    4. Gosund WB4 8W- OTA Flash - geht nicht
      smarthome2020 @pampulea last edited by smarthome2020
      @pampulea
      Musst mal bisschen googlen.
      Hier wird zB auch von Birnen berichtet, bei denen der Flashvorgang nicht klappte. Sind paar Lösungen oder Anregungen dabei.
      Tuya-Convert-Problems
      Du hast bei deinem RPi aber auch kein WLAN konfiguriert oder? Dein RPi ist über LAN angebunden?
      Hier meine Konsoleninfos von vor paar Tagen:
      pi@raspberrypi:~/tuya-convert $ sudo ./start_flash.sh
      tuya-convert v2.4.3
      Checking for network interface wlan0... Found.
      Checking UDP port 53... Occupied by dnsmasq with PID 542.
      Port 53 is needed to resolve DNS queries
      Do you wish to terminate dnsmasq? [y/N] y
      Attempting to stop dnsmasq.service
      Checking UDP port 67... Available.
      Checking TCP port 80... Available.
      Checking TCP port 443... Available.
      Checking UDP port 6666... Available.
      Checking UDP port 6667... Available.
      Checking TCP port 1883... Occupied by mosquitto with PID 527.
      Port 1883 is needed to run MQTT
      Do you wish to terminate mosquitto? [y/N] y
      Attempting to stop mosquitto.service
      Checking TCP port 8886... Available.
      sudo: ufw: command not found
        Starting AP in a screen.
        Starting web server in a screen
        Starting Mosquitto in a screen
        Starting PSK frontend in a screen
        Starting Tuya Discovery in a screen
      IMPORTANT
      1. Connect any other device (a smartphone or something) to the WIFI vtrust-flash
         This step is IMPORTANT otherwise the smartconfig may not work!
      2. Put your IoT device in autoconfig/smartconfig/pairing mode (LED will blink fast). This is usually done by pressing and holding the primary button of the device
         Make sure nothing else is plugged into your IoT device while attempting to flash.
      3. Press ENTER to continue
      Starting smart config pairing procedure
      Waiting for the device to install the intermediate firmware
      Put device in EZ config mode (blinking fast)
      Sending SSID                  vtrust-flash
      Sending wifiPassword
      Sending token                 00000000
      Sending secret                0101
      SmartConfig complete.
      Resending SmartConfig Packets
      IoT-device is online with ip 10.42.42.42
      Fetching firmware backup
        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                       Dload  Upload   Total   Spent    Left  Speed
      100 1024k  100 1024k    0     0  41760      0  0:00:25  0:00:25 --:--:-- 22918
      curl: Saved to filename 'firmware-b9ad8c.bin'
      Getting Info from IoT-device
      VTRUST-FLASH 1.5
      (c) VTRUST GMBH https://www.vtrust.de/35c3/
      READ FLASH: http://10.42.42.42/backup
      ChipID: b9ad8c
      MAC: C1:C1:C1:C1:C1
      BootVersion: 7
      BootMode: normal
      FlashMode: 1M DOUT @ 40MHz
      FlashChipId: 144051
      FlashChipRealSize: 1024K
      Active Userspace: user2 0x81000
      Ready to flash third party firmware!
      For your convenience, the following firmware images are already included in this repository:
        Tasmota v8.1.0.2 (wifiman)
        ESPurna 1.13.5 (base)
      You can also provide your own image by placing it in the /files directory
      Please ensure the firmware fits the device and includes the bootloader
      MAXIMUM SIZE IS 512KB
      Available options:
        0) return to stock
        1) flash espurna.bin
        2) flash tasmota.bin
        q) quit; do nothing
      Please select 0-2: 2
      Are you sure you want to flash tasmota.bin? This is the point of no return [y/N] y
      Attempting to flash tasmota.bin, this may take a few seconds...
      Flashed http://10.42.42.1/files/tasmota.bin successfully in 15172ms, rebooting...
      Look for a tasmota-xxxx SSID to which you can connect and configure
      Be sure to configure your device for proper function!
      HAVE FUN!
      Do you want to flash another device? [y/N]
      Hier wird in einem anderen Beitrag auch nochmal das Flashen thematisiert: OTA-Flash
      Wie du beim Vergleich siehst, packt er die Verbindung nicht zur Birne.
      Daher mach wirklich mal das 5GHz aus. Zur Not nochmal die SD-Karte wie in meiner Anleitung beschrieben neu aufsetzen.
      In der Anleitung, die den Birnen beigelegt ist, steht aber auch WB4 drin? Sollte auf dem Cover der Anleitung stehen.
        @smarthome2020
        Ich werde nochmal versuchen.
        Melde ich mich mit dem Neuigkeiten!
        Schöne Abend,
        Valentin
          wannabe last edited by wannabe
          Die Logdateien aus tuya-convert/scripts wären gut
            @smarthome2020
            habe den 5Ghz Band ausgeschaltet.
            Immer noch nicht.
            Ich installiere auf neue SD-Karte und versuche nochmal.
            Melde mich wenn ich so weit bin.
            Danke Euch,
            Valentin
              habe heute auf eine neue Installierte Openhab SD-Karte nochmal probiert.
              Und klappt immer noch nicht.
              Anbei die log´s die ich gefunden habe.
              Mit der Hoffnung das mir jemand hilft,
              Beste Grüße,
              Valentin
              smarthack-wifi.log
              smarthack-web.log
              smarthack-udp.log
              smarthack-psk.log
              smarthack-mqtt.log
                ID: 0242416f68626d6436614739314946523199b1fd7c4380200f439b4c79633f3398e5f6cb2a81b70545aaddaac993ef0d6a
                PSK: 458bd69c8dc4ae92f87b664842b70d8e955681aa3181df8a9e85ba6af9b100b3
                could not establish sslpsk socket: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac
                das sieht komisch aus oder anders gesagt, in meinen logs taucht sowas nicht auf. Aber einschätzen aus welcher Richtung der Fehler kommt, puh.
                Also die WB4 scheint laut internet flashbar
                Du hast berreits andere Geräte geflashed
                Netwerkanbindungen sind korrekt? LAN und WLAN
                Du siehst den AccessPoint von anderen Geräten aus?
                Versuch evtl. mal ein anderes Smartphone/Tablet
                  @wannabe
                  So weit kam ich aber auch.
                  Klar sehe ich die WLAN von Raspberry auch von andere Gerät. Iphone von meinen Frau.
                  Und ja habe bisher 20 Gosund Steckdose OTA gefläsht.
                  Nur die "verdammte" LED will nicht.
                  Nicht Slim sende ich dann zurück an Ama...
                  Andere Frage: Welche LED E27 kann ich OTA flashen?
                  Vielen Dank Euch für die Hilfe!
                  Beste Grüße,
                  Valentin
                    smarthome2020 last edited by
                    Kann einer mal Logs nach erfolgreichem Flash zum Vergleich dazu packen?
                    Da ich meine kleine SD Karte verloren habe, hab ich keine Logs
                      smarthome2020 @wannabe last edited by
                      @wannabe
                      Ich weiß auch nicht, was das ganze heißen soll. Schick sie zur Not zurück und sei nicht traurig:
                      Die einzelnen Farben der LEDs entsprechen auf maximaler Lichtstärke vielleicht 40% der Lichtstärke des Weiß.
                      Ist für mich nicht so wirklich überzeugend. Hab zwei der Birnen und würde mir so aktuell keine wieder kaufen.
                      Brauche nur die Dimmfunktion der Birne aktuell. Die soll es aber auch bei anderen geben.
                      • Fenian
                        Fenian last edited by
                        Tuya hat wohl mal wieder was an der Firmware geändert.
                        Hier gibt es ein paar Informationen dazu
                        Ich vermute mal, dass ist der Grund für das Problem von @pampulea
                          pampulea last edited by pampulea
                          @smarthome2020
                          nur mal klar zu stellen, ich brauche nicht umbedingt die Gosund LED´s. Habe nur bei Euch im Forum gelesen und dachte dass probiere ich auch mal.
                          Aber ich hätte trotzdem ein LED Birne probiert. Könnte mir jemand sagen was es noch mit Tasmota funktioniert? Ich meine mit E27 Fassung. Wo möglich von Amaz... Da kann ich aber wenn es nicht funktioniert wieder zurücksenden.
                          Vielen Dank schon im Voraus.
                          @Fenian
                          Danke dir habe aber die nasse voll. Sende ich mal zurück. Vor allem der @wannabe hat mit sehr geholfen mit seinen Erfahrung mit dem LED Birne.
                          Beste Güße aus Opelstadt,
                          Valentin
                          Fenian S 2 Replies Last reply Reply Quote 0
                          • Fenian
                            Fenian @pampulea last edited by
                            @pampulea sagte in Gosund WB4 8W- OTA Flash - geht nicht:
                            Das wollte ich dir mit dem Post auch nahe legen. 😉
                            Solange das Problem nicht gelöst ist, kannst du OTA mit Tuya-Convert vergessen.
                            Hier findest du Listen mit kompatiblen Geräten (tuya-convert)
                            Aber ich schätze mal auch bei diesen könnte es je nach Fertigungsdatum zu dem Problem kommen.
                              smarthome2020 @Fenian last edited by
                              @Fenian
                              Ja. Hatte mir vor kurzem nochmal 4 zusätzliche Gosund Steckdosen gekauft. Wollte das Löten auf so kleinem Raum vermeiden. Hatte Glück und hab nun 8 WLAN Steckdosen. Mehr brauche ich wohl vorerst nicht. Sonst baue ich Shellys ein.
                              Danke für den Link.
                                @pampulea
                                Ja, danke, dass du das alles hier weiterverfolgt hast. Andere können daraus nun lernen, dass die Birne nicht mehr geht über OTA.
                                Twoflash 20 1 Reply Last reply Reply Quote 0
                                • Twoflash 20
                                  Twoflash 20 @smarthome2020 last edited by
                                  @smarthome2020 Hey, Ich habe schon seit Monaten versucht meine Gosund WB4 Lampe zu flashen... Heißt es denn jetzt, dass es überhaupt nicht funktioniert?
                                  Mein einziges Ziel ist es halt nur mit der RPI 4 meine Lampen zu steuern. Gibt es denn dafür evtl. eine andere Möglichkeit?
                                  LG
                                    TorstenSmartHome @Twoflash 20 last edited by
                                    @Twoflash-20
                                    Ich habe es auch vergeblich versucht.....per OTA keine Chance.
                                    Also, kräftig an der Kugel gedreht und dann abgezogen.
                                    Kupfer-Aufkleber un der Mitte ab.....LED-Feld ist nur gesteckt.
                                    Mit FT232 wie überall beschrieben geflasht.
                                    (GPI00 auf GND bei Starten usw.)
                                    Aber ACHTUNG !!!!!!!!!
                                    RX auf RX und TX auf TX,
                                    normalerweise muss man die Kabel vertauschen....hier aber nicht.
                                    Dann gehts weiter wie in der Anleitung....viel Spass!!Gosund Platine.jpg Gosund Aufkleber.jpg
                                    Torsten
                                    lucasmenno M 2 Replies Last reply Reply Quote 0
                                    • lucasmenno
                                      lucasmenno @TorstenSmartHome last edited by
                                      @torstensmarthome eine meiner 4 Lampen habe ich grade gewalltsam geöffnet, wenn eine hin ist, dann sei es drum.
                                      Ich würde diese nun auch gern mit Tasmota um weitere Funktionen erweitern.
                                      Mein Chip im inneren sieht aber anders aus als deiner und das bringt mich nun schon ins schwanken wo ich den FT232 ansetzen kann.
                                      Ich bräuchte da einmal Hilfe und Unterstützung bitte 🙂
                                        Max Wedell @TorstenSmartHome last edited by
                                        @torstensmarthome
                                        Das Abziehen der Kugel ging relativ leicht, auch die LED-Platine ist abgezogen. Die Chip-Platine steckt allerdings noch im Restgehäuse und scheint mir nicht herausziehbar, ohne daß etwas zu Bruch geht. Fürs Anlöten der Kontakte steckt sie mir noch zu weit im Gehäuse, sodaß schwer ranzukommen ist. Wie hast Du das gelöst?
                                        wb4 gosund ota
                                        3796
