    4. zigbee: nach update von nodejs startet adapter nicht mehr
    UNSOLVED zigbee: nach update von nodejs startet adapter nicht mehr
    • Glasfaser
      Glasfaser @tom_33 last edited by Glasfaser
      @tom_33
      nein, zigbee macht immer noch errors
      und welche !?
      Jetzt sag nicht ... npm rebulid
        tom_33 @Glasfaser last edited by tom_33
        @Glasfaser
        ihr seid wirklich spitze! hilfe ohne ende!
        nein npm rebuild hat keine faxen gemacht
        host.ioBroker-RasPi	2020-04-26 00:34:16.543	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.ioBroker-RasPi	2020-04-26 00:34:16.543	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker-RasPi	2020-04-26 00:34:16.543	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
        host.ioBroker-RasPi	2020-04-26 00:34:16.542	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
        host.ioBroker-RasPi	2020-04-26 00:34:16.542	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
        host.ioBroker-RasPi	2020-04-26 00:34:16.541	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:112:48)
        host.ioBroker-RasPi	2020-04-26 00:34:16.541	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.ioBroker-RasPi	2020-04-26 00:34:16.541	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
        host.ioBroker-RasPi	2020-04-26 00:34:16.540	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.ioBroker-RasPi	2020-04-26 00:34:16.540	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker-RasPi	2020-04-26 00:34:16.540	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
        host.ioBroker-RasPi	2020-04-26 00:34:16.539	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.ioBroker-RasPi	2020-04-26 00:34:16.539	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        host.ioBroker-RasPi	2020-04-26 00:34:16.539	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
        host.ioBroker-RasPi	2020-04-26 00:34:16.538	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.ioBroker-RasPi	2020-04-26 00:34:16.538	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
        host.ioBroker-RasPi	2020-04-26 00:34:16.538	error	Caught by controller[0]: ^
        host.ioBroker-RasPi	2020-04-26 00:34:16.537	error	Caught by controller[0]: throw e;
        host.ioBroker-RasPi	2020-04-26 00:34:16.536	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:121
        host.ioBroker-RasPi	2020-04-26 00:33:52.912	info	"system.adapter.zigbee.0" disabled
        host.ioBroker-RasPi	2020-04-26 00:33:45.862	info	Restart adapter system.adapter.zigbee.0 because enabled
        • Glasfaser
          @tom_33
          Stoppe die Instanz , Sichere die Daten , deinstalliere Zigbee und dann über die Katze neu .
          Aber die neue 1.1.1
          Thomas Braun T 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Glasfaser last edited by
            @Glasfaser
            Ist serialport im Modul zigbee enthalten oder was eigenes? Scheint mir da zu klemmen.
            npm rebuild serialport
            vielleicht?
            Glasfaser 2 Replies Last reply Reply Quote 0
              @Glasfaser
              instanz stoppen: ok
              daten sichern: hm, da muss ich mit WinSCP den/die ?-ordner auf meinen windosrechner ziehen?
              btw: zigbee 1.1.1 läuft schon jetzt
              • Glasfaser
                Glasfaser @Thomas Braun last edited by Glasfaser
                @Thomas-Braun
                Ich habe es vorgestern selber so gehabt , wo ich node hochgezogen habe . Da ging npm rebuild auch nicht .
                Habe es dann so wie oben durchgeführt .
                Edit :
                Sehe gerade beim Zigbee Adapter (Instanz ) da kann man keine Daten sichern
                • Glasfaser
                  @tom_33
                  Welche JS Version hast du !?
                  • Glasfaser
                    @Thomas-Braun
                    Ist trotzdem ein Rätsel !
                      @Glasfaser sagte in zigbee: nach update von nodejs startet adapter nicht mehr:
                      @tom_33
                      ich hoffe, das ist die korrekte antwort: Node.js v12.16.2
                      • Glasfaser
                        @tom_33
                        Nee ...
                        cd /opt/iobroker
                        iobroker version
                          iobroker version
                          pi@ioBroker-RasPi:/opt/iobroker $ iobroker version
                          2.2.9
                          Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @tom_33 last edited by Thomas Braun
                            @tom_33 2.2.9 ist natürlich auch schon etwas angegraut.
                            Zusammen mit nodejs 12 würde ich die auf 3.x.x. ziehen.
                            Willkommen in der 'dependency hell'! 🙂
                            • Glasfaser
                              @tom_33
                              Hast du jetzt Zigbee komplett deinstalliert , auch aus den Adaptern und dann neu installiert
                              @Thomas-Braun
                              Meist du das heißt ... ein Zusammenhang mit der NPM Meldung .
                              Ich habe auch noch 2.2.9 und die gleichen Fehler gehabt !
                                @Glasfaser
                                nein, den zigbee-adapter habe ich nur gestoppt. ich habe nach einer möglichkeit gesucht, meine konfiguration/daten zu sichern.
                                aber ich ziehs durch - schmeiß ihn raus
                                  Thomas Braun Most Active last edited by
                                  Ich bin raus... Reif für die Falle.
                                  Ich kann auch nicht mehr wirklich weiterhelfen, fahre hier 'latest' mit node14, aber ohne zigbee...
                                    tom_33 @Thomas Braun last edited by
                                    @Thomas-Braun nochmals vielen dank und gute nacht
                                      tom_33 @tom_33 last edited by
                                      und einen sehr guten morgen!
                                      nochmals mit dem reparierten system gestartet und den zigbee-stick aus der usb schnittstelle entfernt.
                                      wieder angesteckt und die zigbee geräte waren wieder ohne fehlermeldungen da. ich habe sie nur wieder benamsen müssen. z.b. 00dffec12874 = BAD_Hzg usw.
                                      vielen dank an thomas und glasfaser, welche sich die nacht mit mir um die ohren gehauen haben!!
                                        @tom_33
                                        Ah, das freut mich!
                                        node8 nodejs 12 zigbee adapter
                                        3221
