    4. js-controller 3.0/3.1 jetzt im Latest!
    • dslraser
      dslraser Forum Testing Most Active @dirk1962 last edited by dslraser
      @dirk1962 sagte in js-controller 3.0 jetzt im Latest!:
      @dslraser
      Ich habe den Befehl nach "iobroker stop" im Verzeichnis "opt/iobroker" ausgeführt.
      Mache ich da was falsch?
      @apollon77
      Beim heutigen Update (iot 1.4.14) ist es wieder da...
      2020-05-02 13:05:48.477 - warn: iot.0 (1102) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      Thomas Braun dirk1962 apollon77 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @dslraser last edited by
        Canvas rebuilden.
        • dirk1962
          dirk1962 @dslraser last edited by
          @dslraser
          Jepp, war bei mir auch so.😕 😕 Aber ich weiß ja jetzt, wie man es fixt. 😊 😊
          • dslraser
            dslraser Forum Testing Most Active @Thomas Braun last edited by
            @Thomas-Braun sagte in js-controller 3.0 jetzt im Latest!:
            Canvas rebuilden.
            ich habe das damit gemacht
            iobroker rebuild iot --install
            oder doch noch irgendwie anders ?
              @dslraser
              npm rebuild canvas
              In /opt/iobroker
              dslraser apollon77 2 Replies Last reply Reply Quote 0
              • dslraser
                dslraser Forum Testing Most Active @Thomas Braun last edited by dslraser
                npm rebuild canvas
                habe ich eben gemacht
                root@iobroker:/opt/iobroker# npm rebuild canvas
                > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
                > node-pre-gyp install --fallback-to-build
                node-pre-gyp WARN Using request for node-pre-gyp https download
                [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" already installed
                Pass --update-binary to reinstall or --build-from-source to recompile
                > canvas@2.6.1 install /opt/iobroker/node_modules/iobroker.iot/node_modules/canvas
                [canvas] Success: "/opt/iobroker/node_modules/iobroker.iot/node_modules/canvas/build/Release/canvas.node" already installed
                canvas@2.6.1 /opt/iobroker/node_modules/canvas
                canvas@2.6.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/canvas
                  @dslraser Nicht als root!
                  • dslraser
                    @Thomas-Braun
                    sondern ? (Portainer---Docker)
                      @dslraser Ach, der blöde Docker...
                      npm rebuild canvas --build-from-source
                      • dslraser
                        root@iobroker:/opt/iobroker# npm rebuild canvas --build-from-source
                        Package pixman-1 was not found in the pkg-config search path.
                        Perhaps you should add the directory containing `pixman-1.pc'
                        to the PKG_CONFIG_PATH environment variable
                        No package 'pixman-1' found
                        gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                        gyp ERR! configure error
                        gyp ERR! stack Error: `gyp` failed with exit code: 1
                        gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                        gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                        gyp ERR! System Linux 4.4.59+
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                        gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        gyp ERR! node -v v12.16.3
                        gyp ERR! node-gyp -v v5.1.0
                        gyp ERR! not ok
                        node-pre-gyp ERR! build error
                        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                        node-pre-gyp ERR! System Linux 4.4.59+
                        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        node-pre-gyp ERR! node -v v12.16.3
                        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                        node-pre-gyp ERR! not ok
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the canvas@2.6.1 install script.
                        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        npm ERR!     /opt/iobroker/.npm/_logs/2020-05-02T11_26_33_480Z-debug.log
                          @dslraser Da fehlen jetzt die -dev-Pakete aus dem graphic stack. Ich weiß aber nicht wo man die bei deinem System her bekommt.
                          • dslraser
                            @Thomas-Braun
                            ich bin jetzt mal ne Stunde wech, nachher gets weiter.
                              liv-in-sky last edited by
                              was sind das für warnungen ? weiß jmd, wie man die die wegbekommen kann
                              web.1	2020-05-02 13:43:02.580	warn	(22881) readFile will not read this file (uploads/files/1588419094081-xxxxxxxxxxxxxx6f-0378895cb788-grafik.png) in future versions: assets is not an object of type "meta"
                              kommt so alle 20-30 sekunden - die
                              • dslraser
                                Was für Infos brauchst Du dafür ?
                                  apollon77 @dslraser last edited by
                                  @dslraser Poste mal das install log von dem update
                                    apollon77 @Thomas Braun last edited by
                                    @Thomas-Braun Das iobroker rebuild iot --install ist der preferred way mit controller 3.0!
                                    dirk1962 1 Reply Last reply Reply Quote 0
                                      @Thomas-Braun Und genau aus dem grund haben wir das eigene Kommando! @Thomas-Braun Bitte empfehle das in Zukunft. Danke!
                                      • dslraser
                                        dslraser Forum Testing Most Active @apollon77 last edited by
                                        @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                                        vom iot Update, oder welches meinst Du ?
                                          apollon77 @liv-in-sky last edited by
                                          @liv-in-sky eigene Files die du irgendwie aus nem eigenen Folder lesen willst oder so? Der Name ist "assets" ... klingelt da was vllt?
                                            apollon77 @dslraser last edited by apollon77
                                            @dslraser Die sollte der Adapter an sich installieren ... mach mal ein apt installmit der Liste die da angegeben ist https://github.com/ioBroker/ioBroker.iot/blob/master/io-package.json#L243
                                            Deswegen wäre ich mal über ein Install Log vom Adapter echt erfreut
                                            Bzw bitte führe mal im container das hier aus
                                            node -e 'console.log(process.platform);'
                                            Was ist das Ergebnis?
                                            js-controller
                                            127
                                            1340
                                            433055
