    4. Material Design Widgets: Wetter View
      RalfEngelberth @sigi234 last edited by Negalein
      {"axisLabels":["1h","2h","3h","4h","5h","6h","7h","8h","9h","10h","11h","12h","13h","14h","15h","16h","17h","18h","19h","20h","21h","22h","23h","24h"],"graphs":[{"data":[9,8,6,6,5,5,6,7,9,11,12,13,14,16,16,16,16,16,15,12,11,10,9,8],"type":"line","color":"gray","legendText":"Temperatur","line_pointSizeHover":5,"line_pointSize":0,"line_Tension":0.3,"yAxis_show":false,"yAxis_gridLines_show":false,"yAxis_gridLines_ticks_length":5,"yAxis_min":0,"yAxis_max":25,"yAxis_step":5,"yAxis_position":"left","yAxis_appendix":" °C","yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","displayOrder":0,"tooltip_AppendText":" °C","datalabel_backgroundColor":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"datalabel_color":"white","datalabel_offset":-10,"datalabel_fontFamily":"RobotoCondensed-Light","datalabel_fontSize":12,"datalabel_borderRadius":6,"datalabel_steps":2,"line_PointColor":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorBorder":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorHover":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorBorderHover":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"use_gradient_color":true,"gradient_color":[{"value":-20,"color":"#5b2c6f66"},{"value":0,"color":"#2874a666"},{"value":14,"color":"#73c6b666"},{"value":22,"color":"#00800066"},{"value":27,"color":"#ffa50066"},{"value":35,"color":"#ff000066"}],"use_line_gradient_fill_color":true,"line_gradient_fill_color":[{"value":-20,"color":"#5b2c6f66"},{"value":0,"color":"#2874a666"},{"value":14,"color":"#73c6b666"},{"value":22,"color":"#00800066"},{"value":27,"color":"#ffa50066"},{"value":35,"color":"#ff000066"}]},{"data":[10,10,10,10,10,10,10,10,0,0,0,0,0,0,0,0,0,0,0,1,2,2,2,3],"type":"line","color":"#0d47a1","legendText":"Regenwahrscheinlichkeit","line_UseFillColor":true,"line_pointSize":0,"line_pointSizeHover":5,"yAxis_min":0,"yAxis_max":100,"yAxis_maxSteps":10,"yAxis_position":"left","yAxis_gridLines_show":false,"yAxis_gridLines_border_show":false,"yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","yAxis_appendix":" %","displayOrder":1,"tooltip_AppendText":" %","datalabel_show":false}]}
        sigi234 Forum Testing Most Active @RalfEngelberth last edited by
        @RalfEngelberth
        Ok, was sagt die Console unter F12
          @sigi234 Ich hoffe, ich habe hier das Richtige.
          sigi234 Scrounger 2 Replies Last reply Reply Quote 0
            @RalfEngelberth
            Ok, das sollte sich @Scrounger mal ansehen. Ev. meldet er sich.
              @sigi234 ok
              • Scrounger
                Scrounger Developer @RalfEngelberth last edited by
                @RalfEngelberth sagte in Material Design Widgets: Wetter View:
                ![Bild Text](c1f6d83c-180b-4d24-83d7-886db20e68a0-image.png Bild Link)
                Das ist ein Edge spezifischer Fehler, der bei mir auch kommt. Das muss ich mir in Ruhe anschauen und im MDW fixen
                  RalfEngelberth @Scrounger last edited by
                  @Scrounger sagte in Material Design Widgets: Wetter View:
                  Habe gerade den Firefox installiert.
                  Damit geht es
                  • Scrounger
                    @RalfEngelberth
                    Ja auch mit Chrome geht es, nur halt der Edge macht hier probleme.
                    Hab den Fehler behoben, fix gibts dann in der nächsten version.
                    Falls du nicht warten willst kannst von github installieren -> danach muss iobroker upload vis ausgeführt werden!
                      Aiouh @Scrounger last edited by
                      @Scrounger
                      darf man hier auch ein Lob loswerden, nicht nur Probleme ?
                      Ich bin als ziemlicher Neuling einfach nach der Anleitung vorgegangen und ALLES hat auf Anhieb funktioniert.
                      Vielen Dank für die klasse Arbeit (Kaffee ist unterwegs 😉 )
                      Gruss Karl-Heinz
                        Smart86 last edited by Smart86
                        Sehr cooles Plugin. Ein kleines Problem habe ich aber noch, vielleicht gibt es ja eine einfache Lösung. Am Handy im Hochformat überlagern sich leider die Zahlen mit den Icons. Hat wer ne Idee?
                        • Scrounger
                          Scrounger Developer @Aiouh last edited by
                          @Aiouh sagte in Material Design Widgets: Wetter View:
                          @Scrounger
                          Gruss Karl-Heinz
                          Ich weiß zwar nicht ob das die Forumsregeln gestatten 😉 aber ich freue mich immer über ein Lob, genauso wie zu lesen, wenn meine Projekte bei Euch funktionieren!
                          @Smart86 sagte in Material Design Widgets: Wetter View:
                          Das musst du über das Widget Grid View einstellen. Dort kannst du festlegen ab welcher Auflösung die Regeln für Handy / Tablet und Desktop gelten und für diese dann die Spalten einstellen. Das Widget hat auch einen Auflösungsassitenten, der dir hilft die entsprechenden Auflösung zu erkennen.
                          Am besten einfach mal mit rum spielen, dann bekommst den Dreh raus.
                            Smart86 @Scrounger last edited by
                            Vielen Dank. Habe es in den Einstellungen gefunden bzw. die Spaltenanzahl geändert. Jetzt schaut es gut aus .-)
                              HoffmannOs last edited by
                              Ich suche mir schon nen Wolf, wie kann ich denn die Cards die derzeit in Weiss sind an mein Design im Script anpassen?
                                sigi234 Forum Testing Most Active @HoffmannOs last edited by
                                @HoffmannOs sagte in Material Design Widgets: Wetter View:
                                  Hoovercraft last edited by Hoovercraft
                                  Hier stand mal eine Fehlerbeschreibung, konnte sie aber selbst fixen.
                                  Wunderground scheint die Koordinaten nicht zu mögen. Nachdem ich meine Stadt mit Namen angegeben habe, sind die FM weg.
                                  • dirk1962
                                    dirk1962 last edited by
                                    Kann bitte einer erklären, wie ihr die einzelnen Views in eure vis integriert habt.
                                    Jeden einzelnen view in eure kopiert oder gibt es eine andere Lösung?
                                    Glasfaser Scrounger 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      Glasfaser @dirk1962 last edited by Glasfaser
                                      @dirk1962 sagte in Material Design Widgets: Wetter View:
                                      Genau , + die CSS bei Projekt nicht vergessen .
                                      • Scrounger
                                        Scrounger Developer @dirk1962 last edited by
                                        Gibt es, mit texteditor die vis-views.json bearbeiten und die views aus dem projekt en block kopieren.
                                        Achtung!!! Damit kann man sich auch sein gesamtes Projekt kaputt machen. Man sollte also wissen was man macht!
                                        AxelF1977 1 Reply Last reply Reply Quote 0
                                        • AxelF1977
                                          AxelF1977 @Scrounger last edited by
                                          erstmal danke für die klasse Arbeit. Funktioniert soweit wie beschrieben, aber einiges klappt noch nicht, siehe Screenshots.
                                          Alles installiert und eingefügt wie auf Github beschrieben
                                          1b9843ee-98d7-419f-b488-bf010d3913d7-image.png d1fa279e-faba-444f-856c-eec117dee38e-image.png
                                          Ich hab da NULL Werte. Die Instanzen sind auch installiert und konfiguriert. Einzig für wheatherunderground hab ich keinen API Schlüssel, aber da ist ja nicht zwingend erforderlich
                                          Für das letzte Widget Windy, kann man da die Location einstellen?
                                          • Glasfaser
                                            Glasfaser @AxelF1977 last edited by
                                            @AxelF1977 sagte in Material Design Widgets: Wetter View:
                                            Suche dir eine Station in der Nähe .. und trage Sie einfach ein .
                                            Link Text
                                            und hier noch , falls du Probleme hast ... Am Ende des Thread´s ist die Lösung
                                            Link Text
                                            Einfach im Link auf deine Werte ändern , Lat / Lon
                                            .......&detailLat=xxxxxxxxx&detailLon=xxxxxxxx&metricWind=default......
                                            AxelF1977 1 Reply Last reply Reply Quote 2
                                            daswetter javascript material design widgets pollenflug statusanzeige vis weatherunderground wetter
                                            78
                                            665
                                            161242
