    4. [gelöst] Ping-Adapter pingt nicht mehr
    SOLVED [gelöst] Ping-Adapter pingt nicht mehr
    • Meister Mopper
      Meister Mopper @Thomas Braun last edited by
      @Thomas-Braun macht er nicht:
      $ adduser thomas sudo
      -sh: 4: adduser: not found
      • Meister Mopper
        Meister Mopper @Meister Mopper last edited by
        @Meister-Mopper Sorry, mein Fehler
        root@iobroker:~# adduser thomas sudo
        Adding user `thomas' to group `sudo' ...
        Adding user thomas to group sudo
        Done.
          Thomas Braun Most Active @Meister Mopper last edited by Thomas Braun
          @Meister-Mopper
          Ich bin nicht ganz sicher ob das funktioniert, aber versuch mal dem User die default Gruppen noch mitzugeben:
          sudo useradd -D thomas
          • Meister Mopper
            @Thomas-Braun Da kommen nur die ganzen Schaltererläuterungen:
            $ sudo useradd -D thomas
            Usage: useradd [options] LOGIN
                  useradd -D
                  useradd -D [options]
            Options:
             -b, --base-dir BASE_DIR       base directory for the home directory of the
                                           new account
             -c, --comment COMMENT         GECOS field of the new account
             -d, --home-dir HOME_DIR       home directory of the new account
             -D, --defaults                print or change default useradd configuration
             -e, --expiredate EXPIRE_DATE  expiration date of the new account
             -f, --inactive INACTIVE       password inactivity period of the new account
             -g, --gid GROUP               name or ID of the primary group of the new
                                           account
             -G, --groups GROUPS           list of supplementary groups of the new
                                           account
             -h, --help                    display this help message and exit
             -k, --skel SKEL_DIR           use this alternative skeleton directory
             -K, --key KEY=VALUE           override /etc/login.defs defaults
             -l, --no-log-init             do not add the user to the lastlog and
                                           faillog databases
             -m, --create-home             create the user's home directory
             -M, --no-create-home          do not create the user's home directory
             -N, --no-user-group           do not create a group with the same name as
                                           the user
             -o, --non-unique              allow to create users with duplicate
                                           (non-unique) UID
             -p, --password PASSWORD       encrypted password of the new account
             -r, --system                  create a system account
             -R, --root CHROOT_DIR         directory to chroot into
             -s, --shell SHELL             login shell of the new account
             -u, --uid UID                 user ID of the new account
             -U, --user-group              create a group with the same name as the user
             -Z, --selinux-user SEUSER     use a specific SEUSER for the SELinux user mapping
              @Meister-Mopper
              sudo adduser thomas
              • Meister Mopper
                @Thomas-Braun sagte in Ping-Adapter pingt nicht mehr:
                sudo adduser thomas
                $ sudo adduser thomas
                adduser: The user `thomas' already exists.
                Das hat er aber weiter oben schon ausgeworfen. Mit sudo kann ich jetzt pingen, aber offenbar der iobroker nicht.
                  @Meister-Mopper
                  Die 'iobroker' ist vermutlich genauso gruppenlos wie 'thomas'.
                  sudo -u iobroker groups
                  • Meister Mopper
                    $ sudo -u iobroker groups
                    iobroker tty dialout audio video
                      @Meister-Mopper
                      Hmmm. Eigentlich sollte 'dialout' richtig sein.
                      Keine Ahnung dann...
                      • Meister Mopper
                        @Thomas-Braun habe das bei vmware gefunden und es hat funktioniert:
                        Als root ausführen:
                        chmod 4755 /bin/ping
                        [gpadmin@hdm4] ping -c 1 admin.pivotal.com
                        ping: icmp open socket: Operation not permitted
                        You may see such an error if setuid bit (s) is not set on /bin/ping command.
                        Verify using:
                        [INCORRECT]
                        ls -al /bin/ping
                        -rwxr-xr-x 1 root root 40760 May 20 2011 /bin/ping
                        [CORRECT]
                        [root@pccadmin ~]# chmod 4755 /bin/ping
                        [root@pccadmin ~]# ls -tlr /bin/ping
                        -rwsr-xr-x. 1 root root 40760 Jul 18 2011 /bin/ping
                        where: s instead of x in the owner permissions means that the setuid is enabled, so this file will be executed with root permissions by all users.
                        Thomas Braun Axel Koeneke Rainer.K 3 Replies Last reply Reply Quote 4
                          @Meister-Mopper
                          Jetzt hat ping das setuid bit. Da hatte ich eben auch mal dran gedacht, das zu setzen. Nagut, wenn es nun geht...
                          Aber auch das sollst du nicht als root setzen, sondern mit
                          sudo
                          vor dem Befehl...
                          • Meister Mopper
                            @Thomas-Braun Alles klar, ich danke Dir für den guten Rat.
                              @Meister-Mopper
                              root login ist Tabu!
                              • Meister Mopper
                                Meister Mopper last edited by Meister Mopper
                                Sollte man denn root generell löschen, und wie kommt man dann an die root-Rechte, wenn sie mal nötig sind? Sorry, ich blicke da noch nicht durch.
                                  @Meister-Mopper
                                  Es gibt Distributionen, die haben keinen (aktiven) root. Man kann den unter debian auch ausknipsen. Würde ich aber nicht machen.
                                  Entsprechende Rechte bekommst du, wenn halt 'sudo' vor den Befehl gesetzt wird. In ganz außergewöhnlichen Fällen kann man auch per
                                  sudo su
                                  wieder 'root' werden. Aber das darf nur an besonders hohen Feiertagen der Fall sein.
                                  • Meister Mopper
                                    @Thomas-Braun @Meister-Mopper Wahrscheinlich - nach all den Informationen - sollte man nach der abschließenden Konfiguration "sudo su" den root-user löschen, oder?
                                      @Meister-Mopper
                                      Ich würde es nicht machen. Entfernt dein System nur weiter vom 'Standard' und macht ggf. das Helfen bei Problemen schwieriger.
                                      Hab oben auch einen Fehler im Befehl. Richtig muss es
                                      sudo su -
                                      heißen. Das - ist wichtig! Setzt die Rechte bzw. das Environment in der shell. Aber da du ja eh nicht mehr root werden musst kannste das auch wieder vergessen.
                                      • Axel Koeneke
                                        Axel Koeneke @Meister Mopper last edited by
                                        @meister-mopper sagte in [gelöst] Ping-Adapter pingt nicht mehr:
                                        Danke für den Tip!
                                        Ich hatte genau das gleiche Problem nach einer neuen, sauberen LCX Installation.
                                        VG
                                        Axel
                                        • Rainer.K
                                          Rainer.K @Meister Mopper last edited by Rainer.K
                                          @meister-mopper Auch von mir vielen Dank! Ich bin schon verzweifelt, da die Instanzen Ping und Lupusec partout nicht funktionieren wollten. Der Fehler ist bei dem Neuaufbau von IoBroker mit einem neu angelegten LCX-Container (Ubuntu 20.0.4) aufgetreten.
                                          ping-adapter
                                          3651
