    4. Hue Adapter 3.0.X - Test
      SSW-mcor last edited by
      Ok, habs.
      Wie hättest du es gern, habs jetzt in ein Textdokument gespeichert.
      • foxriver76
        foxriver76 Developer @SSW-mcor last edited by
        @SSW-mcor passt oder hier in Code Tags. Und bitte noch den Namen von deiner Steckdose die Leistung messen kann, damit ich danach suchen kann. 😉
        • Dr. Bakterius
          Dr. Bakterius Most Active @foxriver76 last edited by
          @foxriver76 Okay, ein Upload kann nie schaden. Gesagt - getan. Letzte Nacht kam dann folgender Error:
          Could not poll all: read ECONNRESET
          • foxriver76
            foxriver76 Developer @Dr. Bakterius last edited by
            @Dr-Bakterius das passt. So sollte die Fehlermeldung aussehen. Wenn das 1 mal am Tag ca. vorkommt würde ich mir da keine weiteren Gedanken machen. Habe ich bei vielen Adaptern.
              SSW-mcor @foxriver76 last edited by SSW-mcor
              @foxriver76 :
              getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":true,"bri":77,"hue":792,"sat":202,"effect":"none","xy":[0.615,0.332],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-01-08T08:58:46"},"type":"Extended color light","name":"Schacht","modelid":"LST002","manufacturername":"Philips","productname":"Hue lightstrip plus","capabilities":{"certified":true,"control":{"mindimlevel":25,"maxlumen":1600,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huelightstrip","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"2":{"state":{"on":false,"bri":254,"hue":10778,"sat":251,"effect":"none","xy":[0.5609,0.4042],"ct":500,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T09:17:33"},"type":"Extended color light","name":"Sven","modelid":"LCT007","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":800,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"floorshade","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"3":{"state":{"on":false,"bri":254,"hue":8597,"sat":121,"effect":"none","xy":[0.4452,0.4068],"ct":343,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-01-08T07:28:03"},"type":"Extended color light","name":"Heizung links","modelid":"LST002","manufacturername":"Philips","productname":"Hue lightstrip plus","capabilities":{"certified":true,"control":{"mindimlevel":25,"maxlumen":1600,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huelightstrip","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"4":{"state":{"on":false,"bri":254,"hue":15342,"sat":121,"effect":"none","xy":[0.4448,0.4066],"ct":343,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T09:17:24"},"type":"Extended color light","name":"Heizung Spot links","modelid":"LCT003","manufacturername":"Philips","productname":"Hue color spot","capabilities":{"certified":true,"control":{"mindimlevel":5000,"maxlumen":250,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"spotbulb","function":"mixed","direction":"downwards","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"5":{"state":{"on":false,"bri":254,"hue":8597,"sat":121,"effect":"none","xy":[0.4452,0.4068],"ct":343,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T09:17:19"},"type":"Extended color light","name":"Treppe oben","modelid":"LST002","manufacturername":"Philips","productname":"Hue lightstrip plus","capabilities":{"certified":true,"control":{"mindimlevel":25,"maxlumen":1600,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huelightstrip","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"6":{"state":{"on":false,"bri":254,"hue":8597,"sat":121,"effect":"none","xy":[0.4452,0.4068],"ct":343,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-01-05T10:20:33"},"type":"Extended color light","name":"Heizung rechts","modelid":"LST002","manufacturername":"Philips","productname":"Hue lightstrip plus","capabilities":{"certified":true,"control":{"mindimlevel":25,"maxlumen":1600,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huelightstrip","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"7":{"state":{"on":true,"bri":77,"hue":3779,"sat":252,"effect":"none","xy":[0.6127,0.3662],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T09:17:12"},"type":"Extended color light","name":"Schräge","modelid":"LST002","manufacturername":"Philips","productname":"Hue lightstrip plus","capabilities":{"certified":true,"control":{"mindimlevel":25,"maxlumen":1600,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huelightstrip","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"8":{"state":{"on":false,"bri":254,"hue":15342,"sat":121,"effect":"none","xy":[0.4448,0.4066],"ct":343,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-01-08T08:50:13"},"type":"Extended color light","name":"Heizung Spot rechts","modelid":"LCT003","manufacturername":"Philips","productname":"Hue color spot","capabilities":{"certified":true,"control":{"mindimlevel":5000,"maxlumen":250,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"spotbulb","function":"mixed","direction":"downwards","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"9":{"state":{"on":false,"bri":254,"hue":10778,"sat":251,"effect":"none","xy":[0.5609,0.4042],"ct":500,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T09:17:05"},"type":"Extended color light","name":"Sandra","modelid":"LCT007","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":800,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"floorshade","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"10":{"state":{"on":true,"bri":130,"hue":7605,"sat":252,"effect":"none","xy":[0.5943,0.3802],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T18:39:04"},"type":"Extended color light","name":"Gartenkugel rechts","modelid":"LCT001","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":5000,"maxlumen":600,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":false}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26581"},"11":{"state":{"on":true,"bri":130,"hue":62591,"sat":253,"effect":"none","xy":[0.593,0.2773],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T18:38:58"},"type":"Extended color light","name":"Gartenkugel links","modelid":"LCT001","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":5000,"maxlumen":600,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":false}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26581"},"12":{"state":{"on":true,"bri":77,"hue":3779,"sat":254,"effect":"none","xy":[0.6145,0.3661],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-06T09:49:12"},"type":"Extended color light","name":"Küchenecke rechts","modelid":"LCT010","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":1000,"maxlumen":806,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.46.13_r26312","swconfigid":"0CE67A8F","productid":"Philips-LCT010-1-A19ECLv4"},"13":{"state":{"on":true,"bri":77,"hue":628,"sat":252,"effect":"none","xy":[0.6764,0.3184],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2018-12-06T09:49:21"},"type":"Extended color light","name":"Küchenecke links","modelid":"LCT010","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":1000,"maxlumen":806,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.46.13_r26312","swconfigid":"0CE67A8F","productid":"Philips-LCT010-1-A19ECLv4"},"14":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":false},"swupdate":{"state":"notupdatable","lastinstall":null},"type":"On/Off plug-in unit","name":"Eingangsfenster-Osram","modelid":"Plug 01","manufacturername":"OSRAM","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"V1.04.12"},"16":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":true},"swupdate":{"state":"notupdatable","lastinstall":null},"type":"On/Off plug-in unit","name":"HomeMaticIP","modelid":"Plug 01","manufacturername":"OSRAM","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"ceilingsquare","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"V1.04.12"},"17":{"state":{"on":true,"bri":253,"hue":8019,"sat":252,"effect":"none","xy":[0.6099,0.321],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":false},"swupdate":{"state":"noupdates","lastinstall":"2018-12-13T18:38:38"},"type":"Extended color light","name":"Garten-3","modelid":"LCT001","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":5000,"maxlumen":600,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":false}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26581"},"18":{"state":{"on":true,"bri":125,"hue":5411,"sat":254,"effect":"none","xy":[0.5848,0.3958],"ct":447,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":false},"swupdate":{"state":"noupdates","lastinstall":"2018-12-06T09:49:16"},"type":"Extended color light","name":"Küstennebel","modelid":"LCT010","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":1000,"maxlumen":806,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"floorlantern","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.46.13_r26312","swconfigid":"0CE67A8F","productid":"Philips-LCT010-1-A19ECLv4"},"19":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":false},"swupdate":{"state":"notupdatable","lastinstall":null},"type":"On/Off plug-in unit","name":"Treppe","modelid":"Plug 01","manufacturername":"OSRAM","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"V1.05.09"},"20":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":true},"swupdate":{"state":"notupdatable","lastinstall":null},"type":"On/Off plug-in unit","name":"Bogen Küche","modelid":"SP 120","manufacturername":"innr","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"},"21":{"state":{"on":true,"bri":127,"hue":3043,"sat":254,"effect":"none","xy":[0.6123,0.3772],"ct":555,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"notupdatable","lastinstall":null},"type":"Extended color light","name":"PC","modelid":"RB 285 C","manufacturername":"innr","productname":"Extended color light","capabilities":{"certified":false,"control":{"colorgamuttype":"other","colorgamut":[[0.7,0.3],[0.11,0.82],[0.12,0.08]],"ct":{"min":153,"max":555}},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"bollard","function":"mixed","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"},"22":{"state":{"on":false,"bri":64,"hue":9619,"sat":220,"effect":"none","xy":[0.6331,0.35],"ct":447,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":false},"swupdate":{"state":"notupdatable","lastinstall":null},"type":"Extended color light","name":"Esszimmer_Türe","modelid":"RB 285 C","manufacturername":"innr","productname":"Extended color light","capabilities":{"certified":false,"control":{"colorgamuttype":"other","colorgamut":[[0.7,0.3],[0.11,0.82],[0.12,0.08]],"ct":{"min":153,"max":555}},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"classicbulb","function":"mixed","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"},"23":{"state":{"on":true,"bri":254,"hue":5701,"sat":253,"effect":"none","xy":[0.6063,0.3714],"ct":346,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":false},"swupdate":{"state":"noupdates","lastinstall":"2019-08-18T08:34:23"},"type":"Extended color light","name":"Fenster Esszimmer","modelid":"LCT007","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":800,"colorgamuttype":"B","colorgamut":[[0.675,0.322],[0.409,0.518],[0.167,0.04]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"floorshade","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"5.127.1.26420"},"26":{"state":{"on":false,"bri":127,"hue":2755,"sat":254,"effect":"none","xy":[0.6354,0.3504],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-09-20T08:52:52"},"type":"Extended color light","name":"BadEcke","modelid":"LCT015","manufacturername":"Philips","productname":"Hue color lamp","capabilities":{"certified":true,"control":{"mindimlevel":1000,"maxlumen":806,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.46.13_r26312","swconfigid":"52E3234B","productid":"Philips-LCT015-1-A19ECLv5"},"27":{"state":{"on":false,"alert":"select","mode":"homeautomation","reachable":false},"swupdate":{"state":"noupdates","lastinstall":"2019-09-20T11:56:30"},"type":"On/Off plug-in unit","name":"Hue Plug Lounge","modelid":"LOM001","manufacturername":"Philips","productname":"Hue Smart plug","capabilities":{"certified":true,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.55.10_r29112","swconfigid":"A641B5AB","productid":"SmartPlug_OnOff_v01-00_01"},"28":{"state":{"on":true,"bri":36,"hue":6014,"sat":249,"effect":"none","xy":[0.5653,0.3998],"ct":500,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-11-07T09:23:47"},"type":"Extended color light","name":"Hausnummer","modelid":"1743830P7","manufacturername":"Philips","productname":"Hue outdoor wall","capabilities":{"certified":true,"control":{"mindimlevel":100,"maxlumen":1134,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"walllantern","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.46.13_r26312","swconfigid":"C379D180","productid":"3241-3127-7871_HC01_PSU01"},"29":{"state":{"on":false,"bri":254,"alert":"select","mode":"homeautomation","reachable":false},"swupdate":{"state":"noupdates","lastinstall":"2019-11-22T16:03:50"},"type":"Dimmable light","name":"Filament bulb Esstisch rechts","modelid":"LWO001","manufacturername":"Philips","productname":"Hue filament bulb","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":550},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"vintagebulb","function":"decorative","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.55.8_r28815","swconfigid":"E552ED14","productid":"Philips-LWO001-1-G93CFDLv1"},"30":{"state":{"on":false,"bri":254,"alert":"select","mode":"homeautomation","reachable":false},"swupdate":{"state":"noupdates","lastinstall":"2019-11-22T16:03:51"},"type":"Dimmable light","name":"Filament bulb Esstisch links","modelid":"LWO001","manufacturername":"Philips","productname":"Hue filament bulb","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":550},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"vintagebulb","function":"decorative","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.55.8_r28815","swconfigid":"E552ED14","productid":"Philips-LWO001-1-G93CFDLv1"},"31":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":true},"swupdate":{"state":"notupdatable","lastinstall":"2019-11-23T17:14:05"},"type":"On/Off plug-in unit","name":"Bogen Esszimmer","modelid":"SP 120","manufacturername":"innr","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"},"32":{"state":{"on":true,"bri":38,"hue":6263,"sat":251,"effect":"none","xy":[0.5617,0.4038],"ct":500,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-11-26T22:35:10"},"type":"Extended color light","name":"Stern Eingang","modelid":"LCT012","manufacturername":"Philips","productname":"Hue color candle","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":450,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"candlebulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"","swversion":"1.46.13_r26312","swconfigid":"8C67986F","productid":"Philips-LCT012-1-E14ECLv1"},"33":{"state":{"on":false,"alert":"select","mode":"homeautomation","reachable":false},"swupdate":{"state":"notupdatable","lastinstall":"2019-11-26T18:47:48"},"type":"On/Off plug-in unit","name":"On/Off plug 1","modelid":"SP 120","manufacturername":"innr","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"},"34":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":true},"swupdate":{"state":"notupdatable","lastinstall":"2019-12-29T11:23:44"},"type":"On/Off plug-in unit","name":"Glocke und Sterne","modelid":"SP 120","manufacturername":"innr","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"},"35":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":false},"swupdate":{"state":"notupdatable","lastinstall":"2019-12-29T12:08:45"},"type":"On/Off plug-in unit","name":"Waschmaschine","modelid":"SP 120","manufacturername":"innr","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"},"36":{"state":{"on":true,"alert":"select","mode":"homeautomation","reachable":true},"swupdate":{"state":"notupdatable","lastinstall":"2019-12-29T12:10:16"},"type":"On/Off plug-in unit","name":"Trockner","modelid":"SP 120","manufacturername":"innr","productname":"On/Off plug","capabilities":{"certified":false,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"","swversion":"2.0"}},"groups":{"1":{"name":"Schlafzimmer","lights":["9","2"],"sensors":[],"type":"Room","state":{"all_on":false,"any_on":false},"recycle":false,"class":"Bedroom","action":{"on":false,"bri":254,"hue":10778,"sat":251,"effect":"none","xy":[0.5609,0.4042],"ct":500,"alert":"none","colormode":"xy"}},"2":{"name":"discoAGroup","lights":["21","13","12","10","11","1","7"],"sensors":[],"type":"LightGroup","state":{"all_on":true,"any_on":true},"recycle":false,"action":{"on":true,"bri":77,"hue":3779,"sat":252,"effect":"none","xy":[0.6127,0.3662],"ct":153,"alert":"select","colormode":"xy"}},"3":{"name":"Esszimmer","lights":["23","21"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Dining","action":{"on":true,"bri":127,"hue":3043,"sat":254,"effect":"none","xy":[0.6123,0.3772],"ct":555,"alert":"select","colormode":"xy"}},"4":{"name":"Küche","lights":["18","13","12"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Kitchen","action":{"on":true,"bri":77,"hue":3779,"sat":254,"effect":"none","xy":[0.6145,0.3661],"ct":153,"alert":"select","colormode":"xy"}},"5":{"name":"Gartenkugeln","lights":["17","10","11"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Garden","action":{"on":true,"bri":130,"hue":62591,"sat":253,"effect":"none","xy":[0.593,0.2773],"ct":153,"alert":"select","colormode":"xy"}},"6":{"name":"Eingang","lights":["14","19","1","7"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Hallway","action":{"on":true,"bri":77,"hue":3779,"sat":252,"effect":"none","xy":[0.6127,0.3662],"ct":153,"alert":"select","colormode":"xy"}},"7":{"name":"discoAGroupOdd","lights":["13","10","1"],"sensors":[],"type":"LightGroup","state":{"all_on":true,"any_on":true},"recycle":false,"action":{"on":true,"bri":77,"hue":792,"sat":202,"effect":"none","xy":[0.615,0.332],"ct":153,"alert":"select","colormode":"xy"}},"8":{"name":"discoAGroupEven","lights":["21","12","11","7"],"sensors":[],"type":"LightGroup","state":{"all_on":true,"any_on":true},"recycle":false,"action":{"on":true,"bri":77,"hue":3779,"sat":252,"effect":"none","xy":[0.6127,0.3662],"ct":153,"alert":"select","colormode":"xy"}},"9":{"name":"Group for wakeup","lights":["9","2"],"sensors":[],"type":"LightGroup","state":{"all_on":false,"any_on":false},"recycle":true,"action":{"on":false,"bri":254,"hue":10778,"sat":251,"effect":"none","xy":[0.5609,0.4042],"ct":500,"alert":"none","colormode":"xy"}},"10":{"name":"Bad","lights":["26"],"sensors":[],"type":"Room","state":{"all_on":false,"any_on":false},"recycle":false,"class":"Bathroom","action":{"on":false,"bri":127,"hue":2755,"sat":254,"effect":"none","xy":[0.6354,0.3504],"ct":153,"alert":"select","colormode":"xy"}},"11":{"name":"Heizung","lights":["5","8","6","4","3"],"sensors":[],"type":"Room","state":{"all_on":false,"any_on":false},"recycle":false,"class":"Other","action":{"on":false,"bri":254,"hue":8597,"sat":121,"effect":"none","xy":[0.4452,0.4068],"ct":343,"alert":"select","colormode":"xy"}},"12":{"name":"hgrp-0008355838","lights":["6","7","22","18","3","4","13","14","16","9","20","2","12","11","1","21","17","5","19","10","8"],"sensors":[],"type":"LightGroup","state":{"all_on":false,"any_on":true},"recycle":false,"action":{"on":false,"bri":254,"hue":15342,"sat":121,"effect":"none","xy":[0.4448,0.4066],"ct":343,"alert":"select","colormode":"xy"}},"13":{"name":"Sterne","lights":["34","31","20","32"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Home","action":{"on":true,"bri":38,"hue":6263,"sat":251,"effect":"none","xy":[0.5617,0.4038],"ct":500,"alert":"select","colormode":"xy"}},"14":{"name":"Homematic_immer_an","lights":["16"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Home","action":{"on":true,"alert":"select"}},"15":{"name":"Lounge","lights":["27"],"sensors":[],"type":"Room","state":{"all_on":false,"any_on":false},"recycle":false,"class":"Lounge","action":{"on":false,"alert":"select"}},"16":{"name":"Entertainment-Bereich 1","lights":["23","12","13","18"],"sensors":[],"type":"Entertainment","state":{"all_on":true,"any_on":true},"recycle":false,"class":"TV","stream":{"proxymode":"auto","proxynode":"/lights/12","active":false,"owner":null},"locations":{"12":[-0.91,0.71,0],"13":[-0.76,0.22,0],"18":[-0.39,0.63,0],"23":[0.88,0.98,0]},"action":{"on":true,"bri":125,"hue":5411,"sat":254,"effect":"none","xy":[0.5848,0.3958],"ct":447,"alert":"none","colormode":"xy"}},"17":{"name":"Haustür","lights":["28"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Front door","action":{"on":true,"bri":36,"hue":6014,"sat":249,"effect":"none","xy":[0.5653,0.3998],"ct":500,"alert":"select","colormode":"xy"}},"18":{"name":"Esstisch","lights":["29","30"],"sensors":[],"type":"Room","state":{"all_on":false,"any_on":false},"recycle":false,"class":"Dining","action":{"on":false,"bri":254,"alert":"select"}},"19":{"name":"Wohnzimmer","lights":[],"sensors":[],"type":"Room","state":{"all_on":false,"any_on":false},"recycle":false,"class":"Living room","action":{"on":false,"alert":"none"}},"20":{"name":"Waschen|Trocknen","lights":["35","36"],"sensors":[],"type":"Room","state":{"all_on":true,"any_on":true},"recycle":false,"class":"Laundry room","action":{"on":true,"alert":"select"}}},"config":{"name":"Philips hue","zigbeechannel":15,"bridgeid":"001788FFFE4B9E70","mac":"00:17:88:4b:9e:70","dhcp":true,"ipaddress":"192.168.178.27","netmask":"255.255.255.0","gateway":"192.168.178.1","proxyaddress":"none","proxyport":0,"UTC":"2020-01-30T18:35:46","localtime":"2020-01-30T19:35:46","timezone":"Europe/Berlin","modelid":"BSB002","datastoreversion":"88","swversion":"1935144040","apiversion":"1.35.0","swupdate":{"updatestate":0,"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"url":"","text":"","notify":true},"swupdate2":{"checkforupdate":false,"lastchange":"2020-01-26T02:57:55","bridge":{"state":"noupdates","lastinstall":"2020-01-14T19:15:23"},"state":"noupdates","autoinstall":{"updatetime":"T10:00:00","on":true}},"linkbutton":false,"portalservices":true,"portalconnection":"connected","portalstate":{"signedon":true,"incoming":false,"outgoing":true,"communication":"disconnected"}
              War noch länger aber hab den Rest mal weg. Suchen tust du am besten nach innr, das sind die Steckdosen, die das im Zigbee-Adapter können.
              Hat bissel gedauert, musste bei mir alles neu machen, nach dem ich den neuen Admin-Adapter installiert hatte 😞
              Danke...
              • foxriver76
                Scheint so als würde die Hue Bridge die Info leider nicht zur Verfügung stellen. Die Hue Bewegungssensoren haben z. B. extra einen State der die Temperatur enthält. Die oben enthaltenen Infos sind leider alles an das ich heran komme.
                • dslraser
                  @foxriver76
                  Ich habe heute angefangen alias'e einzurichten, dabei ist mir was komisches aufgefallen. (hat aber nichts mit alias zu tun)
                  Ich habe in der App Räume erstellt und meistens mehrere Lampen zugeordnet.
                  Beispel:
                  In jedem Raum ist immer eine Lampe dabei, die den kompletten Raum als true (eingeschaltet) zeigt, also nicht nur anyon, sondern on als true.
                  Am Beispiel Wohnzimmer (bei mir 7 Lampen) kann ich 6 einzelne Lampen einschalten, aber der Raum wird richtiger Weise mit false angezeigt, nur anyon mit true. Wenn ich eine bestimmte Lampe einschalte, dann wird auch der Raum als true gezeigt, auch wenn alle anderen aus sind.
                  Das ist in jedem Raum so.
                  Hier nochmal in der iQontrol Ansicht
                  Deckenlampe gehört zum Wohnzimmer
                  (Das gesamte Wohnzimmer wird als eingeschaltet gezeigt=Bug ?)
                  Die Fernehlampen sind an und gehören zum Wohnzimmer
                  (hier ist es richtig, der komplette Raum wird nicht als eingeschaltet gezeigt)
                  Wie gesagt, das Verhalten ist in jedem Raum mit mehreren Lampen so. Eine "bestimmte" Lampe in jedem Raum lässt den kompletten Raum als angeschaltet anzeigen.
                  • foxriver76
                    foxriver76 Developer @dslraser last edited by foxriver76
                    @dslraser Moin,
                    der State wird so 1 zu 1 aus der API ausgelesen und ich habe da in Erinnerung, dass das nicht immer heißt, dass auch alle Lichter der Gruppe an sind. Es gibt soweit ich mich erinnern kann im von der API gelieferten JSON noch einen separaten key all_on. Letztendlich ist allerdings der on state der den die API als steuerbar deklariert. Man könnte evtl noch den all_on Status mit in ioBroker darstellen.
                    P.S. in der Hue App wird ja die Gruppe meines Wissens nach auch als an angezeigt, wenn nicht alle Lichter darin an sind.
                    • Newpicsel
                      Newpicsel last edited by
                      Moin, hat schon jemand eine Lösung für das Helligkeitsproblem bei command Befehlen?
                      Gerade bei der Alarm Funktion wäre das schon hilfreich...
                      Danke und schöne Grüße
                      • dslraser
                        dslraser Forum Testing Most Active @Newpicsel last edited by
                        @Newpicsel sagte in Hue Adapter 3.0.X - Test:
                        Welches Problem meinst Du damit ?
                        Newpicsel 1 Reply Last reply Reply Quote 0
                        • Newpicsel
                          Newpicsel @dslraser last edited by Newpicsel
                          @dslraser
                          Egal welchen Level wert man angiebt, werden immer 100% geschaltet, wenn ich eine Lampe per command schalte, stört mich persönlich nur wenn ich ein direkten Alarm steuere um die Lampen so zum Blinken bringen möchte, tritt bei mir aber immer auf wenn ich eine Lampe über command steuere.
                          Hatte weiter oben gelesen, dass jemand auch das Problem hat, aber eine Lösung konnte ich bisher nicht wirklich finden.
                          • BBTown
                            BBTown @Newpicsel last edited by
                            @Newpicsel
                            Du solltest einfach mal deine commands zeigen
                            • Newpicsel
                              Ok, hier zb. {„level“:50,“hue“:0,“sat“:254,“alert“:“iselect“,“transitiontime“:0}
                              • BBTown
                                @Newpicsel wie verhält sich denn die HUE wenn Du per command nur "level":50 absetzt?
                                • Newpicsel
                                  Newpicsel @BBTown last edited by
                                  @BBTown nur Level 50 geht, sobald ich in irgendeiner Form eine Farbe mit angebe, klappt es nicht, habe es auch mit rgb probiert, gleiches Problem.
                                  Irgendwo habe ich mal gelesen, dass es mit dem xy wert funktionieren soll, ich kann mit diesen Werten allerdings nichts anfangen und das kann ja eigentlich auch nicht Sinn der Sache sein denke ich...
                                  dslraser BBTown 2 Replies Last reply Reply Quote 0
                                  • dslraser
                                    dslraser Forum Testing Most Active @Newpicsel last edited by dslraser
                                    @Newpicsel
                                    ich schalte damit Alarm (Das ist rot, kannst aber auch g = grün, oder b = blau nehmen). Die Helligkeit sieht mir aber immer gleich aus...
                                    {"level":100, "r":100,"alert":"lselect", "transitiontime":0}
                                    • BBTown
                                      BBTown @Newpicsel last edited by BBTown
                                      @Newpicsel
                                      du musst schon die richtige Einstellung wählen ... @dslraser hat in seinem Beispiel eben nicht HUE sondern RGB ... und nun kommt es drauf an was bei dir eingestellt ist.
                                      Genau deshalb wollte ich wissen was geschieht wenn Du nur Level beinflußt
                                      • Newpicsel
                                        Newpicsel @BBTown last edited by Newpicsel
                                        @BBTown
                                        Was wäre denn die richtige Einstellung? Wie gesagt auch mit rgb hab ich es ausprobiert.
                                        Auch @dslraser schrieb ja, die Helligkeit sieht immer gleich aus, genau das ist ja mein Problem.
                                        Mir scheint es als würde sobald eine Farbe im Spiel ist, Level nicht berücksichtigt, hier würde es eventuell helfen die xy Werte für den command zu nehmen, dieser gibt ja Level und Color an, aber dieser Wert wird bei mir auch nicht aktualisiert wenn ich die Lampe manuel auf ein Level und Color einstelle, sonst könnte ich diesen Wert benutzen.
                                        Aber wie gesagt, so alleine sagt mir ein xy wert erstmal nichts.
                                        BBTown dslraser 2 Replies Last reply Reply Quote 0
                                        • BBTown
                                          Ich kann dir das nicht beantworten, ich benutze keine HUE-Alarme.
                                          Deine Aussage war "Level" reagiert nicht über Command, und ich wollte dir einen Ansatz geben erst einmal zu Testen ob es wirklich an "Level" liegt, und das tut es nicht!
                                          Es liegt an einer anderen Kombination des Commands.
                                          Da mußt Du dich wohl oder übel comand für command herantasten müssen.
                                          • dslraser
                                            @Newpicsel
                                            ich bin mir nicht sicher, aber iselect lässt ja die Lampe ca. 15 mal selbst blinken, vielleicht ist das blinken dann immer mit 100 % Helligkeit ?
                                            In allen anderen Befehlen kann ich die Lampen in jeder Farbe und Helligkeit über command schalten.
                                            31.7k
                                            79.8k
                                            hue lightning phillips test
                                            24
                                            123
                                            11166
