    4. Sonoff 4CH Pro Rev2
    Sonoff 4CH Pro Rev2
      bob der 1. @bob der 1. last edited by bob der 1.
      @RalfEngelberth
        RalfEngelberth last edited by
        Noch eine Info:
        Wenn ich über http schalte, empfängt der Sonoff und schaltet das Relais
        Hier der Befehlt
        http://192.168.1.163/cm?cmnd=Power1 off
        Demnach müsste doch der Fehler aus IoBroker kommen.
        Hier noch einen Auszug aus der IoBroker LOG
        2020-04-26 21:06:55.037  - debug: mqtt.1 (11796) stateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"ON","ack":false,"ts":1587928015028,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928015028}
        2020-04-26 21:06:55.038  - debug: mqtt.1 (11796) onStateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"ON","ack":false,"ts":1587928015028,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928015028}
        2020-04-26 21:06:56.041  - debug: mqtt.1 (11796) stateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"OFF","ack":false,"ts":1587928016034,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928016034}
        2020-04-26 21:06:56.042  - debug: mqtt.1 (11796) onStateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"OFF","ack":false,"ts":1587928016034,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928016034}
        2020-04-26 21:06:56.250  - debug: mqtt.1 (11796) stateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"ON","ack":false,"ts":1587928016241,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928016241}
        2020-04-26 21:06:56.251  - debug: mqtt.1 (11796) onStateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"ON","ack":false,"ts":1587928016241,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928016241}
        2020-04-26 21:06:57.245  - debug: mqtt.1 (11796) stateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"OFF","ack":false,"ts":1587928017242,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928017242}
        2020-04-26 21:06:57.246  - debug: mqtt.1 (11796) onStateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"OFF","ack":false,"ts":1587928017242,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928017242}
        2020-04-26 21:06:57.507  - debug: mqtt.1 (11796) stateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"ON","ack":false,"ts":1587928017504,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928017504}
        2020-04-26 21:06:57.508  - debug: mqtt.1 (11796) onStateChange mqtt.1.stat.bewaesserung.POWER2: {"val":"ON","ack":false,"ts":1587928017504,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1587928017504}
          RalfEngelberth @bob der 1. last edited by
          @bob-der-1 sagte in Sonoff 4CH Pro Rev2:
          @RalfEngelberth
          Hat auch keine Veränderung gebracht
            bob der 1. @RalfEngelberth last edited by
            @RalfEngelberth
            Dann liegt es am Adapter oder haste ein skript im Hintergrund laufen?
              @bob-der-1 Einen Skript habe ich nicht am laufen.
              Warum gehen denn alle anderen Sonoff?
              Welchen Fehler sollte der Adapter haben?
                RalfEngelberth @RalfEngelberth last edited by
                @RalfEngelberth sagte in Sonoff 4CH Pro Rev2:
                Noch eine Info:
                Hier der Befehlt
                Mit dem Sonoff-Adapter geht es.
                Aber warum????
                  @RalfEngelberth
                  Mit dem Sonoff geht es mit mqtt nicht wirklich?
                  Her je,endweder stimmen die Mqtt Einstellungen im Sonoff zu Mqtt nicht oder ich habe gerade keine Idee.
                  Kannste mal von der Oberfläche des Sonoff die Startseite zeigen...also das webif
                    @bob-der-1 ![Bild Text](49e968f8-2ea7-458d-8c8e-c6eb0386b491-image.png Bild Link)
                      @RalfEngelberth
                      Bitte mal bild vom Mqtt....wo deine passwort port stehen.
                        @bob-der-1 ![Bild Text](84668ac4-fcac-46ed-abe1-698993bacb1c-image.png Bild Link)
                          bob der 1. @RalfEngelberth last edited by bob der 1.
                          @RalfEngelberth
                          Meinte den Mqtt Adapter vom Broker.
                          Mache das bei mir parallel mit....kann ja nicht sein
                            @bob-der-1 ![Bild Text](018b9582-5751-4781-9420-667cadcf6a0f-image.png Bild Link)
                              @bob-der-1 ![Bild Text](5dde6fc8-2241-407e-a23e-c5a71eafad03-image.png Bild Link)
                                @RalfEngelberth
                                Schau dir mal deine Ports an!
                                Mqtt und Sonoff Adapter senden wohl auf dem gleichen Port...und im Sonoff ist auch ein anderer....
                                B R 2 Replies Last reply Reply Quote 0
                                  @RalfEngelberth
                                  Einstellungen IM Sonoff.
                                  MQTT Host 192.168.178.XX
                                  MQTT Port 1889
                                  MQTT Benutzer Sonoff
                                  MQTT Client Th16
                                  MQTT Topic Sonoff
                                  MQTT Group Topic cmnd/sonoffs/
                                  MQTT Full Topic cmnd/Sonoff/
                                  MQTT Fallback-Topic cmnd/Th16_fb/
                                  Port im MQTT Adapter = 1889
                                  Port im Sonoff Adapter = 1883
                                  und wenn der 4Pro mit dem Sonoff Adapter schaltet ist er dort verbunden!Da deine Ports nicht stimmen.
                                    @RalfEngelberth
                                    Der mqtt hat den Port 1883 und der sonoff den Port 1889.
                                    Ich habe gerade auf sonoff eingestellt. Sorry, hatte ich nicht gesagt. Habe soviel schon ausprobiert.
                                    Natürlich muss der Port in Tasmota auf 1883 für mqtt im IoBroker.
                                      @RalfEngelberth
                                      Und geht es nun?
                                      Sorry?.....gaaanz locker was meinst du was ich schon verbogen habe
                                        @bob-der-1 Nein
                                        Ich hab ja nichts geändert.
                                        Ich hatte beim probieren die Ports geändert.
                                        Der Fehler ist immer noch der alte.
                                          @RalfEngelberth
                                          Haste den Sonoff und mqtt auch nicht auf dem gleichen Port laufen...also die Adapter?
                                            @RalfEngelberth
                                            Ich habe es gerade nochmal überprüft.
                                            Wenn ich in Tasmota den Port 1883 einstelle, ändert sich das Online im mqtt/IoBroker
                                            Wenn ich in Tasmota den Port 1889 einstelle, ändert sich das Online im sonoff/IoBroker
                                            Also müsste das richtig sein
                                            iobroker sonoff 4ch pro r2 sonoff mqtt tasmota
                                            2209
