    4. Hallo Tester.
    Hallo Tester.
    • derAuge
      derAuge last edited by
      Da ich meinen TestPi neu aufsetzen muss , bin ich dabei
      Jürgen
      • derAuge
        Hallo nochmal.
        Die Neuinstallation ist nun geschafft.
        Folgende Schritte wurden durchgeführt:
        ! 1. Download Raspbian Jessie Lite # Minimal image based on Debian Jessie (2016-03-18-raspbian-jessie-lite)
        ! https://downloads.raspberrypi.org/raspbian_lite_latest
        ! 2. Image auf SD-Karte bringen
        ! a.) die SD-Karte formatieren # Option = FORMAT SIZE AD JUSTMENT ON
        ! https://www.sdcard.org/downloads/format … tterv4.zip
        ! b.) auf SD-Karte kopieren
        ! https://sourceforge.net/projects/win32diskimager/
        ! 3. Karte einlegen und RPi starten
        ! 4. mit Putty per ssh am RPi anmelden
        ! 5. alle Konfigurationen durchführen
        ! sudo raspi-config
        ! 1 Expand Filesystem
        ! 2 Change User Password
        ! 3 Boot Options
        ! B1 Console Text console, requiring user to logi
        ! 4 Wait for Network at Boot
        ! Fast Boot without waiting for network connection
        ! 5 Internationalisation Options Set up language and regional settings to match your location │
        ! I1 Change Locale
        ! * de_DE.UTF-8 UTF-8
        Default locale for the system environment: de_DE.UTF-8
        I2 Change Timezone Set up timezone to match your location
        Geographic area: Europe
        Time zone: Berlin
        I3 Change Keyboard Layout Set the keyboard layout to match your keyboard
        Keyboard model: Generic 105-key (Intl) PC
        Keyboard layout: Other
        Country of origin for the keyboard: German
        Keyboard layout: German - German (qwerty)
        Key to function as AltGr: Right Alt (AltGr)
        Compose key: Left Logo key
        I4 Change Wi-fi Country Set the legal channels used in your country
        DE Germany
        6 Enable Camera # Enable support for Raspberry Pi camera? <disable>7 Add to Rastrack
        8 Overclock
        9 Advanced Options
        A1 Overscan You may need to configure overscan if black bars are present on display
        A2 Hostname Set the visible name for this Pi on a network
        RPi3-1
        A3 Memory Split Change the amount of memory made available to the GPU
        A4 SSH Enable/Disable remote command line access to your Pi using SSH
         <enable>A5 Device Tree Enable/Disable the use of Device Tree
        A6 SPI Enable/Disable automatic loading of SPI kernel module (needed for e.g. PiFace)
        A7 I2C Enable/Disable automatic loading of I2C kernel module
        A8 Serial Enable/Disable shell and kernel messages on the serial connection
        A9 Audio Force audio out through HDMI or 3.5mm jack
        AA GL Driver Enable/Disable experimental desktop GL driver
        A0 Update Update this tool to the latest version
        0 About raspi-config Information about this configuration tool
         <finish>6\. dem Nutzer Root ein Passwort vergeben
        sudo passwd root
        Enter new UNIX password:
        Retype new UNIX password:
        passwd: password updated successfully
        7\. System neu starten
        sudo reboot
        Broadcast message from pi@raspberrypi on pts/0 (Sat 2016-03-19 15:00:53 CET):
        The system is going down for reboot NOW!
        a.) mit Putty per ssh am RPi anmelden
        su
        Passwort:
        root@RPi2-1:/home/pi#
        nun sind wir als Root im System
        ##### System Update: (als Root angemeldet)
        apt-get update && apt-get upgrade -y
        ##### Installing Node.js via package manager #####
        curl -sL [https://deb.nodesource.com/setup_4.x](https://deb.nodesource.com/setup_4.x) | sudo -E bash -
        apt-get install -y nodejs
        ##### nodejs (4.4.3-1nodesource1~jessie1) wird eingerichtet …
        npm install npm -g
        uname -a && node -v && npm -v
        Folgendes System steht nun bereit:
         *   uname -a && node -v && npm -v
            Linux RPi2-1 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
            v4.4.3
            3.8.8
        Dann die installation laut Vorgabe im erstern Post:
        Siehe Log-File  ![315_rpi2-1_20160504_110438_install_test_millisekunden.log](/assets/uploads/files/315_rpi2-1_20160504_110438_install_test_millisekunden.log)
        Dort gibt es einige Warnungen
        Im AdminWebGui ist nun "nur" admin installiert
        wie soll es nun weiter gehen?
        Jürgen</finish></enable></disable>
        • derAuge
          Beim versuch nun über WebUI den SQL-Adapter zu installieren:
          2016-05-04 12:52:45.851  - info: iobroker add sql
          2016-05-04 12:52:48.846  - info: iobroker host.RPi2-1 install adapter sql
          2016-05-04 12:52:48.852  - info: iobroker npm install --production --prefix "/opt/iobroker/node_modules/iobroker.sql" (System call)
          2016-05-04 12:55:42.666  - info: iobroker npm
          2016-05-04 12:55:42.677  - info: iobroker  ERR! Linux 4.1.19-v7+
          2016-05-04 12:55:42.697  - info: iobroker npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.sql"npm ERR! node v4.4.3
          npm ERR! npm  v3.8.8
          npm ERR! path /opt/iobroker/node_modules/iobroker.sql/node_modules/.staging/iobroker.sql-15764de6
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall rename
          2016-05-04 12:55:42.715  - info: iobroker
          2016-05-04 12:55:42.729  - info: iobroker npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.sql/node_modules/.staging/iobroker.sql-15764de6' -> '/opt/iobroker/node_modules/iobroker.sql'
          2016-05-04 12:55:42.739  - info: iobroker npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.sql/node_modules/.staging/iobroker.sql-15764de6' -> '/opt/iobroker/node_modules/iobroker.sql'npm ERR! enoent This is most likely not a problem with npm itself
          npm ERR! enoent and is related to npm not being able to find a file.
          npm ERR! enoent
          2016-05-04 12:55:43.345  - info: iobroker
          2016-05-04 12:55:43.349  - info: iobroker npm
          2016-05-04 12:55:43.357  - info: iobroker ERR! Please include the following file with any support request:npm ERR!     /opt/npm-debug.log
          2016-05-04 12:55:43.445  - info: iobroker Cannot install iobroker.sql: 254
          2016-05-04 12:55:43.478  - info: iobroker exit 25
          • eric2905
            eric2905 last edited by
            Da mein Pine64 (mit 2 GB RAM) auch da ist und mittlerweile läuft, werde ich das auch mit ausprobieren (auf Ubuntu).
            Wird spannend 😄
            Gruß,
            Eric
              RS_Tobi last edited by
              bin gerade am Installieren, soll ich mal eine bestimmte NODE version ausprobieren?
              mfg
              Tobi
                um noch einen Exoten vorzustellen: Ich habe eben meinen BananaPi M3 mit Raspbian Lite for BPi beglückt, node js nach der Schnellanleitung für RasPi installiert:
                curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
                sudo apt-get install -y build-essential python-rpi.gpio nodejs
                und anschließend ioBroker nach Bluefox' code im ersten Post.
                Lief wunderbar durch bis auf die Warnuung der veralteten Versionen von Jade und graceful-fs.
                Ich werde mal einige andere Adapter hinzuladen und dann sehen wir mal weiter.
                Rainer
                • ruhr70
                  ruhr70 last edited by
                  Müsste nicht die nächste Stufe der Tests ein Update laufender Systeme sein?
                    Da sind ja die richtigen zusammen 😉
                    Habe die neue Version natürlich direkt nutzen wollen um ruhr70s Buetoothscanner unter Raspbian for BPi zu testen.
                    Der javascript Adapter scheint Probleme zu machen. Leider bin ich da wohl nicht der Richtige um das näher einzugrenzen.
                    Zuerst hatte sich unter Objekte der Ordner javascript.0 zweimal angelegt.
                    im ersten die Ordner bluetooth und scriptEnabled; im zweiten zweimal der Ordner SkriptEnabled.
                    Nach einem iobroker stop und iobroker start das jedoch in der "Langschreibweise eingegeben werden musste:
                    root@BPi-M3:/opt/iobroker# node node_modules/iobroker.js-controller/iobroker.js stop
                    Stopping iobroker controller daemon...
                    iobroker controller daemon stopped.
                    Exit code for "killall.sh": 0
                    root@BPi-M3:/opt/iobroker# node node_modules/iobroker.js-controller/iobroker.js start
                    Starting iobroker controller daemon...
                    iobroker controller daemon started. PID: 2601
                    sah es erst mal gut aus - Inzwischen scaltet sich der js-Adapter immer nur kurz grün und lange rot.
                    Das log zeigt folgendes:
                    host-BPi-M3 04 20:39:59.503 info Restart adapter system.adapter.javascript.0 because enabled
                    host-BPi-M3 04 20:39:59.503 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                    TypeError: 04 20:39:59.454 error at Timer.listOnTimeout (timers.js:92:15)
                    TypeError: 04 20:39:59.454 error at [object Object].ontimeout [as _onTimeout] (timers.js:209:34)
                    TypeError: 04 20:39:59.454 error at [object Object]. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1720:44)
                    TypeError: 04 20:39:59.454 error at Object.main (script.js.Bluetoothscanner:1840:63)
                    TypeError: 04 20:39:59.454 error at datum (script.js.Bluetoothscanner:909:12)
                    TypeError: 04 20:39:59.454 error at sandbox.formatDate (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1759:32)
                    TypeError: 04 20:39:59.454 error at Adapter.formatDate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1661:28)
                    TypeError: 04 20:39:59.454 error isDuration.toLowerCase is not a function
                    uncaught 04 20:39:59.437 error exception: isDuration.toLowerCase is not a function
                    javascript-0 04 20:39:58.427 info script.js.Bluetoothscanner: registered 0 subscriptions and 0 schedules
                    javascript-0 04 20:39:58.421 info script.js.Bluetoothscanner: debug2: dpAnlegen() - Datenpunkte angelegt (createState) in javascript.0.Bluetooth.
                    javascript-0 04 20:39:58.404 info script.js.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
                    javascript-0 04 20:39:58.404 info script.js.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
                    javascript-0 04 20:39:58.400 info script.js.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
                    javascript-0 04 20:39:58.399 info script.js.Bluetoothscanner: --== script.js.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
                    javascript-0 04 20:39:58.212 info Start javascript script.js.Bluetoothscanner
                    javascript-0 04 20:39:58.123 info received all objects
                    javascript-0 04 20:39:57.992 info received all states
                    javascript-0 04 20:39:57.730 info requesting all objects
                    javascript-0 04 20:39:57.725 info requesting all states
                    javascript-0 04 20:39:57.697 info starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.javascript
                    host-BPi-M3 04 20:39:52.899 info instance system.adapter.javascript.0 started with pid 3052
                    host-BPi-M3 04 20:39:22.861 info Restart adapter system.adapter.javascript.0 because enabled
                    in der browserkonsole erschien:
                    Error: Fancytree assertion failed: scrollIntoView node is invisible
                    Stack-Trace:
                    .error@http://192.168.138.49:8081/lib/js/jquery-1.11.1.min.js:2:1809
                    e@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:67
                    q.prototype.scrollIntoView@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:15146
                    q.prototype.makeVisible/<@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:11524
                    m.Callbacks/j@http://192.168.138.49:8081/lib/js/jquery-1.11.1.min.js:2:27239
                    m.Callbacks/k.add@http://192.168.138.49:8081/lib/js/jquery-1.11.1.min.js:2:27553
                    q.prototype.makeVisible@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:11488
                    showActive/<@http://192.168.138.49:8081/js/selectID.js:392:25
                    q.prototype.visit@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:17234
                    q.prototype.visit@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:17303
                    r.prototype.visit@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:22898
                    showActive@http://192.168.138.49:8081/js/selectID.js:388:13
                    methods.show@http://192.168.138.49:8081/js/selectID.js:2078:21
                    $.fn.selectId@http://192.168.138.49:8081/js/selectID.js:2360:20
                    Scripts/this.init@http://192.168.138.49:8081/adapter/javascript/tab.js:717:1
                    getObjects/
                    Weitere Info gerne
                    Rainer
                    • eric2905
                      <u>SQL-Adapter</u>
                      Host: Raspberry Pi2 B+
                      Image: von "unserer" Webseite
                      Konfig :
                      DB-Type: SQLite3
                      Datei für sqlite: sqlite.db
                      Entprellzeit: 10000
                      Vorhaltezei:t 1 Jahr
                      sql-0	05 05:56:33.043	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427781018, 49.98, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                      sql-0	05 05:55:54.056	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427743028, 49.98, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                      sql-0	05 05:54:41.047	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1462427679960, 231.1, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                      sql-0	05 05:54:26.093	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427662018, 49.99, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                      sql-0	05 05:53:15.425	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427590980, 49.98, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                      • ruhr70
                        Auf Ubuntu 16.04. Server installiert.
                        node v4.4.3
                        npm 2.15.1
                        SQL-Adpater mit der mitinstallierten sqlite.
                        Alle neuen Adapter plus dem Javascript Adapter. Derzeit nichts auffälliges.
                        Nur die beiden Warnungen am Anfang:````
                        npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
                        npm WARN deprecated graceful-fs@2.0.3: graceful-fs v3.0.0 and before will fail on node releases >= v6.0. Please update to graceful-fs@^4.0.0 as soon as possible. Use 'npm ls graceful-fs' to find it in the tree.
                        Ich spiele dann mal ein paar Szenarien durch.
                        • Bluefox
                          Bluefox last edited by
                          Ok.
                          Danke. So muss es auch sein. Laufen. 8-)
                          Achte bitte auf die Charts.
                          • ruhr70
                            die Meldung habe ich auch:
                            sql-0	05 15:12:26.167	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462453935160, 56.14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                            • eric2905
                              Ich mache nachher den Raspi komplett platt, installiere ein nackiges Image und installiere alles neu/manuell.
                              Mal sehen, ob der SQL-Adapter dann ohne Meldung läuft.
                              • ruhr70
                                @ruhr70:
                                node v4.4.3
                                npm 2.15.1
                                Ich spiele dann mal ein paar Szenarien durch. `
                                Gerade den Host mit der VM neu gestartet. Danach lief ioBroker nicht. Ich wollte es dann manuell starten, aber "iobroker" fehlt :?: :shock:
                                root@ubuntu-1604-dev:/opt/iobroker# ls
                                etc  iobroker-data  killall.sh  log  node_modules  reinstall.sh
                                  @ruhr70:
                                  Ich wollte es dann manuell starten, aber "iobroker" fehlt :?: :shock: `
                                  Wie denn?
                                  so?
                                  aus /opt/iobroker klappt es nicht!
                                  siehe auch:
                                  http://forum.iobroker.net/viewtopic.php … 789#p25195
                                  Rainer
                                  • ruhr70
                                    @Homoran:
                                    siehe auch:
                                    http://forum.iobroker.net/viewtopic.php … 789#p25195 `
                                    OK. Das war etwas voreilig 😄
                                    ````funktioniert.
                                    Die Datei ****iobroker**** wurde nur nicht angelegt.
                                    Ich hab jetzt das erste Mal reingeschaut, was da überhaupt drin steht :oops: :
                                    node node_modules/iobroker.js-controller/iobroker.js $1 $2 $3 $4 $5
                                    Und Autostart ist mit der Testinstallation nicht aktiv.
                                      Hi Leute,
                                      mal ein Lob und großes DANKESCHÖN an alle mitwirkenden und Bluefox.
                                      Ich habe auch getestet und zwar mit meiner "alten" Himbeere.
                                      FAZIT: Läuft besser, schneller und meines Erachtens auch wesentlicher Stabiler als das was ich vor 4 Wochen
                                      neu aufgesetzt habe.
                                      Früher musste ich meinen Admin oft 2 bis 3 mal aktualliesiern bis er mir alle Icons geladen hat und die Adapter in den
                                      Unterordner richtig hinterlegt hat.
                                      Nun habe ich damit keinerlei Probleme mehr. Funktioniert aufs erste mal.
                                      Davor hat ich auch dieses Problem beim Adapter installieren. http://forum.iobroker.net/viewtopic.php?f=22&t=1544
                                      Dieser ist bisher noch nicht aufgetaucht! (derzeit 3 Adapter installiert)
                                      Meine HARDWARE:
                                      Raspberry Pi 1 B+
                                      Jessie Lite image
                                      Vorgehensweise und alle Infos zum System und zur Installation hier im Spoiler.
                                      ! sudo raspi-config
                                      ! sudo nano /etc/ssh/sshd_config
                                      ! sudo /etc/init.d/ssh restart
                                      ! sudo su
                                      ! passwd
                                      ! sudo apt-get update && sudo apt-get upgrade
                                      ! reboot
                                      ! apt-get install npm
                                      ! apt-get install git
                                      ! reboot
                                      ! wget https://nodejs.org/dist/v4.4.3/node-v4. … v6l.tar.xz
                                      ! sudo tar -xvf node-v4.4.3-linux-armv6l.tar.xz
                                      ! cd node-v4.4.3-linux-armv6l
                                      ! sudo cp -R * /usr/local/
                                      ! sudo apt-get install build-essential python-rpi.gpio nodejs
                                      ! root@raspberrypi:~# uname -a && node -v && nodejs -v && npm -v
                                      ! Linux raspberrypi 4.1.19+ #858 Tue Mar 15 15:52:03 GMT 2016 armv6l GNU/Linux
                                      ! v4.4.3
                                      ! v0.10.29
                                      ! 2.15.1
                                      ! Reboot
                                      ! mkdir /opt/iobroker
                                      ! cd /opt/iobroker
                                      ! sudo chmod 777 .
                                      ! sudo npm install https://github.com/ioBroker/ioBroker.js ... all/master --production
                                      ! iobroker.js-controller@0.8.10 node_modules/iobroker.js-controller
                                      ! ├── mime@1.3.4
                                      ! ├── daemonize2@0.4.2
                                      ! ├── adm-zip@0.4.7
                                      ! ├── ncp@2.0.0
                                      ! ├── semver@4.3.6
                                      ! ├── node.extend@1.1.5 (is@3.1.0)
                                      ! ├── node-schedule@1.0.0 (long-timeout@0.0.2, cron-parser@1.1.0)
                                      ! ├── winston@2.2.0 (cycle@1.0.3, stack-trace@0.0.9, isstream@0.1.2, eyes@0.1.8, async@1.0.0, pkginfo@0.3.1, colors@1.0.3)
                                      ! ├── yargs@3.32.0 (decamelize@1.2.0, camelcase@2.1.1, y18n@3.2.1, window-size@0.1.4, cliui@3.2.0, os-locale@1.4.0, string-width@1.0.1)
                                      ! ├── winston-daily-rotate-file@1.0.1 (winston@2.1.1)
                                      ! ├── socket.io@1.4.6 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, socket.io-adapter@0.4.0, engine.io@1.6.9)
                                      ! ├── socket.io-client@1.4.6 (to-array@0.1.4, component-emitter@1.2.0, indexof@0.0.1, object-component@0.0.3, component-bind@1.0.0, backo2@1.0.2, has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, parseuri@0.0.4, engine.io-client@1.6.9)
                                      ! ├── prompt@1.0.0 (revalidator@0.1.8, pkginfo@0.4.0, colors@1.1.2, read@1.0.7, winston@2.1.1, utile@0.3.0)
                                      ! ├── request@2.72.0 (tunnel-agent@0.4.3, aws-sign2@0.6.0, forever-agent@0.6.1, oauth-sign@0.8.2, is-typedarray@1.0.0, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, tough-cookie@2.2.2, node-uuid@1.4.7, qs@6.1.0, combined-stream@1.0.5, mime-types@2.1.11, form-data@1.0.0-rc4, aws4@1.3.2, hawk@3.1.3, bl@1.1.2, http-signature@1.1.1, har-validator@2.0.6)
                                      ! ├── iobroker.admin@1.0.3 (connect-flash@0.1.1, xtend@4.0.1, cookie-parser@1.4.1, passport-local@1.0.0, passport@0.2.2, express-session@1.13.0, body-parser@1.15.1, express@4.13.4)
                                      ! ├── tar.gz@1.0.3 (commander@2.9.0, bluebird@2.10.2, tar@2.2.1, chai@3.5.0, fstream@1.0.8, mocha@2.4.5, mout@0.11.1)
                                      ! └── npm@2.15.5
                                      ! sudo npm install https://github.com/ioBroker/ioBroker.ad ... all/master --production
                                      ! iobroker.admin@1.1.1 node_modules/iobroker.admin
                                      ! ├── connect-flash@0.1.1
                                      ! ├── xtend@4.0.1
                                      ! ├── cookie-parser@1.4.1 (cookie-signature@1.0.6, cookie@0.2.3)
                                      ! ├── passport-local@1.0.0 (passport-strategy@1.0.0)
                                      ! ├── passport@0.2.2 (pause@0.0.1, passport-strategy@1.0.0)
                                      ! ├── express-session@1.13.0 (cookie-signature@1.0.6, utils-merge@1.0.0, on-headers@1.0.1, parseurl@1.3.1, cookie@0.2.3, depd@1.1.0, crc@3.4.0, uid-safe@2.0.0, debug@2.2.0)
                                      ! ├── body-parser@1.15.1 (content-type@1.0.1, bytes@2.3.0, depd@1.1.0, raw-body@2.1.6, http-errors@1.4.0, qs@6.1.0, on-finished@2.3.0, debug@2.2.0, iconv-lite@0.4.13, type-is@1.6.12)
                                      ! ├── express@4.13.4 (escape-html@1.0.3, utils-merge@1.0.0, cookie-signature@1.0.6, content-type@1.0.1, merge-descriptors@1.0.1, methods@1.1.2, vary@1.0.1, content-disposition@0.5.1, cookie@0.1.5, fresh@0.3.0, parseurl@1.3.1, range-parser@1.0.3, serve-static@1.10.2, etag@1.7.0, array-flatten@1.1.1, path-to-regexp@0.1.7, depd@1.1.0, qs@4.0.0, finalhandler@0.4.1, on-finished@2.3.0, debug@2.2.0, proxy-addr@1.0.10, send@0.13.1, accepts@1.2.13, type-is@1.6.12)
                                      ! ├── socket.io@1.4.6 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, socket.io-adapter@0.4.0, engine.io@1.6.9, socket.io-client@1.4.6)
                                      ! └── request@2.72.0 (aws-sign2@0.6.0, tunnel-agent@0.4.3, forever-agent@0.6.1, oauth-sign@0.8.2, is-typedarray@1.0.0, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, tough-cookie@2.2.2, node-uuid@1.4.7, qs@6.1.0, combined-stream@1.0.5, mime-types@2.1.11, form-data@1.0.0-rc4, aws4@1.3.2, bl@1.1.2, hawk@3.1.3, http-signature@1.1.1, har-validator@2.0.6)
                                      ! sudo npm install https://github.com/ioBroker/ioBroker.sql/tarball/master --production
                                      ! > sqlite3@3.1.3 install /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
                                      ! > node-pre-gyp install --fallback-to-build
                                      ! make: Entering directory '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/build'
                                      ! ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3090100/sqlite3.c
                                      ! TOUCH Release/obj.target/deps/action_before_build.stamp
                                      ! CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3090100/sqlite3.o
                                      ! AR(target) Release/obj.target/deps/sqlite3.a
                                      ! COPY Release/sqlite3.a
                                      ! CXX(target) Release/obj.target/node_sqlite3/src/database.o
                                      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
                                      ! ../src/database.cc:143:9: warning: unused variable ‘status’ [-Wunused-variable]
                                      ! int status = uv_queue_work(uv_default_loop(),
                                      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:
                                      ! ../src/database.cc:227:9: warning: unused variable ‘status’ [-Wunused-variable]
                                      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:
                                      ! ../src/database.cc:505:9: warning: unused variable ‘status’ [-Wunused-variable]
                                      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:
                                      ! ../src/database.cc:605:9: warning: unused variable ‘status’ [-Wunused-variable]
                                      ! CXX(target) Release/obj.target/node_sqlite3/src/node_sqlite3.o
                                      ! CXX(target) Release/obj.target/node_sqlite3/src/statement.o
                                      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:
                                      ! ../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
                                      ! In file included from ../src/statement.cc:6:0:
                                      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
                                      ! ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                      ! ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                      ! STATEMENT_BEGIN(Bind);
                                      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:
                                      ! ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                      ! STATEMENT_BEGIN(Get);
                                      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
                                      ! ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                      ! STATEMENT_BEGIN(Run);
                                      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:
                                      ! ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                      ! STATEMENT_BEGIN(All);
                                      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:
                                      ! ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                      ! STATEMENT_BEGIN(Each);
                                      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:
                                      ! ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                      ! STATEMENT_BEGIN(Reset);
                                      ! SOLINK_MODULE(target) Release/obj.target/node_sqlite3.node
                                      ! COPY Release/node_sqlite3.node
                                      ! COPY /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm/node_sqlite3.node
                                      ! TOUCH Release/obj.target/action_after_build.stamp
                                      ! make: Leaving directory '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/build'
                                      ! iobroker.sql@0.2.0 node_modules/iobroker.sql
                                      ! ├── mysql@2.10.2 (bignumber.js@2.1.4, readable-stream@1.1.14)
                                      ! ├── pg@4.5.5 (packet-reader@0.2.0, pg-connection-string@0.1.3, generic-pool@2.1.1, buffer-writer@1.0.1, semver@4.3.6, pg-types@1.11.0, pgpass@0.0.3)
                                      ! ├── sql-client@0.7.0 (argf@0.0.1, optimist@0.6.1, inote-util@0.8.1)
                                      ! ├── mssql@3.2.1 (generic-pool@2.4.2, promise@7.1.1, tedious@1.14.0)
                                      ! └── sqlite3@3.1.3 (nan@2.2.1)
                                      ! sudo npm install https://github.com/ioBroker/ioBroker.hi … all/master --production
                                      ! iobroker.history@0.4.0 node_modules/iobroker.history
                                      ! sudo npm install https://github.com/ioBroker/ioBroker.fl ... all/master --production
                                      ! iobroker.flot@1.2.0 node_modules/iobroker.flot
                                      ! sudo npm install https://github.com/ioBroker/ioBroker.ri ... all/master --production
                                      ! iobroker.rickshaw@0.4.0 node_modules/iobroker.rickshaw
                                      ! sudo chmod 777 * -R
                                      ! node node_modules/iobroker.js-controller/iobroker.js start
                                      ! Starting iobroker controller daemon...
                                      ! iobroker controller daemon started. PID: 961
                                      • Bluefox
                                        @ruhr70:
                                        @Homoran:
                                        siehe auch:
                                        ````funktioniert.
                                        Und Autostart ist mit der Testinstallation nicht aktiv. `
                                        Autostart und die Datei "iobroker" wird nur wenn man mit "npm install iobroker" installiert.
                                        Diese Installation nimmt aber die Versionen von NPM. Und ich will, dass ihr GITHUB testet. 8-)
                                        • derAuge
                                          HAbe nochmal neu installiert.
                                          nun funktioniert die installation
                                          root@RPi2-1:/opt/iobroker#  uname -a && node -v && nodejs -v && npm -v
                                          v4.4.3
                                          v0.10.29
                                          2.15.1
                                          Ein Adapter zickt noch ein wenig:
                                          2016-05-06 16:30:12.045 - info: host.RPi2-1 Restart adapter system.adapter.history.0 because enabled
                                          2016-05-06 16:30:42.074 - info: host.RPi2-1 instance system.adapter.history.0 started with pid 930
                                          2016-05-06 16:30:42.768 - error: host.RPi2-1 instance system.adapter.history.0 terminated with code 1 ()
                                          2016-05-06 16:30:42.769 - info: host.RPi2-1 Restart adapter system.adapter.history.0 because enabled
                                          2016-05-06 16:31:12.802 - info: host.RPi2-1 instance system.adapter.history.0 started with pid 935
                                          2016-05-06 16:31:13.543 - error: host.RPi2-1 instance system.adapter.history.0 terminated with code 1 ()
                                          2016-05-06 16:31:13.545 - info: host.RPi2-1 Restart adapter system.adapter.history.0 because enabled
                                          habe ihn schon mal gelöscht und wieder neu installiert. keine änderung
                                          Jürgen
                                          • Bluefox
                                            @derAuge:
                                            v4.4.3
                                            v0.10.29
                                            2.15.1
                                            Jürgen `
                                            Ich habe history gefixt. Bitte updaten
                                            7171
