    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    • cvidal
      cvidal Forum Testing @tombox last edited by
      @tombox Neuinstallation hilft hier nicht bei npm rebuild bekomme ich Errors mit denen ich nicht weiterkomme.
      root@IoBroker:/home/christian# cd /opt/iobroker
      root@IoBroker:/opt/iobroker# npm rebuild
      iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      node lib/preinstallCheck.js
      NPM version: 6.14.4
      iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
      node iobroker.js setup first
      acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
      node scripts/postinstall
      Greenlock and ACME.js v3 are on the way!
      Watch for updates at https://indiegogo.com/at/greenlock
      authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
      node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
      ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
      ../authenticate_pam.cc:107:87: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
      keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
      In file included from ../authenticate_pam.cc:23:0:
      ../../nan/nan.h:1024:46: note: declared here
      NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
      ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../authenticate_pam.cc:147:83: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
      al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
      In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14:0,
      from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27,
      from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67,
      from ../../nan/nan.h:54,
      /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:3553:51: note: declared here
      V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
      /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
      declarator attribute((deprecated(message)))
      ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
      serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
      In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67:0,
      /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
      int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
      /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
      ../authenticate_pam.cc:152:69: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
      res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
      ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
      remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
      ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
      username->WriteUtf8(m->username, sizeof(m->username) - 1);
      ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
      password->WriteUtf8(m->password, sizeof(m->password) - 1);
      ../authenticate_pam.cc: At global scope:
      ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
      void init(Handle<Object> exports) {
      ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
      ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
      ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
      In file included from ../../nan/nan.h:54:0,
      ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
      NODE_MODULE(authenticate_pam, init);
      /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
      (node::addon_register_func) (regfunc),
      ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
      authenticate_pam.target.mk:111: die Regel für Ziel „Release/obj.target/authenticate_pam/authenticate_pam.o“ scheiterte
      make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack at ChildProcess.emit (events.js:310:20)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 4.9.0-11-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      gyp ERR! node -v v12.16.2
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! authenticate-pam@1.0.2 install: node-gyp rebuild
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the authenticate-pam@1.0.2 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! /home/iobroker/.npm/_logs/2020-04-14T20_19_29_910Z-debug.log
      • Wszene
        Wszene last edited by
        Hallo Zusammen,
        Ich bekomme seid dem 24.04 keine Daten mehr
        Das heist in der App wird alles aktualisiert aber im ioBroker nicht
        Marcel
          Scooty last edited by Scooty
          Hier leider auch (Skoda), Auszug aus dem Log:
          vw-connect.0	2020-04-30 17:31:00.777	error	(1538) 400
          vw-connect.0	2020-04-30 17:31:00.776	error	(1538) Failing to refresh token.
          vw-connect.0	2020-04-30 17:31:00.353	debug	(1538) refreshToken
          vw-connect.0	2020-04-30 17:07:25.361	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/dwap/v1/$type/$country/vehicles/$vin/history
          vw-connect.0	2020-04-30 17:07:25.360	debug	(1538) 403
          vw-connect.0	2020-04-30 17:07:25.353	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/rs/v1/$type/$country/vehicles/$vin/status
          vw-connect.0	2020-04-30 17:07:25.352	debug	(1538) 502
          vw-connect.0	2020-04-30 17:07:25.322	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/cf/v1/$type/$country/vehicles/$vin/position
          vw-connect.0	2020-04-30 17:07:25.321	debug	(1538) 403
          vw-connect.0	2020-04-30 17:07:25.287	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/batterycharge/v1/$type/$country/vehicles/$vin/charger
          vw-connect.0	2020-04-30 17:07:25.287	debug	(1538) 403
          vw-connect.0	2020-04-30 17:07:25.185	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/departuretimer/v1/$type/$country/vehicles/$vin/timer
          vw-connect.0	2020-04-30 17:07:25.184	debug	(1538) 403
          vw-connect.0	2020-04-30 17:07:24.808	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/vsr/v1/$type/$country/vehicles/$vin/status
          vw-connect.0	2020-04-30 17:07:24.807	debug	(1538) 403
          vw-connect.0	2020-04-30 17:07:24.796	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/climatisation/v1/$type/$country/vehicles/$vin/climater
          vw-connect.0	2020-04-30 17:07:24.795	debug	(1538) 403
          vw-connect.0	2020-04-30 17:07:23.662	debug	(1538) {"destinations":[]}
          vw-connect.0	2020-04-30 17:07:23.416	debug	(1538) error while getting https://msg.volkswagen.de/fs-car/bs/tripstatistics/v1/$type/$country/vehicles/$vin/tripdata/$tripType?type=list
          vw-connect.0	2020-04-30 17:07:23.415	debug	(1538) 400
          vw-connect.0	2020-04-30 16:43:13.279	debug	(1538) {"access_token":"xxxx
          vw-connect.0	2020-04-30 16:43:13.108	debug	(1538) refreshToken
          vw-connect.0	2020-04-30 16:37:00.846	error	(1538) 400
          vw-connect.0	2020-04-30 16:37:00.845	error	(1538) Failing to refresh token.
          vw-connect.0	2020-04-30 16:37:00.352	debug	(1538) refreshToken
          Access Token habe ich unkenntlich gemacht.
          Fehler mit "Failing to refresh token" war weiter oben schon ´mal erwähnt, leider ohne Lösung, die ich nachvollziehen könnte.
          Viele Grüße,
          Andreas
            fritz0815 last edited by
            Hallo
            bei mir (node js 12, js-controller@3.0.20) kommt folgende Fehler.
            Ich habe bereits das Objekt vw-connect.0 gelöscht - danach werden die Unterobjekte: Fahrzg-Id, info und personal angelegt und personal korrekt gefüllt
            Viele Grüße
            Markus
            2020-05-01 16:24:35.200 - info: vw-connect.0 (30760) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.20
            2020-05-01 16:24:38.884 - error: vw-connect.0 (30760) 406
            2020-05-01 16:24:38.887 - error: vw-connect.0 (30760) uncaught exception: undefined
            2020-05-01 16:24:38.889 - error: vw-connect.0 (30760) uncaught exception: Cannot read property 'stack' of undefined
            2020-05-01 16:24:38.895 - error: vw-connect.0 (30760) TypeError: Cannot read property 'stack' of undefined
            at process.exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8238:17)
            at process.emit (events.js:310:20)
            at processPromiseRejections (internal/process/promises.js:209:33)
            at processTicksAndRejections (internal/process/task_queues.js:98:32)
            2020-05-01 16:24:38.897 - info: vw-connect.0 (30760) cleaned everything up...
            2020-05-01 16:24:38.963 - info: vw-connect.0 (30760) terminating
            2020-05-01 16:24:38.965 - info: vw-connect.0 (30760) Terminated (NO_ERROR): Without reason
              tombox @fritz0815 last edited by
              @fritz0815 du kannst versuchen die js controller rversion 3.0.21 via github zu installieren
                tombox @Scooty last edited by
                @Scooty kommt das mit dem refresh token dauerhaft?
                  Scooty @tombox last edited by
                  @tombox :
                  Ja, es kam dauerhaft. Zwischenzeitlich habe ich aber den Adapter ca. 12h gestoppt.
                  Gerade nochmals gestartet, Token-Fehler tritt nicht auf (vielleicht hatte VW mich temporär wegen der Anfragen ausgesperrt?).
                  Wie bei @fritz0815 werden die persönliche Daten und die FIN geladen, aber danach nun folgender Fehler:
                  vw-connect.0	2020-05-02 12:29:32.389	error	(1912) 406
                  vw-connect.0	2020-05-02 12:29:32.320	error	(1912) 403
                  vw-connect.0	2020-05-02 12:29:30.814	debug	(1912) {"userVehicles":{"vehicle":["xxxx"]}}
                  vw-connect.0	2020-05-02 12:29:29.910	debug	(1912) {"firstName":"Andreas","lastName":"Kxxxx","salutation":"SALUTATION:MR","dateOfBirth":"19xx-xx-xx","nickname":"Andreas","businessIdentifierType":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","businessIdent
                  vw-connect.0	2020-05-02 12:29:29.686	debug	(1912) getData
                  vw-connect.0	2020-05-02 12:29:29.682	debug	(1912) Login successful
                  vw-connect.0	2020-05-02 12:29:29.146	debug	(1912) Error: Invalid protocol: skodaconnect:
                  vw-connect.0	2020-05-02 12:29:28.259	debug	(1912) {"date":"Sat, 02 May 2020 10:29:28 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locatio
                  vw-connect.0	2020-05-02 12:29:28.259	debug	(1912) ""
                  vw-connect.0	2020-05-02 12:29:27.782	debug	(1912) parsePasswordForm
                  vw-connect.0	2020-05-02 12:29:26.789	debug	(1912) parseEmailForm
                  vw-connect.0	2020-05-02 12:29:24.524	info	(1912) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.19.0
                  JS controller: 2.2.9
                  Viele Grüße,
                  Andreas
                    tombox @Scooty last edited by tombox
                    @Scooty Alles was in debug produziert wird sind keine Fehler die relevant sind. Fehler 406 oder 403 sind schon relevant also werden keine weiteren Daten geladen?
                      @tombox
                      Alles klar.
                      Ja, es wurden keine weiteren Daten geladen (nur die VIN und persönlichen).
                      Inzwischen kommen allerdings wieder nur die Meldungen
                      vw-connect.0	2020-05-02 14:39:07.018	error	(1941) 400
                      vw-connect.0	2020-05-02 14:39:07.017	error	(1941) Failing to refresh token.
                      und es findet keinerlei Aktualisierung statt.
                      Viele Grüße,
                      Andreas
                        @Scooty aber über die App geht alles
                          fritz0815 @tombox last edited by
                          @tombox sagte in Test Adapter VW Connect v0.0.x:
                          ich werde berichten
                          • Wszene
                            @tombox
                            Bei mir geht es über die App
                            aber im ioBroker das selbe Problem
                            Ich habe aber js controller noch nicht auf die github version geupdatet
                              @tombox said in Test Adapter VW Connect v0.0.x:
                              Ja, auch hier geht über die App alles.
                              • U
                                Ultor last edited by
                                bei mir geht der Adapter nach dem Update auf die JS-Controller Version 3.0.21 (installiert via Github) nach Wechsel auf Grün direkt wieder auf Rot. Die Skoda-App funktioniert.
                                Ich habe das Objekt vw-connect.0 gelöscht sowie die Instanz des Adapters neu angelegt, das hat leider nichts gebracht.
                                Wäre für Tipps dankbar.
                                Gruß,
                                Daniel
                                host.ioBroker-RasPi4	2020-05-05 19:41:07.842	info	instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
                                vw-connect.0	2020-05-05 19:41:06.415	error	(2195) unhandled promise rejection: undefined
                                vw-connect.0	2020-05-05 19:41:06.414	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                vw-connect.0	2020-05-05 19:41:06.413	error	(2195) 429
                                vw-connect.0	2020-05-05 19:41:06.359	info	(2195) Terminated (NO_ERROR): Without reason
                                vw-connect.0	2020-05-05 19:41:06.358	info	(2195) terminating
                                vw-connect.0	2020-05-05 19:41:05.962	info	(2195) cleaned everything up...
                                vw-connect.0	2020-05-05 19:41:05.961	error	(2195) unhandled promise rejection: undefined
                                vw-connect.0	2020-05-05 19:41:05.961	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                vw-connect.0	2020-05-05 19:41:05.959	error	(2195) 406
                                vw-connect.0	2020-05-05 19:41:05.703	debug	(2195) {"userVehicles":{"vehicle":["XXXXXXXXXXXXXXXXX"]}}
                                vw-connect.0	2020-05-05 19:41:05.444	debug	(2195) {"firstName":"XXXXX","lastName":"XXXXX","salutation":"SALUTATION:MR","dateOfBirth":"XXXX-XX-XX","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"XXXXX","businessIdentifierTyp
                                vw-connect.0	2020-05-05 19:41:05.201	debug	(2195) getData
                                vw-connect.0	2020-05-05 19:41:05.200	debug	(2195) Login successful
                                vw-connect.0	2020-05-05 19:41:04.687	debug	(2195) Error: Invalid protocol: skodaconnect:
                                vw-connect.0	2020-05-05 19:41:03.896	debug	(2195) {"date":"Tue, 05 May 2020 17:41:03 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locatio
                                vw-connect.0	2020-05-05 19:41:03.894	debug	(2195) ""
                                vw-connect.0	2020-05-05 19:41:03.490	debug	(2195) parsePasswordForm
                                vw-connect.0	2020-05-05 19:41:02.961	debug	(2195) parseEmailForm
                                vw-connect.0	2020-05-05 19:41:01.925	info	(2195) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.21
                                • opossum
                                  opossum last edited by opossum
                                  habe das Problem auch. Habe den Adapter extra deinstalliert. dann neu installiert. Daten eingetragen (vorher im Web kontrolliert, ob ich mich verbinden kann). Adapter aktiviert, kurz gelb, dann grün und sofort wieder auf rot. Hatte dazu ein Issue erstellt. Heute die Nachricht bekommen, ich soll Adapter von Github installieren oder den js-conroller 3.0.21. Habe bisher nur den 3.0.20 installiert. Aber laut @Ultor bringt das ja auch keine Punkte. Naja, teste ich dann von zeit zu zeit wieder.
                                    tombox @opossum last edited by
                                    @opossum @Ultor bitte den adapter über github also den katzen button unter adapters installieren und neustarten ob da aussagekräftiger fehler bekommen
                                    bzw bräuchte für skoda kurz zugangsdaten per pn um den fehler zu lokalisieren
                                    • opossum
                                      Hallo, @tombox ,
                                      mache ich, melde mich gleich noch einmal.
                                      • opossum
                                        immer noch das gleiche Verhalten. Hier mal das Log:
                                        host.iobrokerprod	2020-05-09 18:15:24.221	info	"system.adapter.vw-connect.0" disabled
                                        host.iobrokerprod	2020-05-09 18:15:23.574	info	Restart adapter system.adapter.vw-connect.0 because enabled
                                        host.iobrokerprod	2020-05-09 18:15:23.574	info	instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
                                        vw-connect.0	2020-05-09 18:15:23.548	error	(22894) [object Object]
                                        vw-connect.0	2020-05-09 18:15:23.548	error	(22894) 400
                                        vw-connect.0	2020-05-09 18:15:23.055	info	(22894) Terminated (NO_ERROR): Without reason
                                        vw-connect.0	2020-05-09 18:15:23.055	info	(22894) terminating
                                        vw-connect.0	2020-05-09 18:15:23.052	info	(22894) cleaned everything up...
                                        vw-connect.0	2020-05-09 18:15:23.051	error	at processTicksAndRejections (internal/process/task_queues.js:98:32)
                                        vw-connect.0	2020-05-09 18:15:23.051	error	at processPromiseRejections (internal/process/promises.js:209:33)
                                        vw-connect.0	2020-05-09 18:15:23.051	error	at process.emit (events.js:310:20)
                                        vw-connect.0	2020-05-09 18:15:23.051	error	at process.exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8238:17)
                                        vw-connect.0	2020-05-09 18:15:23.051	error	(22894) TypeError: Cannot read property 'stack' of undefined
                                        vw-connect.0	2020-05-09 18:15:23.050	error	(22894) uncaught exception: Cannot read property 'stack' of undefined
                                        vw-connect.0	2020-05-09 18:15:23.050	error	(22894) uncaught exception: undefined
                                        vw-connect.0	2020-05-09 18:15:23.049	error	(22894) 406
                                        vw-connect.0	2020-05-09 18:15:20.054	info	(22894) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.20
                                        host.iobrokerprod	2020-05-09 18:15:18.958	info	instance system.adapter.vw-connect.0 started with pid 22894
                                        host.iobrokerprod	2020-05-09 18:15:18.933	info	"system.adapter.vw-connect.0" enabled
                                        Schicke Dir mal die Zugangsdaten per Chat.
                                          @opossum @Ultor ist gefixt im latest und im github
                                          • opossum
                                            Hallo, @tombox ,
                                            vielen Dank für den schnellen Fix, jetzt bleibt der Adapter grün.
                                            1.4k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1603431
