      sigi234 Forum Testing Most Active @simatec last edited by sigi234
      @simatec sagte in Test Adapter Backitup v1.5.x:
      @sigi234
      Wann kommt die Meldung?
      Nach dem Update und nachdem ich in den Einstellungen war. Beobachte weiter.
      Kommt was in Sentry an?
      • simatec
        simatec Developer Most Active @sigi234 last edited by
        @sigi234
        Im Sentry wird nix gemeldet. Poste mal bitte den kompletten Log.
          @sigi234
          Bin am Handy, Log lösche ich immer. Muss ich später nachsehen, ev finde ich den Log doch noch wo.
          backitup.0	2020-04-22 21:14:05.536	debug	(26436) No backup file was found
          backitup.0	2020-04-22 21:14:04.806	debug	(26436) system.adapter.admin.0: logging true
          backitup.0	2020-04-22 21:14:03.524	error	(26436) Error: OOPS: cannot change directory:/shares
          backitup.0	2020-04-22 21:14:03.201	info	(26436) [ccu] backup was activated at 04:30 every 3 day(s)
          backitup.0	2020-04-22 21:14:03.194	info	(26436) [iobroker] backup was activated at 02:00 every 1 day(s)
          backitup.0	2020-04-22 21:14:03.166	info	(26436) starting. Version 1.5.1 in C:/Program Files/iobroker/Test/node_modules/iobroker.backitup, node: v10.16.3, js-controller: 3.0.14
          backitup.0	2020-04-22 21:14:03.010	debug	(26436) Plugin sentry Initialize Plugin (enabled=true)
          backitup.0	2020-04-22 21:14:02.736	debug	(26436) statesDB connected
          backitup.0	2020-04-22 21:14:02.736	debug	(26436) States connected to redis: 127.0.0.1:9000
          backitup.0	2020-04-22 21:14:02.723	debug	(26436) States create System PubSub Client
          backitup.0	2020-04-22 21:14:02.722	debug	(26436) States create User PubSub Client
          backitup.0	2020-04-22 21:14:02.714	debug	(26436) Redis States: Use Redis connection: 127.0.0.1:9000
          backitup.0	2020-04-22 21:14:02.713	debug	(26436) objectDB connected
          backitup.0	2020-04-22 21:14:02.708	debug	(26436) Objects connected to redis: 127.0.0.1:9013
          backitup.0	2020-04-22 21:14:02.682	debug	(26436) Objects client initialize lua scripts
          backitup.0	2020-04-22 21:14:02.680	debug	(26436) Objects create User PubSub Client
          backitup.0	2020-04-22 21:14:02.679	debug	(26436) Objects create System PubSub Client
          backitup.0	2020-04-22 21:14:02.649	debug	(26436) Objects client ready ... initialize now
          backitup.0	2020-04-22 21:14:02.625	debug	(26436) Redis Objects: Use Redis connection: 127.0.0.1:9013
          backitup.0	2020-04-22 21:13:56.364	info	(24196) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          backitup.0	2020-04-22 21:13:56.363	info	(24196) terminating
          backitup.0	2020-04-22 21:13:56.363	info	(24196) cleaned everything up...
          backitup.0	2020-04-22 21:13:56.363	info	(24196) Got terminate signal TERMINATE_YOURSELF
          backitup.0	2020-04-22 21:13:45.081	error	(24196) Error: OOPS: cannot change directory:/shares
          backitup.0	2020-04-22 21:13:44.780	info	(24196) [ccu] backup was activated at 04:30 every 3 day(s)
          backitup.0	2020-04-22 21:13:44.773	info	(24196) [iobroker] backup was activated at 02:00 every 1 day(s)
          backitup.0	2020-04-22 21:13:44.673	info	(24196) starting. Version 1.5.1 in C:/Program Files/iobroker/Test/node_modules/iobroker.backitup, node: v10.16.3, js-controller: 3.0.14
          backitup.0	2020-04-22 21:13:37.752	info	(17324) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          backitup.0	2020-04-22 21:13:37.751	info	(17324) terminating
          backitup.0	2020-04-22 21:13:37.751	info	(17324) cleaned everything up...
          backitup.0	2020-04-22 21:13:37.750	info	(17324) Got terminate signal TERMINATE_YOURSELF
          Fehler kommt wenn ich den Adapter neu starte.
          Log nach Backup:
          email.0	2020-04-22 21:21:21.604	info	(15820) sent to xxxxx@xxxxx.at
          backitup.0	2020-04-22 21:21:20.181	debug	(26436) [iobroker] exec: done
          backitup.0	2020-04-22 21:21:20.179	debug	(26436) [iobroker/history] backitup.0.history.json
          backitup.0	2020-04-22 21:21:20.178	debug	(26436) [iobroker] exec: done
          backitup.0	2020-04-22 21:21:20.176	debug	(26436) [iobroker/history] backitup.0.history.html
          email.0	2020-04-22 21:21:20.160	info	(15820) Send email: {"text":"BackItUp:\nDas Backup wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!!\n\nftp: Error: OOPS: 500 OOPS: child died","to":"xxxxx@xxxx.at","subject":
          backitup.0	2020-04-22 21:21:20.147	debug	(26436) [iobroker/email] done
          backitup.0	2020-04-22 21:21:20.146	debug	(26436) sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
          backitup.0	2020-04-22 21:21:20.134	debug	(26436) [iobroker/clean] done
          backitup.0	2020-04-22 21:21:20.132	debug	(26436) [iobroker/clean] Backup files not deleted from C:/Program Files/iobroker/Test/backups because some errors.
          backitup.0	2020-04-22 21:21:20.129	debug	(26436) [iobroker/ftp] [IGNORED] Error: OOPS: cannot change directory:/shares
          backitup.0	2020-04-22 21:21:19.875	debug	(26436) [iobroker/iobroker] done
          backitup.0	2020-04-22 21:21:18.844	debug	(26436) [iobroker/iobroker] Backup created: C:\Program Files\iobroker\Test\backups\iobroker_2020_04_22-21_21_04_backupiobroker.tar.gz
          backitup.0	2020-04-22 21:21:07.280	debug	(26436) [iobroker/iobroker] host.Medion(Test) 22816 objects saved
          backitup.0	2020-04-22 21:21:07.253	debug	(26436) [iobroker/iobroker] host.Medion(Test) 20804 states saved
          backitup.0	2020-04-22 21:21:07.053	debug	(26436) system.adapter.admin.0: logging true
          OS: win32
          JS controller 3.0.14
          INFO!!!
          Warte, habe Probleme mit dem NAT! Hatte gestern einen Stromausfall.
          Geht wieder , NAS defekt. Habe auf HDD Copy umgestellt.
          • simatec
            Ab sofort ist die Version 1.5.1 auf Github und npm . In Laufe des Tages dann auch über die Latest Repo zu installieren ...
            Changelog
            1.5.1 (23.04.2020)
            • (simatec) Bugfix list from nas
            • (simatec) Bugfix sentry errors
              Lstt last edited by
              Is it possible support several bases MySql to backup?Скриншот 23-04-2020 133752.jpg
              • Stephan Schleich
                Stephan Schleich last edited by
                Woran kann der Versionsunterschied liegen? Verwahrungsort ist default.
                ich hab vermutlich aus Testzwecken mal ein gibhub download angestoßen, und heute den von npm drüber installiert.
                Kann ich das ohne Adapter löschen korrigieren, sonst sind ja alle Adapter Settings weg oder?
                  Kueppert @Stephan Schleich last edited by
                  @Stephan-Schleich ich habe auch die v1.5.2 drauf. Warum willst du das ändern?
                  Stephan Schleich 1 Reply Last reply Reply Quote 0
                  • Stephan Schleich
                    Stephan Schleich @Kueppert last edited by
                    @Kueppert Will ich nicht, es geht mir im den Versionsunterschied der Anzeige
                    • simatec
                      simatec Developer Most Active @Stephan Schleich last edited by
                      @Stephan-Schleich
                      Default ist stable und da ist die Version 1.4.5 aktuell.
                      Da du über Github installiert hast, hast du aber 1.5.2
                      • Stephan Schleich
                        Stephan Schleich @simatec last edited by
                        @simatec ich hab über npm installiert, dachte das wäre dann immer die stable Version - scheinbar hab ich da aber ein denkfehler
                          Jan1 @Stephan Schleich last edited by
                          @Stephan-Schleich
                          Installiert wird eigentlich grundsätzlich über den Admin, alles andere geht zwar auch, wobei man wissen sollte was man tut 😉
                          • JB_Sullivan
                            JB_Sullivan last edited by
                            Moin zusammen - kurze Frage: Nach dem Adapter Update auf 1.5.4 bekommt man folgende WARN Meldung.
                            backitup.0	2020-05-01 08:09:07.530	warn	at processImmediate (timers.js:658:5)
                            backitup.0	2020-05-01 08:09:07.530	warn	at tryOnImmediate (timers.js:676:5)
                            backitup.0	2020-05-01 08:09:07.530	warn	at runCallback (timers.js:705:18)
                            backitup.0	2020-05-01 08:09:07.530	warn	at Immediate.setImmediate [as _onImmediate] (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:227:41)
                            backitup.0	2020-05-01 08:09:07.530	warn	at change (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\adapter.js:4808:34)
                            backitup.0	2020-05-01 08:09:07.530	warn	at Adapter.emit (events.js:198:13)
                            backitup.0	2020-05-01 08:09:07.530	warn	at Adapter.adapter.on.obj (C:\iobroker\GLT\node_modules\iobroker.backitup\main.js:118:21)
                            backitup.0	2020-05-01 08:09:07.530	warn	at module.exports (C:\iobroker\GLT\node_modules\iobroker.backitup\lib\list.js:22:40)
                            backitup.0	2020-05-01 08:09:07.530	warn	(10580) TypeError: Cannot read property 'type' of null
                            backitup.0	2020-05-01 08:09:07.526	warn	(10580) States system pmessage io.messagebox.system.adapter.backitup.0 {"command":"list","message":"local","from":"system.adapter.admin.0","callback":{"message":"local","id":37,"ack":false,"time":158
                            Man muss seine Instanz Einstellungen editieren und erneut speichern, dann funktioniert auch wieder die "Wiederherstellen - Backups aufrufen" Funktion. Ohne erneutes abspeichern der Einstellungen passiert hier nämlich nichts mehr.
                            Dann noch eine andere Frage: Wenn unter BackItUp die Anzahl der Backups eingestellt ist, wird dann ALLES gelöscht, was älter ist als diese eingestellte Anzahl?
                            Ich habe früher immer Backups in den Backup Ordner geschoben die ich persönlich für wichtig hielt. BackItUp hat nur seine selbst angelegten Backups verwaltet und diese fortwährend erneuert. Dateien die ich in diesen Ordner kopiert habe, wurden nicht "angefasst".
                            Seit einiger Zeit, scheint BackItUp aber ALLES in dem Backup Odner zu löschen was nicht seiner eingestellten Anzahl entspricht.
                            Beispiel:
                            01.01.2020 - händisch von mir in den Ordner kopiert
                            29.02.2020 BackItUp Automatisch erzeugt
                            01.03.2020 BackItUp Automatisch erzeugt
                            02.03.2020 BackItUp Automatisch erzeugt
                            03.03.2020 BackItUp Automatisch erzeugt
                            04.03.2020 BackItUp Automatisch erzeugt
                            Mit anderen Worten, die automatisch erzeugten werden fortlaufend überschrieben und die Datei vom 01.01.2020 wird gelöscht. Früher wäre die Datei vom 01.01.2020 erhalten geblieben.
                            PS: Ist eine Windows Installation 😉
                            • simatec
                              simatec Developer Most Active @JB_Sullivan last edited by
                              @JB_Sullivan
                              Die Warnung schaue ich mir an ...
                              Zu dem löschen ... alle Files mit beginnend mit "iobroker_" werden nach Datum geprüft und dann gelöscht.
                              Willst du also alte Backups aufheben, dann gib ihnen einen anderen Namen.
                                skokarl last edited by
                                Ich hatte vorhin eine Meldung im Log die ich früher noch nie gesehen hatte.
                                Möglicherweise hängt es mit dem letzten Update zusammen.
                                • simatec
                                  simatec Developer Most Active @skokarl last edited by
                                  @skokarl
                                  Kannst du bitte mal den Log posten?
                                  Ein Screenshot ist da nicht so praktikabel
                                    skokarl @simatec last edited by
                                    @simatec
                                    Wir stellen das nochmal zurück,
                                    hab eben den Adapter auf debug gestellt und das Backup händisch angestossen,
                                    alles sauber, keine Fehler.
                                    Vielleicht hatte heute Nacht meine NAS ein kurzes Problem, das kann tatsächlich sein, weil ich
                                    im Moment sowieso mit meinem Netzwerk oben im Haus sporadisch Ärger habe.
                                    Ich beobachte das, ansonsten gibt's beim nächsten Mal nen Log.
                                    • simatec
                                      @skokarl
                                      Kannst du bitte trotzdem den Log mal posten.
                                      Ich habe im Sentry die Fehlermeldungen auch ein paar mal gesehen.
                                        skokarl @simatec last edited by skokarl
                                        @simatec
                                        viel Müll drin..... 🙂
                                        guck einfach nur bei 01:00 Uhr .... edit: log wieder entfernt
                                        und eben hab ich ja nochmal händisch getestet.
                                          crunchip Forum Testing Most Active last edited by crunchip
                                          update 1.5.4 auf 1.5.5 klappt nicht
                                          2020-05-02 23:54:13.608 - info: host.IoBroker iobroker upgrade backitup
                                          2020-05-02 23:54:16.107 - info: host.IoBroker iobroker Update backitup from @1.5.4 to @1.5.5
                                          2020-05-02 23:54:16.147 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                                          2020-05-02 23:54:16.224 - info: host.IoBroker "system.adapter.backitup.0" disabled
                                          2020-05-02 23:54:16.231 - info: backitup.0 (4649) Got terminate signal TERMINATE_YOURSELF
                                          2020-05-02 23:54:16.224 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                          2020-05-02 23:54:16.226 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
                                          2020-05-02 23:54:16.233 - info: backitup.0 (4649) cleaned everything up...
                                          2020-05-02 23:54:16.234 - info: backitup.0 (4649) terminating
                                          2020-05-02 23:54:16.240 - info: backitup.0 (4649) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2020-05-02 23:54:16.790 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2020-05-02 23:54:16.941 - info: host.IoBroker iobroker NPM version: 6.14.4
                                          2020-05-02 23:54:16.949 - info: host.IoBroker iobroker npm install iobroker.backitup@1.5.5 --loglevel error --prefix "/opt/iobroker" (System call)
                                          2020-05-02 23:54:34.439 - info: host.IoBroker iobroker npm ERR! code ETARGETnpm ERR! notarget No matching version found for iobroker.backitup@1.5.5.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
                                          2020-05-02 23:54:34.446 - info: host.IoBroker iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-02T21_54_34_430Z-debug.log
                                          2020-05-02 23:54:34.518 - info: host.IoBroker iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                          2020-05-02 23:54:34.762 - info: host.IoBroker iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                          2020-05-02 23:54:34.841 - info: host.IoBroker iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                          2020-05-02 23:54:34.914 - info: host.IoBroker iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                          2020-05-02 23:54:34.973 - info: host.IoBroker iobroker Adapter "backitup" updated
                                          2020-05-02 23:54:34.974 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is started
                                          2020-05-02 23:54:35.047 - info: host.IoBroker "system.adapter.backitup.0" enabled
                                          2020-05-02 23:54:35.073 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 6761
                                          2020-05-02 23:54:36.091 - info: host.IoBroker iobroker exit 0
                                          2020-05-02 23:54:41.857 - info: backitup.0 (6761) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.20.1, js-controller: 3.0.20
                                          2020-05-02 23:54:41.914 - info: backitup.0 (6761) [iobroker] backup was activated at 05:30 every 1 day(s)
                                          • mickym
                                            mickym Most Active @crunchip last edited by
                                            @crunchip Ja genau diese Fehler hatte ich auch. Über GitHub aber nun 1.5.6 bereits installiert und das klappte ohne Fehler.
                                            Glasfaser 1 Reply Last reply Reply Quote 1
                                            170
                                            2780
                                            2346642
