    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер KODI
    Драйвер KODI
    • I
      instalator last edited by
      Если закрыть Коди, то драйвер падает с непонятной ошибкой
      Server-PC 2016-04-27 21:39:57 info host.Server-PC instance system.adapter.kodi.0 started with pid 2692
      Server-PC 2016-04-27 21:39:27 info host.Server-PC Restart adapter system.adapter.kodi.0 because enabled
      Server-PC 2016-04-27 21:39:27 error host.Server-PC instance system.adapter.kodi.0 terminated with code 0 (OK)
      kodi.0 2016-04-27 21:39:26 debug kodi.0 Response GetPlayerId [[],{"muted":false,"volume":100}]
      Из-за чего происходит ошибка непонятно, как можно выловить эти ошибки и отработать? Может возможно подписаться на 'error' модуля kodi-ws?
      у него есть self.emit но я так понимаю чтобы подписаться на них в самом драйвере нужно как то их сделать видимыми в самом драйвере.
      • I
        Виджеты для КОДИ:
        [{"tpl":"tplkodiProgressBar","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid":"kodi.0.playing_time","oid_curtime":"kodi.0.playing_time","oid_curtimetotal":"kodi.0.playing_time_total","oid_seek":"kodi.0.seek"},"style":{"left":"93px","top":"436px","width":"514px","height":"12px","color":"","background-color":"#a50d0d"},"widgetSet":"kodi"},{"tpl":"tplkodiPlaylist","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_playlist":"kodi.0.playlist","oid_goto":"kodi.0.GoTo","oid_position":"kodi.0.position"},"style":{"left":"91px","top":"186px","width":"511px","height":"241px","color":"#2d8f39","background-color":"#0f0505","border-radius":"5px","border-style":"groove","border-color":"#0a8aeb","padding-left":"","box-shadow":"","font-size":"x-small"},"widgetSet":"kodi"},{"tpl":"tplkodiButton","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_play":"kodi.0.play","oid_speed":"kodi.0.speed","oid_prev":"kodi.0.previous","oid_next":"kodi.0.next","oid_stop":"kodi.0.stop","oid_mute":"kodi.0.mute","oid_rpt":"kodi.0.repeat","oid_shf":"kodi.0.shuffle","oid_seek":"kodi.0.seek"},"style":{"left":"88px","top":"458px","width":"400px","height":"50px"},"widgetSet":"kodi"},{"tpl":"tplJquiSlider","data":{"oid":"kodi.0.volume","visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"min":"0","max":"100","step":"1"},"style":{"left":"490px","top":"469px","width":"102px","height":"23px"},"widgetSet":"jqui"},{"tpl":"tplkodiCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_codec":"kodi.0.codec"},"style":{"left":"96px","top":"520px","width":"50px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiAspect","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_aspect":"kodi.0.info.video_aspect"},"style":{"left":"272px","top":"520px","width":"36px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiResolut","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_resolut":"kodi.0.info.video_height"},"style":{"left":"232px","top":"520px","width":"35px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiChannel","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_channel":"kodi.0.channels"},"style":{"left":"150px","top":"520px","width":"28px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiVideoCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_videocodec":"kodi.0.info.video_codec"},"style":{"left":"183px","top":"520px","width":"46px","height":"25px"},"widgetSet":"kodi"}]
        • Bluefox
          Bluefox last edited by
          Запости скрины для затравки 😉
          • I
            @Bluefox:
            Запости скрины для затравки 😉 `
            • I
              @Bluefox:
              Немогу победить почему драйвер падает при закрытии КОДИ, причем он падает даже если вызов всех функции в main закоментить кроме getConnection.
              Получается какой то встроенный модуль дает исключение. Может посмотреть?
              • Bluefox
                BTW: https://github.com/ioBroker/ioBroker/wi … connection
                Проблема с падением ещё есть?
                • I
                  @Bluefox:
                  Проблема с падением ещё есть? `
                  Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                  • Bluefox
                    @instalator:
                    @Bluefox:
                    Проблема с падением ещё есть? Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                    У меня нет KODI. С какой ошибкой сваливается и где?
                    Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin.
                    • Bluefox
                      Ты не можешь создать все переменные, как info.connection в io-package.json?
                      А то при установке значения ты всегда создаёшь (или перезаписываешь) объект.
                      function setObject(name, val, type){
                      if (type){
                      name = type +'.'+ name;
                      object = {
                      type: 'state',
                      common: {
                      role: 'media',
                      type: typeof val
                      native: {}
                      adapter.setObject(name, object, function (err, obj) {
                      adapter.setState(name, {val: val, ack: true});
                      Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта.
                      Вот этого я тоже не пойму..
                      [https://github.com/instalator/iobroker. … di.js#L255](https://github.com/instalator/iobroker.kodi/blob/master/kodi.js#L255)
                      • I
                        @Bluefox:
                        Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта. `
                        Это переделаю.
                        @Bluefox:
                        https://github.com/instalator/iobroker. … di.js#L255 `
                        Если этой строки не добавить, то драйвер не реагирует на message. И только после того как из самого драйвера отправишь сообщение то начинает работать и из драйвера JS. Поэтому сделал пока так и хотел тебя спросить по этому вопросу.
                        • I
                          @Bluefox:
                          @instalator:
                          @Bluefox:
                          Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin. `
                          info.connection добавил, интересная штука, только сейчас увидел ее в работе)
                          А вот по падению не понятно.
                          Если в драйвере оставляю в main только этот код:
                          getConnection(function (err, _connection) {
                          if (_connection){
                          стартануть драйвер, а потом закрыть программу КОДИ, то драйвер просто падает.
                          Из лога ошибка не ясна.
                          host-Server-PC	2016-05-04 19:39:14	info	Restart adapter system.adapter.kodi.0 because enabled
                          host-Server-PC	2016-05-04 19:39:14	error	instance system.adapter.kodi.0 terminated with code 0 (OK)
                          kodi-0	2016-05-04 19:39:12	debug	Response GetPlayerId [[],{"muted":false,"volume":100}]
                          • I
                            Вот просто свалился и все, сам не перезапускается.
                            • Bluefox
                              @instalator:
                              Вот просто свалился и все, сам не перезапускается. `
                              Я бы мог сегодня посмотреть по teamViewer
                              • Bluefox
                                У меня работают message. И так
                                sendTo('kodi.0', 'send', {message: 'hallo', text: 'text'});
                                и так
                                sendTo('kodi.0', 'send', 'text');
                                Тебе надо перезапустить брокер, т.к. я не понимаю, почему в объекте не было
                                > "messagebox": true,
                                • I
                                  Добавил виджет обложки
                                  [{"tpl":"tplkodiThumbnail","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"visibility-oid":"","oid_thumbnail":"kodi.0.info.thumbnail","oid_type":"kodi.0.type","oid_server":"192.168.1.10:8041"},"style":{"left":"97px","top":"123px","width":"53px","height":"52px"},"widgetSet":"kodi"}]
                                  • I
                                    Плейлист поддерживает PVR плейлист
                                    • aurodionov
                                      aurodionov last edited by
                                      Аможно папочку со значками каналов
                                      • I
                                        @aurodionov:
                                        Аможно папочку со значками каналов `
                                        Со значками беда.
                                        На винде они грузятся с сервера на основе плейлиста, а вот в openElec почему то не показывает значки с сервера. я парсил их с сайта.
                                        На винде версия PVR 1,12,12 а на малинке 1,11,4 и как обновить не знаю, в репозитории показывает что нет обновлений.
                                        266_1.rar
                                        • I
                                          Накатил обновление Openelec до 7 Beta, все стало отображаться.
                                          • V
                                            vtec last edited by
                                            @aurodionov:
                                            Здесь есть архив со значками и вообще рассказываю как настроить от А до Я 🙂
                                            https://www.youtube.com/watch?v=6SsBn7bxt5k
                                            8496
