    4. js-controller 3.0/3.1 jetzt im Latest!
    • O
      oFbEQnpoLKKl6mbY5e13 last edited by oFbEQnpoLKKl6mbY5e13
      Ist also nicht ungewöhnlich oder wie ist das gemeint?
      So viel tritt das bei mir nicht auf.
        amsernat last edited by
        Frage von Noob:
        nach js-controller update funkt backitup nicht mehr.
        kann mir bitte jemand sagen was hier schief gelaufen ist?
        Danke im Voraus.
        host.raspberrypi	2020-05-01 12:56:19.026	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
        host.raspberrypi	2020-05-01 12:56:07.650	info	Restart adapter system.adapter.backitup.0 because enabled
        host.raspberrypi	2020-05-01 12:56:07.649	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        host.raspberrypi	2020-05-01 12:56:07.649	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:840:9
        host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at detectLatestBackupFile (/opt/iobroker/node_modules/iobroker.backitup/main.js:699:33)
        host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at Array.map (<anonymous>)
        host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:699:48
        host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at new Promise (<anonymous>)
        host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:700:13
        host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at module.exports (/opt/iobroker/node_modules/iobroker.backitup/lib/list.js:72:36)
        host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at Object.list (/opt/iobroker/node_modules/iobroker.backitup/lib/list/googledrive.js:6:24)
        host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31)
        host.raspberrypi	2020-05-01 12:56:07.646	error	Caught by controller[1]: at JSON.parse (<anonymous>)
        host.raspberrypi	2020-05-01 12:56:07.646	error	Caught by controller[1]: SyntaxError: Unexpected token ' in JSON at position 1
        host.raspberrypi	2020-05-01 12:56:07.645	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
        backitup.0	2020-05-01 12:56:07.108	info	(20766) Terminated (NO_ERROR): Without reason
        backitup.0	2020-05-01 12:56:07.106	info	(20766) terminating
        backitup.0	2020-05-01 12:56:07.057	info	(20766) cleaned everything up...
        backitup.0	2020-05-01 12:56:07.055	error	(20766) SyntaxError: Unexpected token ' in JSON at position 1 at JSON.parse (<anonymous>) at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31) at O
        backitup.0	2020-05-01 12:56:07.049	error	(20766) uncaught exception: Unexpected token ' in JSON at position 1
        backitup.0	2020-05-01 12:56:06.962	info	(20766) [iobroker] backup was activated at 02:00 every 3 day(s)
        backitup.0	2020-05-01 12:56:06.903	info	(20766) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.16.3, js-controller: 3.0.20
        host.raspberrypi	2020-05-01 12:56:02.989	info	instance system.adapter.backitup.0 started with pid 20766
        pi@raspberrypi:~ $ node -v
        v12.16.3
        pi@raspberrypi:~ $ iobroker status
        At least one iobroker host is running.
        Objects type: file
        States  type: file
        pi@raspberrypi:~ $ npm -v
        6.14.4
        RAM
        3.81 GB
        System Betriebszeit
        14 T. 01:25:12
        Festplatte Größe
        28.98 GB
        Festplatte frei
        22.98 GB
        Anzahl der Adapter
        346
        Betriebszeit
        13:25:16
        Aktive Instanzen
        21
        raspberrypi
        Typ: js-controller
        Titel: JS controller
        OS: linux
        Verfügbar: 3.0.20
        Installiert: 3.0.20
        Ereignisse: ⇥26 / ↦15
          Marty56 last edited by apollon77
          Habe die Version 3.0.20 installiert. Soweit keine Probleme. Gut Arbeit.
          Im Log File habe jetzt ein paar Warnings, z. B.
          readFile 2020-05-01 14:05:43.635 warn will not read this file (devices/cpu.png) in future versions: icons-open-icon-library-png is not an object of type "meta"
          Es handelt sich da wohl um eigene Icons, die ich in VIS verwende.
          Bei dem Update vom VIS Module gab es auch mal eine Memory Warnung, aber nach Abschuss der Installation war wieder ausreichend Memory frei.
          Bei Zigbee Adapter gab es die Warnung
          zigbee.0 2020-05-01 14:05:07.228 warn (COMPACT) no connection to objects DB
          Er scheint aber zu laufen.
          Ich habe auch versucht auf die neueste Version (4.5.1) der Script Engine upzudaten, aber die Installation scheint nicht zu funktionieren und es wird immer noch 4.4.3 angezeigt.
          2020-05-01 14:18:19.059 - info: host.ioBroker-RasPi4 iobroker Update javascript from @4.4.3 to @4.5.1
          2020-05-01 14:18:21.640 - info: host.ioBroker-RasPi4 iobroker NPM version: 6.11.3
          2020-05-01 14:18:21.646 - info: host.ioBroker-RasPi4 iobroker npm install iobroker.javascript@4.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
          2020-05-01 14:19:25.371 - info: host.ioBroker-RasPi4 iobroker npm
          2020-05-01 14:19:25.377 - info: host.ioBroker-RasPi4 iobroker ERR! code ENOTSUPnpm ERR! notsup
          2020-05-01 14:19:25.383 - info: host.ioBroker-RasPi4 iobroker Unsupported engine for puppeteer@3.0.2: wanted: {"node":">=10.18.1"} (current: {"node":"10.17.0","npm":"6.11.3"})npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Required: {"node":">=10.18.1"}npm ERR! notsup Actual: {"npm":"6.11.3","node":"10.17.0"}
          2020-05-01 14:19:25.473 - info: host.ioBroker-RasPi4 iobroker
          2020-05-01 14:19:25.478 - info: host.ioBroker-RasPi4 iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-01T12_19_25_434Z-debug.log
          2020-05-01 14:19:25.985 - info: host.ioBroker-RasPi4 iobroker Update "system.adapter.javascript.0"
          2020-05-01 14:19:26.178 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 (force=false, process=true)
          2020-05-01 14:19:26.197 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 send kill signal
          2020-05-01 14:19:26.197 - info: javascript.0 (3513) Got terminate signal TERMINATE_YOURSELF
          2020-05-01 14:19:26.208 - info: javascript.0 (3513) Stop script script.js.common.Heizung
          2020-05-01 14:19:26.215 - info: javascript.0 (3513) Stop script script.js.common.Jalousien
          2020-05-01 14:19:26.220 - info: javascript.0 (3513) Stop script script.js.common.Licht_und_Schalter
          2020-05-01 14:19:26.224 - info: javascript.0 (3513) Stop script script.js.common.Sicherheit
          2020-05-01 14:19:26.228 - info: javascript.0 (3513) Stop script script.js.common.Sound
          2020-05-01 14:19:26.231 - info: javascript.0 (3513) Stop script script.js.common.Systeminfo
          2020-05-01 14:19:26.235 - info: javascript.0 (3513) Stop script script.js.common.Waschen
          2020-05-01 14:19:26.237 - info: javascript.0 (3513) Stop script script.js.common.Tagescharakteristik
          2020-05-01 14:19:26.240 - info: javascript.0 (3513) Stop script script.js.common.Email_und_Telegram_über_IFTTT_senden
          2020-05-01 14:19:26.243 - info: javascript.0 (3513) Stop script script.js.common.Batteriezustände_und_Fensteröffnungen
          2020-05-01 14:19:26.248 - info: javascript.0 (3513) Stop script script.js.common.Feuchte_und_Belüftung
          2020-05-01 14:19:26.251 - info: javascript.0 (3513) Stop script script.js.common.Telefonanrufe_verarbeiten
          2020-05-01 14:19:26.253 - info: javascript.0 (3513) Stop script script.js.common.Presence
          2020-05-01 14:19:26.256 - info: javascript.0 (3513) Stop script script.js.common.Wetter_und_Bewässerung_mit_Promisses
          2020-05-01 14:19:26.260 - info: javascript.0 (3513) terminating
          2020-05-01 14:19:26.263 - info: javascript.0 (3513) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2020-05-01 14:19:26.875 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2020-05-01 14:19:29.332 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 started with pid 3893
          Edit: code tags
          Thomas Braun BBTown apollon77 4 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Marty56 last edited by
            @Marty56 Dein node ist zu alt. Auf eine aktuelle 10er bringen, ich würde aber direkt auf node 12 springen.
            • BBTown
              BBTown @Marty56 last edited by BBTown
              @Marty56
              mal etwas OT ... Du hast bereits 700 post hier, und packst dennoch die LOGs nicht in code-Tags, das kann ich nicht nachvollziehen ... es gibt so viele User die von unterwegs mobil hier reinschauen und versuchen zu unterstützen, für die ist so eine Antwort einfach schei...
              J apollon77 2 Replies Last reply Reply Quote 0
                Jan1 @BBTown last edited by
                @BBTown
                Und er schafft es auch nicht den ersten Post zu lesen, in dem sehr deutlich steht, dass mindestens Node 10 vorausgesetzt wird.
                  Thomas Braun Most Active @Jan1 last edited by Thomas Braun
                  @Jan1 said in js-controller 3.0 jetzt im Latest!:
                  @BBTown
                  node10 hat er ja, allerdings ist die minor version auch zu alt:
                  "node":"10.17.0
                    Jan1 @Thomas Braun last edited by
                    @Thomas-Braun
                    Die wird doch mit nem System Update hochgezogen und das sollte wohl auch ab und an gemacht werden.
                      apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
                      @oFbEQnpoLKKl6mbY5e13 der fehler passiert wenn ein Adapter zu lange braucht um die Verbindung mit der iobroker dB zu bekommen. Kann es sein das in den Situationen recht viel Last auf der Liste herrschen? Wie geht es den Prozessen/cpu/RAM ...?
                        apollon77 @amsernat last edited by
                        @amsernat irgend ein json file ist kaputt. Speicher mal die konfig neu. Hat nix mit Controller zu tun. Bitte in einem der backitup threads fragen Oder-Neiße-Linie anlegen.
                        • O
                          oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                          @apollon77
                          Heute macht mein NAS ein RAID-Scrubbing, da ist es ziemlich träge. Das dauert auch fast den ganzen Tag. Ich beobachte das.
                            apollon77 @Marty56 last edited by
                            @Marty56 zu dem Icon Thema. Eigene icons in eigenen Verzeichnissen sind schon seit controller 2.2 „böse“. Bitte sauber aufsetzen oder in einen Ordner bewegen wo sie erlaubt sind.
                              apollon77 @Thomas Braun last edited by
                              @Thomas-Braun exakr. Formal muss der js Adapter das korrekt angeben. Legt bitte jemand ein issue dort an?
                                @oFbEQnpoLKKl6mbY5e13 das wär eine Vermutung weil damit i/o Träger ist.
                                  apollon77 @BBTown last edited by
                                  @BBTown ich hab’s mal gefixt.
                                    Aber auch nur, wenn man ein Repo für node hat und halt auch das Gesamtsystem ab und an frisch hält. Ich würde das wenigstens so einmal im Monat machen.
                                      @Thomas-Braun
                                      Auf dem Pi und jetzt mit Debian auf dem Beelink war das auf alle Fälle immer so 🙂
                                      • padrino
                                        padrino Most Active last edited by
                                        So, jetzt wage ich mich an den Kram und was ist?
                                        Ich krieg es ja nicht mal hin NodeJS auf V12 upzudaten. 😞 (wie man es macht, steht wohl nirgends, nur dass man muss?)
                                        Ich weiß schon, wieso ich die ganze Zeit bei V1 geblieben bin... das lief wenigstens. 😢
                                        • BBTown
                                          BBTown @padrino last edited by
                                          @padrino
                                          ernsthaft, jetzt???????????????
                                            @BBTown
                                            Das blinkt nicht, deshalb wir es gerne übersehen 😉
                                            padrino M 2 Replies Last reply Reply Quote 0
                                            js-controller
                                            127
                                            1340
                                            432616
