    4. [Neuer Adapter] Life360
      A Former User last edited by Negalein
      Wenn ich versuche den Adapter im ioBroker anzulegen scheitere ich. Hier die Debug Ausgabe:
      $ ./iobroker url "https://github.com/MiGoller/ioBroker.life360/tree/master" --debug
      install https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22
      NPM version: 6.14.3
      npm install https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22 --loglevel error --prefix "/opt/iobroker" (System call)
      npm
       ERR! code E404
      npm
       ERR! 404 Not Found - GET https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22npm ERR! 404 npm ERR! 404  'https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22' is not in the npm registry.
      npm ERR! 404 Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm
       ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-03-29T15_32_16_720Z-debug.log
      upload [18] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/words.js words.js application/javascript
      upload [17] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/tsconfig.json tsconfig.json application/json
      upload [16] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/style.css style.css text/css
      upload [15] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/life360.png life360.png image/png
      upload [14] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/ioBroker.life360.settings.myplaces.png  image/png
      upload [13] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/ioBroker.life360.settings.life360.png  image/png
      upload [12] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/ioBroker.life360.settings.integration.png  image/png
      upload [11] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/index_m.html index_m.html text/html
      upload [10] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [7] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/admin.d.ts admin.d.ts video/mp2t
      process exited with code 0
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
        A Former User @Guest last edited by
        @Ken-Popper Hi, installierst du den Adapter über die Weboberfläche heraus?
        Irgendwie ein komischer Aufruf der Installation...
        • Negalein
          hab mir gerade die App installiert.
          Gibt es einen Trick/Möglichkeit, den Zonenradius kleiner als 76m einzustellen?
            @ilovegym Ja über die Web-Oberfläche vom ioBroker. Unter Adapter und dann über "installieren aus eigener URL"
            • MiGoller
              MiGoller Developer @cb187 last edited by
              @cb187 Hey. Danke für das Feedback. Der Wert sollte eigentlich truebzw. false anzeigen, je nachdem ob die die betreffende Person sich im entsprechenden Kreis befindet. Ist das bei Dir nicht der Fall? Oder meinst Du die Bezeichnung "Present"? Beides kann ich überprüfen.
              • MiGoller
                MiGoller Developer @edonisXP last edited by
                @edonisXP Hey. Danke für das Feedback. Das Verhalten der Life360 App kenne ich aktuell sowohl von Android wie auch von iOS Geräten. Die Maßnahmen der Hersteller zum Energiesparen schlagen gerade bei den Positions- und Ortungsinformationen durch, die Life360 benötigt. Nach iOS Upgrades erhalte ich permanent Meldungen, ob Life360 wirklich immer im Hintergrund die Postionsdaten abfragen darf. Da dann auf "Immer" einstellen. Bei Android sieht das je nach Version und Hersteller anders aus. Huawei / Honor haben da ganz tolle Ideen, wie sich Strom sparen lässt. Da gibt es aber aktuell viele Anleitungen, wie das genau in welcher Kombination zu schaffen ist.
                Bitte einmal testen, ob sich das Verhalten sofort bessert, wenn das Gerät an das Netzteil angeschlossen wird.
                • MiGoller
                  MiGoller Developer @R1Snake last edited by
                  @R1Snake , @ThimThaler : Hey. Sorry, sollte ich besser dokumentieren. Danke. Genau das ist die Lösung.
                    mikiline last edited by
                    bekomme seit Update JS-Controller (3.0.18 oder auch schon eine version vorher) folgende Meldung
                    Ist das problem bereits bekannt oder ich habe etwas falsch?
                    Herzlichen Dank
                    MiGoller 1 Reply Last reply Reply Quote 0
                    • MiGoller
                      MiGoller Developer @mikiline last edited by
                      Hey @mikiline,
                      Vielen Dank für das Feedback. Bislang ist mir das noch nicht gemeldet worden. Ich werde mal schauen, was die Ursache sein könnte.
                      Eigentlich sollte der Zeitstempel der letzten Positionsbestimmung einer Person in einem ioBroker Datenpunkt gespeichert werden. Folgende Infos würden mir helfen?
                      • Hast Du eine Person bzw. einen Kontakt in einem Deiner Kreise, die das Teilen der Positionen in der Mobile-App deaktiviert hat?
                      • Wie sieht die Darstellung in der Web-Anwendung im Browser aus? Siehst Du die Position aller Mitglieder Deiner Kreise? Sieht das Ergebnis wie erwartet aus?
                      • Hast Du in der Konfiguration des Adapters auf den Reiter "Integration" die Standortverfolgung aktiviert?
                      Viele Grüße,
                      MiGoller
                        mikiline @MiGoller last edited by
                        @MiGoller
                        Hi 😉
                        also angehakt ist alles. Eine person hat das Teilen auf "Aus" und im Webbrowser sieht es OK aus, bis auf die Person die auf "Aus" ist, sind alle da.
                        Falls Du prüfen kannst wer die Standortmitteilung auf "Aus" hat und dies der Fehler sein sollte, kannst du das evtl mit auswerten?
                        Danke!
                        • MiGoller
                          Hey @mikiline ,
                          alles klar. Vielen Dank für das Prüfen der Einstellung. Es ist das, was ich vermutet hatte. Ich werde heute Abend mal den Code etwas anpassen, dass hier die Fehlerbehandlung deutlich besser sein wird.
                          In einem zweiten nachgelagerten Schritt werde ich dann schauen, wie ich das in die Darstellung einbaue, ob das Teilen der Position in einer Mobile-App deaktiviert ist. Nur ein Hinweis, ich habe auch schon Daten von Life360 gesehen, dass mehrere Mobile-Apps Standortdaten liefern. Das Gerät, das immer an einem Ort war, lieferte die Standortdaten, auf dem Hauptgerät des Benutzers war das Teilen der Position deaktiviert. Das konnte ich aus Sicht der Daten aber nicht unterscheiden.
                          Viele Grüße,
                          MiGoller
                          • MiGoller
                            MiGoller Developer last edited by MiGoller
                            ich habe eine neue Version des Adapters veröffentlicht und würde mich über Feedback freuen. Gem. der Anforderungen an das Testen von Adaptern ( https://forum.iobroker.net/topic/26085/richtlinien-für-die-kategorie-tester ) möchte ich den Thread mit Euch gemeinsam unter https://forum.iobroker.net/topic/32718/test-adapter-life360-v0-2-x-github-npm weiterführen.
                            @mikiline : Die Ursache für den Fehler habe ich gefunden: Es war das Nicht-Teilen der Position eines Benutzers. Das hatte ich nicht berücksichtigt. Es gibt jetzt auch einen neuen Datenpunkt isSharingLocation für die einzelnen Personen life360.0.people.xxx.isSharingLocation, der anzeigt, ob ein Benutzer seinen Standort teilt.
                            Viele Grüße,
                            MiGoller
                              @MiGoller
                              super, Danke 😉 Tolle Arbeit!
                                Sascha12 last edited by Sascha12
                                @MiGoller Danke, super Adapter.
                                So wie ich das sehe funktioniert alles...
                                Hat nun jemand eine Ansicht für VIS gebaut?
                                Da ich in VIS garnichts kann, da ich Habpanel benutze, wäre ich für alles dankbar... 😉
                                LG Sascha
                                PS: Noch eine Frage: Es wäre für mich in Habpanel von Vorteil, unter "People" und dann der Person auch den aktuellen Ort der Person abgelegt zu bekommen als Datenpunkt. Geht das, oder übersehe ich vielleicht sogar etwas?
                                • MiGoller
                                  MiGoller Developer @Sascha12 last edited by
                                  @Sascha12 Vielen Dank für das Feedback. Es freut mich, dass Du auch einen Nutzen aus dem Adapter ziehen kannst.
                                  Zu Deiner Frage: Das würde generell gehen. Bislang bilde ich das im Adapter so ab, dass Du ausgehend von einem "Place" sehen kannst, wer dort gerade anwesend ist. Diese Information findest Du Stand heute nicht unter den Personen; eine Visualisierung hatte ich mit den "Places" unter Personen auch noch nicht im Blick, aber warum nicht. Bislang findest Du unter einer Person die GPS-Koordinaten z.B. für die Anzeige auf einer Karte, für Berechnungen, etc. . Wenn der Bedarf da ist, nehme ich das aber gerne mit für die kommenden Anpassungen und Erweiterung mit auf. Gerne darfst Du auch direkt ein Issue unter https://github.com/MiGoller/ioBroker.life360/issues eröffnen, dann habe ich da alles auf der Liste.
                                  Aktuell bleibt Dir dann aber z.B. die Möglichkeit, mit einem Skript die Information aus dem "Places"-Bereich und dem "People"-Bereich für die Visualisierung zusammenzutragen, so dass Du an einer Stelle alle Informationen für HabPanel hast.
                                  Hilft Dir das weiter?
                                  VG, MiGoller
                                    Sascha12 @MiGoller last edited by
                                    @MiGoller Danke Dir. Genau das Script habe ich mir in der Zwischenzeit bereits angelegt 😉
                                    LG Sascha
                                    • O
                                      oetti @MiGoller last edited by
                                      @MiGoller
                                      Danke für den Life360 Adapter - läuft super 👍
                                      OT
                                      Hast du zum Thema Bluetooth Beacons / ESPs irgendetwas lesbares hinterlegt? Das Thema finde ich ebenfalls sehr interessant, zumal Inhouse-Präsenz noch ganz andere Herausforderungen hat.
                                      Ich hatte bis dato nur Versuche mit WLAN (Mikrotik + Capsman) gemacht, um rauszufinden, welches Device an welchem AP angemeldet ist. Funktioniert, allerdings nur, wenn man das Handy in der
                                      Tasche hat 😁
                                      • MiGoller
                                        MiGoller Developer @oetti last edited by
                                        @oetti Vielen Dank für das Feedback.
                                        Bzgl. des Beacons und der ESPs schaue ich mal nach, wo ich den Code habe. Den kann ich dann gern auf Github oder Gitlab teilen; aber ich muss Dich warnen, das war wirklich schnell und schmutzig. 😉
                                        Ich bin mir in der Zwischenzeit nicht mehr so sicher, ob diese Art der Inhouse-Präsenz für mich zielführend ist. Ich habe es als Komfortmerkmal erlebt, das toll ist, wenn es funktioniert. Werden die Beacons nicht schnell genug wieder erkannt, griff bei mir immer der "Automatismus": Works as designed, nur dass der WAF gegen minus Unendlich ging.
                                          Jaschkopf @MiGoller last edited by
                                          @MiGoller Moin. Hab deinen Adapter gerade installiert und mir ein Konto auf der Android App eingerichtet. Leider kann der Adapter keine Verbindung herstellen mit der Fehlermeldung das die Credentials falsch sind. DIe stimmen aber zu 100%. weder mit der Email, noch mit der Handynummer bekomme ich eine Verbindung (natürlich nicht beides gleichzeitig sondern nacheinander getestet). Hat Life360 vielleicht die API geändert? Hier das Log:
                                          2020-09-15 16:32:12.245 - info: host.iobroker instance system.adapter.life360.1 started with pid 14607
                                          2020-09-15 16:32:13.372 - info: life360.1 (14607) starting. Version 0.2.11 in /opt/iobroker/node_modules/iobroker.life360, node: v12.18.3, js-controller: 3.1.6
                                          2020-09-15 16:32:13.389 - info: life360.1 (14607) Polling enabled every 60 seconds.
                                          2020-09-15 16:32:14.263 - error: life360.1 (14607) Connection established but failed to authenticate. Check your credentials!
                                          2020-09-15 16:32:14.266 - info: life360.1 (14607) Waiting for online operations to finish ...
                                          2020-09-15 16:32:14.268 - error: life360.1 (14607) Error: Error: Connection established but failed to authenticate. Check your credentials!
                                          2020-09-15 16:32:14.269 - warn: life360.1 (14607) No data received from Life360 cloud services!
                                          Das System läuft auf einer Debian 10.5.0 VM in Proxmox mit Node v12.18.3 und NPM 6.14.6.
                                          Gruß Jaschkopf
                                          ? J 2 Replies Last reply Reply Quote 0
                                            A Former User @Jaschkopf last edited by
                                            @Jaschkopf vielleicht n Leerzeichen in den credentials ausversehen drin oder hinten dran - da bin ich auch schon wahnsinnig geworden.. copy-paste war böse..?
                                            Der Adapter läuft bei mir einwandfrei.. die haben nix geändert.
                                            adapter geoposition life360 präsenzmelder
                                            85
                                            708
                                            175722
