    4. js-controller 3.0/3.1 jetzt im Latest!
      knopers1 @Marty56 last edited by knopers1
      Das Update des RFLink-Adapters zerschießt mir die Serielle Schnittstelle.
      raspberrypi
      Betriebssystem
          linux
      Betriebssystem
          linux
      Architektur
          arm
      CPUs
      Geschwindigkeit
          1500 MHz
      Modell
          ARMv7 Processor rev 3 (v7l)
      RAM
          3.81 GB
      System Betriebszeit
          10 T. 22:55:36
      Node.js
          v10.20.1 (Empfohlene Version v12.16.3)
      NPM
          6.14.4
      Festplatte Größe
          233.73 GB
      Festplatte frei
          229.18 GB
      Anzahl der Adapter
          346
      Betriebszeit
          3 T. 00:01:36
      Aktive Instanzen
          23
      Hostname
          raspberrypi
      Das hier stimmt nicht:
      2020-05-01 08:32:49.599 - error: rflink.0 (2973) uncaught exception: SerialPort.list no longer takes a callback and only returns a promise
      2020-05-01 08:32:49.609 - error: rflink.0 (2973) TypeError: SerialPort.list no longer takes a callback and only returns a promise
      2020-05-01 08:30:03.576 - info: host.raspberrypi iobroker upload [2] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/rflink.png rflink.png image/png
      2020-05-01 08:30:03.635 - info: host.raspberrypi iobroker upload [1] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/parse.js parse.js application/javascript
      2020-05-01 08:30:03.714 - info: host.raspberrypi iobroker upload [0] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/index.html index.html text/html
      2020-05-01 08:30:03.770 - info: host.raspberrypi iobroker Adapter "rflink" updated
      2020-05-01 08:30:03.771 - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.rflink.0" is started
      2020-05-01 08:30:03.795 - info: host.raspberrypi "system.adapter.rflink.0" enabled
      2020-05-01 08:30:03.814 - info: host.raspberrypi instance system.adapter.rflink.0 started with pid 1666
      2020-05-01 08:30:04.820 - info: host.raspberrypi iobroker exit 0
      2020-05-01 08:30:06.134 - info: rflink.0 (1666) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.rflink, node: v10.20.1, js-controller: 3.0.20
      2020-05-01 08:30:06.282 - info: rflink.0 (1666) Serial port opened
      2020-05-01 08:30:07.212 - info: rflink.0 (1666) Connected
      2020-05-01 08:30:09.311 - info: ical.0 (1645) Terminated (NO_ERROR): Without reason
      2020-05-01 08:30:09.830 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2020-05-01 08:30:21.393 - error: rflink.0 (1666) uncaught exception: SerialPort.list no longer takes a callback and only returns a promise
      2020-05-01 08:30:21.397 - error: rflink.0 (1666) TypeError: SerialPort.list no longer takes a callback and only returns a promise
      at Function.SerialPort.list (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:651:11)
      at Adapter.adapter.on.obj (/opt/iobroker/node_modules/iobroker.rflink/main.js:43:36)
      at Adapter.emit (events.js:198:13)
      at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5304:34)
      at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:234:41)
      at runCallback (timers.js:705:18)
      at tryOnImmediate (timers.js:676:5)
      at processImmediate (timers.js:658:5)
      2020-05-01 08:30:21.493 - info: rflink.0 (1666) terminating
      2020-05-01 08:30:21.495 - info: rflink.0 (1666) Terminated (NO_ERROR): Without reason
      2020-05-01 08:30:22.018 - info: host.raspberrypi instance system.adapter.rflink.0 terminated with code 0 (NO_ERROR)
      2020-05-01 08:30:22.019 - info: host.raspberrypi Restart adapter system.adapter.rflink.0 because enabled
      2020-05-01 08:30:52.044 - info: host.raspberrypi instance system.adapter.rflink.0 started with pid 2299
      2020-05-01 08:30:53.956 - info: rflink.0 (2299) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.rflink, node: v10.20.1, js-controller: 3.0.20
      2020-05-01 08:30:54.095 - info: rflink.0 (2299) Serial port opened
      2020-05-01 08:30:55.025 - info: rflink.0 (2299) Connected
      2020-05-01 08:31:00.460 - info: javascript.0 (30309) script.js.common.StromzaehlerWemo: setForeignState(id=javascript.0.StromMeter.Wert, state="648578.00")
      2020-05-01 08:31:06.026 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      2020-05-01 08:31:22.254 - error: rflink.0 (2299) uncaught exception: SerialPort.list no longer takes a callback and only returns a promise
      2020-05-01 08:31:22.264 - error: rflink.0 (2299) TypeError: SerialPort.list no longer takes a callback and only returns a promise
      2020-05-01 08:31:22.334 - info: rflink.0 (2299) terminating
      2020-05-01 08:31:22.335 - info: rflink.0 (2299) Terminated (NO_ERROR): Without reason
      2020-05-01 08:31:22.853 - info: host.raspberrypi instance system.adapter.rflink.0 terminated with code 0 (NO_ERROR)
      2020-05-01 08:31:22.853 - info: host.raspberrypi Restart adapter system.adapter.rflink.0 because enabled
      2020-05-01 08:31:48.770 - info: host.raspberrypi "system.adapter.rflink.0" disabled
      2020-05-01 08:31:54.229 - info: host.raspberrypi "system.adapter.rflink.0" enabled
      2020-05-01 08:31:54.229 - info: host.raspberrypi stopInstance system.adapter.rflink.0 (force=false, process=true)
      2020-05-01 08:31:54.231 - info: host.raspberrypi stopInstance system.adapter.rflink.0 send kill signal
      2020-05-01 08:31:55.292 - info: host.raspberrypi stopInstance system.adapter.rflink.0 killing pid 2957
      2020-05-01 08:31:55.302 - info: rflink.0 (2957) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.rflink, node: v10.20.1, js-controller: 3.0.20
      2020-05-01 08:31:55.453 - info: rflink.0 (2957) Serial port opened
      2020-05-01 08:31:56.383 - info: rflink.0 (2957) Connected
      2020-05-01 08:31:57.267 - info: host.raspberrypi instance system.adapter.rflink.0 started with pid 2973
      2020-05-01 08:31:57.273 - warn: rflink.0 (2957) Got terminate signal. Checking desired PID: 0 vs own PID 2957
      2020-05-01 08:31:57.277 - info: rflink.0 (2957) terminating
      2020-05-01 08:31:57.279 - info: rflink.0 (2957) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-05-01 08:31:57.288 - warn: rflink.0 (2957) Got terminate signal. Checking desired PID: 2973 vs own PID 2957
      2020-05-01 08:31:57.804 - error: host.raspberrypi instance system.adapter.rflink.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2020-05-01 08:31:57.804 - info: host.raspberrypi Do not restart adapter system.adapter.rflink.0 because desired by instance
      2020-05-01 08:31:59.163 - info: rflink.0 (2973) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.rflink, node: v10.20.1, js-controller: 3.0.20
      2020-05-01 08:31:59.665 - info: rflink.0 (2973) Serial port opened
      2020-05-01 08:32:00.594 - info: rflink.0 (2973) Connected
      2020-05-01 08:32:00.814 - info: javascript.0 (30309) script.js.common.StromzaehlerWemo: setForeignState(id=javascript.0.StromMeter.Wert, state="648579.00")
      2020-05-01 08:32:49.775 - info: rflink.0 (2973) terminating
      2020-05-01 08:32:49.776 - info: rflink.0 (2973) Terminated (NO_ERROR): Without reason
      2020-05-01 08:32:50.295 - info: host.raspberrypi instance system.adapter.rflink.0 terminated with code 0 (NO_ERROR)
      2020-05-01 08:32:50.296 - info: host.raspberrypi Restart adapter system.adapter.rflink.0 because enabled
      apollon77 2 Replies Last reply Reply Quote 0
        apollon77 @rewenode last edited by
        @rewenode naja ein bissl optimiert haben wir aber direkt nach dem Start ist das schwer zu sagen. Warte mal wie es morgen aussieht.
          apollon77 @Marty56 last edited by
          @Marty56 hm ... klingt nach einem issue für Vis wo sich GitHub freut.
            apollon77 @knopers1 last edited by
            @knopers1 Jupp. Ich bin schuld. Fix version kommt nachher.
              liv-in-sky @Marty56 last edited by
              @Marty56
              erstmal danke für's melden - werde das morgen nochmal näher ansehen, ob ich das irgendwie nachvollziehen kann - meld mich dann
                @knopers1 rflink 2.1.4 sollte das gefixt haben
                • Thisoft
                  Thisoft last edited by
                  ich bekomme aktuell nach dem Update auf Node 12 und js-controller 3.0.20 folgenden Fehler vom SQL-Adapter:
                  sql.0
                  2020-05-03 04:26:14.114
                  error
                  (7144) ConnectionError: Failed to connect to 192.168.137.xxx:1433 - Cannot call write after a stream was destroyed
                  was kann ich denn dagegen tun?
                    knopers1 @apollon77 last edited by
                    @apollon77 said in js-controller 3.0 jetzt im Latest!:
                    ja, 2.1.4 läuft wieder :). Besten Dank. Meine Anerkennung apollon77. "Du hast es drauf"
                      apollon77 @Thisoft last edited by
                      @Thisoft nur Update von dem genannten oder auch von sql? Welche sql Version?
                      Wann kommt der Fehler?
                      Bissl mehr context und log wäre schön.
                      • Thisoft
                        @apollon77 Sorry, war schon spät 😉 Also, ich hab zuerst von nodejs 8.x auf 12.16.3 updatet. Danach:
                        npm rebuild
                        was mir mit der folgenden Ausgabe antwortet:
                        @types/node@12.7.1 /home/iobroker/node_modules/@types/node
                        das kommt mir schonmal komisch vor...?
                        Dann reboot, danach "iobroker" update und "iobroker upgrade self"
                        Danach den Installationsfixer drüber laufen lassen. Der hat alles ohne Fehlermeldung ausgeführt.
                        Danach alle Adapter die zum Update anstanden über die Adminoberfläche updatet, u.a. auch den SQL-Adapter auf 1.12.3
                        Ja, und das wäre jetzt ertstmal der Stand. Hier nochmal ein Log vom SQL-Adapter mit Debug-Logging:
                        2020-05-03 11:11:57.617  - info: host.ioBroker-Ubuntu Restart adapter system.adapter.sql.0 because enabled
                        2020-05-03 11:11:58.636  - info: host.ioBroker-Ubuntu instance system.adapter.sql.0 started with pid 5436
                        2020-05-03 11:11:58.915  - debug: sql.0 (5436) Redis Objects: Use Redis connection: 0.0.0.0:9001
                        2020-05-03 11:11:58.933  - debug: sql.0 (5436) Objects client ready ... initialize now
                        2020-05-03 11:11:58.935  - debug: sql.0 (5436) Objects create System PubSub Client
                        2020-05-03 11:11:58.935  - debug: sql.0 (5436) Objects create User PubSub Client
                        2020-05-03 11:11:58.936  - debug: sql.0 (5436) Objects client initialize lua scripts
                        2020-05-03 11:11:58.946  - debug: sql.0 (5436) Objects connected to redis: 0.0.0.0:9001
                        2020-05-03 11:11:58.948  - debug: sql.0 (5436) objectDB connected
                        2020-05-03 11:11:58.948  - debug: sql.0 (5436) Redis States: Use Redis connection: 0.0.0.0:9000
                        2020-05-03 11:11:58.952  - debug: sql.0 (5436) States create User PubSub Client
                        2020-05-03 11:11:58.953  - debug: sql.0 (5436) States create System PubSub Client
                        2020-05-03 11:11:58.957  - debug: sql.0 (5436) States connected to redis: 0.0.0.0:9000
                        2020-05-03 11:11:58.958  - debug: sql.0 (5436) statesDB connected
                        2020-05-03 11:11:59.755  - debug: sql.0 (5436) Plugin sentry Initialize Plugin (enabled=true)
                        2020-05-03 11:11:59.801  - info: sql.0 (5436) starting. Version 1.12.3 in /opt/iobroker/node_modules/iobroker.sql, node: v12.16.3, js-controller: 3.0.20
                        2020-05-03 11:12:00.024  - info: host.ioBroker-Ubuntu instance system.adapter.weatherunderground.0 started with pid 5452
                        2020-05-03 11:12:00.072  - debug: sql.0 (5436) system.adapter.admin.0: logging true
                        2020-05-03 11:12:00.091  - error: sql.0 (5436) ConnectionError: Failed to connect to 192.168.137.13:1433 - Cannot call write after a stream was destroyed
                        Hilft das weiter?
                        • Peoples
                          Peoples @apollon77 last edited by
                          @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                          • Der neue js-controller kann erkennen wenn es ein Node.js Update gab durch welches ggf, Adapter nicht mehr funktionieren und sollte diese automatisch reparieren (rebuilden). Wer also überlegt in dem Zuge des Tests seine Node.js Version anzuheben bitte mal explizit NICHT die übliche Anleitung nach dem Node-js update mit dem Rebuild befolgen sondern ioBroker einfach nach dem Node.js Update starten. Interessant ist ob sich alles selbst "heilt" 🙂
                          Update wie beschrieben durchgeführt, Zigbee war veraltet beim ersten "Trying to rebuild it..." kein Erfolg danach kam dann ein zweiter Versuch welcher den Zigbee-Adapter wieder reparieren konnte.
                          Bis jetzt bei mir keine Probleme Top wie immer
                            @Thisoft ip ist korrekt? Port auch? Es sieht so aus als ob die dB Verbindung geschlossen wird. Sagt das logfile der Datenbank irgendwas?
                            Downgrade gern mal auf sql 1.9.x und schau was da passiert. Würde mich aber wundern wenn es da tut.
                            Thisoft 1 Reply Last reply Reply Quote 0
                              apollon77 @Peoples last edited by
                              @Peoples Jupp. So soll es quasi sein.
                              • Thisoft
                                Thisoft @apollon77 last edited by
                                @apollon77 Auch wenn Du's nicht erwartest, aber die Version 1.9.5 funktioniert. Was mir dabei allerdings auffällt, er führt beim Starten automatisch ein Rebuild aus:
                                2020-05-03 11:34:26.099 - info: host.ioBroker-Ubuntu Adapter system.adapter.sql.0 needs rebuild and will be restarted afterwards.
                                2020-05-03 11:34:26.099 - info: host.ioBroker-Ubuntu system.adapter.sql.0 will be rebuilt
                                2020-05-03 11:34:26.099 - warn: host.ioBroker-Ubuntu adapter "sql" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                2020-05-03 11:34:26.100 - info: host.ioBroker-Ubuntu iobroker rebuild sql --install
                                2020-05-03 11:34:26.240 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.sql"
                                2020-05-03 11:34:40.150 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: ../deps/libmagic/src/fsmagic.c: In function ‘file_fsmagic’:../deps/libmagic/src/fsmagic.c:223:13: warning: In the GNU C Library, "major" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "major", include directly. If you did not intend to use a system-defined macro "major", you should undefine it after including . COMMA, (long)major(sb->st_rdev), ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:224:13: warning: In the GNU C Library, "minor" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "minor", include directly. If you did not intend to use a system-defined macro "minor", you should undefine it after including . (long)minor(sb->st_rdev)) == -1) ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:258:13: warning: In the GNU C Library, "major" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "major", include directly. If you did not intend to use a system-defined macro "major", you should undefine it after including . COMMA, (long)major(sb->st_rdev), ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:259:13: warning: In the GNU C Library, "minor" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "minor", include directly. If you did not intend to use a system-defined macro "minor", you should undefine it after including . (long)minor(sb->st_rdev)) == -1) ^~~~~~~~~~~~~~~~~~~~~~~~~~~
                                2020-05-03 11:34:45.056 - info: host.ioBroker-Ubuntu iobroker npm-rebuild:
                                2020-05-03 11:34:45.057 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: Rebuild sql done
                                2020-05-03 11:34:46.060 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: exit 0
                                2020-05-03 11:34:46.082 - info: host.ioBroker-Ubuntu instance system.adapter.sql.0 started with pid 7239
                                Wenn ich wieder auf die 1.12 gehe macht er das nicht - und es funktioniert eben auch nicht...
                                Übrigens, ich hab einen MS-SQLServer im Einsatz. Ist der vielleicht zu selten um genug getestet zu sein 😉 ?
                                  Marty56 @apollon77 last edited by
                                  @apollon77 Würde ich natürlich machen, aber ich stehe mit dem VIS auf Kriegsfuß und blicke bis heute bei dem Tool nicht durch. Ich habe über die Zeit vermutlich irgendwo in den Verzeichnissen herumgefummelt und ich würde nicht ausschließen, dass ich da Mist gebaut habe und dass die Warnings drauf zurückzuführen sind.
                                    liv-in-sky @apollon77 last edited by
                                    @apollon77
                                    vis alleine ist das nicht
                                    habe auch von sayit meldungen - leider weiß ich nicht mehr, wo diese dateien herkommen (ob das standard dateien sind oder ob ich kopiert habe) - sayit habe ich schon ewig nicht mehr angesehen - die dateien liegen unter
                                    readFile	2020-05-03 16:03:35.104	warn	will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
                                    sayit.0	2020-05-03 16:03:35.103	warn	(423) readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
                                    readFile	2020-05-03 16:03:35.100	warn	will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
                                    sayit.0	2020-05-03 16:03:35.064	warn	(423) readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
                                    muss bei jedem adapter ein git issue angelegt werden ?
                                    crunchip apollon77 2 Replies Last reply Reply Quote 0
                                      crunchip Forum Testing Most Active @liv-in-sky last edited by
                                      @liv-in-sky hehe, ich schon wieder
                                      scheinbar standard Dateien, die habe ich auch, habe sie auch bereits gelöscht und werden wieder angelegt
                                        liv-in-sky @crunchip last edited by
                                        @crunchip bekommst du die warnungen auch im log ?
                                          @liv-in-sky ja
                                            @crunchip diese files finde ich wenigstens - die anderen von weiter oben finde ich nicht mal - da scheint tatsächlich irgendwo in der vis noch etwas altes zu stehen ???
                                            js-controller
                                            127
                                            1340
                                            433134
