    4. js-controller 3.0/3.1 jetzt im Latest!
      e-s @Thomas Braun last edited by
      @Thomas-Braun
      ok, danke erstmal. den npm Fehler habe ich jetzt weg. Dafür habe ich einen Fehler im npm rebuild vom serialport, wofür auch immer der ist.
         V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
      /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3642:37: note:   candidate expects 3 arguments, 2 provided
      ../src/serialport.cpp:331:96: error: no matching function for call to âv8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)â
           results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
      In file included from /home/iobroker/.cache/node-gyp/14.0.0/include/node/node.h:67:0,
                       from ../../nan/nan.h:56,
                       from ../src/./serialport.h:6,
                       from ../src/serialport.cpp:1:
      /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3639:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)
      /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3639:37: note:   candidate expects 3 arguments, 2 provided
      /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3642:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)
      ../src/serialport.cpp:336:30: warning: âv8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) constâ is deprecated [-Wdeprecated-declarations]
         data->callback.Call(2, argv);
      In file included from ../src/./serialport.h:6:0,
      ../../nan/nan.h:1742:3: note: declared here
         Call(int argc, v8::Local<v8::Value> argv[]) const {
      ../src/serialport.cpp: In function âvoid EIO_AfterGetBaudRate(uv_work_t*)â:
      ../src/serialport.cpp:378:106: error: no matching function for call to âv8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)â
           results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
      ../src/serialport.cpp:383:30: warning: âv8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) constâ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function âvoid EIO_AfterDrain(uv_work_t*)â:
      ../src/serialport.cpp:424:30: warning: âv8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) constâ is deprecated [-Wdeprecated-declarations]
         data->callback.Call(1, argv);
      ../src/serialport.cpp: At global scope:
      ../src/serialport.cpp:460:17: error: variable or field âinitâ declared void
         void init(v8::Handle<v8::Object> target) {
      ../src/serialport.cpp:460:17: error: âHandleâ is not a member of âv8â
      ../src/serialport.cpp:460:34: error: expected primary-expression before â>â token
      ../src/serialport.cpp:460:36: error: âtargetâ was not declared in this scope
      ../src/serialport.cpp:460:36: note: suggested alternative: âtzsetâ
                                          tzset
      In file included from ../../nan/nan.h:56:0,
      ../src/serialport.cpp:485:25: error: âinitâ was not declared in this scope
       NODE_MODULE(serialport, init);
      /home/iobroker/.cache/node-gyp/14.0.0/include/node/node.h:731:36: note: in definition of macro âNODE_MODULE_Xâ
             (node::addon_register_func) (regfunc),                          \
      ../src/serialport.cpp:485:1: note: in expansion of macro âNODE_MODULEâ
      ../src/serialport.cpp:485:25: note: suggested alternative: âintâ
      serialport.target.mk:114: recipe for target 'Release/obj.target/serialport/src/serialport.o' failed
      make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
      make: Verzeichnis â/opt/iobroker/node_modules/serialport/buildâ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
      gyp ERR! System Linux 4.15.0-96-generic
      gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/serialport
      gyp ERR! node -v v14.0.0
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the serialport@6.2.2 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2020-04-27T21_15_55_218Z-debug.log
      apollon77 K 2 Replies Last reply Reply Quote 0
        apollon77 @e-s last edited by
        @e-s Da scheint irgendeiner Deiner Adapter noch serialpot 6 zu nutzen was mit Node 12 schon nicht mehr geescheit tut. Also hier wäre der Tipp mal die Adapter zu prüfen die Seriell arbeiten ob es Updates gibt
          Kueppert @e-s last edited by
          @e-s könnte zB der Zigbee-Adapter sein. Ich hab den auch drauf und auch WARN Meldungen gehabt beim Update von Node. Allerdings keine ERR-Meldungen.
            e-s @apollon77 last edited by
            @apollon77
            Einer von euch ist Schuld... 😊
            serialport nutzt keiner meiner Adapter, aber ich habe herausgefunden, das discovery das braucht.
            Da ich aber den Adapter gelöscht habe, wurden die Abhängigkeiten nicht mehr angepasst bzw überprüft.
            Also hätte beim löschen des Adapters auch die zusätzlichen deps gelöscht werden müssen, das wiederum ist auch blöd wenn mehrere Adapter die Abhängigkeit brauchen.
            Ein Teufelskreis, ich werde jetzt kurz discovery installieren und somit hoffen das serialport dann auf 8.0.7 angehoben wird, so wie es im git steht.
            Oder habt Ihr eine bessere Idee?
              A Former User @e-s last edited by
              @e-s @apollon77
              genau das Problem hab ich auch...
              Der Discovery wird ja nur nach dem Einrichten gebraucht, daher gelöscht.. 2 Jahre her.. 🤦
              • MiGoller
                MiGoller Developer last edited by
                Hallo zusammen.
                Vielen Dank für die gute Arbeit! Das möchte ich erst einmal loswerden.
                Beim Upgrade des js-controllers von 2.2.9 auf 3.0.19 auf meiner Prod-Umgebung habe ich allerdings folgende Meldung bei der Installation gesehen.
                $ sudo iobroker upgrade self
                Update js-controller from @2.2.9 to @3.0.19
                NPM version: 6.14.4
                npm install iobroker.js-controller@3.0.19 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                (node:14431) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
                    at _0x411ccb._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115051)
                    at processTicksAndRejections (internal/process/task_queues.js:97:5)
                (node:14431) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                (node:14431) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                Müsste da nicht wahrscheinlich callback statt allback stehen? Habe mir den Code noch nicht angeschaut.
                Viele Grüße, MiGoller
                MiGoller B 2 Replies Last reply Reply Quote 0
                  e-s @Guest last edited by e-s
                  @ilovegym @apollon77
                  Mach das bloß nicht manuell...
                  discovery installíeren hat nichts gebracht, also habe ich mit
                  npm i serialport@8.0.7
                  aktualisiert.
                  Dann kam aber der nächste Fehler, bluetooth -hci-socket wollte nicht, also auch den aktualiert obwohl ich den nicht benötige.
                  npm i @abandonware/bluetooth-hci-socket@0.5.3-5
                  jetzt kam ein Fehler von @serialport/bindings
                  npm i @serialport/bindings@@8.0.7
                  anschließend gab es keine Fehler mehr bei npm rebuild
                  • MiGoller
                    MiGoller Developer @MiGoller last edited by
                    @MiGoller sagte in js-controller 3.0 jetzt im Latest!:
                    Hallo zusammen.
                    NPM version: 6.14.4
                    Hallo zusammen, nachdem auch die Version 3.0.18 in Verbindung mit Redis kein lauffähiges System mehr hervorgebracht hat, habe ich einen "Rücksturz" auf 2.2.9 durchgeführt. Letzt läuft es erst einmal wieder.
                    Könnte da ein Zusammenhang mit meiner Redis-Konfiguration bestehen, die unter Version 2 des Controllers problemlos läuft?
                      blackeagle998 @MiGoller last edited by
                      Hallo zusammen.
                      NPM version: 6.14.4
                      Hallo, ich habe gerade exakt den gleichen Fehler, ebenfalls von Version 2.2.9 zu 3.0.19.
                      khg 1 Reply Last reply Reply Quote 0
                        Der controller 3.0.20 ist auf Github - der fixt das ... sorry ...
                        Sollte bald im Latest Repo sein, alternativ IM IOBROKER-VERZEICHNIS(!!) ein "npm install iobroker.js-controller@3.0.20" ausführen
                        Changelog:
                        3.0.20 (2020-04-28) Release Elena
                        • (Apollon77) make sure disabling instances while installation is running do not crash the controller (Sentry IOBROKER-JS-CONTROLLER-Z)
                        • (From Forum) prevent error on backup restore
                        • (Apollon77) Make sure error handing do not throw exception
                        • (Apollon77) Catch all errors when trying to store the File DB (Sentry IOBROKER-JS-CONTROLLER-14/15)
                        • (Apollon77) Make sure also edge cases on start adapter are handled correctly (Sentry IOBROKER-JS-CONTROLLER-12)
                        • (Apollon77) Use 3.3.4 of objects library to prevent an error from 3.3.3
                        ? sigi234 2 Replies Last reply Reply Quote 4
                        • khg
                          khg @blackeagle998 last edited by
                          update js-controller 3.0.18 --> 30.19 nicht möglich.
                          Node.js v12.16.2
                          NPM 6.14.4
                          Detail:
                          int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
                          In file included from ../src/epoll.cc:11:
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Localv8::Context) const’
                          V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/epoll.cc:247:47: error: no matching function for call to ‘v8::Value::Int32Value()’
                          int err = epoll->Remove(info[0]->Int32Value());
                          In file included from ../src/epoll.cc:12:
                          ../src/epoll.cc: At global scope:
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
                          NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
                          ../src/epoll.cc:381:1: note: in expansion of macro ‘NODE_MODULE’
                          NODE_MODULE(epoll, Epoll::Init)
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/node_object_wrap.h:85:78: required from here
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:10226:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void (
                          )(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                          reinterpret_cast<Callback>(callback), type);
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
                          ../../nan/nan_object_wrap.h:66:61: required from here
                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:10226:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void (
                          )(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                          make: *** [epoll.target.mk:111: Release/obj.target/epoll/src/epoll.o] Fehler 1
                          gyp ERR! stack Error: make failed with exit code: 2
                          gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                          gyp ERR! stack at ChildProcess.emit (events.js:310:20)
                          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                          gyp ERR! System Linux 5.4.28-rockchip
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
                          gyp ERR! node -v v12.16.2
                          gyp ERR! not ok
                          (node:19963) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
                          (node:19963) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                          (node:19963) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code
                          bleibt hier händen und Abbruch mit Ctrl-C.
                          iobroker start
                          iobroker status
                          (node:26663) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
                          (node:26663) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                          (node:26663) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                            sigi234 Forum Testing Most Active @khg last edited by
                            @khg
                            Bitte benutzt die Code Tags Funktion -> </>
                            Hier gehts zur Hilfe.
                              @e-s Hi, Danke, hat geholfen. Musste noch node-gyp drüberbügeln, dann war da auch Ruhe.
                              • khg
                                khg @sigi234 last edited by khg
                                @sigi234 sagte in js-controller 3.0 jetzt im Latest!:
                                ok, schaue ich mir an,
                                eben wurde der js-controller 3.0.20 erstellt und das Problem ist damit behoben.
                                  A Former User @apollon77 last edited by
                                  @apollon77
                                  Also, die Elena verträgt sich wohl ganz gut mit der Silvia, Tessa und Buster. Mit der Debbie schau ich die Tage dann noch.. 🙂
                                    sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
                                    @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                                    Diesmal geht es bei mir nicht.
                                    C:\Program Files\iobroker\Test>iobroker upgrade self
                                    Update js-controller from @3.0.19 to @3.0.20
                                    NPM version: 6.9.0
                                    npm install iobroker.js-controller@3.0.20 --loglevel error --unsafe-perm (System call)
                                    npm ERR! path C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller
                                    npm ERR! code EBUSY
                                    npm ERR! errno -4082
                                    npm ERR! syscall rename
                                    npm ERR! EBUSY: resource busy or locked, rename 'C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller' -> 'C:\Program Files\iobroker\Test\node_modules\.iobroker.js-controller.DELETE'
                                    npm ERR!     C:\Program Files\iobroker\Test\env\npm-cache\_logs\2020-04-28T11_49_52_485Z-debug.log
                                    host.Medion(Test) Cannot install iobroker.js-controller@3.0.20: 4294963214
                                    Wollen zu viele gleichzeitig updaten?
                                    • Diginix
                                      Diginix last edited by
                                      @apollon77 Seit 3.0.19 werden die Logs wieder gezippt rotiert. Mein Logrotate max 14 days hat das Update von Version 2 auf 3 überlebt aber warum das nicht-zippen nicht? Wie konnte man das in der iobroker.json abstellen?
                                      apollon77 Mauflo 2 Replies Last reply Reply Quote 0
                                        apollon77 @Diginix last edited by
                                        @Diginix Seit der 3.0.0 ist das wieder so - war eigentlich ein Fehler das es in der 2.2 doch nicht drin war. Ausschalten in der iobroker-data/iobroker.json siehe https://github.com/ioBroker/ioBroker.js-controller/blob/master/README.md#file-based-logging
                                          @apollon77
                                          Hattest du dir meine vorherigen posts durchgelesen, hätte iobroker die veralteten und ungenutzten deps aktualisieren oder löschen sollen, oder muss man das weiter per Hand machen?
                                          Oder sollte man wenn man doch häufig testet und löscht, den data Ordner in einer Neuinstallation restoren um sich von alter last zu trennen?
                                            cybertron last edited by cybertron
                                            Das Update auf 3.0.19 hat heute morgen zwar geklapt, alledings rannten der Master und auch alle Slaves danach in einer Art Dauer-Reboot-Schleife.
                                            In der Anzeige über htop starteten die einzelnen Adapter, waren aber danach direkt wieder verschwunden.
                                            Da der Master gar nicht mehr auf die Füsse kam, hab ich diesen über den Snapshot wieder zurück auf 3.0.14 geholt.
                                            Einen Slave habe ich über ein erneutes Update dann vorhin auf 3.0.20 gebracht.
                                            Einen weiteren über eine Neuinstallation erst auf 2.x.x und daraus auf 3.0.20.
                                            Jetzt wollte ich den Master und einen 3. Slave noch machen.
                                            Dabei bekomme ich jedoch folgende Meldung:
                                            root@mh-iobroker-00:/opt/iobroker# iobroker upgrade self
                                            Update js-controller from @3.0.14 to @3.0.20
                                            NPM version: 6.14.4
                                            npm install iobroker.js-controller@3.0.20 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                            readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
                                            readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
                                            npm ERR! Unexpected end of JSON input while parsing near '...0","@sentry/utils":"5'
                                            npm ERR!     /home/iobroker/.npm/_logs/2020-04-28T13_30_05_795Z-debug.log
                                            Starting node restart.js
                                            Eine komplette Neuinstallation beim Slave endet ebenfals fehlerhaft.
                                                Welcome to the ioBroker installer!
                                                Installer version: 2020-04-12
                                                Installing prerequisites (1/4)
                                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                            OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                                            Changing npm registry to https://registry.npmjs.org
                                            Installed gcc-c++
                                                Creating ioBroker user and directory (2/4)
                                            Created /etc/sudoers.d/iobroker
                                            Directory /opt/iobroker created
                                                Installing ioBroker (3/4)
                                            npm ERR! Unexpected end of JSON input while parsing near '...yIFwMzo/6PwmhXvvwYnEz'
                                            npm ERR!     /root/.npm/_logs/2020-04-28T13_17_27_855Z-debug.log
                                                Finalizing installation (4/4)
                                            Enabling autostart...
                                            Autostart enabled!
                                            Fixing directory permissions...
                                                ioBroker was installed successfully
                                                Open http://192.168.30.242:8081 in a browser and start configuring!
                                            You need to re-login before doing anything else on the console!
                                            js-controller
                                            127
                                            1340
                                            431925
