenes programmiert oder so, sondern einfach den Standard aus dem Adapter-Template von ioBroker übernommen. Vielleicht weiß das einer der ioBroker-Godfathers hier?
                      blackeagle998 @eMd last edited by
                      @eMd
                      Schau mal hier, da habe ich das kurz erläutert und bildlich dargestellt:
                      https://forum.iobroker.net/topic/32404/zeigt-her-eure-iqontrol-visualisierung/30
                        blackeagle998 @s.bormann last edited by
                        @s-bormann
                        Hätte ja sein können, dass du es problemlos ändern kannst.
                        Halb so wild, trotzdem danke für die schnelle Rückmeldung!
                          heinzie last edited by
                          vielleicht ist das hier schon mal erklärt worden, finde es aber leider nicht.
                          Ich möchte gerne das Gerät: Hoematic-Thermostat abhängig von der Einstellung Tag bzw. Nachtemperatur aktiv bzw. deaktiv schalten. Kann man das irgendwo einstellen?
                            eMd last edited by
                            Mir ist grad auch was aufgefallen, ich habe ein Fenster mit 3 Statis.
                            0 - closed
                            1 - gekippt
                            2 - open.
                            Bei 0 und 2 sehe ich das icon für auf und zu, sobald aber 1 gekippt zutrifft sehe ich kein icon... Also ein Button für diese Fälle wäre noch cool.
                            MfG
                            eMd
                            • s.bormann
                              Eigentlich sollte das Icon für offen angezeigt werden.
                              • siggi85
                                siggi85 last edited by
                                @s-bormann Wäre es möglich bei Slidern eine Option einzufügen, dass der Wert erst beim Loslassen des Sliders übermittelt wird? Somit würde das Standardverhalten unbeeinflusst sein.
                                Wenn man auf einigen Systemen den Slider viel hin und her bewegt (oder zu langsam bewegt), kann es passieren, dass so viele Aktualisierungen statt finden, dass das Endgerät bisschen überlastet wird von den ganzen Anfragen. Oder bspw. bei meiner Markise über Shelly 2.5 habe ich den Slider zu langsam bewegt und das Relais mehrfach kurz hintereinander geschaltet hat. Das muss ja nicht unbedingt sein. 🙂
                                  Jan1 last edited by
                                  Kann es sein, dass das Update auf 3.3.4 nicht funktioniert? Läuft bei mir ohne Fehler durch, bleibt aber bei 3.3.3 und es wird weiterhin ein Update angezeigt.
                                  sigi234 frankthegreat 2 Replies Last reply Reply Quote 0
                                    sigi234 Forum Testing Most Active @Jan1 last edited by
                                    @Jan1 sagte in Test Adapter iqontrol v0.2.x:
                                    Kann ich bestätigen.
                                    CKMartens 1 Reply Last reply Reply Quote 0
                                    • frankthegreat
                                      frankthegreat @Jan1 last edited by
                                      @Jan1 Gerade probiert, läuft bei mir auch nicht.
                                      • CKMartens
                                        CKMartens @sigi234 last edited by
                                        Bei mir auch. Bleibt nach Update auf 0.3.3
                                        Update iqontrol from @0.3.3 to @0.3.4
                                        NPM version: 6.14.4
                                        npm install iobroker.iqontrol@0.3.4 --loglevel error --prefix "/opt/iobroker" (System call)
                                        npm ERR! code ETARGET
                                        npm ERR! notarget No matching version found for iobroker.iqontrol@0.3.4.
                                        npm ERR! notarget In most cases you or one of your dependencies are requesting
                                        npm ERR! notarget a package version that doesn't exist.
                                          rebel85 last edited by
                                          läuft bei mir auch nciht und auch genauso wi in den vorherigen posts
                                          • MichMein
                                            MichMein last edited by
                                            Wenn ihr über die Katze installiert wird es 0.3.5
                                            1.0k
                                            296
                                            7636
                                            6852628
