    4. Zigbee Adapter und Conbee Unterstützung
    • Plasmachef
      Plasmachef last edited by
      Hallo!
      Bin hier grad am Testen und versuche meinen Raspi Pi 4 mit Raspbee II und dem Danalock zusammen zubringen.
      • Raspbee II eingesteckt und die raspi-config umgestellt
      • Zigbee über Katze geladen, Instanz angelegt und den Adapter ausgewählt
      --> Instanz grün 🙂
      Instanz und Danalock V3 auf pairing ... jetzt kommts:
      2020-04-28 17:50:04.559 - info: zigbee.0 (14579) Starting interview of '0x000b57fffe46ebec'
      2020-04-28 17:50:16.207 - info: zigbee.0 (14579) Successfully interviewed '0x000b57fffe46ebec', device has succesfully been paired
      2020-04-28 17:50:16.207 - info: zigbee.0 (14579) Device '0x000b57fffe46ebec' is supported, identified as: Danalock BT/ZB smartlock (V3-BTZB)
      2020-04-28 17:50:16.209 - info: zigbee.0 (14579) Configuring 0x000b57fffe46ebec V3-BTZB
      2020-04-28 17:50:18.218 - error: zigbee.0 (14579) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 1 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
      at Endpoint. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:326:23)
      at Generator.next ()
      at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:5:58))
      2020-04-28 17:50:43.201 - info: zigbee.0 (14579) Zigbee: stop joining
      2020-04-28 17:50:50.582 - info: zigbee.0 (14579) Configuring 0x000b57fffe46ebec V3-BTZB
      2020-04-28 17:50:53.099 - error: zigbee.0 (14579) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 2 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
      Es werde zwar ein paar Objekte angelegt und er erkennt auch locked und unlocked, aber das wars.
      Bitte um Hilfe
      Grüße Plasma
      Glasfaser 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @Plasmachef last edited by
        @Plasmachef sagte in Zigbee Adapter und Conbee Unterstützung:
        mit Raspbee II
        Hier im Thread geht es um Zigbee Adapter und Conbee Unterstützung
        haselchen Plasmachef 3 Replies Last reply Reply Quote 1
        • haselchen
          haselchen Most Active @Glasfaser last edited by
          @Glasfaser , die Docker-Conbee-Polizei 😬
          • Glasfaser
            Glasfaser @Plasmachef last edited by Glasfaser
            @Plasmachef
            Hier ein Thread zb. Link Text
            und gebe auch dein Zigbee Adapter Version an .
            • Plasmachef
              Plasmachef @Glasfaser last edited by
              @Glasfaser sorry, dachte, da der Adapter beides kann bin ich hier auch richtig...
              "ioBroker adapter for Zigbee devices via TI cc2531/cc2530/cc26x2r/cc2538 and deCONZ ConBee/RaspBee"
              • Plasmachef
                @Glasfaser... so... habe für Samstag das Teil bestellt... sollte der Fehler wieder auftreten, was ich vermute, dann bin ich wieder da 😊
                Plasmachef 1 Reply Last reply Reply Quote 0
                • c_hoch_b
                  c_hoch_b @justr last edited by
                  @justr gut zu Lesen. Der Umzug von DeConz zum Zigbee wird mein UrlaubsProjekt 🙂
                  Ich habe ja die Hoffnung, dass die mit dem Stick verbundenen Geräte automatisch vom Zigbee-Adapter erkannt werden...?
                  Wenn nicht, wird das viel Arbeit.
                  Naja, für uns SmartHome-Nerds liegt die Frusttolleranz ja höher 😉 - nur nicht bei meiner besseren hälfte 🙂
                  justr 1 Reply Last reply Reply Quote 0
                  • justr
                    justr @c_hoch_b last edited by
                    @c_hoch_b Viel Erfolg! Ich musste die Devices leider neu anlernen. Evtl. hatte ich aber zu viel rumprobiert und dabei die Config verloren. Allerdings verliere ich alle paar Tage (einmal beim Einrichten und dann noch einmal in den letzten 10 Tagen) die Verbindung zum Conbee ohne Info-, Warn- oder Fehlermeldung. Auch die Instanz bleibt grün. Nach einem Restart der Instanz läuft aber alles wieder. Wenn es weiterhin passiert, werde ich mir wohl ein kleines Restart-Skript schreiben, welches triggert, wenn einer der Timestamps für die "link_quality" der Devices seit mehr als einer Stunde nicht mehr aktualisiert wurde. Wenn es aber immer erst nach mehreren Tagen passiert, reicht auch ein Auto-Restart jede Nacht. Werde es weiter beobachten...
                    c_hoch_b 1 Reply Last reply Reply Quote 1
                    • c_hoch_b
                      @justr danke für die Info und Hinweis! Dann verzweifle ich nicht gleich :).
                      Und es ist ja noch Beta, vlt. wird das Problem ja noch behoben...
                      • Schuko80
                        Schuko80 @arteck last edited by
                        @arteck sagte in Zigbee Adapter und Conbee Unterstützung:
                        @Schuko80 mit den schnippseln kann ich nix anfagen
                        stell mal bitte ordentliches LOG rein
                        vor allem was wann sich verabschiedet wenn du es nochvolziehen kannst
                        Da verabschiedet sich gar nichts, es läuft gar nicht erst:
                        • Conbee wird erkannt
                        • scannen nach Devices -> OK
                        • Device wird richtig erkannt -> zu 90% OK, sonst noch mal löschen und neu pairen -> OK
                          -Status in Objekte -> availabel = true - alles andere ist leer
                        • Steuern einer Ikea Lampe geht, wenn ich state auf true setze.
                        Kachel in Zigbee zeigt keine Verbindung
                        Log wie folgt:
                        zigbee.0	2020-04-29 20:00:56.192	debug	(2343) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 20:00:56.191	debug	(2343) getBinding result: []
                        zigbee.0	2020-04-29 20:00:55.203	debug	(2343) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 20:00:55.202	debug	(2343) getDevices result: [{"type":"device","common":{"name":"TRADFRI bulb E27 WS clear 950lm","type":"TRADFRI bulb E27 WS clear 950lm","icon":"img/ikea_bulb_E27.png"},"native":{"id":"000b57fffe2289d7
                        zigbee.0	2020-04-29 20:00:55.196	debug	(2343) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 20:00:55.195	debug	(2343) getBinding result: []
                        zigbee.0	2020-04-29 20:00:54.766	debug	(2343) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 20:00:54.766	debug	(2343) getDevices result: [{"type":"device","common":{"name":"TRADFRI bulb E27 WS clear 950lm","type":"TRADFRI bulb E27 WS clear 950lm","icon":"img/ikea_bulb_E27.png"},"native":{"id":"000b57fffe2289d7
                        zigbee.0	2020-04-29 20:00:54.655	debug	(2343) new device 0x000b57fffe2289d7 42472 TRADFRI bulb E27 WS clear 950lm
                        zigbee.0	2020-04-29 20:00:54.650	debug	(2343) New device event: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"devic
                        zigbee.0	2020-04-29 20:00:54.648	info	(2343) Device '0x000b57fffe2289d7' is supported, identified as: IKEA TRADFRI LED bulb E26/E27 950 lumen, dimmable, white spectrum, clear (LED1546G12)
                        zigbee.0	2020-04-29 20:00:54.648	info	(2343) Successfully interviewed '0x000b57fffe2289d7', device has succesfully been paired
                        zigbee.0	2020-04-29 20:00:54.647	debug	(2343) handleDeviceInterview. {"status":"successful","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID"
                        zigbee.0	2020-04-29 20:00:54.485	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:54.484	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"swBuildId":"2.3.007"}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:54.483	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:54.342	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:54.341	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20190520"}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:54.339	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:54.183	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:54.182	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"hwVersion":1}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:54.179	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:54.038	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:54.037	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"stackVersion":98}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:54.035	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:53.877	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:53.877	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"appVersion":33}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:53.875	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:53.735	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:53.734	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:53.731	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:53.589	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:53.588	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"powerSource":1}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:53.587	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:53.430	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:53.429	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"IKEA of Sweden"}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:53.427	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:53.301	debug	(2343) Wrong device 000b57fffe2289d7 null
                        zigbee.0	2020-04-29 20:00:53.294	debug	(2343) Publish available for 0x000b57fffe2289d7 = true
                        zigbee.0	2020-04-29 20:00:53.291	debug	(2343) Type readResponse device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-04-29 20:00:53.289	debug	(2343) Received Zigbee message from '0x000b57fffe2289d7', type 'readResponse', cluster 'genBasic', data '{"modelId":"TRADFRI bulb E27 WS clear 950lm"}' from endpoint 1 with groupID null
                        zigbee.0	2020-04-29 20:00:53.285	debug	(2343) handleMessage. {"type":"readResponse","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-04-29 20:00:27.341	debug	(2343) User stateChange zigbee.0.info.pairingMode {"val":false,"ack":false,"ts":1588183227336,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1588182011624}
                        zigbee.0	2020-04-29 20:00:27.335	info	(2343) Zigbee: stop joining
                        zigbee.0	2020-04-29 20:00:10.650	debug	(2343) Failed to get map: "TypeError: Cannot read property 'stack' of undefined\n at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:536:115)"
                        zigbee.0	2020-04-29 19:59:51.834	info	(2343) Starting interview of '0x000b57fffe2289d7'
                        zigbee.0	2020-04-29 19:59:51.831	debug	(2343) handleDeviceInterview. {"status":"started","device":{"ID":3,"_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_endpoints":[],"_interviewCompleted":false,"_interviewing":false,"meta":{},
                        zigbee.0	2020-04-29 19:59:51.830	debug	(2343) handleDeviceJoined. {"device":{"ID":3,"_ieeeAddr":"0x000b57fffe2289d7","_networkAddress":42472,"_endpoints":[],"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":null}}
                        zigbee.0	2020-04-29 19:59:25.996	debug	(2343) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
                        zigbee.0	2020-04-29 19:59:25.996	info	(2343) Zigbee: allowing new devices to join.
                        zigbee.0	2020-04-29 19:59:10.534	debug	(2343) LQI succeeded for 'Coordinator'
                        zigbee.0	2020-04-29 19:59:09.477	debug	(2343) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:59:09.476	debug	(2343) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/ttyS
                        zigbee.0	2020-04-29 19:59:09.455	debug	(2343) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:59:09.454	debug	(2343) getBinding result: []
                        zigbee.0	2020-04-29 19:59:09.330	debug	(2343) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:59:09.330	debug	(2343) getDevices result: [{"_id":"0x00212effff00b043","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff00b043","_networkA
                        zigbee.0	2020-04-29 19:59:09.285	debug	(2343) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:59:09.285	debug	(2343) getGroups result: {}
                        zigbee.0	2020-04-29 19:59:09.280	debug	(2343) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:59:01.750	debug	(2343) User stateChange zigbee.0.info.pairingMode {"val":false,"ack":false,"ts":1588183141743,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1588182011624}
                        zigbee.0	2020-04-29 19:59:01.742	info	(2343) Zigbee: stop joining
                        zigbee.0	2020-04-29 19:58:59.628	debug	(2343) Failed to get map: "TypeError: Cannot read property 'stack' of undefined\n at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:536:115)"
                        zigbee.0	2020-04-29 19:58:00.435	debug	(2343) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
                        zigbee.0	2020-04-29 19:58:00.433	info	(2343) Zigbee: allowing new devices to join.
                        zigbee.0	2020-04-29 19:57:59.379	debug	(2343) LQI succeeded for 'Coordinator'
                        zigbee.0	2020-04-29 19:57:58.353	debug	(2343) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:57:58.352	debug	(2343) getBinding result: []
                        zigbee.0	2020-04-29 19:57:58.301	debug	(2343) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:57:58.300	debug	(2343) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/ttyS
                        zigbee.0	2020-04-29 19:57:58.184	debug	(2343) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:57:58.183	debug	(2343) getDevices result: [{"_id":"0x00212effff00b043","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff00b043","_networkA
                        zigbee.0	2020-04-29 19:57:58.130	debug	(2343) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:57:58.130	debug	(2343) getGroups result: {}
                        zigbee.0	2020-04-29 19:57:58.120	debug	(2343) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-04-29 19:57:41.990	info	(2343) Zigbee started
                          MartinMuc @MartinMuc last edited by
                          @MartinMuc said in Zigbee Adapter und Conbee Unterstützung:
                          Meine Hue Lampen funktionieren einwandfrei mit dem ConbeeII, ich habe allerdings Probleme mit den HUE Bewegungsmeldern und Schaltern.
                          Beim Bewegungsmelder bekomme ich beim anlernen folgenden Fehler, das hat zur folge das er zwar angezegit wird, aber ich keine Daten empfange. Selbst PRoblem besteht bei dem Dimmerschalter.
                          Hat jemand eine Idee was hier krumm sein könnte ? Version ist die 1.1.0.0
                          Martin
                          zigbee.0	2020-04-17 13:54:02.203	error	at Object.delayAction [as action] (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:360:69))
                          zigbee.0	2020-04-17 13:54:02.203	error	(1525) Failed to do action 0x0017880110486638 RWL021, attempt 2 (TypeError: Cannot read property 'stack' of undefined
                          zigbee.0	2020-04-17 13:54:01.203	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65))
                          zigbee.0	2020-04-17 13:54:01.203	error	at Generator.throw (<anonymous>)
                          zigbee.0	2020-04-17 13:54:01.203	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:244:23)
                          zigbee.0	2020-04-17 13:54:01.203	error	(1525) Failed to configure 0x0017880110486638 RWL021, attempt NaN (Error: Bind 0x0017880110486638/1 genLevelCtrl from '0x00212effff054b00/1' failed (undefined)
                          zigbee.0	2020-04-17 13:53:01.239	info	(1525) Do action on 0x0017880110486638 RWL021
                          zigbee.0	2020-04-17 13:53:01.239	info	(1525) Do action succesfully 0x0017880110486638 RWL021
                          zigbee.0	2020-04-17 13:53:00.638	info	(1525) Do action on 0x0017880110486638 RWL021
                          zigbee.0	2020-04-17 13:53:00.637	info	(1525) Configuring 0x0017880110486638 RWL021
                          zigbee.0	2020-04-17 13:46:26.582	info	(1525) Zigbee: stop joining
                          zigbee.0	2020-04-17 13:45:59.447	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:5:58))
                          zigbee.0	2020-04-17 13:45:59.447	error	at Generator.next (<anonymous>)
                          zigbee.0	2020-04-17 13:45:59.447	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:326:23)
                          zigbee.0	2020-04-17 13:45:59.447	error	(1525) Failed to configure 0x0017880102006d0c SML001, attempt 1 (Error: ConfigureReporting 0x0017880102006d0c/2 genPowerCfg([{"attribute":"batteryPercentageRemaining","minimumReportInterval":3600,"ma
                          zigbee.0	2020-04-17 13:45:56.849	info	(1525) Configuring 0x0017880102006d0c SML001
                          zigbee.0	2020-04-17 13:45:56.847	info	(1525) Device '0x0017880102006d0c' is supported, identified as: Philips Hue motion sensor (9290012607)
                          zigbee.0	2020-04-17 13:45:56.846	info	(1525) Successfully interviewed '0x0017880102006d0c', device has succesfully been paired
                          zigbee.0	2020-04-17 13:45:48.425	info	(1525) Starting interview of '0x0017880102006d0c'
                          Pairing time left: 27
                          Error: Failed to configure 0x0017880102006d0c SML001, attempt 1 (Error: ConfigureReporting 0x0017880102006d0c/2 genPowerCfg([{"attribute":"batteryPercentageRemaining","minimumReportInterval":3600,"maximumReportInterval":62000,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (TypeError: payload is not iterable)
                              at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:5:58)). undefined
                          Pairing time left: 28
                          Pairing time left: 29
                          New device joined '0x0017880102006d0c' model SML001
                          Interview successful: {"friendly_name":"0x0017880102006d0c","model":"9290012607","vendor":"Philips","description":"Hue motion sensor","supported":true}
                          Pairing time left: 30
                          Pairing time left: 31
                          Pairing time left: 32
                          Pairing time left: 33
                          Pairing time left: 34
                          Pairing time left: 35
                          Pairing time left: 36
                          Pairing time left: 37
                          Pairing time left: 38
                          Interview started: 0x0017880102006d0c
                          Niemand eine Idee ? Bastle heute noch ein bisschen wenn es dann nicht klappt muss ich die alte Huebridge ausgraben und die einbinden (was ich eigentlich vermeiden wollte)
                          • Plasmachef
                            Plasmachef @Plasmachef last edited by
                            Hallo die Zweite,
                            jetzt mit anderer Hardware und dem SELBEN Problem:
                            Bin hier grad am Testen und versuche meinen Raspi Pi 4 mit Conbee II und dem Danalock zusammen zubringen.
                            Conbee II eingesteckt
                            Zigbee über Katze geladen (Version 1.1.1), Instanz angelegt und die Hardware ausgewählt
                            --> Instanz grün 🙂
                            2020-05-02 15:17:59.402 - info: zigbee.0 (10320) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                            2020-05-02 15:17:59.437 - info: zigbee.0 (10320) Starting Zigbee...
                            2020-05-02 15:17:59.857 - info: zigbee.0 (10320) Coordinator firmware version: {"type":"ConBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                            2020-05-02 15:18:00.066 - info: zigbee.0 (10320) Unable to disable LED, unsupported function.
                            2020-05-02 15:18:00.067 - info: zigbee.0 (10320) --> transmitPower : normal
                            2020-05-02 15:18:00.069 - info: zigbee.0 (10320) Unable to set transmit power, unsupported function.
                            2020-05-02 15:18:00.071 - info: zigbee.0 (10320) Currently no devices.
                            2020-05-02 15:18:00.072 - info: zigbee.0 (10320) Zigbee started
                            2020-05-02 15:19:23.143 - info: zigbee.0 (10320) Zigbee: allowing new devices to join.
                            2020-05-02 15:19:31.554 - info: zigbee.0 (10320) Starting interview of '0x000b57fffe46ebec'
                            2020-05-02 15:19:43.707 - info: zigbee.0 (10320) Successfully interviewed '0x000b57fffe46ebec', device has succesfully been paired
                            2020-05-02 15:19:43.708 - info: zigbee.0 (10320) Device '0x000b57fffe46ebec' is supported, identified as: Danalock BT/ZB smartlock (V3-BTZB)
                            2020-05-02 15:19:43.711 - info: zigbee.0 (10320) Configuring 0x000b57fffe46ebec V3-BTZB
                            2020-05-02 15:19:45.724 - error: zigbee.0 (10320) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 1 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                            Leider kann ich mit dem Teil so nichts anfangen 😞
                            Einige Objekte wurden angelegt, aber mehr passiert leider nicht ... kann nichts schalten oder konfigurieren ... auch das Lock gibt kein Feedback zur Instanz
                            Könnt ihr mir bitte helfen?
                            Danke und Grüße Plasma
                            • Plasmachef
                              Plasmachef last edited by Plasmachef
                              so ... jetzt wirds spannend ... es gibt noch mehr zu berichten:
                              ich hab dann mal bisschen mit dem Teil "gespielt" und siehe da... der Befehl lock bzw. unlock wurde akzepiert und auch korrekt quittiert.
                              nach restart der instanz bekam ich dann noch ein weiteres objekt dazu: available
                              die anderen objekte waren tot ... und auch available hat nicht wirklich sich verändert.
                              ich hatte mal einen verbindungsabbruch simuliert in dem in die batterien rausnahm ... seither ging gar nichts mehr.
                              • konnte das gerät nicht löschen
                              • pairing zählte nur noch von 5 runter statt von 60
                              • instanz löschen und neu aufsetzen half auch nichts...er merkte sich alle allen daten 😞
                                -neustart von iobroker brachte auch nichts
                              ich lösche die instanz (zigbee.0) und legte eine neue an (zigbee.1)
                              hier gab es keine altlasten und das pairing klappte
                              man konnte wieder zugreifen auf das gerät ... sogar diesmal mit zugabe:
                              linkquality kam mit dazu und refreshte sich auch regelmäßig ... immer so zwischen 3 und 4 ... was das auch immer bedeutet.
                              nachfolgend alle logeinträge von instanz zigbee.1
                              2020-05-02 16:45:56.301 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 156 (156)
                              2020-05-02 16:45:56.302 - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
                              2020-05-02 16:46:54.917 - info: host.raspberrypi iobroker add zigbee 1 --host raspberrypi
                              2020-05-02 16:46:56.601 - info: host.raspberrypi iobroker host.raspberrypi create instance zigbee
                              2020-05-02 16:46:56.630 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.1.info.groups created
                              2020-05-02 16:46:56.659 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.1.info.pairingMessage created
                              2020-05-02 16:46:56.688 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.1.info.pairingCountdown created
                              2020-05-02 16:46:56.717 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.1.info.pairingMode created
                              2020-05-02 16:46:56.747 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.1.info.connection created
                              2020-05-02 16:46:56.777 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.1.info created
                              2020-05-02 16:46:56.811 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.sigKill created
                              2020-05-02 16:46:56.844 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.eventLoopLag created
                              2020-05-02 16:46:56.879 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.outputCount created
                              2020-05-02 16:46:56.911 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.inputCount created
                              2020-05-02 16:46:56.943 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.uptime created
                              2020-05-02 16:46:56.975 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.memRss created
                              2020-05-02 16:46:57.007 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.memHeapTotal created
                              2020-05-02 16:46:57.039 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.memHeapUsed created
                              2020-05-02 16:46:57.070 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.cputime created
                              2020-05-02 16:46:57.102 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.cpu created
                              2020-05-02 16:46:57.137 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.compactMode created
                              2020-05-02 16:46:57.179 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.connected created
                              2020-05-02 16:46:57.222 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1.alive created
                              2020-05-02 16:46:57.305 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.1 created
                              2020-05-02 16:46:58.314 - info: host.raspberrypi iobroker exit 0
                              2020-05-02 16:46:59.830 - info: host.raspberrypi instance system.adapter.zigbee.1 started with pid 9847
                              2020-05-02 16:47:03.617 - info: zigbee.1 (9847) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                              2020-05-02 16:47:03.649 - error: zigbee.1 (9847) Serial port not selected! Go to settings page.
                              2020-05-02 16:47:03.652 - info: zigbee.1 (9847) Starting Zigbee...
                              2020-05-02 16:47:03.962 - error: zigbee.1 (9847) Failed to start Zigbee
                              2020-05-02 16:47:03.963 - error: zigbee.1 (9847) Error: No path provided and failed to auto detect path
                              at Function. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/adapter.js:69:27)
                              at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/adapter.js:5:58)
                              at processTicksAndRejections (internal/process/task_queues.js:97:5)
                              2020-05-02 16:47:13.966 - info: zigbee.1 (9847) Try to reconnect. 1 attempts left
                              2020-05-02 16:47:13.967 - info: zigbee.1 (9847) Starting Zigbee...
                              2020-05-02 16:47:14.172 - error: zigbee.1 (9847) Failed to start Zigbee
                              2020-05-02 16:47:14.173 - error: zigbee.1 (9847) Error: No path provided and failed to auto detect path
                              2020-05-02 16:47:41.210 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 (force=false, process=true)
                              2020-05-02 16:47:41.228 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 send kill signal
                              2020-05-02 16:47:41.228 - info: zigbee.1 (9847) Got terminate signal TERMINATE_YOURSELF
                              2020-05-02 16:47:41.231 - info: zigbee.1 (9847) cleaned everything up...
                              2020-05-02 16:47:41.243 - error: zigbee.1 (9847) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                              at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55)
                              at Function.byIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:208:16)
                              at Controller.getDeviceByIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:235:31)
                              at ZigbeeController.getDevice (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:212:30)
                              at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:319:30)
                              at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:24)
                              at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:334:17))
                              2020-05-02 16:47:41.245 - info: zigbee.1 (9847) terminating
                              2020-05-02 16:47:41.247 - info: zigbee.1 (9847) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-05-02 16:47:41.775 - info: host.raspberrypi instance system.adapter.zigbee.1 terminated with code 156 (156)
                              2020-05-02 16:47:43.812 - info: host.raspberrypi instance system.adapter.zigbee.1 started with pid 11027
                              2020-05-02 16:47:46.082 - info: zigbee.1 (11027) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                              2020-05-02 16:47:46.150 - error: zigbee.1 (11027) Serial port not selected! Go to settings page.
                              2020-05-02 16:47:46.155 - info: zigbee.1 (11027) Starting Zigbee...
                              2020-05-02 16:47:46.609 - info: zigbee.1 (11027) Coordinator firmware version: {"type":"ConBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                              2020-05-02 16:47:53.137 - info: zigbee.1 (11027) Unable to disable LED, unsupported function.
                              2020-05-02 16:47:53.139 - info: zigbee.1 (11027) --> transmitPower : normal
                              2020-05-02 16:47:53.141 - info: zigbee.1 (11027) Unable to set transmit power, unsupported function.
                              2020-05-02 16:47:53.144 - info: zigbee.1 (11027) Currently no devices.
                              2020-05-02 16:47:53.145 - info: zigbee.1 (11027) Zigbee started
                              2020-05-02 16:48:41.400 - info: zigbee.1 (11027) Zigbee: allowing new devices to join.
                              2020-05-02 16:48:54.061 - info: zigbee.1 (11027) Starting interview of '0x000b57fffe46ebec'
                              2020-05-02 16:49:05.697 - info: zigbee.1 (11027) Successfully interviewed '0x000b57fffe46ebec', device has succesfully been paired
                              2020-05-02 16:49:05.699 - info: zigbee.1 (11027) Device '0x000b57fffe46ebec' is supported, identified as: Danalock BT/ZB smartlock (V3-BTZB)
                              2020-05-02 16:49:05.703 - info: zigbee.1 (11027) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:49:07.709 - error: zigbee.1 (11027) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 1 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:49:25.572 - info: zigbee.1 (11027) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:49:27.590 - error: zigbee.1 (11027) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 2 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:49:28.590 - info: zigbee.1 (11027) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:49:30.607 - error: zigbee.1 (11027) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 3 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:49:31.618 - info: zigbee.1 (11027) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:49:33.630 - error: zigbee.1 (11027) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 4 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:49:34.631 - info: zigbee.1 (11027) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:49:36.649 - error: zigbee.1 (11027) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 5 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:49:43.076 - info: zigbee.1 (11027) Zigbee: stop joining
                              2020-05-02 16:52:52.952 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 (force=false, process=true)
                              2020-05-02 16:52:52.964 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 send kill signal
                              2020-05-02 16:52:52.965 - info: zigbee.1 (11027) Got terminate signal TERMINATE_YOURSELF
                              2020-05-02 16:52:52.967 - info: zigbee.1 (11027) cleaned everything up...
                              2020-05-02 16:52:52.970 - info: zigbee.1 (11027) Zigbee: disabling joining new devices.
                              2020-05-02 16:52:53.470 - info: zigbee.1 (11027) terminating
                              2020-05-02 16:52:53.471 - info: zigbee.1 (11027) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-05-02 16:52:53.970 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 killing pid 11027
                              2020-05-02 16:52:54.028 - info: host.raspberrypi instance system.adapter.zigbee.1 terminated with code 156 (156)
                              2020-05-02 16:52:55.524 - info: host.raspberrypi instance system.adapter.zigbee.1 started with pid 18536
                              2020-05-02 16:52:57.823 - info: zigbee.1 (18536) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                              2020-05-02 16:52:57.869 - error: zigbee.1 (18536) Serial port not selected! Go to settings page.
                              2020-05-02 16:52:57.873 - info: zigbee.1 (18536) Starting Zigbee...
                              2020-05-02 16:52:58.322 - info: zigbee.1 (18536) Coordinator firmware version: {"type":"ConBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                              2020-05-02 16:52:58.523 - info: zigbee.1 (18536) Unable to disable LED, unsupported function.
                              2020-05-02 16:52:58.524 - info: zigbee.1 (18536) --> transmitPower : normal
                              2020-05-02 16:52:58.525 - info: zigbee.1 (18536) Unable to set transmit power, unsupported function.
                              2020-05-02 16:52:58.530 - info: zigbee.1 (18536) Currently 1 devices are joined:
                              2020-05-02 16:52:58.533 - info: zigbee.1 (18536) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:52:58.540 - info: zigbee.1 (18536) 0x000b57fffe46ebec (addr 61935): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                              2020-05-02 16:52:58.541 - info: zigbee.1 (18536) Zigbee started
                              2020-05-02 16:53:02.407 - error: zigbee.1 (18536) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 1 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:53:30.919 - info: zigbee.1 (18536) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:53:33.426 - error: zigbee.1 (18536) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 2 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:53:47.481 - info: zigbee.1 (18536) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:53:49.984 - error: zigbee.1 (18536) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 3 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:56:02.105 - info: zigbee.1 (18536) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:56:07.125 - error: zigbee.1 (18536) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 4 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              2020-05-02 16:56:53.605 - info: zigbee.1 (18536) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 16:56:57.118 - error: zigbee.1 (18536) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 5 (Error: ConfigureReporting 0x000b57fffe46ebec/1 closuresDoorLock([{"attribute":"lockState","minimumReportInterval":0,"maximumReportInterval":3600,"reportableChange":0}], {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":true}) failed (Error: Status 'INVALID_DATA_TYPE')
                              ... und wieder zeigt available nicht den richtigen zustand an
                              hab die batterie erneut rausgenommen ... wieder kein kontakt bzw kein lock / unlock möglich
                              neustart der instanz bring nichts
                              2020-05-02 17:28:36.558 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 (force=false, process=true)
                              2020-05-02 17:28:36.570 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 send kill signal
                              2020-05-02 17:28:36.571 - info: zigbee.1 (3673) Got terminate signal TERMINATE_YOURSELF
                              2020-05-02 17:28:36.573 - info: zigbee.1 (3673) cleaned everything up...
                              2020-05-02 17:28:36.576 - info: zigbee.1 (3673) Zigbee: disabling joining new devices.
                              2020-05-02 17:28:37.076 - info: zigbee.1 (3673) terminating
                              2020-05-02 17:28:37.078 - info: zigbee.1 (3673) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-05-02 17:28:37.576 - info: host.raspberrypi stopInstance system.adapter.zigbee.1 killing pid 3673
                              2020-05-02 17:28:37.629 - info: host.raspberrypi instance system.adapter.zigbee.1 terminated with code 156 (156)
                              2020-05-02 17:28:39.129 - info: host.raspberrypi instance system.adapter.zigbee.1 started with pid 5617
                              2020-05-02 17:28:41.476 - info: zigbee.1 (5617) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                              2020-05-02 17:28:41.510 - info: zigbee.1 (5617) Starting Zigbee...
                              2020-05-02 17:28:41.928 - info: zigbee.1 (5617) Coordinator firmware version: {"type":"ConBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                              2020-05-02 17:28:42.131 - info: zigbee.1 (5617) Unable to disable LED, unsupported function.
                              2020-05-02 17:28:42.132 - info: zigbee.1 (5617) --> transmitPower : normal
                              2020-05-02 17:28:42.134 - info: zigbee.1 (5617) Unable to set transmit power, unsupported function.
                              2020-05-02 17:28:42.142 - info: zigbee.1 (5617) Currently 1 devices are joined:
                              2020-05-02 17:28:42.148 - info: zigbee.1 (5617) Configuring 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 17:28:42.162 - info: zigbee.1 (5617) 0x000b57fffe46ebec (addr 61935): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                              2020-05-02 17:28:42.164 - info: zigbee.1 (5617) Zigbee started
                              2020-05-02 17:29:42.783 - error: zigbee.1 (5617) Failed to configure 0x000b57fffe46ebec V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe46ebec/1 closuresDoorLock from '0x00212effff05994f/1' failed (undefined)
                              at Endpoint. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:244:23)
                              at Generator.throw ()
                              das gerät scheint zwar kontakt zu haben, aber kommunikation ist nicht möglich
                              wieder lässt sich das Lock nicht aus der instanz löschen und beim pairing erscheint dann folgendes
                              2020-05-02 17:47:24.636 - info: zigbee.1 (5617) Do action on 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 17:47:34.795 - info: zigbee.1 (5617) Do action on 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 17:48:07.605 - info: zigbee.1 (5617) Do action on 0x000b57fffe46ebec V3-BTZB
                              2020-05-02 17:48:12.949 - info: zigbee.1 (5617) Zigbee: allowing new devices to join.
                              2020-05-02 17:48:24.967 - error: zigbee.1 (5617) Failed to do action 0x000b57fffe46ebec V3-BTZB, attempt 1 (TypeError: Cannot read property 'stack' of undefined
                              at Object.action (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:360:69))
                              2020-05-02 17:48:34.975 - error: zigbee.1 (5617) Failed to do action 0x000b57fffe46ebec V3-BTZB, attempt 1 (TypeError: Cannot read property 'stack' of undefined
                              2020-05-02 17:49:07.984 - error: zigbee.1 (5617) Failed to do action 0x000b57fffe46ebec V3-BTZB, attempt 1 (TypeError: Cannot read property 'stack' of undefined
                              2020-05-02 17:49:19.007 - info: zigbee.1 (5617) Zigbee: stop joining
                              ich hoffe sehr, dass meine ausführung helfen ... bin auch gerne bereit weitere test zu machen
                              danke schön
                              plasma 🙂
                                arteck Developer Most Active @Plasmachef last edited by
                                der Danalock bekommt "Failed to configure 0x000b57fffe46ebec V3-BTZB" .. ergo keine konfiguration vom Conbee...
                                ist ja hat beta ..
                                • Plasmachef
                                  Plasmachef @arteck last edited by Plasmachef
                                  ist ja hat beta ..
                                  danke für die schnelle Antwort 🙂
                                  was heißt das jetzt für mich?
                                  wie kann ich unterstützen / helfen? ... was braucht ihr /du?
                                  • Plasmachef
                                    im übrigen hab ich festgestellt, dass ich die "verbrannten instanzen" zurücksetzen kann, indem ich unter /iobroker-data die verzeichnisse zigbee_0 bzw zigbee_1 entferne, nachdem ich die instanzen gelöscht hatte.
                                      @Plasmachef ich garnix... da ich den Conbee und das Danalok nicht habe.. kann ich dir nix zu sagen.. sry
                                      • c_hoch_b
                                        c_hoch_b last edited by c_hoch_b
                                        Moin,
                                        ich habe jetzt angefangen meine Geräte zu Pairen und bei dem Hue-Dimmer-Switch bekomme ich diverse Fehlermeldungen (siehe Log) das einbinden wird aber abgeschlossen. Doch ohne funktion.
                                        Hab auch schon mehrfach Gelöscht und neu-Gepairt, leider ohne Erfolg.
                                        zigbee.0	2020-05-03 09:54:04.677	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65))
                                        zigbee.0	2020-05-03 09:54:04.677	error	at Generator.throw (<anonymous>)
                                        zigbee.0	2020-05-03 09:54:04.677	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:244:23)
                                        zigbee.0	2020-05-03 09:54:04.677	error	(1328) Failed to configure 0x001788010807ecb2 RWL021, attempt 1 (Error: Bind 0x001788010807ecb2/1 genOnOff from '0x00212effff048af7/1' failed
                                        c_hoch_b 1 Reply Last reply Reply Quote 0
                                        • c_hoch_b
                                          c_hoch_b @c_hoch_b last edited by
                                          @c_hoch_b
                                          beim Hue Motion Sensor sieht es auch nicht besser aus...
                                          zigbee.0	2020-05-03 10:03:01.460	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:5:58))
                                          zigbee.0	2020-05-03 10:03:01.460	error	at Generator.next (<anonymous>)
                                          zigbee.0	2020-05-03 10:03:01.460	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:326:23)
                                          zigbee.0	2020-05-03 10:03:01.460	error	(1328) Failed to configure 0x0017880106f46ae3 SML001, attempt 1 (Error: ConfigureReporting 0x0017880106f46ae3/2 genPowerCfg([{"attribute":"bat
                                          könnte es mit LightLink zusammenhängen??
                                          • Plasmachef
                                            Plasmachef @c_hoch_b last edited by
                                            @c_hoch_b Arteck hat mir bei
                                            so geantwortet:
                                            ist ja hat beta .."
                                            siehe paar Einträge drüber!
                                            31.7k
                                            79.8k
                                            conbee deconz ersatz zigbee
                                            48
                                            235
                                            44651
