    4. Test Adapter Worx v0.4.x
      skokarl last edited by
      ich bekomme hier aktuell Fehlermeldungen.
      IOBroker ist auf alle neuen Versionen aktualisiert.
        steimi last edited by
        gleiche Fehlermeldungen bei mir...
        • lobomau
          lobomau last edited by
          geht bei mir auch nicht, aber anderer Fehler:
          host.ioBrokerCT	2020-04-26 11:46:15.413	info	Restart adapter system.adapter.worx.0 because enabled
          host.ioBrokerCT	2020-04-26 11:46:15.412	info	instance system.adapter.worx.0 terminated with code 0 (NO_ERROR)
          worx.0	2020-04-26 11:46:14.825	info	(22295) Terminated (NO_ERROR): Without reason
          worx.0	2020-04-26 11:46:14.823	info	(22295) terminating
          worx.0	2020-04-26 11:46:14.803	info	(22295) cleaned everything up...
          worx.0	2020-04-26 11:46:14.802	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
          worx.0	2020-04-26 11:46:14.802	error	at endReadableNT (_stream_readable.js:1187:12)
          worx.0	2020-04-26 11:46:14.802	error	at IncomingMessage.emit (events.js:322:22)
          worx.0	2020-04-26 11:46:14.802	error	at Object.onceWrapper (events.js:416:28)
          worx.0	2020-04-26 11:46:14.802	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
          worx.0	2020-04-26 11:46:14.802	error	at Request.emit (events.js:310:20)
          worx.0	2020-04-26 11:46:14.802	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
          worx.0	2020-04-26 11:46:14.802	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          worx.0	2020-04-26 11:46:14.802	error	at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/plumbing.js:46:31)
          worx.0	2020-04-26 11:46:14.802	error	at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/plumbing.js:104:33)
          worx.0	2020-04-26 11:46:14.802	error	at new StatusCodeError (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js:32:15)
          worx.0	2020-04-26 11:46:14.802	error	(22295) StatusCodeError: 422 - {"message":"Missing coordinates","code":"422.005"}
          worx.0	2020-04-26 11:46:14.800	error	(22295) uncaught exception: 422 - {"message":"Missing coordinates","code":"422.005"}
          worx.0	2020-04-26 11:46:08.393	info	(22295) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.worx, node: v12.16.2, js-controller: 3.0.18
          lobomau 1 Reply Last reply Reply Quote 0
            Letty last edited by
            Die Antwort vom Worx Kundenservice ist auch da:
            Hallo Armin,
            Es ist besser Smart Home nicht verwenden.
            Wenn Sie eine inoffizielle App, Software oder Suite nutzen, sollten Sie diese deinstallieren und vom Roboter trennen. Wir unterstützen nur die offizielle Worx-Landroid-App, die Sie im App Store/Play Store herunterladen können. Die meisten Apps von Drittanbietern können sich negativ auf die Servereinstellungen auswirken, sodass wir sie vorerst nicht unterstützen. Wir weisen darauf hin, dass einige dieser Apps von unseren Sicherheitssystemen als bösartig eingestuft werden könnten, was eine vorübergehende Sperrung des Kontos zur Folge hat.
            LG,
            Elena
            M cvidal 3 Replies Last reply Reply Quote 0
              mrniceguy @Letty last edited by
              @Letty
              Ja, die selbe eMail habe ich auch erhalten.
              • cvidal
                cvidal Forum Testing @Letty last edited by
                @Letty Ich warte immer noch auf eine Antwort, am Telefon kann mir da aber keiner helfen und per E-mail meldet sich keiner.
                Ich habe gestern mit Amazon Telefoniert und kann meinen Landroid zurück schicken und bekomme dann den vollen Preis erstattet obwohl der Lamdroid keine Garantie mehr hat.
                Ich habe aber auch das Problem das er meldet das es Probleme mit dem Begrenzungskabel gibt... hab es durchgemessen und kann Probleme ausschließen.
                Naja also jetzt habe ich mir die neue Version bestellt... Bin gespannt.
                • cvidal
                  @Letty @mrniceguy
                  Ist denn euer Konto auch gesperrt?
                  • lobomau
                    lobomau @cvidal last edited by lobomau
                    @cvidal bei mir ist nichts gesperrt und ich habe auch keine eMail erhalten.
                    Adapter habe ich aber jetzt ausgeschaltet, da er bei mir nicht mehr funktioniert.
                    • cvidal
                      Sollte der Adapter nicht erst einmal stillgelegt werden? Oder zumindest eine Warnung ausgesprochen werden? So ists momentan eher Kontraproduktiv.
                        Als mein Konto läuft ganz normal.
                        Der Adapter hat die letzten Tage auch normal funktioniert bei mir.
                        Jetzt läuft er gerade nicht werde es später aber noch einmal testen.
                        @cvidal Hast du noch den das Modell vor 2019? Oder gibts heuer wieder eine neue Version ?
                        cvidal 1 Reply Last reply Reply Quote 0
                          mrniceguy last edited by
                          MeisterTr hat auf Github eine neue Version 1.0.1 bereitgestellt.
                          Mit dieser werden die States nicht nacheinander sondern im Bündel abgerufen. Beim mir funktioniert es damit wieder, ohne das ich von Worx direkt geblockt werde.
                          • cvidal
                            @Letty sagte in Test Adapter Worx v0.4.x:
                            <Ja meiner ist von 2018, jetzt habe ich mir den 2019/20er bestellt.
                            • Meistertr
                              Meistertr Developer last edited by Meistertr
                              Ich weiß nicht was hier für ein irrglaube herrscht. Die states werden immer gebündelt abgerufen, wie schon seit beginn des Adapters. Der Adapter erzeugt keinen "unnötigen" Traffic sondern wartet nahezu immer auf den Server bis er was sendet.
                              Da der Zugang zum Worx server nicht offiziell ist, gibt es keine Doku darüber, sondern alles per try an error. Bis lang ging ich davon aus, dass der einen "State" namens Active angibt ob geblockt oder nicht, dass scheint nicht so zu sein und das habe ich nun geändert.
                              ICH KANN NUR EINDRINGLICH DAVON ABRATEN WORX BEZÜGLICH DES PROBLEMS ZU KONTAKTIEREN. Da es keine offizielle Schnittstelle ist und wenn sie sich gestört fühlen oder denken dass es dem ruf schadet das ganze einfach beenden.
                              Wenn der Adapter meldet geblockt und die App normal funktioniert ist alles ok, dann liegt es am Adapter. Da "Blocken" hier bedeutet, dasss der Mqtt Client für 24h abgeschaltet wird, das würde auch die app betreffen.
                              Der Adapter arbeitet genauso wie die app. zu beginn wird einmal die Config geholt und das wars, danach läuft alles von den Server.
                              Ich habe den Text im log mit dem Blocken reingenommen, da es zu missverständnissen kam, wenn jemand tatsächlich gebblockt war es immer wieder versucht hat und so aus der Schleife nicht rauskam. Scheinbar läuft dass nun in die andere Richtung...
                              Ich kann nur nochmal sagen, dass Lasst die finger vom Worx Support. Man ruft ja auch nicht den Internetanbieter an wenn der PC kaputt ist.. !! Wenn das beim Support eine größere Sache wird ist dass seitens Worx ein Klick und die Api ist dicht !!!
                              • Meistertr
                                ich habe den Adapter noch ncih tmit js3 getestet werde ich aber schnellstmöglich nachholen und die fehler beheben.
                                • Meistertr
                                  @cvidal deine Probleme scheinen nix mit dem Adapter zu tun zu haben. Der Adapter verhält sich passive. Wenn er nicht verbinden kann belässt er es einfach dabei.Wenn die Push nachrichten kommen, ist dein Konto auch nicht geblockt
                                  • Meistertr
                                    Und BITTE!! nur die Fehlermeldung hilft niemanden weiter bitte einen Debug Logauszug damit ich sehen kann wieso der Fehler entsteht!!
                                    • cvidal
                                      cvidal Forum Testing @Meistertr last edited by
                                      Ich hatte die App seit 2 Jahren am laufen, dieses Jahr geht es aber nicht mehr.
                                      Laufen da vom Adapter nicht zu viele anfragen sodass Worx diese Sperrt?
                                      Woher weiß Worx sonst das ioBroker etc. genutzt wird?
                                      S Meistertr 2 Replies Last reply Reply Quote 0
                                        skokarl @cvidal last edited by skokarl
                                        @cvidal
                                        ich versteh dein Problem nicht.
                                        Installier mal die APP neu, und wenn sie dann nicht geht, rufst Du Worx an und sagst Deine APP geht nicht.
                                        Das hat doch alles nix mit dem IOBroker oder dem Adapter zu tun.
                                        • Meistertr
                                          Meistertr Developer @cvidal last edited by
                                          @cvidal nein der Adapter macht eine Anfrage beim Start. Danach läuft alles vom Server. Genau wie die App. Sofern kein Script dies beeinflusst. Der einzige Fall wo der Adapter Störungen verursachen kann ist in einer bootloop die durch Fehlermeldungen verursacht werden könnte. Und den Adapter permanent neustarten lässt.
                                          • cvidal
                                            cvidal Forum Testing @skokarl last edited by
                                            @skokarl Hatte ich bereits im vorherigen Post geschrieben das ich Worx kontaktiert und die App mit neuer E-mail installiert habe... Was das mit dem Adapter zutun haben könnte ist ja meine Frage gewesen.
                                            @Meistertr Ah okay, das war mir nicht bewusst. Heute kommt mein neuer Landroid an. Mal sehen ob der läuft.
                                            1.0k
                                            landroid worx
                                            36
                                            198
                                            26232
