    4. js-controller 3.0/3.1 jetzt im Latest!
    • O
      oFbEQnpoLKKl6mbY5e13 last edited by oFbEQnpoLKKl6mbY5e13
      Schön, dass mit 3.0.20 der HMIP-Adapter wieder funktioniert. Totzdem schlägt der erste Start gegebenenfalls fehl oder er stürzt im Betrieb ab:
      hmip.0	2020-04-29 23:00:00.786	error	at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/receiver.js:138:22)
      hmip.0	2020-04-29 23:00:00.786	error	at Receiver.getData (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/receiver.js:352:17)
      hmip.0	2020-04-29 23:00:00.786	error	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/receiver.js:413:14)
      hmip.0	2020-04-29 23:00:00.786	error	at Receiver.emit (events.js:310:20)
      hmip.0	2020-04-29 23:00:00.786	error	at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/websocket.js:800:20)
      hmip.0	2020-04-29 23:00:00.786	error	at WebSocket.emit (events.js:310:20)
      hmip.0	2020-04-29 23:00:00.786	error	at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.hmip/api/hm-cloud-api.js:152:18)
      hmip.0	2020-04-29 23:00:00.786	error	at HmCloudAPI._parseEventdata (/opt/iobroker/node_modules/iobroker.hmip/api/hm-cloud-api.js:200:22)
      hmip.0	2020-04-29 23:00:00.786	error	at HmIpCloudAccesspointAdapter._eventRaised (/opt/iobroker/node_modules/iobroker.hmip/main.js:288:28)
      hmip.0	2020-04-29 23:00:00.786	error	at HmIpCloudAccesspointAdapter._updateHomeStates (/opt/iobroker/node_modules/iobroker.hmip/main.js:808:58)
      hmip.0	2020-04-29 23:00:00.786	error	(430) TypeError: Cannot read property 'id' of undefined
      hmip.0	2020-04-29 23:00:00.782	error	(430) uncaught exception: Cannot read property 'id' of undefined
        apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
        @oFbEQnpoLKKl6mbY5e13 Issue im GitHub beim Adapter ist angelegt?
        • O
          oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
          @apollon77
          Es gab ja eines, was wohl vorschnell geschlossen wurde. Aber abgesehen davon bringt das wohl eh nichts, denn Jogibear macht ja am Adapter nichts mehr, was kein Vorwurf ist.
            LJSven @foxriver76 last edited by LJSven
            @foxriver76 sagte in js-controller 3.0 jetzt im Latest!:
            Na du meinst doch oben dass dein Router neu gestartet wird. Währenddessen verlieren die Hosts logischerweise die Verbindung zueinander wenn sie über diesen verbunden sind.
            Der Host ist ja online, wenn ich auf Hosts gehe - trotzdem erscheint diese Meldung. Ebenso sind alle Adapter GRÜN, die auf den Host installiert sind. Die Meldung kommt über einige Stunden, da ist der Router längst neu gestartet.
              @oFbEQnpoLKKl6mbY5e13 Leg es bitte an bzw reopen wenn falsch geschlossen. Kriegen wir alles irgendwie hin
                crunchip Forum Testing Most Active last edited by crunchip
                ich habe gerade meinen proxmox Server neu gestartet und wollte das iobroker log im Anschluss betrachten, welche (Warn/Fehler-Meldungen) bei einem Neu-Start auftauchen, jedoch finde ich nun dieses vor
                bin im latest
                admin 4.1.1
                js-controller 3.0.20
                der Inhalt von diesem log besteht aus
                2020-05-01 00:00:52.952 - info: host.IoBroker iobroker.js-controller version 3.0.20 js-controller starting
                2020-05-01 00:00:52.962 - info: host.IoBroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                2020-05-01 00:00:52.964 - info: host.IoBroker hostname: IoBroker, node: v10.20.1
                2020-05-01 00:00:52.967 - info: host.IoBroker ip addresses: xx.xx.xx.xx fe:xx:xx:xx:xx:xx
                2020-05-01 00:00:57.407 - info: host.IoBroker connected to Objects and States
                2020-05-01 00:00:58.974 - info: host.IoBroker 110 instances found
                2020-05-01 00:00:59.138 - info: host.IoBroker starting 71 instances
                2020-05-01 00:00:59.315 - info: host.IoBroker instance system.adapter.admin.0 started with pid 905
                2020-05-01 00:01:04.320 - info: host.IoBroker instance system.adapter.alexa2.0 started with pid 916
                2020-05-01 00:01:07.278 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 923
                2020-05-01 00:01:07.525 - info: admin.0 (905) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v10.20.1, js-controller: 3.0.20
                2020-05-01 00:01:07.762 - info: admin.0 (905) requesting all states
                2020-05-01 00:01:07.766 - info: admin.0 (905) requesting all objects
                2020-05-01 00:01:14.281 - info: host.IoBroker instance system.adapter.ble.0 started with pid 943
                2020-05-01 00:01:15.172 - info: host.IoBroker instance system.adapter.broadlink2.0 started with pid 950
                2020-05-01 00:01:18.289 - info: alexa2.0 (916) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v10.20.1, js-controller: 3.0.20
                edit: gerade noch entdeckt
                  Bist Deiner Zeit voraus, hä 😉 Zeitzohne prüfen?
                    crunchip Forum Testing Most Active @apollon77 last edited by
                    @apollon77 was soll sich da geändert haben? war doch nur ein Neustart!?
                    root@IoBroker:~# date
                    Do 30. Apr 23:09:06 CEST 2020
                    root@IoBroker:~# cat /etc/timezone
                    Europe/Berlin
                      apollon77 @crunchip last edited by
                      @crunchip Interessant ... Ich hatte einen Bericht von einem befreundeten user das irgendwie die Zeiteinstellung des iobroker user ne andere war oder so ... bei dem ist das gestern passiert. Keine Idee warum
                        crunchip Forum Testing Most Active @apollon77 last edited by crunchip
                        @apollon77 auch wenn ich mich mit meinem user einlogge, stimmt die Zeit, oder meintest du etwas anderes?
                        Habe den Rechner auch nochmal neu gestartet, jedoch das gleiche wieder.
                        Das richtige log ist ja vorhanden, siehe screen von oben, da steht auch alles korrekt drin, nur das zusätzlich diese 2020 -05-01.gz aufgelistet ist
                        naja mal abwarten, was nach 0:00 Uhr passiert
                          Thomas Braun Most Active @crunchip last edited by
                          @crunchip
                          date -u
                            crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                            @Thomas-Braun kommt aufs gleiche raus wie oben
                            root@IoBroker:~# date -u
                            Do 30. Apr 21:49:35 UTC 2020
                            jedenfalls stimmt seit dem erneuten Neustart die Betriebszeit wieder
                            Thomas Braun wendy2702 2 Replies Last reply Reply Quote 0
                              @crunchip
                              Was fährst du da für ein System?
                              timedatectl status
                              macht dich evtl. auch schlauer.
                              • wendy2702
                                wendy2702 @crunchip last edited by
                                @crunchip wie das gleiche wie oben?
                                Hier steht „UTC“ oder habe ich was verpasst
                                  crunchip Forum Testing Most Active @wendy2702 last edited by
                                  @wendy2702 ja UTC, oben CEST(2Std weiter) ist schon korrekt so
                                  • wendy2702
                                    War nur verwundert weil die Differenz keine 2 Stunden ist. Liegt aber wohl an der Differenz der Abfragen.
                                      @Thomas-Braun ne Debian Vm in Proxmox
                                      root@IoBroker:~# timedatectl status
                                            Local time: Fr 2020-05-01 00:05:43 CEST
                                        Universal time: Do 2020-04-30 22:05:43 UTC
                                              RTC time: Fr 2020-05-01 00:05:43
                                       Network time on: yes
                                      NTP synchronized: yes
                                       RTC in local TZ: no
                                      zumindest geht das log richtig weiter,
                                        @crunchip
                                        Ich glaube da liegt der Hund begraben:
                                        RTC in local TZ: no
                                        Und in der Oberfläche von Proxmox steht sinngemäß:
                                        RTC in local TZ: yes
                                        Ich vermute das beißt sich irgendwie.
                                          @Thomas-Braun ja, das habe ich schon gesehen, deswegen den screen mit angefügt, aber wie gesagt, es war nur ein Neustart
                                            @crunchip Ich denke die beiden Einstellungen sollten gleich sein.
                                            Hab nur keinen Idee ob man besser im System anfängt oder in den Proxmox-Einstellungen.
                                            js-controller
                                            127
                                            1340
                                            432470
