    4. tr-64 Ad. startet nach Node.js-Update auf V12 nicht mehr
    SOLVED tr-64 Ad. startet nach Node.js-Update auf V12 nicht mehr
    • crepp1967
      crepp1967 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspbian
      Node-Version: v12.16.2
      Nodejs-Version: v12.16.2
      NPM-Version: 6.14.4
      Installationsart: Skript
      Image genutzt: Nein
      Nachdem ich heute mein Node.js auf Version 12 (wie empfohlen) gebracht habe, spinnt mein tr-64 Adapter (Community Version)
      Er wird nicht mehr grün. Das Log spukt das aus:
      tr-064-community.0	2020-04-27 00:51:30.623	error	(12996) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1006:20) at Object.options.ready (/opt/iobro
      tr-064-community.0	2020-04-27 00:51:30.619	error	(12996) uncaught exception: Cannot read property 'getState' of undefined
      tr-064-community.0	2020-04-27 00:51:30.590	info	(12996) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v12.16.2, js-controller: 3.0.18
      host.raspisuper	2020-04-27 00:51:28.235	info	instance system.adapter.tr-064-community.0 started with pid 12996
      host.raspisuper	2020-04-27 00:50:58.214	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.raspisuper	2020-04-27 00:50:58.213	info	instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
      tr-064-community.0	2020-04-27 00:50:57.673	info	(12866) Terminated (NO_ERROR): Without reason
      tr-064-community.0	2020-04-27 00:50:57.672	info	(12866) terminating
      tr-064-community.0	2020-04-27 00:50:57.624	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      tr-064-community.0	2020-04-27 00:50:57.624	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8066:76
      tr-064-community.0	2020-04-27 00:50:57.624	error	at Object.options.ready (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1120:13)
      tr-064-community.0	2020-04-27 00:50:57.624	error	at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1006:20)
      tr-064-community.0	2020-04-27 00:50:57.624	error	(12866) TypeError: Cannot read property 'getState' of undefined
      tr-064-community.0	2020-04-27 00:50:57.620	error	(12866) uncaught exception: Cannot read property 'getState' of undefined
      Was kann ich tun damit er wieder läuft?
      Neuinstallation inkl Neustart des Raspi habe ich schon probiert - Fehlanzeige.
      crepp
      • haselchen
        haselchen Most Active @crepp1967 last edited by
        @crepp1967
        Liegt daran weil er nicht mehr gepflegt wird.
        Gibt nur noch einen TR064 Adapter
        • crepp1967
          Ich dachte es gibt nur noch den tr-64 community Adapter ?
          • haselchen
            @crepp1967
            Hier steht eigentlich alles drin was Du brauchst, inklusive Anleitung bei Nodejs 12
            https://forum.iobroker.net/topic/30915/adapter-tr-064?page=1
            crepp1967 1 Reply Last reply Reply Quote 0
            • crepp1967
              crepp1967 @haselchen last edited by
              @haselchen
              Danke, es läuft (wieder) Grund war dass ich noch den community-Adapter installiert hatte die aber nun nicht mehr unterstützt wird. Ich hatte damals die community Version installiert da der Entwickler den normalen tr-64 Adapter nicht mehr weiterentwickelt hat.
              Das sich hier was geändert hat habe ich nicht mitbekommen ...
              Trotzdem danke für Deinen Support.
              crepp
              tr-64.community adapter node12
