    4. zigbee: nach update von nodejs startet adapter nicht mehr
    UNSOLVED zigbee: nach update von nodejs startet adapter nicht mehr
      Thomas Braun Most Active @tom_33 last edited by Thomas Braun
      @tom_33 Versuch mal
      sudo npm uninstall -g npm
        tom_33 @Thomas Braun last edited by tom_33
        @Thomas-Braun
        da sind aber noch einige meldungen, mit den gleichen hinweisen, darüber
        sorry! sudo vergessen. keine meldungen aber auch keine änderung
          @tom_33
          Schön wäre, wenn du die Konsolenausgabe in Gänze (inkl. deiner Eingabe) hier reinkopieren würdest. In Code-Tags, bitte.
            Thomas Braun Most Active @Thomas Braun last edited by
            ls -la /usr/local/bin/npm
              @Thomas-Braun
              code tags kannte ich noch nicht...
              pi@ioBroker-RasPi:/opt/iobroker $ ls -la /usr/bin/npm
              lrwxrwxrwx 1 root root 38 Apr  8 22:27 /usr/bin/npm -> ../lib/node_modules/npm/bin/npm-cli.js
              pi@ioBroker-RasPi:/opt/iobroker $ npm uninstall -g npm
              npm WARN npm npm does not support Node.js v12.16.2
              npm WARN npm You should probably upgrade to a newer version of node as we
              npm WARN npm can't make any promises that npm will work with this version.
              npm WARN npm Supported releases of Node.js are the latest release of 6, 8, 9, 10, 11.
              npm WARN npm You can find the latest version at https://nodejs.org/
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/abbrev
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-regex
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansicolors
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansistyles
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aproba
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/archy
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asap
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/assert-plus
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asynckit
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws-sign2
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws4
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/balanced-match
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bluebird
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/buffer-from
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/builtins
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byline
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byte-size
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/call-limit
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/camelcase
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/capture-stack-trace
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/caseless
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chownr
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ci-info
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-boxes
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/clone
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/co
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/code-point-at
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-name
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-convert
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-styles
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/colors
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-map
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/brace-expansion
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/console-control-strings
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/core-util-is
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/create-error-class
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/yallist
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/crypto-random-string
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cyclist
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dashdash
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debug/node_modules/ms
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debuglog
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decamelize
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decode-uri-component
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/deep-extend
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/defaults
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delayed-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/combined-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delegates
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-indent
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-newline
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dotenv
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexer3
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/editor
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/env-paths
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/err-code
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promise
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promisify
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agent-base
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/escape-string-regexp
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/execa/node_modules/get-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extend
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extsprintf
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-deep-equal
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-json-stable-stringify
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/figgy-pudding
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-npm-prefix
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/forever-agent
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs.realpath
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/function-bind
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/aproba
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/genfun
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-caller-file
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/getpass
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/got/node_modules/get-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-schema
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-flag
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-symbols
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-unicode
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/hosted-git-info
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-cache-semantics
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-proxy-agent
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/https-proxy-agent
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iferr
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/import-lazy
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/imurmurhash
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/infer-owner
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inherits
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ini
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/global-dirs
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/invert-kv
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip-regex
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cidr-regex
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-callable
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-ci/node_modules/ci-info
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-cidr
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-date-object
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-npm
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-obj
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dot-prop
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-redirect
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-regex
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-retry-allowed
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-symbol
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-to-primitive
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-abstract
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-typedarray
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isarray
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isexe
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isstream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsbn
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-parse-better-errors
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema-traverse
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ajv
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-stringify-safe
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsonparse
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lazy-property
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lcid
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseindexof
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._bindcallback
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._cacheindexof
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createset
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._getnative
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createcache
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._root
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseuniq
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.clonedeep
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.restparam
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.union
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.uniq
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.without
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lowercase-keys
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/meant
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mem/node_modules/mimic-fn
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-db
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-types
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/form-data
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimatch
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ignore-walk
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp/node_modules/minimist
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cmd-shim
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ms
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/humanize-ms
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agentkeepalive
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mute-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nice-try
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-cache-filename
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-logical-tree
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-bundled
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-packlist
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-user-validate
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/number-is-nan
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/oauth-sign
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-assign
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-keys
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/define-properties
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object.getownpropertydescriptors
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/opener
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-homedir
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-tmpdir
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/osenv
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-defer
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/map-age-cleaner
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-finally
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-is-promise
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-try
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-limit
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-locate
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-exists
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/locate-path
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-up
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-absolute
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-inside
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-path-inside
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-installed-globally
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-key
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-run-path
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-parse
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/performance-now
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pify
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-dir
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prepend-http
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/process-nextick-args
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-inflight
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-retry/node_modules/retry
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/proto-list
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/config-chain
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/protoduck
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prr
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/errno
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pseudomap
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/lru-cache
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/psl
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/punycode
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qrcode-terminal
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qs
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qw
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rc/node_modules/minimist
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promzard
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-cmd-shim
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-directory
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-main-filename
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/resolve-from
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/retry
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/run-queue/node_modules/aproba
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safe-buffer
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safer-buffer
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asn1
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ecc-jsbn
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iconv-lite
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/encoding
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-fetch-npm
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-install-checks
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver-diff
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/set-blocking
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sha
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-regex
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-command
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/signal-exit
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lockfile
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/slide
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/smart-buffer
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/node_modules/agent-base
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-object
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-exceptions
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-expression-parse
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-correct
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/split-on-first
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ssri
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-shift
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strict-uri-encode
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/query-string
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string_decoder/node_modules/safe-buffer
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-align
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-table3
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-audit-report
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stringify-package
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-ansi
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-columns
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/string-width
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-eof
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-json-comments
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-auth-token
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-url
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/supports-color
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chalk
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/text-table
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/JSONStream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/string_decoder
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/timed-out
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tiny-relative-date
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tough-cookie
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tunnel-agent
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tweetnacl
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bcrypt-pbkdf
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sshpk
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/typedarray
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uid-number
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/umask
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-slug
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-filename
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-string
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unpipe
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unzip-response
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/url-parse-lax
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/package-json
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/latest-version
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-deprecate
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/readable-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-extend
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-promisify
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uuid
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-license
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-name
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-package-arg
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lock-verify
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-pick-manifest
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/verror
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsprim
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-signature
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/request
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wcwidth
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/columnify
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/term-size
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-locale/node_modules/cross-spawn
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which-module
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wide-align/node_modules/string-width
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npmlog
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/widest-line
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/boxen
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/worker-farm
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrappy
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dezalgo
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/once
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/end-of-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-each
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inflight
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-json
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/init-package-json
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rimraf
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-vacuum
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pump
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-stream
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-locale/node_modules/execa
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pumpify/node_modules/pump
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readdir-scoped-modules
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-installed
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-tree
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/write-file-atomic
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bin-links
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xdg-basedir
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/configstore
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/update-notifier
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xtend
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mississippi
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/y18n
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yallist
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-minipass/node_modules/minipass
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lru-cache
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cacache
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-fetch-happen
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmaccess
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmhook
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmorg
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmpublish
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmsearch
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmteam
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-profile
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minizlib/node_modules/minipass
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote/node_modules/minipass
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/minipass
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-lifecycle
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libcipm
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs-parser
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/y18n
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpx
              npm ERR! path /usr/lib/node_modules/npm/node_modules/abbrev
              npm ERR! code EACCES
              npm ERR! errno -13
              npm ERR! syscall access
              npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
              npm ERR!  [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'] {
              npm ERR!   stack: "Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'",
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'access',
              npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/abbrev'
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator (though this is not recommended).
              npm ERR!     /home/iobroker/.npm/_logs/2020-04-25T21_27_29_359Z-debug.log
              pi@ioBroker-RasPi:/opt/iobroker $ npm -v
              6.4.1
              pi@ioBroker-RasPi:/opt/iobroker $ sudo npm uninstall -g npm
              removed 435 packages in 27.413s
              6.4.1
              pi@ioBroker-RasPi:/opt/iobroker $ ls -la /usr/local/bin/npm
              lrwxrwxrwx 1 root staff 38 Okt 25  2019 /usr/local/bin/npm -> ../lib/node_modules/npm/bin/npm-cli.js
                @tom_33
                Dann versuchen wir die Holzhammermethode:
                sudo rm -rf /usr/local/bin/npm
                Und dann nochmal mit
                which npm
                schauen ob die Version aus /usr/bin genutzt wird
                  @Thomas-Braun
                  pi@ioBroker-RasPi:/opt/iobroker $ sudo rm -rf /usr/local/bin/npm
                  Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die
                  Regeln erklärt hat.  Normalerweise läuft es auf drei Regeln hinaus:
                      #1) Respektieren Sie die Privatsphäre anderer.
                      #2) Denken Sie nach, bevor Sie tippen.
                      #3) Mit großer Macht kommt große Verantwortung.
                  [sudo] Passwort für pi:
                  pi@ioBroker-RasPi:/opt/iobroker $ which npm
                  ich bemüh mich eh die 3 regeln einzuhalten 😉
                    @tom_33
                    Okay, ist offenbar weg...
                    ls -la /usr/bin/npm
                      @Thomas-Braun sagte in zigbee: nach update von nodejs startet adapter nicht mehr:
                      ls -la /usr/bin/npm
                      ls: Zugriff auf '/usr/bin/npm' nicht möglich: Datei oder Verzeichnis nicht gefunden
                      yep!
                        @tom_33
                        Dann noch ein
                        sudo apt-get install --reinstall nodejs
                          pi@ioBroker-RasPi:/opt/iobroker $ sudo apt-get install --reinstall nodejs
                          0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen noch 0 B von 15,9 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                          (Lese Datenbank ... 56088 Dateien und Verzeichnisse sind derzeit installiert.)
                          Vorbereitung zum Entpacken von .../nodejs_12.16.2-1nodesource1_armhf.deb ...
                          Entpacken von nodejs (12.16.2-1nodesource1) über (12.16.2-1nodesource1) ...
                          nodejs (12.16.2-1nodesource1) wird eingerichtet ...
                          Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                          6.14.4
                          das sieht mal schon besser aus. ein fix steht evtl. noch aus und dann den iobroker starten?
                            @tom_33
                            Jetzt bist du sauber.
                            Der fixer kann nicht Schaden,
                            npm rebuild
                            in /opt/iobroker und dann würde ich den iobroker wieder anorgeln.
                            Ich würde allerdings an deiner Stelle überlegen, den Stretch auf Buster zu hieven.
                              @Thomas-Braun
                              ein ganz großes danke an dich für die geduld mit mir. da bin ich jetzt uptodate.
                              zigbee zickt leider immer noch gleich rum. z.zt. schnurrt die katze, mal sehen ob's was bringt.
                              das sagt mir leider gar nichts
                              pi@ioBroker-RasPi:~ $ nodejs -v
                              v12.16.2
                              pi@ioBroker-RasPi:~ $ node -v
                              v12.16.2
                              pi@ioBroker-RasPi:~ $ npm -v
                              6.14.4
                              host.ioBroker-RasPi	2020-04-26 00:08:12.025	info	Restart adapter system.adapter.zigbee.0 because enabled
                              host.ioBroker-RasPi	2020-04-26 00:08:12.025	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.024	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.023	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.023	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.022	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.021	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:112:48)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.021	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.020	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.019	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.018	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.018	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                              host.ioBroker-RasPi	2020-04-26 00:08:12.017	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                              host.ioBroker-RasPi	2020-04-26 00:08:12.016	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                              host.ioBroker-RasPi	2020-04-26 00:08:12.016	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                              host.ioBroker-RasPi	2020-04-26 00:08:12.015	error	Caught by controller[0]: was compiled against a different Node.js version using
                              host.ioBroker-RasPi	2020-04-26 00:08:12.014	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                              host.ioBroker-RasPi	2020-04-26 00:08:12.013	error	Caught by controller[0]: ^
                              host.ioBroker-RasPi	2020-04-26 00:08:12.012	error	Caught by controller[0]: throw e;
                              host.ioBroker-RasPi	2020-04-26 00:08:12.010	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:121
                              host.ioBroker-RasPi	2020-04-26 00:08:11.364	info	instance system.adapter.zigbee.0 started with pid 1971
                              Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                @tom_33
                                Du musst im Verzeichnis /opt/iobroker noch ein
                                npm rebuild
                                ausführen.
                                'Stretch' ist die sog. 'oldstable' Version on Debian, 'Buster' die aktuelle 'stable'. Debian wird zwar immer sehr lange gepflegt, aber man sollte da doch irgendwann auch sein System nachziehen.
                                • Glasfaser
                                  Glasfaser @Thomas Braun last edited by
                                  @Thomas-Braun
                                  tolle Leistung ... bzw. Geduld 👍
                                    Thomas Braun Most Active @Glasfaser last edited by
                                    @Glasfaser said in zigbee: nach update von nodejs startet adapter nicht mehr:
                                    @Thomas-Braun
                                    Danke. Aber tom_33 war ja auch pflegeleicht und hat alles schön umgesetzt.
                                    Glasfaser T 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      Glasfaser @Thomas Braun last edited by Glasfaser
                                      Da kann ich dir Recht geben , viele ballern zwischdurch noch andere Befehle dazu .
                                      • Glasfaser
                                        Glasfaser @tom_33 last edited by
                                        @tom_33
                                        und alles klar .... mit Zigbee !?
                                          @Thomas-Braun
                                          da schließe ich mich an glasfaser an. und das andere seh ich als lob 🙂
                                          nein, zigbee macht immer noch errors. grrrr
                                          • Glasfaser
                                            Glasfaser @tom_33 last edited by Glasfaser
                                            @tom_33
                                            und welche !?
                                            Jetzt sag nicht ... npm rebulid
                                            node8 nodejs 12 zigbee adapter
                                            3222
