    5. Waschmaschine
    Waschmaschine
      Sepp55464 last edited by
      Vielleicht hilft dir mein Skript
        <variables>
          <variable type="" id="Hhe!Hg(xh7gHuy(6hLlx">Waschmaschine_Dauerzaehler</variable>
          <variable type="" id=";y1}Hi=}pdvws@je`5g*">WaschmaschineEinAus</variable>
          <variable type="undefined" id="timeout3">timeout3</variable>
          <variable type="undefined" id="Dauerzaehler">Dauerzaehler</variable>
          <variable type="undefined" id="timeout2">timeout2</variable>
          <variable type="undefined" id="timeout">timeout</variable>
        </variables>
        <block type="variables_set" id="#tQ1FLFGKUhY/n@+2v+L" x="13" y="-62">
          <field name="VAR" id="Hhe!Hg(xh7gHuy(6hLlx" variabletype="">Waschmaschine_Dauerzaehler</field>
            <block type="math_number" id="n7J3jl%iQv$o0|:ziws|">
              <field name="NUM">0</field>
            <block type="variables_set" id="U@kYzXZme7c_*Uk)IuPm">
              <field name="VAR" id=";y1}Hi=}pdvws@je`5g*" variabletype="">WaschmaschineEinAus</field>
                <block type="logic_boolean" id="#xjPS!k_7bYBUV}GE@Ji">
                <block type="on_ext" id="%l??Ns0%ZOhlZQJn)RIY">
                  <value name="OID0">
                    <shadow type="field_oid" id="8p+iN2CjzC1M$2o|Xq=m">
                      <field name="oid">sonoff.0.SH_Waschmaschine_Keller.ENERGY_Power</field>
                    <block type="controls_if" id="-4y,4m5H6`8[U,UjJH(0">
                        <block type="logic_operation" id="-^U__L=#GGG_LD~6o~hg" inline="false">
                          <field name="OP">AND</field>
                          <comment pinned="false" h="90" w="276">Falls Maschinengang erkannt (Wattzahl &gt;10) UND Modus ist auf falsch dann starte und schreibe den aktuellen verbrauch in DP</comment>
                            <block type="logic_compare" id="-%Kg)H+S;{}Yyd@cqe=l">
                              <field name="OP">GTE</field>
                                <block type="on_source" id="QS5)==Ahwtfe.nNTl`R@">
                                <block type="math_number" id="OT1x**T)z3hCtGxhqDDI">
                                  <field name="NUM">12</field>
                            <block type="logic_compare" id=",LW+*+gUB/lbO[yiNJdv">
                              <field name="OP">EQ</field>
                                <block type="variables_get" id="[$/1md}o9xogfLp*!}WA">
                                <block type="logic_boolean" id="V}KP*,b;J,.3q802Q0l^">
                        <block type="variables_set" id="HHIFm}6:*U#VVrIRv7e|">
                            <block type="logic_boolean" id="%.`!o$LmcZOm0##5WWoJ">
                            <block type="telegram" id="5=|wMO.9[SHb3Zk2@BSt">
                              <field name="LOG"></field>
                              <value name="MESSAGE">
                                <shadow type="text" id="Kg;[X9f6%4!)kf:3}RwL">
                                  <field name="TEXT">Waschmaschine gestartet</field>
                              <value name="USERNAME">
                                <block type="text" id="n|=#HQoo99ooPz3rBz4H">
                                  <field name="TEXT"></field>
                                <block type="control" id="[)j~N!(tB0+$IKN/TQV4">
                                  <field name="OID">javascript.0.Sonstige.Energieueberwachung.Waschmaschine.Waschstart</field>
                                    <block type="get_value" id="`*fHoyq$BY7kQu@1/t::">
                                      <field name="OID">sonoff.0.SH_Waschmaschine_Keller.ENERGY_Total</field>
                                    <block type="timeouts_setinterval" id="80-Y$b]E}H$59*M]Ez/,">
                                      <field name="NAME">Dauerzaehler</field>
                                      <field name="INTERVAL">1</field>
                                        <block type="math_change" id="dEv]%1h|Rwk;-L7)Wf_~">
                                          <value name="DELTA">
                                            <shadow type="math_number" id="a33@3paIo~y.$^q.*~*[">
                                              <field name="NUM">1</field>
                      <value name="IF1">
                        <block type="logic_operation" id="[:7QWv4Op8S6o@lG45(y" inline="false">
                          <comment pinned="false" h="94" w="164">Falls Verbrauch unter 3 Watt fällt und der Modus ist Wahr dann beende den Waschmodus.</comment>
                            <block type="logic_compare" id="igy_8vlVI|k$sL-O!_Ya">
                              <field name="OP">LTE</field>
                                <block type="on_source" id="oKi^o%$Qa%i0^MVE?s)Y">
                                <block type="math_number" id="*bx}yjZ_C7J2#/$NzLoS">
                                  <field name="NUM">4</field>
                            <block type="logic_compare" id="}A,!m2TVXL.^LQWg%!e|">
                                <block type="variables_get" id="r/rnzWL?1!/.2!+pr@5(">
                                <block type="logic_boolean" id="S,c^%F*KOd(.(Q(BL!=g">
                      <statement name="DO1">
                        <block type="timeouts_settimeout" id="n6OU?~VJ9O@1;?;?v[}w">
                          <field name="NAME">timeout3</field>
                          <field name="DELAY">3</field>
                            <block type="controls_if" id="Ru#jm0kAdQ5s!lWw8-ZF">
                                <block type="logic_operation" id="JotSxV7L@8aDs,_6JaUV" inline="false">
                                    <block type="logic_compare" id="b/FaS!8mVUO{hnTc4B[6">
                                        <block type="on_source" id="dVvU8WoX0X;M=N=WK;(h">
                                        <block type="math_number" id=",F%?(OrtuVj_V~!;.6/+">
                                    <block type="logic_compare" id="X8IF*lSL$KZGbw+(B`Vk">
                                        <block type="variables_get" id="y~Gc(BiT2KWngQJRPcmM">
                                        <block type="logic_boolean" id=",mTckZE~,,T--ya6Jl^i">
                                <block type="timeouts_clearinterval" id="U,jzx?Ey?4jm/#tjYSPO">
                                    <block type="variables_set" id="vj!Vu=sDr5yt.:ZU#OfU">
                                        <block type="logic_boolean" id="5xCJ(QRB3mIo5.*f1Fsg">
                                        <block type="control" id="ZJLwAoNe[2g:dp:QCr=^">
                                          <field name="OID">javascript.0.Sonstige.Energieueberwachung.Waschmaschine.Waschende</field>
                                            <block type="get_value" id="`sEwFAU9zKYNAz{GFsgC">
                                            <block type="timeouts_settimeout" id=",NjGW@Wtt+n7RKNkcxK!">
                                              <field name="DELAY">5</field>
                                                <block type="telegram" id=":)Sqh|eio_J%+h7Q@6nJ">
                                                    <shadow type="text" id="zaE.r=+WylppU_4Nmdx~">
                                                      <field name="TEXT">Waschmaschine ist fertig</field>
                                                    <block type="text_join" id="3,~.TJZeugM.!B%S1^X}">
                                                      <mutation items="13"></mutation>
                                                      <value name="ADD0">
                                                        <block type="text" id="|9?4%ic*sy2}Q088ry:q">
                                                          <field name="TEXT">Die Waschmaschine ist fertig!</field>
                                                      <value name="ADD1">
                                                        <block type="time_get" id="a?D^RPe+s+Si=*kkfgj[">
                                                          <mutation format="true" language="false"></mutation>
                                                          <field name="OPTION">custom</field>
                                                          <field name="FORMAT">\n</field>
                                                      <value name="ADD2">
                                                        <block type="text" id="bo,?noy~Q_fU|mOY{L#L">
                                                          <field name="TEXT">Dauer: </field>
                                                      <value name="ADD3">
                                                        <block type="variables_get" id="UWw#{Zvec^I@@szY?`2w">
                                                      <value name="ADD4">
                                                        <block type="text" id="M^]iVwQ,prG!`L|C~)~g">
                                                          <field name="TEXT"> Minuten.</field>
                                                      <value name="ADD5">
                                                        <block type="time_get" id="8u(%B16pz]eRN}PV5dst">
                                                      <value name="ADD6">
                                                        <block type="text" id="5C!gUPV|`b@=iFX@aJeI">
                                                          <field name="TEXT">Verbrauch: </field>
                                                      <value name="ADD7">
                                                        <block type="math_rndfixed" id="VKS0i5D@QcR(K8~HBVt*">
                                                          <field name="n">2</field>
                                                          <value name="x">
                                                            <shadow type="math_number" id="/mj1cO@W#rIj@,l-hhT(">
                                                              <field name="NUM">3.1234</field>
                                                            <block type="math_arithmetic" id="a9lUI_@{%c|:}2r]9,3=">
        <shadow type="math_number" id="Vt0U^|-5/xSi)-0R$lvC">
        <block type="get_value" id="n.xJH}U%IgpOj2qa_[d7">
        <shadow type="math_number" id="kjky7:Z,vFRr8V{DWBlc">
        <block type="get_value" id="g%bFIVmFv8)gI{%-jcRB">
                                                      <value name="ADD8">
                                                        <block type="text" id="?3@1QC?jSS#7UdzSm),X">
                                                          <field name="TEXT"> kWh.</field>
                                                      <value name="ADD9">
                                                        <block type="time_get" id="BE%B6PWxaT1!ksrO8=F}">
                                                      <value name="ADD10">
                                                        <block type="text" id="OZG2U8*$5^Y~7us`n98M">
                                                          <field name="TEXT">Kosten: </field>
                                                      <value name="ADD11">
                                                        <block type="math_arithmetic" id="BCwbs!Im7D^MQ^?u-n[?">
                                                            <shadow type="math_number" id="$.jsBRUo-cSN{]xL{GW/">
                                                            <block type="math_rndfixed" id="vMz`ArhYYU5KvzU!CJM-">
                                                              <value name="x">
        <shadow type="math_number" id=",fEIqVcGmmf4,!4)?0b^">
        <block type="math_arithmetic" id="EBsPk7Wu}B*pVRwu`11t">
        <block type="get_value" id="X+Oe]i0kB*xR=4rB/=p3">
        <block type="get_value" id="WS0!QAt)dlmkHoRl`b^7">
                                                            <shadow type="math_number" id="fTs9_kewk!xCWm]N#JQd">
                                                            <block type="get_value" id="0#$phz$rjNdH,Sw+70H/">
                                                              <field name="OID">javascript.0.Sonstige.Energieueberwachung.Strompreis</field>
                                                      <value name="ADD12">
                                                        <block type="text" id="`g7T6{aw*)Xb;2tcAr,;">
                                                          <field name="TEXT"> €.</field>
                                                    <block type="text" id="ClQ#mBX9^]LxIc[8FtLL">
                                                <block type="timeouts_settimeout" id="^Q4mos%.lH(nScu^]C,+">
                                                  <field name="DELAY">60</field>
                                                    <block type="variables_set" id="c+9yEbR]14.2z]jg^oG?">
                                                        <block type="math_number" id="^uz`+l@#(*|kCFi{#TXz">
      LG
        Accu last edited by
        Hi Sepp,
        ich probiere dein script mal aus.
        Werde aber aus folgender Zeile nicht ganz schlau:
        • Asgothian
          Asgothian Developer @Accu last edited by
          @Accu
          Mit dieser Zeile wird ein vom Benutzer angelegter Datenpunkt gefüllt. Nach der Benennung gehe ich davon aus das in diesem Datenpunkt die für den Waschgang angefallene Energie gespeichert wird damit diese zu einem Späteren Zeitpunkt (ggf. in einer Visualisierung) verfügbar ist..
            Wie Asgothian schreibt. Beim oberen X "Waschstart" das ist bei mir ein Datenpunkt der mit dem Wert von meiner Steckdose befüllt wird beim Start des Waschvorgangs. Beim unteren X wird der Datenpunkt "Waschende" befüllt und anschließend werden beide Punkte subtrahiert um den Stromverbrauch des Waschvorgangs zu erhalten. Anschließend wird dieser Wert verwendet um die Kosten pro Waschvorgang zu berechnen berechnet.
            LG
              Dirni @Sepp55464 last edited by
              @Sepp55464 sagte in Waschmaschine:
              Ich habs mittlerweile geschaft und ein funktionierendes Timeout eingefügt.
              Hier die Lösung:
              LG
              Andi
              Könntest du mir sagen ob du hier auch ein Timeout ENDE gesetzt hast und wen ja wo? Ich bekomme immer wieder Meldungen das die Maschine fertig ist.
              • Asgothian
                Asgothian Developer @Dirni last edited by
                @Dirni sagte in Waschmaschine:
                Ein Timeout kann eigentlich nicht der Grund dafür sein das du Regelmäßig Meldungen bekommst das die Maschine Fertig ist. Zeig doch bitte mal dein gesamtes Script, dann sollten wir Dir einen Hinweis geben können wo die regelmassigen Meldungen herkommen können.
                A.
                  Accu last edited by
                  ich habe das Skript einmal etwas angepasst und bei mir laufen lassen.
                  Schaut leider im Ergebnis so aus:
                  Irgendwas scheint mit der Berechnung des Verbrauchs nicht zu klappen. Scheint wohl an den Datenpunkten vom Typ Zahl zu liegen, die ich angelegt und referenziert habe. Außerdem wird das genaue Ende der Waschzeit nicht getroffen 😞
                    <variables>
                    </variables>
                    <block type="variables_set" id="#tQ1FLFGKUhY/n@+2v+L" x="-1213" y="-1087">
                              <value name="OID0">
                                  <field name="oid">hm-rpc.0.KEQ0970473.2.POWER</field>
                                              <field name="TEXT">Die Waschmaschine wäscht jetzt.</field>
                                            <block type="control" id="zDJ/w+}RAYiwfloyzrDG">
                                              <field name="OID">StatusIoT.0.WaMaWaschstart</field>
                                                <block type="get_value" id="={Ei+8*qBg-+KD,[;Jps">
                                                  <field name="OID">hm-rpc.0.KEQ0970473.2.ENERGY_COUNTER</field>
                                  <value name="IF1">
                                                              <value name="ADD0">
                                                              <value name="ADD1">
                                                              <value name="ADD2">
                                                              <value name="ADD3">
                                                              <value name="ADD4">
                                                              <value name="ADD5">
                                                              <value name="ADD6">
                                                              <value name="ADD7">
        <value name="x">
        <field name="OID">StatusIoT.0.WaMaWaschende</field>
                                                              <value name="ADD8">
                                                              <value name="ADD9">
        <value name="x">
        <field name="OID">StatusIoT.0.Strompreis</field>
                  • Asgothian
                    Asgothian Developer @Accu last edited by Asgothian
                    @Accu
                    • Du speicherst aktuell den aktuellen Stand des Energiezählers nur zu Waschbeginn
                    • Bei der Berechnung nutzt du den den Datenpunkt mit dem Stand zu Waschende, ohne das du diesen explizit setzt.
                    Zum Fangen von Wasch-Start und Wasch-Ende: In dem Skript ist die Regel wie folgt:
                    Start des Waschens wenn die Leistung der Steckdose >12 ist.
                    Ende des Waschens wenn die Leistung der Steckdose unter 4 fällt und 3 Minuten später immer noch unter 4 ist.
                    Auffällig ist:
                    • Wenn die Leistungsaufnahme unter 4 liegt aber leicht schwankt, dann wird das Ende nicht sauber erkannt, da der 3 Minuten Timeout bei jedem schwanken erneut gestartet wird, und damit ggf. mehrfach verfügbar ist
                    • Wenn die Leistungsaufnahme leicht schwankt aber über 4 Steigt wird der Timeout nicht beendet.
                    Mein Vorschlag in Pseudocode um das Ende sauberer zu fangen:
                    Falls (WaschmaschineEinAus = wahr)
                      Falls (state value <= 4) und (old value > 4) mache
                        Timeout3 Block wie bisher
                      ende Falls
                      Falls (state value >= 12) und (old value < 12) mache
                        stop Timeout3
                      ende Falls
                    ende Falls
                    Nachtrag: Wichtig ist, das im Timeout3 der "wert" Baustein nicht genutzt werden darf - an dieser Stelle muss die aktuelle Leistungsabfrage neu ermittelt werden.
                      biker1602 last edited by
                      Hallo
                      Ich habe leider das gleiche Problem.
                      Ich habe zwei Datenpunkte erstellt für die Watt Zahl Waschstart und Waschende.
                      Wenn die Maschine fertig ist, dann soll die Zahl vom Waschstart z.B. 99176 vom Waschende 99678 abgezogen wären. Das klappt auch aber ich würde dieses Ergebnis gerne durch 1000 teilen lassen, um dann im Telegramm die richtige Zahl z.B. 0,502 kWh angezeigt zu bekommen.
                      Zusätzlich die Kosten wäre natürlich perfekt.
                      Ich bekomme es aber einfach nicht hin.
                      • Asgothian
                        Asgothian Developer @biker1602 last edited by
                        @biker1602
                        versuch mal so:
                          Dirni @Asgothian last edited by
                          @Asgothian
                          Hi
                          Ich wäre dir echt sehr Dankbar, ich kämpfe nun schon seit einiger Zeit mit diesem Thema herum. Ich weis ich zahlreiche verschiedenen Scripte miteinander vereint aber ich hoffe ihr könnt mir helfen.
                          Wie gesagt
                          Wenn Programmschalter auf 0, dann Verbraucht die Maschine auch 0
                          Wenn wir einen Timer stellen um 6:00 mit einem Waschprogramm dann verbraucht die Maschine zu diesem Zeitpunkt schon gleich viel wie während dem Waschprogramm in den Pausen.
                          Darum benötige ich wenn das Script mal läuft eine Überprüfung, wenn nach Start der Wert von z.b. 4 Watt vorkommt muß überprüft werden ob dieser Wert dauerhgaft ist (dann ist die Maschine fertig) oder ob es sich nur um eine Kurze Pause im Programm handelt wo die Maschin weniger verbraucht.
                            <variables>
                              <variable type="" id="=?OmOeJXP(6k$Q8a4v1*">WaMa_Dauerzaehler</variable>
                              <variable type="" id="Hhe!Hg(xh7gHuy(6hLlx">WaMa_EinAus</variable>
                              <variable type="undefined" id="timeout4">timeout4</variable>
                            </variables>
                            <block type="variables_set" id="VhvVE3UkVJB2fvjGzu*!" x="12" y="-13">
                              <field name="VAR" id="=?OmOeJXP(6k$Q8a4v1*" variabletype="">WaMa_Dauerzaehler</field>
                                <block type="math_number" id="g,Bx,*s}7,][vN=Z-Mt4">
                                <block type="variables_set" id="i@;~wXOo)(5+=$*9v:QF">
                                  <field name="VAR" id="Hhe!Hg(xh7gHuy(6hLlx" variabletype="">WaMa_EinAus</field>
                                    <block type="logic_boolean" id="stD7DD67D[4(YSQ3dCvR">
                                      <value name="OID0">
                                          <field name="oid">shelly.0.SHSW-PM#BA58D8#1.Relay0.Power</field>
                                                      <field name="NUM">5</field>
                                                <block type="control" id="z]7Pj2YXS1-d)pnchN,!">
                                                  <field name="OID">javascript.0.scriptEnabled.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Waschstart</field>
                                                    <block type="get_value" id="b$lgvB*z^u:a@_hX4hL]">
                                                      <field name="OID">shelly.0.SHSW-PM#BA58D8#1.Relay0.Energy</field>
                                                    <block type="timeouts_setinterval" id="(?2yHN!soJ=}mLZ7l]lF">
                                                        <block type="math_change" id="w,FoLyTV8R1TP-!PMN(k">
                                                            <shadow type="math_number" id="H!-!N4kZhgP#5;zrxCTY">
                                                            <block type="math_number" id="AF2;r}gdm2RpvV`mn)fr">
                                          <value name="IF1">
                                              <comment pinned="false" h="80" w="160">Falls Verbrauch unter 3 Watt fällt und der Modus ist Wahr dann beende den Waschmodus.</comment>
                                                  <field name="OP">LT</field>
                                            <block type="comment" id="l_UxyF[7l.W[9+KCjUzR">
                                              <field name="COMMENT">Zusätzliches Timeout "Wenn füre 2 Minuten  weniger wie 5 Watt verbraucht werden ist die Maschine Feritg</field>
                                                <block type="timeouts_settimeout" id="FT-Aebrk1nQxA(D0}bjX">
                                                  <field name="NAME">timeout4</field>
                                                    <block type="controls_if" id="z#h:Sgr$YhLz;/sJ:;q+">
                                                        <block type="logic_operation" id="k8`k9;Ypy[xEoy_mm2)_">
                                                            <block type="logic_compare" id="kg`v@}Wxf%H71-6[LoA2">
        <block type="on_source" id="K/(.^9Kpm4|7=Ye=7lp#">
        <block type="math_number" id="OqAYX/y!j21Y]dVWdJ82">
                                                            <block type="logic_compare" id="7k@eXCwx[(!`$|iKjlX?">
        <block type="variables_get" id="_DQp6uLs##,TQ84hTu,X">
        <block type="logic_boolean" id="m[z$R3x+t7q:t3NePYda">
                                                        <block type="timeouts_clearinterval" id="4Usl2WULucSJQ,Ptrt9^">
        <block type="control" id="{MMg6Za}8I|gw.4cE6oG">
        <field name="OID">javascript.0.scriptEnabled.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Waschende</field>
        <block type="get_value" id="}_}=j6pEBm+0afN/394(">
        <block type="comment" id="P5Kh.,h#^UMV[v`9Yzkh">
        <field name="COMMENT">Daten Schreiben für History Verbrauch pro Waschgang</field>
        <block type="control" id="gHXhqKS,=oO5$AN/c_ha">
        <field name="OID">javascript.0.scriptEnabled.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Stromverbrauch_pro_Waschgang</field>
        <block type="math_rndfixed" id="%DceoHsJ1|2ktnX;ik;Y">
        <value name="x">
        <shadow type="math_number" id="}[m8CJ[~.H(X2Ez)$MNC">
        <block type="math_arithmetic" id="B1^}sQT!K1/]T@W1L[xe" inline="false">
        <shadow type="math_number" id=";x*EJIT-UHcl7Q0j{G#U">
        <block type="get_value" id="4j)vOPYH;mNC!#:Z+WGo">
        <shadow type="math_number" id=")KC,Lt~MMGdb=v/v*dsR">
        <block type="get_value" id="Em,I/QyK(Bar*A)uA#fs">
        <block type="comment" id="wF!c?,7;T=c_:f5E$ca%">
        <field name="COMMENT">Alexa Speak Küche</field>
        <block type="control" id="+SAt@WRkN^,`?mBaWK7X">
        <field name="OID">alexa2.0.Echo-Devices.G090LA09738501SH.Commands.speak-volume</field>
        <block type="math_number" id="fe^Mhowmv1lO*}E|[u!,">
        <field name="NUM">50</field>
        <block type="control" id="w3DS%f?P5Y+pO7;1V~SB">
        <field name="OID">alexa2.0.Echo-Devices.G090LA09738501SH.Commands.announcement</field>
        <block type="text" id="vtK95A?T0Tj#c5DEZ[5~">
        <block type="comment" id="@dC$^axcVYkgm8#naev1">
        <field name="COMMENT">Nachricht über Telegramm</field>
        <mutation items="9"></mutation>
        <value name="ADD0">
        <field name="TEXT">Die Waschmaschine ist Fertig.</field>
        <value name="ADD1">
        <value name="ADD2">
        <block type="text" id="grfj-@D75~7#;4n|*Zja">
        <value name="ADD3">
        <block type="variables_get" id="n.X3BE*TU_{qnfXV+E~:">
        <value name="ADD4">
        <block type="text" id="hB0LeD{cRvcWSjG+y.+=">
        <value name="ADD5">
        <block type="time_get" id="cA93H,ih=ovnjMRR4?Q6">
        <value name="ADD6">
        <block type="text" id="iq5Tj*K!:5+gf]#fZ42]">
        <value name="ADD7">
        <block type="math_rndfixed" id=")6B|F41_epI9gP[THRW[">
        <value name="x">
        <block type="math_arithmetic" id="vkHPDt[yds%_+|}F~JlI" inline="false">
        <block type="get_value" id="v-h3Ax9U5D^A[-sA.*VR">
        <block type="get_value" id="Y8iAp,Pk9o!]nby,SpJ^">
        <value name="ADD8">
        <block type="text" id="Gq}sI5F*R]paEBl+;3+e">
        <block type="text" id="F-U1oN3NElzVk6CJ);7R">
        <field name="TEXT">Dirni</field>
        <block type="timeouts_settimeout" id=":DTtJMZX*6T[m5$MS#FV">
        <field name="DELAY">20</field>
        <block type="variables_set" id=",${esm~ZSiljnImc}dcx">
        <block type="math_number" id=";!%m^7forEuu5xZJ{}fV">
                          • Asgothian
                            @Dirni
                            Dein Script hat die Funktion bereits, allerdings mit einem Fehler:
                            An dieser Stelle darfst du nicht den "Wert" Baustein nehmen sondern musst den Wert des Datenpunktes neu abfragen.
                            A.
                              Hi
                              Das heist in dem Fall so oder, du hast recht er hat ja in dem Fall keinen "WERT" mehr oder?
                                biker1602 @Asgothian last edited by
                                @Asgothian Ich habe es eingegeben mal sehen was bei rauskommt.
                                • Asgothian
                                  @Dirni
                                  Jo, so sollte die Abfrage wirken.
                                  A.
                                    @Asgothian said in Waschmaschine:
                                    @biker1602
                                    versuch mal so:
                                    Funktioniert leider nicht die Werte sind Waschmaschinenstart 99518 und Waschende 99964 und als Telegramm habe ich 99864,482 kWh
                                      Accu last edited by
                                      was meinst du damit? Ich hatte doch das Script von Dir 1:1 übernommen.
                                      • Asgothian
                                        @Accu sagte in Waschmaschine:
                                        Unwahrscheinlich - ich habe keine Leistungsmessung für meine Waschmaschine 😉
                                        Dein Script sieht (lt. deinem Post vom 27.4.) so aus:
                                        Screenshot 2020-04-28 at 14.33.45
                                        In diesem Screenshot kannst du sehen das es zwar einen Befehl "control StatusIoT.0.WaMaWaschstart..." gibt, aber keinen entsprechenden Befehl "control StatusIoT.0.WaMaWaschende..." gibt.
                                        Trotzdem berechnest Du den Energieverbrauch aus "value of Status.Iot.WaMaWaschende - value of Status.IoT.WaMaWaschstart"
                                        Du musst da wo du "set WaschmaschineEinAus to false" machst zusätzlich noch
                                        control StatusIoT.0.WaMaWaschende with value of hm-rpc.0.,..." machen, damit die Berechnung funktioniert.
                                        A.
                                          sorry das ich mich einmische aber fehlt hier nicht dieser Schritt
                                          Und danke nochmal ich muß mein Script aber noch mehr optimieren. ich bekomme jetzt immer noch vereinzelt Nachrichten das die Waschmaschine fertig ist. Ich gehe davon aus das die WATT Werte nicht passen bzw. angepasst werden müssen. Mir ist heute wie ich gleich mal nachgesehen habe aufgefallen das die Waschmaschine bei der Programmwahl einen Ausschlag von ein paar Hundert Watt drin hat. Hier werde ich eine Einschaltverzögerung benötigen. Hat jemand vielleicht einen Tip wie das nun wieder realisiert werden kann?
                                          lg Dirni
                                          @Asgothian sagte in Waschmaschine:
                                          A.
                                          • Asgothian
                                            In deinem fall gibt es eine einfache Option:
                                            Du prüfst einfach ob der Dauerzähler < 5 ist. Wenn ja, dann setzt du die gesamte Erkennung zurück - weniger als 5 Minuten sollte kein Waschgang dauern.
                                            Also in Etwa so:
                                            Das komplette modifizierte Script findest Du im Spoiler, basierend auf dem was du vorher hier im Thread gepostet hast.
                                            Neben der Abfrage auf den Dauerzähler habe ich auch noch eine Zusatzabfrage eingebaut das der vorherige Wert >= 5 und der aktuelle Wert < 5 sein soll, damit der Trigger nur dann aktiv wird wenn die Leistungsaufnahme gerade unter 5 fällt, also nicht jedes mal wenn sie zwischen 3 und 4 herum dümpelt.
                                             <variables>
                                             </variables>
                                             <block type="variables_set" id="VhvVE3UkVJB2fvjGzu*!" x="838" y="13">
                                                       <value name="OID0">
                                                           <value name="IF1">
        <block type="logic_operation" id="Y(DY5TjFzyX=D_%6;##7" inline="false">
        <block type="logic_compare" id="ydDpT$dnoB]3iV0{BiSL">
        <block type="on_source" id="TI;SFi6{]mr@]Ir[QtYg">
        <field name="ATTR">oldState.val</field>
        <block type="math_number" id="wCZMQ`jlh5X9NCvvT5hm">
                                                             <block type="controls_if" id="j]Bz.g6@h:~x5OI%*sl,">
        <block type="logic_compare" id="tzrQnya`pPTfxmf$JOw?">
        <block type="variables_get" id="ZDrx)jUi-}hLCDbisa4J">
        <block type="math_number" id="S=3[Ei2P3sJK$P@2vX%h">
        <block type="timeouts_clearinterval" id="tXdlU6Ola8|=,?XdWjG:">
        <block type="variables_set" id=",twC)Q17F$4[i56z]WM5">
        <block type="math_number" id="St1*yKTJ-gv$5`U6/gy]">
        <block type="variables_set" id="g6;)G_@GU~/L478A/J}m">
        <block type="logic_boolean" id="/`=!fsUh3{P97k|]+wm=">
                                                               <statement name="ELSE">
        <value name="x">
        <value name="ADD0">
        <value name="ADD1">
        <value name="ADD2">
        <value name="ADD3">
        <value name="ADD4">
        <value name="ADD5">
        <value name="ADD6">
        <value name="ADD7">
        <value name="x">
        <value name="ADD8">
                                            blockly
                                            16
                                            109
                                            10146
