    4. js-controller 3.0/3.1 jetzt im Latest!
      Stmiko @apollon77 last edited by Stmiko
      @apollon77 Wo muss ich den Befehl den ausführen? Auf dem Master, oder dem slave (smartmeter läuft auf dem slave) ?
      Viele Grüße,
      Update: OK, läuft wieder, vielen Dank!
      • dslraser
        dslraser Forum Testing Most Active @apollon77 last edited by dslraser
        @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
        3.0.18 (2020-04-23) Release Elena
        Bisher scheint alles zu laufen.
          jf62 last edited by
          Update wirft folgende Fehlermeldung:
          Update js-controller from @3.0.17 to @3.0.18
          NPM version: 6.14.4
          npm install iobroker.js-controller@3.0.18 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
          Package pixman-1 was not found in the pkg-config search path.
          Perhaps you should add the directory containing `pixman-1.pc'
          to the PKG_CONFIG_PATH environment variable
          No package 'pixman-1' found
          gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          gyp ERR! configure error
          gyp ERR! stack Error: `gyp` failed with exit code: 1
          gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
          gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! System Linux 4.19.97-v7l+
          gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
          gyp ERR! cwd /opt/iobroker/node_modules/canvas
          gyp ERR! node -v v10.20.1
          gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
          node-pre-gyp ERR! build error
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
          node-pre-gyp ERR! System Linux 4.19.97-v7l+
          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
          node-pre-gyp ERR! node -v v10.20.1
          node-pre-gyp ERR! node-pre-gyp -v v0.11.0
          node-pre-gyp ERR! not ok
          Starting node restart.js
          Muss ich etwas beachten oder habe ich etwas vergessen. Meldung kam bisher noch nie und alle updates liefen sauber
            eviltrooper last edited by
            Für mich als unwissender 🙂
            Nodejs Update:
            Erst mittels
            Apt-get —purge
            Die alte Version löschen, oder einfach in den apt sources die neue rein und apt-get Update machen?
              Kueppert last edited by Kueppert
              Hi all,
              bin auch jetzt auf die 3.0.18 aufgestiegen. Hab nur paar WARN-Meldungen (die letzte davon ist mir allerdings neu?? bl0.7.0? was ist das?)
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
              + iobroker.js-controller@3.0.18
              updated 11 packages and audited 31078 packages in 60.912s
              21 packages are looking for funding
                run `npm fund` for details
              found 140 low severity vulnerabilities
                run `npm audit fix` to fix them, or `npm audit` for details
              Viele Grüße, Thorsten
              Edit: Instanzen alle grün, keinerlei Fehlermeldungen (tr-064 läuft wie bisher auch 😉 )
              EDIT2: Ich musste nur den IOT rebuilden (schon wieder). Habs mit iobroker rebuild iot gemacht
              • dirk1962
                dirk1962 @apollon77 last edited by
                Läuft ohne Probleme. Der Duty Cycle bei Homematic geht kurzfristig hoch, beruhigt sich aber schnell wieder.
                • dslraser
                  @Kueppert sagte in js-controller 3.0 jetzt im Latest!:
                  Ja, das hatte ich auch. Ich habe es dieses mal gleich mit
                  iobroker rebuild iot --install
                  gemacht.
                    deta Most Active last edited by
                    Oh man, jetzt komme ich nicht mehr auf die Admin oberfläche.
                    iobroker scheint zu laufen
                    oot@rock64:/opt/iobroker# iobroker status
                    At least one iobroker host is running.
                    Objects type: file
                    States  type: file
                    root@rock64:/opt/iobroker#
                    Hab zur Sicherheit ebend noch mal den js Controller neu installiert, aber ich erreiche nicht die ip:8081
                    Was kann ich noch Prüfen?
                    sigi234 apollon77 2 Replies Last reply Reply Quote 0
                      sigi234 Forum Testing Most Active @deta last edited by sigi234
                      @deta sagte in js-controller 3.0 jetzt im Latest!:
                      Objects type: file
                      States  type: file
                      cd /opt/iobroker
                      iobroker list instances
                        deta Most Active @sigi234 last edited by
                        @sigi234 sagte in js-controller 3.0 jetzt im Latest!:
                        Objects type: file
                        States  type: file
                        iobroker start
                        iobroker läuft doch is running steht doch da. mh
                          + instance is alive
                            ChrisXY last edited by
                            also ich hab das Update gemacht vor 3 Tagen. Seit dem ist mein Admin sehr langsam. Iobroker läuft. Auslastung ist auch alles Okay. Telegram befehle alles schnell. Aber die Admin seite läd fast nur. Auch Adapter Updates dauern 5-10 Minuten. Meist hängt der Admin bereich dann. Anderer Browser das selbe die Login abfrage kein Problem. Sehe aber auch keine Fehler im Log. Update heute morgen gemacht und das selbe.
                              + instance is alive
                              https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
                                muckel last edited by
                                Ist schon jemanden aufgefallen, dass im Logwindow beim Chrome der "LOG HERUNTERLADEN" button fehlt?
                                Beim Edge und beim Firefox ist er da. Habt ihr da was geändert, oder liegt es an meinem Chrome-Browser?
                                Windows 10
                                  sigi234 Forum Testing Most Active @muckel last edited by
                                  @muckel sagte in js-controller 3.0 jetzt im Latest!:
                                  Windows 10
                                  Bei mir ist er da.
                                  Windows 10 und Chrome
                                  • AlCalzone
                                    AlCalzone Developer @eviltrooper last edited by
                                    @eviltrooper
                                      muckel @sigi234 last edited by
                                      @sigi234
                                      Bei mir ist er da.
                                      Danke, dann werde ich mich auf die Suche nach dem Fehler machen. 🙂
                                        dtp last edited by
                                        Hab heute den js-controller auf Version 3.0.18 aktualisiert. Im dem Zuge mussten auch gleich sieben meiner Adapter aktualisiert werden. Weiterhin läuft alles flüssig und rund in meinem Docker-Container auf der Synology DiskStation.
                                          dazilla last edited by
                                          Ich komme einfach nicht weiter, habe ein Multihostsystem und auf dem Docker Container von iobroker hat das Update des JS controllers geklappt aber auf dem Slavesystem raspi mit iobroker bekomme ich es nich mehr zum laufen. Ich hatte den Fall schon einmal aber leider finde ich die Lösung nicht mehr. Jemand eine Idee? Ich stehe da auf dem Schlauch ... danke im voraus
                                          Unsupported engine for iobroker.js-controller@3.0.18: wanted: {"node":">=10.0.0"} (current: {"node":"8.16.2","npm":"6.14.4"})
                                          ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! iobroker.js-controller@3.0.18 install: node iobroker.js setup first
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the iobroker.js-controller@3.0.18 install script.
                                            dtp @dazilla last edited by dtp
                                            @dazilla sagte in js-controller 3.0 jetzt im Latest!:
                                            Er sagt doch implizit, was du tun musst. Nämlich node.js auf Version 10 oder größer updaten.
                                            Aber wozu hat man denn ein Multihost-System, wenn man den ioBroker im Docker auf einer DiskStation betreibt? Die hat doch Perfomance genug.
                                            js-controller
                                            127
                                            1340
                                            444823
