    4. js-controller 3.0/3.1 jetzt im Latest!
      DocGame last edited by DocGame
      @apollon77 : Seit dem Update des JS-Controllers ist der iot-adapter rot und ich bekomme ihn weder gelb noch grün.
      Da ich heute auch ein Update des IOT-Adapter gemacht habe, weiß ich leider nicht, welcher der beiden Adapter schuld daran ist.
      Kannst du was aus dem Log rauslesen?(da steht ja auch noch was node)
      iot.0	2020-04-25 23:53:09.153	info	(9500) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      iot.0	2020-04-25 23:53:09.150	info	(9500) terminating
      iot.0	2020-04-25 23:53:09.148	info	(9500) Got terminate signal TERMINATE_YOURSELF
      host.IOBroker(SmartHome)	2020-04-25 23:53:09.126	info	stopInstance system.adapter.iot.0 send kill signal
      host.IOBroker(SmartHome)	2020-04-25 23:53:09.125	info	stopInstance system.adapter.iot.0 (force=false, process=true)
      iot.0	2020-04-25 23:53:05.707	info	(9500) Connection changed: connect
      iot.0	2020-04-25 23:53:03.148	info	(9500) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.0	2020-04-25 23:53:03.142	warn	the module (for instance, using `npm rebuild` or `npm install`).
      iot.0	2020-04-25 23:53:03.142	warn	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      iot.0	2020-04-25 23:53:03.142	warn	NODE_MODULE_VERSION 64. This version of Node.js requires
      iot.0	2020-04-25 23:53:03.142	warn	was compiled against a different Node.js version using
      iot.0	2020-04-25 23:53:03.142	warn	(9500) Cannot initialize getImage: Error: The module '\\?\C:\Iobroker\SmartHome\node_modules\canvas\build\Release\canvas.node'
      iot.0	2020-04-25 23:53:01.442	info	(9500) starting. Version 1.4.10 in C:/Iobroker/SmartHome/node_modules/iobroker.iot, node: v12.16.2, js-controller: 3.0.18
      host.IOBroker(SmartHome)	2020-04-25 23:52:58.103	info	instance system.adapter.iot.0 started with pid 9500
      host.IOBroker(SmartHome)	2020-04-25 23:52:55.611	info	instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      iot.0	2020-04-25 23:52:55.110	info	(10836) Connection lost
      iot.0	2020-04-25 23:52:55.109	info	(10836) Connection changed: disconnect
      • foxriver76
        foxriver76 Developer @DocGame last edited by
        @DocGame liegt an nodejs update. iob rebuild iot bzw iot rebuild iot --install
          DocGame @foxriver76 last edited by
          @foxriver76 auch unter win10?
          • foxriver76
            @DocGame jo
              @foxriver76
              THX.... Es kommen zwar noch Warnmeldungen aber der Adapter ist wieder grün.
              Jetzt hab ich nur noch neen "gelben" Meross-Adapter nachdem ich aber erst morgen schauen werde 😴
              iot.0	2020-04-26 00:26:34.268	info	(10104) Connection changed: connect
              iot.0	2020-04-26 00:26:27.922	info	(10104) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              iot.0	2020-04-26 00:26:27.913	warn
              iot.0	2020-04-26 00:26:27.913	warn	- Search for this error at https://github.com/lovell/sharp/issues
              iot.0	2020-04-26 00:26:27.913	warn	- Consult the installation documentation at https://sharp.pixelplumbing.com/install
              iot.0	2020-04-26 00:26:27.913	warn	"npm install --ignore-scripts=false --verbose" and look for errors
              iot.0	2020-04-26 00:26:27.913	warn	- Remove the "node_modules/sharp" directory then run
              iot.0	2020-04-26 00:26:27.913	warn	\\?\C:\Iobroker\SmartHome\node_modules\iobroker.iot\node_modules\sharp\build\Release\sharp.node
              iot.0	2020-04-26 00:26:27.913	warn	The specified procedure could not be found.
              iot.0	2020-04-26 00:26:27.913	warn	Something went wrong installing the "sharp" module
              iot.0	2020-04-26 00:26:27.913	warn	(10104) Cannot initialize getImage: Error:
              iot.0	2020-04-26 00:26:09.975	info	(10104) starting. Version 1.4.10 in C:/Iobroker/SmartHome/node_modules/iobroker.iot, node: v12.16.2, js-controller: 3.0.18
              host.IOBroker(SmartHome)	2020-04-26 00:26:00.302	info	instance system.adapter.iot.0 started with pid 10104
              host.IOBroker(SmartHome)	2020-04-26 00:25:58.876	info	instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                dtp last edited by dtp
                Ich habe diesen unsäglichen TR-064-Adapter schon vor Monaten gelöscht, weil er mich nur ärgerte und ich auch nahezu keinen Benefit davon hatte, die Zustände meiner FRITZ!Box im ioBroker oder in vis zu erfassen. Mir genügen da absolut die von AVM bereitgestellten Apps.
                  Jan1 @dtp last edited by
                  @dtp
                  Der läuft bei mir jetzt schon fast 2 Jahre ohne Probleme, kein Plan was Du da falsch machst.
                    apollon77 last edited by apollon77
                    Mensch ... sieht ja alles super aus 🙂 15h Ruhe hier im Thread und bereits über 2.000 Installationen der neuen Version.
                    Wir haben die letzten Tage noch einiges Eures Feedback und Themen von verschiedenen Stellen und vor allem auch letzte Randfälle die Sentry gemeldet hat gesammelt und daraus ist die 3.0.19 aka Stable RC1 entstanden. Jetzt bitte alle nochmal updaten - sollte in den nächsten Stunden im Latest bei allen auftauchen.
                    Vor allem die tr-064 Probleme sollten jetzt weniger werden ...
                    3.0.19 (2020-04-26) Release Elena
                    • (Apollon77) make sure to correctly create empty logfile on "delLogs" (Sentry IOBROKER-JS-CONTROLLER-Q)
                    • (foxriver76) make callback consistent when client has closed connection (Sentry IOBROKER-JS-CONTROLLER-R)
                    • (foxriver76) add missing Error for DB closed, which was used but undefined in tools.js
                    • (foxriver76) if buffer is of type object and not a buffer object log a warning - also bufferFrom null will also result in an error, prevent it (Sentry IOBROKER-JS-CONTROLLER-S)
                    • (foxriver76) in edge cases def can be an object, we also support this on extendObject
                    • (foxriver76) make sure stacktrace is there on validateId
                    • (foxriver76) avoid error on installAdapters function due to downloadyRetry (Sentry IOBROKER-JS-CONTROLLER-V)
                    • (Apollon77) make sure Logfile is rewritten with empty content (Sentry IOBROKER-JS-CONTROLLER-Q)
                    • (Apollon77) Update Sentry Plugin to 1.0.0, adds pathBlacklist option, fixes pot. crash reason
                    • (foxriver76) ensure backward compatibility with auto decrypt function
                    • (Apollon77) Re-allow states to be set with no val property but check that there is at least one property
                    • (foxriver76) also call enumerateAdapterDocs when deleting all instances
                    Have fun
                    dslraser BBTown 2 Replies Last reply Reply Quote 3
                      deta Most Active last edited by deta
                      Moin,
                      update ok
                      Was mir aufgefallen ist, bei Upnp und tr-064 Adapter
                      upnp.0	2020-04-27 06:19:06.292	warn	(3135) no connection to objects DB
                      tr-064.0	2020-04-27 06:18:51.565	warn	(2755) no connection to states DB
                      Selbe Fehler bei beiden.
                      Adapter alles aktuell.
                      cu Deta
                        sigi234 Forum Testing Most Active @deta last edited by
                        @deta sagte in js-controller 3.0 jetzt im Latest!:
                        bei UNPD
                        https://forum.iobroker.net/topic/32694/test-adapter-upnp-1-0-x
                          deta Most Active @sigi234 last edited by
                          @sigi234 ist heute Früh als Update mit da gewesen!
                          Dennoch...der Warn
                            apollon77 @deta last edited by
                            @deta der warm heißt nur das die objects dB etwas gebraucht hat um sich zu verbinden. Kann passieren wenn alles startet. Restarte die beiden mal einzeln. Kommt’s dann auch?
                            • bahnuhr
                              bahnuhr Forum Testing Most Active last edited by bahnuhr
                              bin noch nicht auf 3.0
                              Im log erscheint bei mir:
                              telegram.0	2020-04-27 08:00:01.645	warn	(12632) adapter.getMessage is deprecated and will be removed in js-controller 3.0. Please report this warning to the developer of this adapter!
                              Wenn dies schon bekannt, dann gut (habe jetzt nicht den ganzen thread danach durchgeschaut).
                              mfg
                              Dieter
                              • dslraser
                                dslraser Forum Testing Most Active @apollon77 last edited by
                                @apollon77
                                bis auf eine Meldung alles okay.
                                denon.0	2020-04-27 08:14:08.358	error	(576) Could not create DE states: Error: The id is empty! Please provide a valid id.
                                läuft aber trotzdem.(Adapter im Anschluss neu gestartet und läuft)
                                  Kueppert last edited by
                                  Moin,
                                  hab auch die 3.0.19 drauf gemacht. Alles bisher ohne Auffälligkeiten - AUßER der iot...will der schon wieder nen rebuild??
                                  iot.0	2020-04-27 08:20:48.067	warn	(19280) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This
                                  Muss man das bei dem Adapter jetzt jedes Update vom JS-COntroller machen? 😁 Die Meldung ist diesmal aber etwas anders formuliert als sonst...
                                  • BBTown
                                    BBTown @apollon77 last edited by
                                    @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                                    läuft bei mir unauffällig 👍
                                    • AlCalzone
                                      AlCalzone Developer @Kueppert last edited by
                                      @Kueppert Ich glaube eher, dass noch kein Rebuild geschehen ist.
                                        Kueppert @AlCalzone last edited by Kueppert
                                        @AlCalzone dochdoch, hab iobroker rebuild <ADAPTER> nach jedem Update des JS-Controllers gemacht. Ich versuche es jetzt mal mit iobroker rebuild <ADAPTER> --install und werde berichten - beim nächsten JS-Controller-Update 😉
                                        EDIT: nach dem Rebuild keine weitere WARN-Meldung vom Adapter
                                        AlCalzone 1 Reply Last reply Reply Quote 1
                                          LJSven last edited by LJSven
                                          Bei mir wird im Info noch die 10er Node Version angezeigt. Ist die folgende vorgehensweise richtig, um das gesammte System auf den aktuellsten Stand (Betriebssystem, iobroker, node) zu bringen ->
                                          cd /opt/iobroker
                                          iobroker backup
                                          iobroker stop
                                          cd
                                          sudo apt-get update
                                          sudo apt-get upgrade
                                          cd /opt/iobroker
                                          curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                                          sudo apt-get install -y nodejs
                                          iobroker update
                                          iobroker upgrade self
                                          iobroker uprade
                                          iobroker fix
                                          iobroker start
                                          Zuerst den Slave, anschließend den Master!
                                          Könnte man daraus nicht ein Script machen, wie es beim "iobroker fix" auch ist?
                                            apollon77 @bahnuhr last edited by
                                            @bahnuhr Da gibts ein Update für vom Adapter
                                            js-controller
                                            127
                                            1340
                                            431404
