    4. [Log Parser Adapter] Fragen zu Regex und Filterregeln
    • Mic
      Mic Developer @Iccube last edited by
      @Iccube
      Gehe mal im ioBroker Admin links auf "Log", dann oben "LOG HERUNTERLADEN" und da dann die entsprechende Logzeile komplett kopieren und hier in Code-Tags einfügen.
      Iccube BBTown 2 Replies Last reply Reply Quote 0
      • Iccube
        Iccube @Mic last edited by
        @Mic
        2020-04-27 19:20:00.021 - info: host.iobroker instance system.adapter.dwd.0 started with pid 4722
        2020-04-27 19:20:00.623 - info: dwd.0 (4722) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.2, js-controller: 3.0.19
        2020-04-27 19:20:01.376 - info: dwd.0 (4722) Terminated (NO_ERROR): Without reason
        2020-04-27 19:20:01.880 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
        Mic 1 Reply Last reply Reply Quote 0
        • BBTown
          BBTown @Mic last edited by
          @Mic
          Hast Du eine Idee für mich weshalb die Angaben von alexa2.0.History.json nicht in logparser.0.filters.Alexa.json landen?
          * JavaScript Adapter Script for Log-Parser-Adapter: https://github.com/Mic-M/ioBroker.logparser
          * Purpose: Get the history of all spoken Alexa commands into the log
          *          Required: Alexa adapter - https://github.com/Apollon77/ioBroker.alexa2
          * Source:  https://github.com/Mic-M/ioBroker.logparser
          * Autor:   Mic-M (Github) | Mic (ioBroker)
          * Change Log:
          *  1.0.0  Mic-M   * Adoption to Log Parser Adapter
          *  0.1.0  Mic-M   * Initial release (for Log Script - https://github.com/Mic-M/iobroker.logfile-script).
          * Script Settings
          // **Capitalize First Letters**
          // The spoken command to Alexa is being returned in lowercase, like "turn on kitchen light".
          // With this option set to true, the output will be "Turn On Kitchen Light" (so capitalized first letter of each word)
          const g_capFirstLetters = true;
          * End of Script Settings. Please do not change anything below here.
          main();
          function main() {
             // All Alexa adapter instances, so alexa2.0.History.json, alexa2.1.History.json, alexa2.2.History.json, etc.
             on({id: /^alexa2\.\d\.History\.json$/, change:'any'}, function(obj) {
                 // obj.state.val: JSON string of object.
                 // Like: {"name":"Alexa Flur","serialNumber":"xxxxxxxxxx","summary":"Wohnlicht an","creationTime":1582843794820, ... }
                 let objHistory = JSON.parse(obj.state.val);
                 // ignore alexa keywords or empty value.
                 if(! (['', 'alexa','echo','computer'].includes(objHistory['summary']) )) {
                     // ignore "sprich mir nach"
                     if (!(objHistory['summary'].includes('sprich mir nach '))) {
                         log('[Alexa-Log-Script] ##{"message":"' + formatAlexaSummary(objHistory['summary']) + '", "from":"' + objHistory['name'] + '"}##');
          * Formats the Alexa summary text accordingly.
          * @param {string} summaryText   The summary text
          * @return {string} the formatted summary
          function formatAlexaSummary(summaryText) {
             if (g_capFirstLetters) summaryText = summaryText.replace(/(^|\s)\S/g, l => l.toUpperCase()); // Capitalize if set. https://stackoverflow.com/questions/2332811/
             return summaryText;
          • Mic
            @Iccube
            /instance system\.adapter\.[^\s]* Terminated (NO_ERROR): Without reason/ würde eine Logzeile wie diese hier erwarten:
            host.ctioBroker instance system.adapter.dwd.0 Terminated (NO_ERROR): Without reason
            Bei dir ist die Logausgabe aber anders.
            Mache einfach mal das hier in der Global Blacklist: Terminated (NO_ERROR): Without reason
            Das brauchst du wohl bei anderen Adaptern auch nicht, daher generisch.
            Iccube 1 Reply Last reply Reply Quote 0
            • Mic
              Mic Developer @BBTown last edited by
              @BBTown sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
              @Mic
              * Change Log:
              * Script Settings
              main();
              function main() {
                 return summaryText;
              1. Ist das von dir gepostete Script identisch mit https://github.com/Mic-M/ioBroker.logparser/blob/master/accessories/alexa-history.js ?
              2. Sichergestellt, dass das Script läuft?
              3. Was steht genau in "Whitelist UND"? Nur das hier: [Alexa-Log-Script] - ohne Leerzeichen?
              4. Adapterversion ist frisch von Github installiert?
              5. Getestet mit neuem Alexa-Kommando, nachdem Script und Logparser-Adapter gestartet und ein paar Sekunden gewartet wurde?
              • BBTown
                BBTown @Mic last edited by BBTown
                @Mic
                Ich kann alles mit "Ja" beantworten, daher meine Verwunderung
                Es passieren ja nicht wirklich komplizierte Dinge.
                Das Script ist auch relativ simple und klar
                • Iccube
                  @Mic okay hat funktioniert danke dir
                  wie kann ich den solche einträge entfernen :
                  2020-04-27 20:10:00.667 - info: dwd.0 (2072) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.2, js-controller: 3.0.19
                  die kommen ja von mehreren Adaptern
                  würde das so gehen wenn ich das nur eingebe:
                  starting. Version
                  • Mic
                    @BBTown
                    Prüfe mal, was im Logfile selbst ausgegeben wird, wenn du einen Befehl an Alexa absetzt. Da sollte dann vom JavaScript was kommen wie hier: https://github.com/Mic-M/ioBroker.logparser/blob/master/docs/de/logparser.md#beispiel
                    • BBTown
                      @Mic
                      Dann kommt dies hier
                      javascript.0	2020-04-27 20:20:43.248	info	(1370) script.js.common.logparserAlexa: [Alexa-Log-Script] ##{"message":"Licht An", "from":"echoDot (Büro)"}##
                      • Mic
                        @Iccube sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                        starting. Version
                        Du darfst gerne selbst testen 😉
                        Das würde gehen, natürlich kannst du auch komplexer aber exakter abfragen, hier ist https://regex101.com/ hilfreich.
                        Alternativ empfehle ich, bei Adaptern, die rund laufen, das Log-Level in der Adapter-Übersicht von info auf warn zu setzen, dann wird das erst gar nicht ausgegeben.
                        BBTown Iccube 2 Replies Last reply Reply Quote 0
                        • BBTown
                          @Mic
                          Du darfst mich gerne schlagen 😎
                          Aufgrund ddeiner Frage habe ich das Script erneut heruntergeladen und per copy`n paste eingefügt und nun macht es was er soll .... frage mich nicht was bei der ersten Kopie unterwegs verloren gegangen sein kann/soll.
                          Es läuft nun alles wie gewünscht, sorry !
                          .... mal wieder Fehler 40?!?!
                          • Iccube
                            @Mic okay werde ich mal testen danke dir nochmal
                            • Mic
                              Kein Thema, Hauptsache es läuft und ist kein Fehler im Adapter ☺
                                Manu.Oe last edited by
                                gibt es ne Möglichkeit einen Filter zu erstellen der nur Logs vom Javascript Adapter anzeigt?
                                Ich schreibe in meinen ganzen Blocklys Statusmeldungen raus und suche eine Möglichekit, nur diese angezeigt zu bekommen.
                                Danke und Grüße
                                liv-in-sky Mic 2 Replies Last reply Reply Quote 0
                                  liv-in-sky @Manu.Oe last edited by liv-in-sky
                                  @Manu-Oe
                                  hier stand blödsinn
                                  • Negalein
                                    Negalein Global Moderator @liv-in-sky last edited by
                                    @liv-in-sky sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                                    da git es einen anderen adapter dafür
                                    Frage von @Manu-Oe passt hier gut rein.
                                    Hier im Thread geht es eh um Regex und Filterregeln zu @Mic seinem Log Parser Adapter. 😊
                                      liv-in-sky @Negalein last edited by
                                      @Negalein oh sorry- danke für den hinweis
                                      • Negalein
                                        oh sorry
                                        kein Problem 🙂
                                        • Mic
                                          Mic Developer @Manu.Oe last edited by
                                          @Manu-Oe sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                                          Danke und Grüße
                                          Z.B. so:
                                          Whitelist UND: /javascript\.[0-9]/
                                            Super Danke, werd ich gleich ausprobieren 👍
                                            kann man des mit allen Adaptern so machen "/Adaptername.[0-9]/" ?
                                            Das 0-9 steht dann vermutlich für die Instanzen
                                            adapter filter logparser parser regex
                                            4971
