    4. Material Design Widgets: Wetter View
      sigi234 Forum Testing Most Active @RalfEngelberth last edited by
      @RalfEngelberth
      Hast du schon mal die Runtime gestartet, sieht es da auch so aus?
        RalfEngelberth @sigi234 last edited by Negalein
        @sigi234 Hier ein Bild vom Runtime
          sigi234 Forum Testing Most Active @RalfEngelberth last edited by sigi234
          @RalfEngelberth
          Welche Version von Material Design Widgets hast du?
              @RalfEngelberth
              Skript ok, alles Richtig eingestellt?
                @sigi234 Skript läuft.
                Einstellungen im Skript habe ich nur die Region vom Pollenflug geändert.
                sigi234 K 2 Replies Last reply Reply Quote 0
                  @RalfEngelberth sagte in Material Design Widgets: Wetter View:
                  Was steht bei dir in den Objekten unter Chart?
                    {"axisLabels":["1h","2h","3h","4h","5h","6h","7h","8h","9h","10h","11h","12h","13h","14h","15h","16h","17h","18h","19h","20h","21h","22h","23h","24h"],"graphs":[{"data":[9,8,6,6,5,5,6,7,9,11,12,13,14,16,16,16,16,16,15,12,11,10,9,8],"type":"line","color":"gray","legendText":"Temperatur","line_pointSizeHover":5,"line_pointSize":0,"line_Tension":0.3,"yAxis_show":false,"yAxis_gridLines_show":false,"yAxis_gridLines_ticks_length":5,"yAxis_min":0,"yAxis_max":25,"yAxis_step":5,"yAxis_position":"left","yAxis_appendix":" °C","yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","displayOrder":0,"tooltip_AppendText":" °C","datalabel_backgroundColor":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"datalabel_color":"white","datalabel_offset":-10,"datalabel_fontFamily":"RobotoCondensed-Light","datalabel_fontSize":12,"datalabel_borderRadius":6,"datalabel_steps":2,"line_PointColor":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorBorder":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorHover":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorBorderHover":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"use_gradient_color":true,"gradient_color":[{"value":-20,"color":"#5b2c6f66"},{"value":0,"color":"#2874a666"},{"value":14,"color":"#73c6b666"},{"value":22,"color":"#00800066"},{"value":27,"color":"#ffa50066"},{"value":35,"color":"#ff000066"}],"use_line_gradient_fill_color":true,"line_gradient_fill_color":[{"value":-20,"color":"#5b2c6f66"},{"value":0,"color":"#2874a666"},{"value":14,"color":"#73c6b666"},{"value":22,"color":"#00800066"},{"value":27,"color":"#ffa50066"},{"value":35,"color":"#ff000066"}]},{"data":[10,10,10,10,10,10,10,10,0,0,0,0,0,0,0,0,0,0,0,1,2,2,2,3],"type":"line","color":"#0d47a1","legendText":"Regenwahrscheinlichkeit","line_UseFillColor":true,"line_pointSize":0,"line_pointSizeHover":5,"yAxis_min":0,"yAxis_max":100,"yAxis_maxSteps":10,"yAxis_position":"left","yAxis_gridLines_show":false,"yAxis_gridLines_border_show":false,"yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","yAxis_appendix":" %","displayOrder":1,"tooltip_AppendText":" %","datalabel_show":false}]}
                      @RalfEngelberth
                      Ok, was sagt die Console unter F12
                        @sigi234 Ich hoffe, ich habe hier das Richtige.
                        sigi234 Scrounger 2 Replies Last reply Reply Quote 0
                          @RalfEngelberth
                          Ok, das sollte sich @Scrounger mal ansehen. Ev. meldet er sich.
                            @sigi234 ok
                            • Scrounger
                              Scrounger Developer @RalfEngelberth last edited by
                              ![Bild Text](c1f6d83c-180b-4d24-83d7-886db20e68a0-image.png Bild Link)
                              Das ist ein Edge spezifischer Fehler, der bei mir auch kommt. Das muss ich mir in Ruhe anschauen und im MDW fixen
                                RalfEngelberth @Scrounger last edited by
                                @Scrounger sagte in Material Design Widgets: Wetter View:
                                Habe gerade den Firefox installiert.
                                Damit geht es
                                • Scrounger
                                  @RalfEngelberth
                                  Ja auch mit Chrome geht es, nur halt der Edge macht hier probleme.
                                  Hab den Fehler behoben, fix gibts dann in der nächsten version.
                                  Falls du nicht warten willst kannst von github installieren -> danach muss iobroker upload vis ausgeführt werden!
                                    Aiouh @Scrounger last edited by
                                    @Scrounger
                                    darf man hier auch ein Lob loswerden, nicht nur Probleme ?
                                    Ich bin als ziemlicher Neuling einfach nach der Anleitung vorgegangen und ALLES hat auf Anhieb funktioniert.
                                    Vielen Dank für die klasse Arbeit (Kaffee ist unterwegs 😉 )
                                    Gruss Karl-Heinz
                                      Smart86 last edited by Smart86
                                      Sehr cooles Plugin. Ein kleines Problem habe ich aber noch, vielleicht gibt es ja eine einfache Lösung. Am Handy im Hochformat überlagern sich leider die Zahlen mit den Icons. Hat wer ne Idee?
                                      • Scrounger
                                        Scrounger Developer @Aiouh last edited by
                                        @Aiouh sagte in Material Design Widgets: Wetter View:
                                        @Scrounger
                                        Gruss Karl-Heinz
                                        Ich weiß zwar nicht ob das die Forumsregeln gestatten 😉 aber ich freue mich immer über ein Lob, genauso wie zu lesen, wenn meine Projekte bei Euch funktionieren!
                                        @Smart86 sagte in Material Design Widgets: Wetter View:
                                        Das musst du über das Widget Grid View einstellen. Dort kannst du festlegen ab welcher Auflösung die Regeln für Handy / Tablet und Desktop gelten und für diese dann die Spalten einstellen. Das Widget hat auch einen Auflösungsassitenten, der dir hilft die entsprechenden Auflösung zu erkennen.
                                        Am besten einfach mal mit rum spielen, dann bekommst den Dreh raus.
                                          Smart86 @Scrounger last edited by
                                          Vielen Dank. Habe es in den Einstellungen gefunden bzw. die Spaltenanzahl geändert. Jetzt schaut es gut aus .-)
                                            HoffmannOs last edited by
                                            Ich suche mir schon nen Wolf, wie kann ich denn die Cards die derzeit in Weiss sind an mein Design im Script anpassen?
                                            daswetter javascript material design widgets pollenflug statusanzeige vis weatherunderground wetter
                                            78
                                            665
                                            161215
