    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер KODI
    Драйвер KODI
    • I
      instalator last edited by
      Виджеты для КОДИ:
      [{"tpl":"tplkodiProgressBar","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid":"kodi.0.playing_time","oid_curtime":"kodi.0.playing_time","oid_curtimetotal":"kodi.0.playing_time_total","oid_seek":"kodi.0.seek"},"style":{"left":"93px","top":"436px","width":"514px","height":"12px","color":"","background-color":"#a50d0d"},"widgetSet":"kodi"},{"tpl":"tplkodiPlaylist","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_playlist":"kodi.0.playlist","oid_goto":"kodi.0.GoTo","oid_position":"kodi.0.position"},"style":{"left":"91px","top":"186px","width":"511px","height":"241px","color":"#2d8f39","background-color":"#0f0505","border-radius":"5px","border-style":"groove","border-color":"#0a8aeb","padding-left":"","box-shadow":"","font-size":"x-small"},"widgetSet":"kodi"},{"tpl":"tplkodiButton","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_play":"kodi.0.play","oid_speed":"kodi.0.speed","oid_prev":"kodi.0.previous","oid_next":"kodi.0.next","oid_stop":"kodi.0.stop","oid_mute":"kodi.0.mute","oid_rpt":"kodi.0.repeat","oid_shf":"kodi.0.shuffle","oid_seek":"kodi.0.seek"},"style":{"left":"88px","top":"458px","width":"400px","height":"50px"},"widgetSet":"kodi"},{"tpl":"tplJquiSlider","data":{"oid":"kodi.0.volume","visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"min":"0","max":"100","step":"1"},"style":{"left":"490px","top":"469px","width":"102px","height":"23px"},"widgetSet":"jqui"},{"tpl":"tplkodiCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_codec":"kodi.0.codec"},"style":{"left":"96px","top":"520px","width":"50px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiAspect","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_aspect":"kodi.0.info.video_aspect"},"style":{"left":"272px","top":"520px","width":"36px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiResolut","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_resolut":"kodi.0.info.video_height"},"style":{"left":"232px","top":"520px","width":"35px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiChannel","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_channel":"kodi.0.channels"},"style":{"left":"150px","top":"520px","width":"28px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiVideoCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_videocodec":"kodi.0.info.video_codec"},"style":{"left":"183px","top":"520px","width":"46px","height":"25px"},"widgetSet":"kodi"}]
      • Bluefox
        Bluefox last edited by
        Запости скрины для затравки 😉
        • I
          @Bluefox:
          Запости скрины для затравки 😉 `
          • I
            @Bluefox:
            Немогу победить почему драйвер падает при закрытии КОДИ, причем он падает даже если вызов всех функции в main закоментить кроме getConnection.
            Получается какой то встроенный модуль дает исключение. Может посмотреть?
            • Bluefox
              BTW: https://github.com/ioBroker/ioBroker/wi … connection
              Проблема с падением ещё есть?
              • I
                @Bluefox:
                Проблема с падением ещё есть? `
                Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                • Bluefox
                  @instalator:
                  @Bluefox:
                  Проблема с падением ещё есть? Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                  У меня нет KODI. С какой ошибкой сваливается и где?
                  Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin.
                  • Bluefox
                    Ты не можешь создать все переменные, как info.connection в io-package.json?
                    А то при установке значения ты всегда создаёшь (или перезаписываешь) объект.
                    function setObject(name, val, type){
                    if (type){
                    name = type +'.'+ name;
                    object = {
                    type: 'state',
                    common: {
                    role: 'media',
                    type: typeof val
                    native: {}
                    adapter.setObject(name, object, function (err, obj) {
                    adapter.setState(name, {val: val, ack: true});
                    Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта.
                    Вот этого я тоже не пойму..
                    [https://github.com/instalator/iobroker. … di.js#L255](https://github.com/instalator/iobroker.kodi/blob/master/kodi.js#L255)
                    • I
                      @Bluefox:
                      Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта. `
                      Это переделаю.
                      @Bluefox:
                      https://github.com/instalator/iobroker. … di.js#L255 `
                      Если этой строки не добавить, то драйвер не реагирует на message. И только после того как из самого драйвера отправишь сообщение то начинает работать и из драйвера JS. Поэтому сделал пока так и хотел тебя спросить по этому вопросу.
                      • I
                        @Bluefox:
                        @instalator:
                        @Bluefox:
                        Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin. `
                        info.connection добавил, интересная штука, только сейчас увидел ее в работе)
                        А вот по падению не понятно.
                        Если в драйвере оставляю в main только этот код:
                        getConnection(function (err, _connection) {
                        if (_connection){
                        стартануть драйвер, а потом закрыть программу КОДИ, то драйвер просто падает.
                        Из лога ошибка не ясна.
                        host-Server-PC	2016-05-04 19:39:14	info	Restart adapter system.adapter.kodi.0 because enabled
                        host-Server-PC	2016-05-04 19:39:14	error	instance system.adapter.kodi.0 terminated with code 0 (OK)
                        kodi-0	2016-05-04 19:39:12	debug	Response GetPlayerId [[],{"muted":false,"volume":100}]
                        • I
                          Вот просто свалился и все, сам не перезапускается.
                          • Bluefox
                            @instalator:
                            Вот просто свалился и все, сам не перезапускается. `
                            Я бы мог сегодня посмотреть по teamViewer
                            • Bluefox
                              У меня работают message. И так
                              sendTo('kodi.0', 'send', {message: 'hallo', text: 'text'});
                              и так
                              sendTo('kodi.0', 'send', 'text');
                              Тебе надо перезапустить брокер, т.к. я не понимаю, почему в объекте не было
                              > "messagebox": true,
                              • I
                                Добавил виджет обложки
                                [{"tpl":"tplkodiThumbnail","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"visibility-oid":"","oid_thumbnail":"kodi.0.info.thumbnail","oid_type":"kodi.0.type","oid_server":"192.168.1.10:8041"},"style":{"left":"97px","top":"123px","width":"53px","height":"52px"},"widgetSet":"kodi"}]
                                • I
                                  Плейлист поддерживает PVR плейлист
                                  • aurodionov
                                    aurodionov last edited by
                                    Аможно папочку со значками каналов
                                    • I
                                      @aurodionov:
                                      Аможно папочку со значками каналов `
                                      Со значками беда.
                                      На винде они грузятся с сервера на основе плейлиста, а вот в openElec почему то не показывает значки с сервера. я парсил их с сайта.
                                      На винде версия PVR 1,12,12 а на малинке 1,11,4 и как обновить не знаю, в репозитории показывает что нет обновлений.
                                      266_1.rar
                                      • I
                                        Накатил обновление Openelec до 7 Beta, все стало отображаться.
                                        • V
                                          vtec last edited by
                                          @aurodionov:
                                          Здесь есть архив со значками и вообще рассказываю как настроить от А до Я 🙂
                                          https://www.youtube.com/watch?v=6SsBn7bxt5k
                                          • I
                                            @vtec:
                                            @aurodionov:
                                            https://www.youtube.com/watch?v=6SsBn7bxt5k `
                                            16 версию хорошо переработали. Я ничего в PVR не настраиваю, указываю только удаленный плейлист IPTV провайдера и все работает, значки отображает так как они прописаны в файле m3u
                                            8860
