    4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
    • J.A.R.V.I.S.
      J.A.R.V.I.S. Developer last edited by J.A.R.V.I.S.
      Windows 10
      Node 10
      js-controller 2.28
      Bei mir funktioniert der Test unter Windows obgleich mit Curl oder ohne auch nicht.
      Mit Curl:
      2020-04-21 17:13:48.230 - info: vodafone-speedtest.0 (12840) starting. Version 0.0.2 in E:/Program Files/iobroker/SmartHome/node_modules/iobroker.vodafone-speedtest, node: v10.16.3
      2020-04-21 17:13:48.746 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem with value : undefined
      2020-04-21 17:13:48.747 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.753 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.vendor with value :
      2020-04-21 17:13:48.753 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.754 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.code with value : null
      2020-04-21 17:13:48.754 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.755 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.name with value : null
      2020-04-21 17:13:48.755 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.756 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.text with value : null
      2020-04-21 17:13:48.756 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.757 - debug: vodafone-speedtest.0 (12840) Create_state called for : isCustomer with value : false
      2020-04-21 17:13:48.757 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.758 - debug: vodafone-speedtest.0 (12840) Create_state called for : isp with value : Vodafone GmbH
      2020-04-21 17:13:48.759 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.759 - debug: vodafone-speedtest.0 (12840) Create_state called for : ip with value : xxx.xxx.xxx.xxx
      2020-04-21 17:13:48.760 - debug: vodafone-speedtest.0 (12840) Create_state called for : ipCountry with value : DE
      2020-04-21 17:13:48.760 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.761 - debug: vodafone-speedtest.0 (12840) Create_state called for : downstreamSpeed with value : 0
      2020-04-21 17:13:48.761 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.762 - debug: vodafone-speedtest.0 (12840) Create_state called for : upstreamSpeed with value : 0
      2020-04-21 17:13:48.762 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.763 - debug: vodafone-speedtest.0 (12840) Create_state called for : downstreamBooked with value : null
      2020-04-21 17:13:48.763 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) Create_state called for : upstreamBooked with value : null
      2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) Write value : false
      2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) SBC-Init (Success):{"downstreamSpeed":0,"upstreamSpeed":0,"downstreamBooked":null,"upstreamBooked":null,"speedtestId":"xxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"xxx.xxx.xxx.xxx","isCustomer":false,"vendor":"","modemType":null,"plannedImprovement":null,"isO2Customer":false,"swapScenario":null,"swapLink":null}
      2020-04-21 17:13:54.010 - debug: vodafone-speedtest.0 (12840) interval: #13 @Tue Apr 21 2020 17:13:54 GMT+0200 (GMT+02:00)
      2020-04-21 17:13:54.758 - debug: vodafone-speedtest.0 (12840) interval: #12 @Tue Apr 21 2020 17:13:54 GMT+0200 (GMT+02:00)
      2020-04-21 17:13:55.508 - debug: vodafone-speedtest.0 (12840) interval: #11 @Tue Apr 21 2020 17:13:55 GMT+0200 (GMT+02:00)
      2020-04-21 17:13:56.259 - debug: vodafone-speedtest.0 (12840) interval: #10 @Tue Apr 21 2020 17:13:56 GMT+0200 (GMT+02:00)
      2020-04-21 17:13:57.009 - debug: vodafone-speedtest.0 (12840) interval: #9 @Tue Apr 21 2020 17:13:57 GMT+0200 (GMT+02:00)
      2020-04-21 17:13:57.760 - debug: vodafone-speedtest.0 (12840) interval: #8 @Tue Apr 21 2020 17:13:57 GMT+0200 (GMT+02:00)
      2020-04-21 17:13:58.508 - debug: vodafone-speedtest.0 (12840) interval: #7 @Tue Apr 21 2020 17:13:58 GMT+0200 (GMT+02:00)
      2020-04-21 17:13:59.259 - debug: vodafone-speedtest.0 (12840) interval: #6 @Tue Apr 21 2020 17:13:59 GMT+0200 (GMT+02:00)
      2020-04-21 17:14:00.009 - debug: vodafone-speedtest.0 (12840) interval: #5 @Tue Apr 21 2020 17:14:00 GMT+0200 (GMT+02:00)
      2020-04-21 17:14:00.760 - debug: vodafone-speedtest.0 (12840) interval: #4 @Tue Apr 21 2020 17:14:00 GMT+0200 (GMT+02:00)
      2020-04-21 17:14:01.510 - debug: vodafone-speedtest.0 (12840) interval: #3 @Tue Apr 21 2020 17:14:01 GMT+0200 (GMT+02:00)
      2020-04-21 17:14:02.261 - debug: vodafone-speedtest.0 (12840) interval: #2 @Tue Apr 21 2020 17:14:02 GMT+0200 (GMT+02:00)
      2020-04-21 17:14:03.011 - debug: vodafone-speedtest.0 (12840) interval: #1 @Tue Apr 21 2020 17:14:03 GMT+0200 (GMT+02:00)
      2020-04-21 17:14:03.257 - error: vodafone-speedtest.0 (12840) uncaught exception: Curl handle is closed.
      2020-04-21 17:14:03.257 - error: vodafone-speedtest.0 (12840) Error: Curl handle is closed.
      at Curl.close (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\node_modules\node-libcurl\dist\Curl.js:284:21)
      at Timeout.stopDownloadTest (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\main.js:475:29)
      at ontimeout (timers.js:436:11)
      at tryOnTimeout (timers.js:300:5)
      at listOnTimeout (timers.js:263:5)
      at Timer.processTimers (timers.js:223:10)
      2020-04-21 17:14:03.257 - info: vodafone-speedtest.0 (12840) cleaned everything up...
      2020-04-21 17:14:03.259 - info: vodafone-speedtest.0 (12840) terminating
      2020-04-21 17:14:03.259 - info: vodafone-speedtest.0 (12840) Terminated (NO_ERROR): Without reason
      2020-04-21 17:14:03.792 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: Error: Curl handle is closed.
      2020-04-21 17:14:03.793 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Curl.close (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\node_modules\node-libcurl\dist\Curl.js:284:21)
      2020-04-21 17:14:03.793 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Timeout.stopDownloadTest (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\main.js:475:29)
      2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at ontimeout (timers.js:436:11)
      2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
      2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at listOnTimeout (timers.js:263:5)
      2020-04-21 17:14:03.795 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
      2020-04-21 17:14:03.795 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 terminated with code 0 (NO_ERROR)
      Ohne Curl:
      2020-04-21 17:10:43.716 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 started with pid 16092
      2020-04-21 17:10:44.198 - debug: vodafone-speedtest.0 (16092) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-04-21 17:10:44.212 - debug: vodafone-speedtest.0 (16092) Objects client ready ... initialize now
      2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects create System PubSub Client
      2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects create User PubSub Client
      2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects client initialize lua scripts
      2020-04-21 17:10:44.219 - debug: vodafone-speedtest.0 (16092) Objects connected to redis: 127.0.0.1:9001
      2020-04-21 17:10:44.222 - debug: vodafone-speedtest.0 (16092) objectDB connected
      2020-04-21 17:10:44.223 - debug: vodafone-speedtest.0 (16092) Redis States: Use Redis connection: 127.0.0.1:6379
      2020-04-21 17:10:44.227 - debug: vodafone-speedtest.0 (16092) States create User PubSub Client
      2020-04-21 17:10:44.230 - debug: vodafone-speedtest.0 (16092) States create System PubSub Client
      2020-04-21 17:10:44.232 - debug: vodafone-speedtest.0 (16092) States connected to redis: 127.0.0.1:6379
      2020-04-21 17:10:44.233 - debug: vodafone-speedtest.0 (16092) statesDB connected
      2020-04-21 17:10:44.256 - info: vodafone-speedtest.0 (16092) starting. Version 0.0.2 in E:/Program Files/iobroker/SmartHome/node_modules/iobroker.vodafone-speedtest, node: v10.16.3
      2020-04-21 17:10:44.783 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem with value : undefined
      2020-04-21 17:10:44.784 - debug: vodafone-speedtest.0 (16092) Write value : false
      2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.vendor with value :
      2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Write value : false
      2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.code with value : null
      2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Write value : false
      2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.name with value : null
      2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.text with value : null
      2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Write value : false
      2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Create_state called for : isCustomer with value : false
      2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Create_state called for : isp with value : Vodafone GmbH
      2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Create_state called for : ip with value : xxx.xxx.xxx.xxx
      2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Write value : false
      2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Create_state called for : ipCountry with value : DE
      2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Create_state called for : downstreamSpeed with value : 0
      2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Write value : false
      2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Create_state called for : upstreamSpeed with value : 0
      2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Create_state called for : downstreamBooked with value : null
      2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Write value : false
      2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Create_state called for : upstreamBooked with value : null
      2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) SBC-Init (Success):{"downstreamSpeed":0,"upstreamSpeed":0,"downstreamBooked":null,"upstreamBooked":null,"speedtestId":"xxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"xxx.xxx.xxx.xxx","isCustomer":false,"vendor":"","modemType":null,"plannedImprovement":null,"isO2Customer":false,"swapScenario":null,"swapLink":null}
      2020-04-21 17:10:50.036 - debug: vodafone-speedtest.0 (16092) interval: #13 @Tue Apr 21 2020 17:10:50 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:50.788 - debug: vodafone-speedtest.0 (16092) interval: #12 @Tue Apr 21 2020 17:10:50 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:51.536 - debug: vodafone-speedtest.0 (16092) interval: #11 @Tue Apr 21 2020 17:10:51 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:52.286 - debug: vodafone-speedtest.0 (16092) interval: #10 @Tue Apr 21 2020 17:10:52 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:53.036 - debug: vodafone-speedtest.0 (16092) interval: #9 @Tue Apr 21 2020 17:10:53 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:53.786 - debug: vodafone-speedtest.0 (16092) interval: #8 @Tue Apr 21 2020 17:10:53 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:54.538 - debug: vodafone-speedtest.0 (16092) interval: #7 @Tue Apr 21 2020 17:10:54 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:55.287 - debug: vodafone-speedtest.0 (16092) interval: #6 @Tue Apr 21 2020 17:10:55 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:56.036 - debug: vodafone-speedtest.0 (16092) interval: #5 @Tue Apr 21 2020 17:10:56 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:56.786 - debug: vodafone-speedtest.0 (16092) interval: #4 @Tue Apr 21 2020 17:10:56 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:57.536 - debug: vodafone-speedtest.0 (16092) interval: #3 @Tue Apr 21 2020 17:10:57 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:58.286 - debug: vodafone-speedtest.0 (16092) interval: #2 @Tue Apr 21 2020 17:10:58 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:59.036 - debug: vodafone-speedtest.0 (16092) interval: #1 @Tue Apr 21 2020 17:10:59 GMT+0200 (GMT+02:00)
      2020-04-21 17:10:59.287 - warn: vodafone-speedtest.0 (16092) startDownload abort: undefined
      2020-04-21 17:10:59.288 - warn: vodafone-speedtest.0 (16092) startDownload abort: undefined
      2020-04-21 17:10:59.379 - debug: vodafone-speedtest.0 (16092) result:{"type":"download","value":940000}
      2020-04-21 17:10:59.786 - debug: vodafone-speedtest.0 (16092) interval: #0 @Tue Apr 21 2020 17:10:59 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:02.379 - debug: vodafone-speedtest.0 (16092) interval: #16 @Tue Apr 21 2020 17:11:02 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:03.129 - debug: vodafone-speedtest.0 (16092) interval: #15 @Tue Apr 21 2020 17:11:03 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:03.878 - debug: vodafone-speedtest.0 (16092) interval: #14 @Tue Apr 21 2020 17:11:03 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:04.628 - debug: vodafone-speedtest.0 (16092) interval: #13 @Tue Apr 21 2020 17:11:04 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:05.378 - debug: vodafone-speedtest.0 (16092) interval: #12 @Tue Apr 21 2020 17:11:05 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:06.130 - debug: vodafone-speedtest.0 (16092) interval: #11 @Tue Apr 21 2020 17:11:06 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:06.880 - debug: vodafone-speedtest.0 (16092) interval: #10 @Tue Apr 21 2020 17:11:06 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:07.630 - debug: vodafone-speedtest.0 (16092) interval: #9 @Tue Apr 21 2020 17:11:07 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:08.379 - debug: vodafone-speedtest.0 (16092) interval: #8 @Tue Apr 21 2020 17:11:08 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:09.130 - debug: vodafone-speedtest.0 (16092) interval: #7 @Tue Apr 21 2020 17:11:09 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:09.879 - debug: vodafone-speedtest.0 (16092) interval: #6 @Tue Apr 21 2020 17:11:09 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:10.630 - debug: vodafone-speedtest.0 (16092) interval: #5 @Tue Apr 21 2020 17:11:10 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:11.380 - debug: vodafone-speedtest.0 (16092) interval: #4 @Tue Apr 21 2020 17:11:11 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:12.130 - debug: vodafone-speedtest.0 (16092) interval: #3 @Tue Apr 21 2020 17:11:12 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:12.880 - debug: vodafone-speedtest.0 (16092) interval: #2 @Tue Apr 21 2020 17:11:12 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:13.631 - debug: vodafone-speedtest.0 (16092) interval: #1 @Tue Apr 21 2020 17:11:13 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:13.717 - error: vodafone-speedtest.0 (16092) result: Unknown Error 500
      2020-04-21 17:11:14.381 - debug: vodafone-speedtest.0 (16092) interval: #0 @Tue Apr 21 2020 17:11:14 GMT+0200 (GMT+02:00)
      2020-04-21 17:11:26.626 - info: host.DESKTOP-GG5M5BF stopInstance system.adapter.vodafone-speedtest.0 (force=false, process=true)
      2020-04-21 17:11:26.627 - info: vodafone-speedtest.0 (16092) Got terminate signal TERMINATE_YOURSELF
      2020-04-21 17:11:26.627 - info: vodafone-speedtest.0 (16092) cleaned everything up...
      2020-04-21 17:11:26.628 - info: vodafone-speedtest.0 (16092) terminating
      2020-04-21 17:11:26.628 - info: vodafone-speedtest.0 (16092) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-04-21 17:11:26.627 - info: host.DESKTOP-GG5M5BF stopInstance system.adapter.vodafone-speedtest.0 send kill signal
      2020-04-21 17:11:27.190 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      • peterbaumert
        peterbaumert Developer last edited by
        @J-A-R-V-I-S
        Die Einstellung "Use Curl" ist nur dafür da ob er auch für den Download curl nutzen soll, das muss ich noch besser beschreieben. Es geht darum ob du Curl installiert hast. Der Download ohne den Curl haken sieht gut aus und du scheinst 940mbit hinbekommen zu haben 🙂
        Hier https://curl.haxx.se/windows/ solltest du curl installieren können, oder wenn du den Windows Package Manager Chocolatey nutz: https://chocolatey.org/packages/curl
        VG
        Pete
        J.A.R.V.I.S. 1 Reply Last reply Reply Quote 0
        • J.A.R.V.I.S.
          J.A.R.V.I.S. Developer @peterbaumert last edited by
          @peterbaumert Curl ist schon von Windows vorhanden, oder benötigt man eine andere Version?
          peterbaumert 1 Reply Last reply Reply Quote 0
          • peterbaumert
            @J-A-R-V-I-S dann hab ich nichts gesagt 😄 und teste es die tage selbst mal um genau zu sehen was das problem ist.
            Danke für deine Rückmeldungen.
            Pete
            • peterbaumert
              peterbaumert Developer @J.A.R.V.I.S. last edited by
              @J-A-R-V-I-S kannst du dir mal die aktuelle master ausm github installieren und testen ob es damit geht?
              • J.A.R.V.I.S.
                @peterbaumert mit Curl funktioniert es jetzt, ohne auch, aber dann kommen immer noch die ganze Zeit die Warn-Meldungen.
                Und ich glaube der Test ist ein bisschen unrealistisch, der zeigt beim Download immer 940 an.
                • peterbaumert
                  @J-A-R-V-I-S ok das schonmal gut, was hast du denn für eine Leitung? Die meldungen nehm ich noch raus bzw ändere sie in silly
                  J.A.R.V.I.S. Glasfaser 2 Replies Last reply Reply Quote 0
                  • J.A.R.V.I.S.
                    @peterbaumert 1Gbit Leitung, aber ich hatte bei anderen Tests noch nie konstant 940Mbit.
                    ostseereiter 1 Reply Last reply Reply Quote 0
                    • Glasfaser
                      Glasfaser @peterbaumert last edited by Glasfaser
                      @peterbaumert
                      Passt auch nicht mehr .... neu von Git
                      ohne "Use curl for download too"
                      host.iobrokerv4	2020-04-23 15:49:10.198	info	"system.adapter.vodafone-speedtest.0" disabled
                      vodafone-speedtest.0	2020-04-23 15:48:51.082	debug	(9795) interval: #0 @Thu Apr 23 2020 15:48:51 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:50.409	debug	(9795) result:{"type":"upload","value":51730}
                      vodafone-speedtest.0	2020-04-23 15:48:50.408	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:50.407	debug	(9795) Create_state called for : Results.upload_Mb with value : 51.73
                      vodafone-speedtest.0	2020-04-23 15:48:50.406	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:50.406	debug	(9795) Create_state called for : Results.upload_MB with value : 6.46625
                      vodafone-speedtest.0	2020-04-23 15:48:50.405	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:50.404	debug	(9795) Create_state called for : Results.download_Mb with value : 940
                      vodafone-speedtest.0	2020-04-23 15:48:50.404	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:50.403	debug	(9795) Create_state called for : Results.download_MB with value : 117.5
                      vodafone-speedtest.0	2020-04-23 15:48:50.401	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:50.401	debug	(9795) Create_state called for : Results.Last_Run with value : Thu Apr 23 2020 15:48:50 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:50.332	debug	(9795) interval: #1 @Thu Apr 23 2020 15:48:50 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:49.582	debug	(9795) interval: #2 @Thu Apr 23 2020 15:48:49 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:48.832	debug	(9795) interval: #3 @Thu Apr 23 2020 15:48:48 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:48.082	debug	(9795) interval: #4 @Thu Apr 23 2020 15:48:48 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:47.332	debug	(9795) interval: #5 @Thu Apr 23 2020 15:48:47 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:46.581	debug	(9795) interval: #6 @Thu Apr 23 2020 15:48:46 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:45.832	debug	(9795) interval: #7 @Thu Apr 23 2020 15:48:45 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:45.081	debug	(9795) interval: #8 @Thu Apr 23 2020 15:48:45 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:44.330	debug	(9795) interval: #9 @Thu Apr 23 2020 15:48:44 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:43.580	debug	(9795) interval: #10 @Thu Apr 23 2020 15:48:43 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:42.820	debug	(9795) interval: #11 @Thu Apr 23 2020 15:48:42 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:42.070	debug	(9795) interval: #12 @Thu Apr 23 2020 15:48:42 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:41.316	debug	(9795) interval: #13 @Thu Apr 23 2020 15:48:41 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:40.565	debug	(9795) interval: #14 @Thu Apr 23 2020 15:48:40 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:39.815	debug	(9795) interval: #15 @Thu Apr 23 2020 15:48:39 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:39.069	debug	(9795) interval: #16 @Thu Apr 23 2020 15:48:39 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:34.086	debug	(9795) interval: #0 @Thu Apr 23 2020 15:48:34 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:33.604	debug	(9795) result:{"type":"download","value":940000}
                      vodafone-speedtest.0	2020-04-23 15:48:33.524	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.523	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.522	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.521	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.520	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.519	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.518	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.517	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.516	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.515	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.513	warn	(9795) startDownload abort: undefined
                      vodafone-speedtest.0	2020-04-23 15:48:33.337	debug	(9795) interval: #1 @Thu Apr 23 2020 15:48:33 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:32.591	debug	(9795) interval: #2 @Thu Apr 23 2020 15:48:32 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:31.846	debug	(9795) interval: #3 @Thu Apr 23 2020 15:48:31 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:31.084	debug	(9795) interval: #4 @Thu Apr 23 2020 15:48:31 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:30.330	debug	(9795) interval: #5 @Thu Apr 23 2020 15:48:30 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:29.576	debug	(9795) interval: #6 @Thu Apr 23 2020 15:48:29 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:28.825	debug	(9795) interval: #7 @Thu Apr 23 2020 15:48:28 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:28.077	debug	(9795) interval: #8 @Thu Apr 23 2020 15:48:28 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:27.315	debug	(9795) interval: #9 @Thu Apr 23 2020 15:48:27 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:26.560	debug	(9795) interval: #10 @Thu Apr 23 2020 15:48:26 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:25.809	debug	(9795) interval: #11 @Thu Apr 23 2020 15:48:25 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:25.065	debug	(9795) interval: #12 @Thu Apr 23 2020 15:48:25 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:24.271	debug	(9795) interval: #13 @Thu Apr 23 2020 15:48:24 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:48:23.429	debug	(9795) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"
                      vodafone-speedtest.0	2020-04-23 15:48:23.428	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.426	debug	(9795) Create_state called for : upstreamBooked with value : 50
                      vodafone-speedtest.0	2020-04-23 15:48:23.425	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.424	debug	(9795) Create_state called for : downstreamBooked with value : 1000
                      vodafone-speedtest.0	2020-04-23 15:48:23.424	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.423	debug	(9795) Create_state called for : upstreamSpeed with value : 54784
                      vodafone-speedtest.0	2020-04-23 15:48:23.423	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.422	debug	(9795) Create_state called for : downstreamSpeed with value : 1095680
                      vodafone-speedtest.0	2020-04-23 15:48:23.422	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.421	debug	(9795) Create_state called for : ipCountry with value : DE
                      vodafone-speedtest.0	2020-04-23 15:48:23.420	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.420	debug	(9795) Create_state called for : ip with value : xxxxxxxxxxxxxxxxxxx
                      vodafone-speedtest.0	2020-04-23 15:48:23.419	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.419	debug	(9795) Create_state called for : isp with value : Vodafone GmbH
                      vodafone-speedtest.0	2020-04-23 15:48:23.418	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.418	debug	(9795) Create_state called for : isCustomer with value : true
                      vodafone-speedtest.0	2020-04-23 15:48:23.417	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.417	debug	(9795) Create_state called for : modem.text with value : AVM
                      vodafone-speedtest.0	2020-04-23 15:48:23.416	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.416	debug	(9795) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                      vodafone-speedtest.0	2020-04-23 15:48:23.415	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.414	debug	(9795) Create_state called for : modem.code with value : 6591
                      vodafone-speedtest.0	2020-04-23 15:48:23.414	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.413	debug	(9795) Create_state called for : modem.vendor with value : AVM
                      vodafone-speedtest.0	2020-04-23 15:48:23.411	debug	(9795) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:48:23.410	debug	(9795) Create_state called for : modem with value : undefined
                      vodafone-speedtest.0	2020-04-23 15:48:22.392	info	(9795) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                      vodafone-speedtest.0	2020-04-23 15:48:21.674	debug	(9795) statesDB connected
                      vodafone-speedtest.0	2020-04-23 15:48:21.673	debug	(9795) States connected to redis: 127.0.0.1:9000
                      vodafone-speedtest.0	2020-04-23 15:48:21.654	debug	(9795) States create System PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:48:21.652	debug	(9795) States create User PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:48:21.640	debug	(9795) Redis States: Use Redis connection: 127.0.0.1:9000
                      vodafone-speedtest.0	2020-04-23 15:48:21.638	debug	(9795) objectDB connected
                      vodafone-speedtest.0	2020-04-23 15:48:21.633	debug	(9795) Objects connected to redis: 127.0.0.1:9001
                      vodafone-speedtest.0	2020-04-23 15:48:21.591	debug	(9795) Objects client initialize lua scripts
                      vodafone-speedtest.0	2020-04-23 15:48:21.587	debug	(9795) Objects create User PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:48:21.585	debug	(9795) Objects create System PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:48:21.581	debug	(9795) Objects client ready ... initialize now
                      vodafone-speedtest.0	2020-04-23 15:48:21.528	debug	(9795) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.iobrokerv4	2020-04-23 15:48:20.916	info	instance system.adapter.vodafone-speedtest.0 started with pid 9795
                      mit "Use curl for download too"
                      host.iobrokerv4	2020-04-23 15:52:37.906	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
                      host.iobrokerv4	2020-04-23 15:52:37.904	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
                      vodafone-speedtest.0	2020-04-23 15:52:35.372	debug	(12159) interval: #2 @Thu Apr 23 2020 15:52:35 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:34.621	debug	(12159) interval: #3 @Thu Apr 23 2020 15:52:34 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:33.867	debug	(12159) interval: #4 @Thu Apr 23 2020 15:52:33 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:33.117	debug	(12159) interval: #5 @Thu Apr 23 2020 15:52:33 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:32.366	debug	(12159) interval: #6 @Thu Apr 23 2020 15:52:32 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:31.618	debug	(12159) interval: #7 @Thu Apr 23 2020 15:52:31 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:30.857	debug	(12159) interval: #8 @Thu Apr 23 2020 15:52:30 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:30.109	debug	(12159) interval: #9 @Thu Apr 23 2020 15:52:30 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:29.346	debug	(12159) interval: #10 @Thu Apr 23 2020 15:52:29 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:28.596	debug	(12159) interval: #11 @Thu Apr 23 2020 15:52:28 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:27.846	debug	(12159) interval: #12 @Thu Apr 23 2020 15:52:27 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:27.099	debug	(12159) interval: #13 @Thu Apr 23 2020 15:52:27 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:52:25.367	debug	(12159) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":
                      vodafone-speedtest.0	2020-04-23 15:52:25.365	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.365	debug	(12159) Create_state called for : upstreamBooked with value : 50
                      vodafone-speedtest.0	2020-04-23 15:52:25.364	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.364	debug	(12159) Create_state called for : downstreamBooked with value : 1000
                      vodafone-speedtest.0	2020-04-23 15:52:25.363	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.363	debug	(12159) Create_state called for : upstreamSpeed with value : 54784
                      vodafone-speedtest.0	2020-04-23 15:52:25.362	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.361	debug	(12159) Create_state called for : downstreamSpeed with value : 1095680
                      vodafone-speedtest.0	2020-04-23 15:52:25.360	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.360	debug	(12159) Create_state called for : ipCountry with value : DE
                      vodafone-speedtest.0	2020-04-23 15:52:25.359	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.358	debug	(12159) Create_state called for : ip with value : xxxxxxxxxxxxxxxxxxx
                      vodafone-speedtest.0	2020-04-23 15:52:25.357	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.357	debug	(12159) Create_state called for : isp with value : Vodafone GmbH
                      vodafone-speedtest.0	2020-04-23 15:52:25.356	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.355	debug	(12159) Create_state called for : isCustomer with value : true
                      vodafone-speedtest.0	2020-04-23 15:52:25.354	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.353	debug	(12159) Create_state called for : modem.text with value : AVM
                      vodafone-speedtest.0	2020-04-23 15:52:25.352	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.351	debug	(12159) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                      vodafone-speedtest.0	2020-04-23 15:52:25.346	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.345	debug	(12159) Create_state called for : modem.code with value : 6591
                      vodafone-speedtest.0	2020-04-23 15:52:25.344	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.344	debug	(12159) Create_state called for : modem.vendor with value : AVM
                      vodafone-speedtest.0	2020-04-23 15:52:25.341	debug	(12159) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:52:25.340	debug	(12159) Create_state called for : modem with value : undefined
                      vodafone-speedtest.0	2020-04-23 15:52:24.278	info	(12159) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                      vodafone-speedtest.0	2020-04-23 15:52:23.522	debug	(12159) statesDB connected
                      vodafone-speedtest.0	2020-04-23 15:52:23.521	debug	(12159) States connected to redis: 127.0.0.1:9000
                      vodafone-speedtest.0	2020-04-23 15:52:23.500	debug	(12159) States create System PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:52:23.498	debug	(12159) States create User PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:52:23.486	debug	(12159) Redis States: Use Redis connection: 127.0.0.1:9000
                      vodafone-speedtest.0	2020-04-23 15:52:23.484	debug	(12159) objectDB connected
                      vodafone-speedtest.0	2020-04-23 15:52:23.479	debug	(12159) Objects connected to redis: 127.0.0.1:9001
                      vodafone-speedtest.0	2020-04-23 15:52:23.443	debug	(12159) Objects client initialize lua scripts
                      vodafone-speedtest.0	2020-04-23 15:52:23.442	debug	(12159) Objects create User PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:52:23.441	debug	(12159) Objects create System PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:52:23.438	debug	(12159) Objects client ready ... initialize now
                      vodafone-speedtest.0	2020-04-23 15:52:23.392	debug	(12159) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.iobrokerv4	2020-04-23 15:52:22.618	info	instance system.adapter.vodafone-speedtest.0 started with pid 12159
                      host.iobrokerv4	2020-04-23 15:51:52.536	info	Restart adapter system.adapter.vodafone-speedtest.0 because enabled
                      host.iobrokerv4	2020-04-23 15:51:52.536	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
                      host.iobrokerv4	2020-04-23 15:51:52.535	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
                      vodafone-speedtest.0	2020-04-23 15:51:50.104	debug	(11688) interval: #3 @Thu Apr 23 2020 15:51:50 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:49.361	debug	(11688) interval: #4 @Thu Apr 23 2020 15:51:49 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:48.269	debug	(11688) interval: #5 @Thu Apr 23 2020 15:51:48 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:47.516	debug	(11688) interval: #6 @Thu Apr 23 2020 15:51:47 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:46.764	debug	(11688) interval: #7 @Thu Apr 23 2020 15:51:46 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:46.015	debug	(11688) interval: #8 @Thu Apr 23 2020 15:51:46 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:45.263	debug	(11688) interval: #9 @Thu Apr 23 2020 15:51:45 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:44.510	debug	(11688) interval: #10 @Thu Apr 23 2020 15:51:44 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:43.761	debug	(11688) interval: #11 @Thu Apr 23 2020 15:51:43 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:43.009	debug	(11688) interval: #12 @Thu Apr 23 2020 15:51:43 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:42.262	debug	(11688) interval: #13 @Thu Apr 23 2020 15:51:42 GMT+0200 (GMT+02:00)
                      vodafone-speedtest.0	2020-04-23 15:51:40.597	debug	(11688) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":
                      vodafone-speedtest.0	2020-04-23 15:51:40.596	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.596	debug	(11688) Create_state called for : upstreamBooked with value : 50
                      vodafone-speedtest.0	2020-04-23 15:51:40.595	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.594	debug	(11688) Create_state called for : downstreamBooked with value : 1000
                      vodafone-speedtest.0	2020-04-23 15:51:40.594	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.593	debug	(11688) Create_state called for : upstreamSpeed with value : 54784
                      vodafone-speedtest.0	2020-04-23 15:51:40.592	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.592	debug	(11688) Create_state called for : downstreamSpeed with value : 1095680
                      vodafone-speedtest.0	2020-04-23 15:51:40.591	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.591	debug	(11688) Create_state called for : ipCountry with value : DE
                      vodafone-speedtest.0	2020-04-23 15:51:40.590	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.589	debug	(11688) Create_state called for : ip with value : xxxxxxxxxxxxxxxx
                      vodafone-speedtest.0	2020-04-23 15:51:40.589	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.588	debug	(11688) Create_state called for : isp with value : Vodafone GmbH
                      vodafone-speedtest.0	2020-04-23 15:51:40.588	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.587	debug	(11688) Create_state called for : isCustomer with value : true
                      vodafone-speedtest.0	2020-04-23 15:51:40.586	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.585	debug	(11688) Create_state called for : modem.text with value : AVM
                      vodafone-speedtest.0	2020-04-23 15:51:40.585	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.584	debug	(11688) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                      vodafone-speedtest.0	2020-04-23 15:51:40.583	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.583	debug	(11688) Create_state called for : modem.code with value : 6591
                      vodafone-speedtest.0	2020-04-23 15:51:40.582	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.582	debug	(11688) Create_state called for : modem.vendor with value : AVM
                      vodafone-speedtest.0	2020-04-23 15:51:40.579	debug	(11688) Write value : false
                      vodafone-speedtest.0	2020-04-23 15:51:40.578	debug	(11688) Create_state called for : modem with value : undefined
                      vodafone-speedtest.0	2020-04-23 15:51:39.442	info	(11688) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                      vodafone-speedtest.0	2020-04-23 15:51:38.814	debug	(11688) statesDB connected
                      vodafone-speedtest.0	2020-04-23 15:51:38.813	debug	(11688) States connected to redis: 127.0.0.1:9000
                      vodafone-speedtest.0	2020-04-23 15:51:38.794	debug	(11688) States create System PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:51:38.791	debug	(11688) States create User PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:51:38.779	debug	(11688) Redis States: Use Redis connection: 127.0.0.1:9000
                      vodafone-speedtest.0	2020-04-23 15:51:38.777	debug	(11688) objectDB connected
                      vodafone-speedtest.0	2020-04-23 15:51:38.772	debug	(11688) Objects connected to redis: 127.0.0.1:9001
                      vodafone-speedtest.0	2020-04-23 15:51:38.737	debug	(11688) Objects client initialize lua scripts
                      vodafone-speedtest.0	2020-04-23 15:51:38.736	debug	(11688) Objects create User PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:51:38.735	debug	(11688) Objects create System PubSub Client
                      vodafone-speedtest.0	2020-04-23 15:51:38.732	debug	(11688) Objects client ready ... initialize now
                      vodafone-speedtest.0	2020-04-23 15:51:38.691	debug	(11688) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.iobrokerv4	2020-04-23 15:51:38.093	info	instance system.adapter.vodafone-speedtest.0 started with pid 11688
                      • peterbaumert
                        peterbaumert Developer @Glasfaser last edited by
                        @Glasfaser Ich schau mir das an, versuche es bei mir zu debugen. Wenn du auf der Instanz Seite den expert Modus aktiviert hast kannst du die log Option umstellen. Wenn du das auf silly stellen könntest und mir dann den log posten, würde mir das dabei sehr helfen. Danke schonmal.
                        Pete
                        • Dr. Bakterius
                          Dr. Bakterius Most Active last edited by
                          Mir ist aufgefallen, dass sich der Adapter unheimlich viel RAM krallt. Startet so bei 400MB und steigert sich mit der Zeit. Bei 850MB habe ich das System mal neu gestartet doch dann eben 400MB.
                          Während des Tests lasse ich mir das ja einreden, doch danach sollte der RAM wieder freigegeben werden. Auf keinen Fall sollte der Bedarf immer weiter ansteigen.
                          Oder ist das nur bei mir so?
                          arteck RK62 2 Replies Last reply Reply Quote 0
                            arteck Developer Most Active @Dr. Bakterius last edited by
                            @Dr-Bakterius hier ditto
                            • RK62
                              RK62 @Dr. Bakterius last edited by RK62
                              @Dr-Bakterius Bei mir auch. Ich habe die Version 0.0.3 mit ioBroker unter Docker probiert, da hat er sich während / nach der ersten Messung gleich 1085.6 MB geschnappt.
                              Ansonsten problemlos und sie Werte scheinen plausibel.
                              • peterbaumert
                                peterbaumert Developer last edited by peterbaumert
                                Hey, ja an dem Memory Problem bin ich dran. Habe das aber noch nicht so ganz nachvollziehen können. Mit dem debugger zeigt er mir 90mb belegt an, daher ist das momentan ein wenig stochern im Dunkeln. Ich gebe nämlich eigentlich alle Ressourcen nach dem Test wieder frei. Halte euch auf dem laufenden.
                                @arteck @Dr-Bakterius @RK62 könnt ihr mal die neuste ausm master git ziehen?
                                Dr. Bakterius Chaot RK62 B 4 Replies Last reply Reply Quote 0
                                • Dr. Bakterius
                                  Dr. Bakterius Most Active @peterbaumert last edited by
                                  @peterbaumert sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                  Die 0.0.3 von https://github.com/peterbaumert/ioBroker.vodafone-speedtest? Da merke ich beim RAM keinen Unterschied.
                                  • Chaot
                                    Chaot @peterbaumert last edited by
                                    @peterbaumert
                                    Bei mir zieht der Adapter am Anfang 198 MB und steigt dann stetig an.
                                    Geschwindigkeit scheint mit 865 Mb/s zu stimmen.
                                    • RK62
                                      RK62 @peterbaumert last edited by
                                      @peterbaumert Also laut ioBroker-Admin habe ich die 0.0.3 im Einsatz. Habe ich auch über den ioBroker-Admin installiert, nicht über GitHub.
                                      Ich habe mal die history für das Memory aktiviert, siehe rote Linie. Daraus ist ersichtlich, dass das Memory vor dem Start eines Test fast auf 0 geht und während des Tests dann wieder massiv wieder ansteigt.
                                      Vielleicht hilft das bei der Suche.
                                      Gruß, Ralf
                                      • peterbaumert
                                        peterbaumert Developer @RK62 last edited by
                                        @RK62 Vielen dank schonmal dafür, das hilft in der Tat. Dass es während des Tests ansteigt ist an sich normal, da er die runtergeladenen Daten irgendwo zwischenspeichern muss zur Auswertung, aber eigentlich sollte der danach wieder freigegeben werden und nicht erst vor dem nächsten Test. Ich suche weiter nach dem Problem!
                                        • Chaot
                                          Chaot @peterbaumert last edited by Chaot
                                          @peterbaumert
                                          Ich habe eine Warnmeldung drin:
                                          vodafone-speedtest.0	2020-04-29 11:08:45.637	info	(10295) Vodafone-Speedtest finished with 799.539mbit download speed and 55.575mbit upload speed.
                                          vodafone-speedtest.0	2020-04-29 11:08:29.286	warn	(10295) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-29 11:08:29.285	warn	(10295) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-29 11:08:29.284	warn	(10295) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-29 11:08:29.283	warn	(10295) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-29 11:08:29.282	warn	(10295) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-29 11:08:29.275	warn	(10295) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-29 11:08:18.175	info	(10295) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2, js-controller: 3.0.20
                                          Oh, und einen Fehler:
                                          vodafone-speedtest.0	2020-04-29 12:08:19.045	info	(10295) Terminated (NO_ERROR): Without reason
                                          vodafone-speedtest.0	2020-04-29 12:08:19.043	info	(10295) terminating
                                          vodafone-speedtest.0	2020-04-29 12:08:19.023	info	(10295) cleaned everything up...
                                          vodafone-speedtest.0	2020-04-29 12:08:19.017	error	(10295) uncaught exception: undefined
                                            BasGo @peterbaumert last edited by BasGo
                                            Ich war gerade mal so frei und habe - aufgrund des Speicherwachstums - ebenfalls den Master von GitHub genommen: da sieht es dann sehr, sehr gut aus 😉
                                            Außerdem finde ich die Scheduled-Variante für den Adapter charmanter, bei mir steht er aktuell auf "alle 5 Minuten".
                                            31.7k
                                            79.8k
                                            vodafone speedtest
                                            42
                                            202
                                            25285
