    4. Hallo Tester.
    Hallo Tester.
    • derAuge
      derAuge last edited by
      Hallo nochmal.
      Die Neuinstallation ist nun geschafft.
      Folgende Schritte wurden durchgeführt:
      ! 1. Download Raspbian Jessie Lite # Minimal image based on Debian Jessie (2016-03-18-raspbian-jessie-lite)
      ! https://downloads.raspberrypi.org/raspbian_lite_latest
      ! 2. Image auf SD-Karte bringen
      ! a.) die SD-Karte formatieren # Option = FORMAT SIZE AD JUSTMENT ON
      ! https://www.sdcard.org/downloads/format … tterv4.zip
      ! b.) auf SD-Karte kopieren
      ! https://sourceforge.net/projects/win32diskimager/
      ! 3. Karte einlegen und RPi starten
      ! 4. mit Putty per ssh am RPi anmelden
      ! 5. alle Konfigurationen durchführen
      ! sudo raspi-config
      ! 1 Expand Filesystem
      ! 2 Change User Password
      ! 3 Boot Options
      ! B1 Console Text console, requiring user to logi
      ! 4 Wait for Network at Boot
      ! Fast Boot without waiting for network connection
      ! 5 Internationalisation Options Set up language and regional settings to match your location │
      ! I1 Change Locale
      ! * de_DE.UTF-8 UTF-8
      Default locale for the system environment: de_DE.UTF-8
      I2 Change Timezone Set up timezone to match your location
      Geographic area: Europe
      Time zone: Berlin
      I3 Change Keyboard Layout Set the keyboard layout to match your keyboard
      Keyboard model: Generic 105-key (Intl) PC
      Keyboard layout: Other
      Country of origin for the keyboard: German
      Keyboard layout: German - German (qwerty)
      Key to function as AltGr: Right Alt (AltGr)
      Compose key: Left Logo key
      I4 Change Wi-fi Country Set the legal channels used in your country
      DE Germany
      6 Enable Camera # Enable support for Raspberry Pi camera? <disable>7 Add to Rastrack
      8 Overclock
      9 Advanced Options
      A1 Overscan You may need to configure overscan if black bars are present on display
      A2 Hostname Set the visible name for this Pi on a network
      RPi3-1
      A3 Memory Split Change the amount of memory made available to the GPU
      A4 SSH Enable/Disable remote command line access to your Pi using SSH
       <enable>A5 Device Tree Enable/Disable the use of Device Tree
      A6 SPI Enable/Disable automatic loading of SPI kernel module (needed for e.g. PiFace)
      A7 I2C Enable/Disable automatic loading of I2C kernel module
      A8 Serial Enable/Disable shell and kernel messages on the serial connection
      A9 Audio Force audio out through HDMI or 3.5mm jack
      AA GL Driver Enable/Disable experimental desktop GL driver
      A0 Update Update this tool to the latest version
      0 About raspi-config Information about this configuration tool
       <finish>6\. dem Nutzer Root ein Passwort vergeben
      sudo passwd root
      Enter new UNIX password:
      Retype new UNIX password:
      passwd: password updated successfully
      7\. System neu starten
      sudo reboot
      Broadcast message from pi@raspberrypi on pts/0 (Sat 2016-03-19 15:00:53 CET):
      The system is going down for reboot NOW!
      a.) mit Putty per ssh am RPi anmelden
      su
      Passwort:
      root@RPi2-1:/home/pi#
      nun sind wir als Root im System
      ##### System Update: (als Root angemeldet)
      apt-get update && apt-get upgrade -y
      ##### Installing Node.js via package manager #####
      curl -sL [https://deb.nodesource.com/setup_4.x](https://deb.nodesource.com/setup_4.x) | sudo -E bash -
      apt-get install -y nodejs
      ##### nodejs (4.4.3-1nodesource1~jessie1) wird eingerichtet …
      npm install npm -g
      uname -a && node -v && npm -v
      Folgendes System steht nun bereit:
       *   uname -a && node -v && npm -v
          Linux RPi2-1 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
          v4.4.3
          3.8.8
      Dann die installation laut Vorgabe im erstern Post:
      Siehe Log-File  ![315_rpi2-1_20160504_110438_install_test_millisekunden.log](/assets/uploads/files/315_rpi2-1_20160504_110438_install_test_millisekunden.log)
      Dort gibt es einige Warnungen
      Im AdminWebGui ist nun "nur" admin installiert
      wie soll es nun weiter gehen?
      Jürgen</finish></enable></disable>
      • derAuge
        Beim versuch nun über WebUI den SQL-Adapter zu installieren:
        2016-05-04 12:52:45.851  - info: iobroker add sql
        2016-05-04 12:52:48.846  - info: iobroker host.RPi2-1 install adapter sql
        2016-05-04 12:52:48.852  - info: iobroker npm install --production --prefix "/opt/iobroker/node_modules/iobroker.sql" (System call)
        2016-05-04 12:55:42.666  - info: iobroker npm
        2016-05-04 12:55:42.677  - info: iobroker  ERR! Linux 4.1.19-v7+
        2016-05-04 12:55:42.697  - info: iobroker npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.sql"npm ERR! node v4.4.3
        npm ERR! npm  v3.8.8
        npm ERR! path /opt/iobroker/node_modules/iobroker.sql/node_modules/.staging/iobroker.sql-15764de6
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall rename
        2016-05-04 12:55:42.715  - info: iobroker
        2016-05-04 12:55:42.729  - info: iobroker npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.sql/node_modules/.staging/iobroker.sql-15764de6' -> '/opt/iobroker/node_modules/iobroker.sql'
        2016-05-04 12:55:42.739  - info: iobroker npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.sql/node_modules/.staging/iobroker.sql-15764de6' -> '/opt/iobroker/node_modules/iobroker.sql'npm ERR! enoent This is most likely not a problem with npm itself
        npm ERR! enoent and is related to npm not being able to find a file.
        npm ERR! enoent
        2016-05-04 12:55:43.345  - info: iobroker
        2016-05-04 12:55:43.349  - info: iobroker npm
        2016-05-04 12:55:43.357  - info: iobroker ERR! Please include the following file with any support request:npm ERR!     /opt/npm-debug.log
        2016-05-04 12:55:43.445  - info: iobroker Cannot install iobroker.sql: 254
        2016-05-04 12:55:43.478  - info: iobroker exit 25
        • eric2905
          eric2905 last edited by
          Da mein Pine64 (mit 2 GB RAM) auch da ist und mittlerweile läuft, werde ich das auch mit ausprobieren (auf Ubuntu).
          Wird spannend 😄
          Gruß,
          Eric
            RS_Tobi last edited by
            bin gerade am Installieren, soll ich mal eine bestimmte NODE version ausprobieren?
            mfg
            Tobi
              um noch einen Exoten vorzustellen: Ich habe eben meinen BananaPi M3 mit Raspbian Lite for BPi beglückt, node js nach der Schnellanleitung für RasPi installiert:
              curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
              sudo apt-get install -y build-essential python-rpi.gpio nodejs
              und anschließend ioBroker nach Bluefox' code im ersten Post.
              Lief wunderbar durch bis auf die Warnuung der veralteten Versionen von Jade und graceful-fs.
              Ich werde mal einige andere Adapter hinzuladen und dann sehen wir mal weiter.
              Rainer
              • ruhr70
                ruhr70 last edited by
                Müsste nicht die nächste Stufe der Tests ein Update laufender Systeme sein?
                  Da sind ja die richtigen zusammen 😉
                  Habe die neue Version natürlich direkt nutzen wollen um ruhr70s Buetoothscanner unter Raspbian for BPi zu testen.
                  Der javascript Adapter scheint Probleme zu machen. Leider bin ich da wohl nicht der Richtige um das näher einzugrenzen.
                  Zuerst hatte sich unter Objekte der Ordner javascript.0 zweimal angelegt.
                  im ersten die Ordner bluetooth und scriptEnabled; im zweiten zweimal der Ordner SkriptEnabled.
                  Nach einem iobroker stop und iobroker start das jedoch in der "Langschreibweise eingegeben werden musste:
                  root@BPi-M3:/opt/iobroker# node node_modules/iobroker.js-controller/iobroker.js stop
                  Stopping iobroker controller daemon...
                  iobroker controller daemon stopped.
                  Exit code for "killall.sh": 0
                  root@BPi-M3:/opt/iobroker# node node_modules/iobroker.js-controller/iobroker.js start
                  Starting iobroker controller daemon...
                  iobroker controller daemon started. PID: 2601
                  sah es erst mal gut aus - Inzwischen scaltet sich der js-Adapter immer nur kurz grün und lange rot.
                  Das log zeigt folgendes:
                  host-BPi-M3 04 20:39:59.503 info Restart adapter system.adapter.javascript.0 because enabled
                  host-BPi-M3 04 20:39:59.503 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                  TypeError: 04 20:39:59.454 error at Timer.listOnTimeout (timers.js:92:15)
                  TypeError: 04 20:39:59.454 error at [object Object].ontimeout [as _onTimeout] (timers.js:209:34)
                  TypeError: 04 20:39:59.454 error at [object Object]. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1720:44)
                  TypeError: 04 20:39:59.454 error at Object.main (script.js.Bluetoothscanner:1840:63)
                  TypeError: 04 20:39:59.454 error at datum (script.js.Bluetoothscanner:909:12)
                  TypeError: 04 20:39:59.454 error at sandbox.formatDate (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1759:32)
                  TypeError: 04 20:39:59.454 error at Adapter.formatDate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1661:28)
                  TypeError: 04 20:39:59.454 error isDuration.toLowerCase is not a function
                  uncaught 04 20:39:59.437 error exception: isDuration.toLowerCase is not a function
                  javascript-0 04 20:39:58.427 info script.js.Bluetoothscanner: registered 0 subscriptions and 0 schedules
                  javascript-0 04 20:39:58.421 info script.js.Bluetoothscanner: debug2: dpAnlegen() - Datenpunkte angelegt (createState) in javascript.0.Bluetooth.
                  javascript-0 04 20:39:58.404 info script.js.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
                  javascript-0 04 20:39:58.404 info script.js.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
                  javascript-0 04 20:39:58.400 info script.js.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
                  javascript-0 04 20:39:58.399 info script.js.Bluetoothscanner: --== script.js.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
                  javascript-0 04 20:39:58.212 info Start javascript script.js.Bluetoothscanner
                  javascript-0 04 20:39:58.123 info received all objects
                  javascript-0 04 20:39:57.992 info received all states
                  javascript-0 04 20:39:57.730 info requesting all objects
                  javascript-0 04 20:39:57.725 info requesting all states
                  javascript-0 04 20:39:57.697 info starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.javascript
                  host-BPi-M3 04 20:39:52.899 info instance system.adapter.javascript.0 started with pid 3052
                  host-BPi-M3 04 20:39:22.861 info Restart adapter system.adapter.javascript.0 because enabled
                  in der browserkonsole erschien:
                  Error: Fancytree assertion failed: scrollIntoView node is invisible
                  Stack-Trace:
                  .error@http://192.168.138.49:8081/lib/js/jquery-1.11.1.min.js:2:1809
                  e@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:67
                  q.prototype.scrollIntoView@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:15146
                  q.prototype.makeVisible/<@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:11524
                  m.Callbacks/j@http://192.168.138.49:8081/lib/js/jquery-1.11.1.min.js:2:27239
                  m.Callbacks/k.add@http://192.168.138.49:8081/lib/js/jquery-1.11.1.min.js:2:27553
                  q.prototype.makeVisible@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:11488
                  showActive/<@http://192.168.138.49:8081/js/selectID.js:392:25
                  q.prototype.visit@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:17234
                  q.prototype.visit@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:17303
                  r.prototype.visit@http://192.168.138.49:8081/lib/js/jquery.fancytree-all.min.js:12:22898
                  showActive@http://192.168.138.49:8081/js/selectID.js:388:13
                  methods.show@http://192.168.138.49:8081/js/selectID.js:2078:21
                  $.fn.selectId@http://192.168.138.49:8081/js/selectID.js:2360:20
                  Scripts/this.init@http://192.168.138.49:8081/adapter/javascript/tab.js:717:1
                  getObjects/
                  Weitere Info gerne
                  Rainer
                  • eric2905
                    <u>SQL-Adapter</u>
                    Host: Raspberry Pi2 B+
                    Image: von "unserer" Webseite
                    Konfig :
                    DB-Type: SQLite3
                    Datei für sqlite: sqlite.db
                    Entprellzeit: 10000
                    Vorhaltezei:t 1 Jahr
                    sql-0	05 05:56:33.043	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427781018, 49.98, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                    sql-0	05 05:55:54.056	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427743028, 49.98, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                    sql-0	05 05:54:41.047	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1462427679960, 231.1, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                    sql-0	05 05:54:26.093	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427662018, 49.99, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                    sql-0	05 05:53:15.425	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462427590980, 49.98, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                    • ruhr70
                      Auf Ubuntu 16.04. Server installiert.
                      node v4.4.3
                      npm 2.15.1
                      SQL-Adpater mit der mitinstallierten sqlite.
                      Alle neuen Adapter plus dem Javascript Adapter. Derzeit nichts auffälliges.
                      Nur die beiden Warnungen am Anfang:````
                      npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
                      npm WARN deprecated graceful-fs@2.0.3: graceful-fs v3.0.0 and before will fail on node releases >= v6.0. Please update to graceful-fs@^4.0.0 as soon as possible. Use 'npm ls graceful-fs' to find it in the tree.
                      Ich spiele dann mal ein paar Szenarien durch.
                      • Bluefox
                        Bluefox last edited by
                        Ok.
                        Danke. So muss es auch sein. Laufen. 8-)
                        Achte bitte auf die Charts.
                        • ruhr70
                          die Meldung habe ich auch:
                          sql-0	05 15:12:26.167	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1462453935160, 56.14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                          • eric2905
                            Ich mache nachher den Raspi komplett platt, installiere ein nackiges Image und installiere alles neu/manuell.
                            Mal sehen, ob der SQL-Adapter dann ohne Meldung läuft.
                            • ruhr70
                              @ruhr70:
                              node v4.4.3
                              npm 2.15.1
                              Ich spiele dann mal ein paar Szenarien durch. `
                              Gerade den Host mit der VM neu gestartet. Danach lief ioBroker nicht. Ich wollte es dann manuell starten, aber "iobroker" fehlt :?: :shock:
                              root@ubuntu-1604-dev:/opt/iobroker# ls
                              etc  iobroker-data  killall.sh  log  node_modules  reinstall.sh
                                @ruhr70:
                                Ich wollte es dann manuell starten, aber "iobroker" fehlt :?: :shock: `
                                Wie denn?
                                so?
                                aus /opt/iobroker klappt es nicht!
                                siehe auch:
                                http://forum.iobroker.net/viewtopic.php … 789#p25195
                                Rainer
                                • ruhr70
                                  @Homoran:
                                  siehe auch:
                                  http://forum.iobroker.net/viewtopic.php … 789#p25195 `
                                  OK. Das war etwas voreilig 😄
                                  ````funktioniert.
                                  Die Datei ****iobroker**** wurde nur nicht angelegt.
                                  Ich hab jetzt das erste Mal reingeschaut, was da überhaupt drin steht :oops: :
                                  node node_modules/iobroker.js-controller/iobroker.js $1 $2 $3 $4 $5
                                  Und Autostart ist mit der Testinstallation nicht aktiv.
                                    Hi Leute,
                                    mal ein Lob und großes DANKESCHÖN an alle mitwirkenden und Bluefox.
                                    Ich habe auch getestet und zwar mit meiner "alten" Himbeere.
                                    FAZIT: Läuft besser, schneller und meines Erachtens auch wesentlicher Stabiler als das was ich vor 4 Wochen
                                    neu aufgesetzt habe.
                                    Früher musste ich meinen Admin oft 2 bis 3 mal aktualliesiern bis er mir alle Icons geladen hat und die Adapter in den
                                    Unterordner richtig hinterlegt hat.
                                    Nun habe ich damit keinerlei Probleme mehr. Funktioniert aufs erste mal.
                                    Davor hat ich auch dieses Problem beim Adapter installieren. http://forum.iobroker.net/viewtopic.php?f=22&t=1544
                                    Dieser ist bisher noch nicht aufgetaucht! (derzeit 3 Adapter installiert)
                                    Meine HARDWARE:
                                    Raspberry Pi 1 B+
                                    Jessie Lite image
                                    Vorgehensweise und alle Infos zum System und zur Installation hier im Spoiler.
                                    ! sudo raspi-config
                                    ! sudo nano /etc/ssh/sshd_config
                                    ! sudo /etc/init.d/ssh restart
                                    ! sudo su
                                    ! passwd
                                    ! sudo apt-get update && sudo apt-get upgrade
                                    ! reboot
                                    ! apt-get install npm
                                    ! apt-get install git
                                    ! reboot
                                    ! wget https://nodejs.org/dist/v4.4.3/node-v4. … v6l.tar.xz
                                    ! sudo tar -xvf node-v4.4.3-linux-armv6l.tar.xz
                                    ! cd node-v4.4.3-linux-armv6l
                                    ! sudo cp -R * /usr/local/
                                    ! sudo apt-get install build-essential python-rpi.gpio nodejs
                                    ! root@raspberrypi:~# uname -a && node -v && nodejs -v && npm -v
                                    ! Linux raspberrypi 4.1.19+ #858 Tue Mar 15 15:52:03 GMT 2016 armv6l GNU/Linux
                                    ! v4.4.3
                                    ! v0.10.29
                                    ! 2.15.1
                                    ! Reboot
                                    ! mkdir /opt/iobroker
                                    ! cd /opt/iobroker
                                    ! sudo chmod 777 .
                                    ! sudo npm install https://github.com/ioBroker/ioBroker.js ... all/master --production
                                    ! iobroker.js-controller@0.8.10 node_modules/iobroker.js-controller
                                    ! ├── mime@1.3.4
                                    ! ├── daemonize2@0.4.2
                                    ! ├── adm-zip@0.4.7
                                    ! ├── ncp@2.0.0
                                    ! ├── semver@4.3.6
                                    ! ├── node.extend@1.1.5 (is@3.1.0)
                                    ! ├── node-schedule@1.0.0 (long-timeout@0.0.2, cron-parser@1.1.0)
                                    ! ├── winston@2.2.0 (cycle@1.0.3, stack-trace@0.0.9, isstream@0.1.2, eyes@0.1.8, async@1.0.0, pkginfo@0.3.1, colors@1.0.3)
                                    ! ├── yargs@3.32.0 (decamelize@1.2.0, camelcase@2.1.1, y18n@3.2.1, window-size@0.1.4, cliui@3.2.0, os-locale@1.4.0, string-width@1.0.1)
                                    ! ├── winston-daily-rotate-file@1.0.1 (winston@2.1.1)
                                    ! ├── socket.io@1.4.6 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, socket.io-adapter@0.4.0, engine.io@1.6.9)
                                    ! ├── socket.io-client@1.4.6 (to-array@0.1.4, component-emitter@1.2.0, indexof@0.0.1, object-component@0.0.3, component-bind@1.0.0, backo2@1.0.2, has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, parseuri@0.0.4, engine.io-client@1.6.9)
                                    ! ├── prompt@1.0.0 (revalidator@0.1.8, pkginfo@0.4.0, colors@1.1.2, read@1.0.7, winston@2.1.1, utile@0.3.0)
                                    ! ├── request@2.72.0 (tunnel-agent@0.4.3, aws-sign2@0.6.0, forever-agent@0.6.1, oauth-sign@0.8.2, is-typedarray@1.0.0, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, tough-cookie@2.2.2, node-uuid@1.4.7, qs@6.1.0, combined-stream@1.0.5, mime-types@2.1.11, form-data@1.0.0-rc4, aws4@1.3.2, hawk@3.1.3, bl@1.1.2, http-signature@1.1.1, har-validator@2.0.6)
                                    ! ├── iobroker.admin@1.0.3 (connect-flash@0.1.1, xtend@4.0.1, cookie-parser@1.4.1, passport-local@1.0.0, passport@0.2.2, express-session@1.13.0, body-parser@1.15.1, express@4.13.4)
                                    ! ├── tar.gz@1.0.3 (commander@2.9.0, bluebird@2.10.2, tar@2.2.1, chai@3.5.0, fstream@1.0.8, mocha@2.4.5, mout@0.11.1)
                                    ! └── npm@2.15.5
                                    ! sudo npm install https://github.com/ioBroker/ioBroker.ad ... all/master --production
                                    ! iobroker.admin@1.1.1 node_modules/iobroker.admin
                                    ! ├── connect-flash@0.1.1
                                    ! ├── xtend@4.0.1
                                    ! ├── cookie-parser@1.4.1 (cookie-signature@1.0.6, cookie@0.2.3)
                                    ! ├── passport-local@1.0.0 (passport-strategy@1.0.0)
                                    ! ├── passport@0.2.2 (pause@0.0.1, passport-strategy@1.0.0)
                                    ! ├── express-session@1.13.0 (cookie-signature@1.0.6, utils-merge@1.0.0, on-headers@1.0.1, parseurl@1.3.1, cookie@0.2.3, depd@1.1.0, crc@3.4.0, uid-safe@2.0.0, debug@2.2.0)
                                    ! ├── body-parser@1.15.1 (content-type@1.0.1, bytes@2.3.0, depd@1.1.0, raw-body@2.1.6, http-errors@1.4.0, qs@6.1.0, on-finished@2.3.0, debug@2.2.0, iconv-lite@0.4.13, type-is@1.6.12)
                                    ! ├── express@4.13.4 (escape-html@1.0.3, utils-merge@1.0.0, cookie-signature@1.0.6, content-type@1.0.1, merge-descriptors@1.0.1, methods@1.1.2, vary@1.0.1, content-disposition@0.5.1, cookie@0.1.5, fresh@0.3.0, parseurl@1.3.1, range-parser@1.0.3, serve-static@1.10.2, etag@1.7.0, array-flatten@1.1.1, path-to-regexp@0.1.7, depd@1.1.0, qs@4.0.0, finalhandler@0.4.1, on-finished@2.3.0, debug@2.2.0, proxy-addr@1.0.10, send@0.13.1, accepts@1.2.13, type-is@1.6.12)
                                    ! ├── socket.io@1.4.6 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, socket.io-adapter@0.4.0, engine.io@1.6.9, socket.io-client@1.4.6)
                                    ! └── request@2.72.0 (aws-sign2@0.6.0, tunnel-agent@0.4.3, forever-agent@0.6.1, oauth-sign@0.8.2, is-typedarray@1.0.0, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, tough-cookie@2.2.2, node-uuid@1.4.7, qs@6.1.0, combined-stream@1.0.5, mime-types@2.1.11, form-data@1.0.0-rc4, aws4@1.3.2, bl@1.1.2, hawk@3.1.3, http-signature@1.1.1, har-validator@2.0.6)
                                    ! sudo npm install https://github.com/ioBroker/ioBroker.sql/tarball/master --production
                                    ! > sqlite3@3.1.3 install /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
                                    ! > node-pre-gyp install --fallback-to-build
                                    ! make: Entering directory '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/build'
                                    ! ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3090100/sqlite3.c
                                    ! TOUCH Release/obj.target/deps/action_before_build.stamp
                                    ! CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3090100/sqlite3.o
                                    ! AR(target) Release/obj.target/deps/sqlite3.a
                                    ! COPY Release/sqlite3.a
                                    ! CXX(target) Release/obj.target/node_sqlite3/src/database.o
                                    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
                                    ! ../src/database.cc:143:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ! int status = uv_queue_work(uv_default_loop(),
                                    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:
                                    ! ../src/database.cc:227:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:
                                    ! ../src/database.cc:505:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:
                                    ! ../src/database.cc:605:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ! CXX(target) Release/obj.target/node_sqlite3/src/node_sqlite3.o
                                    ! CXX(target) Release/obj.target/node_sqlite3/src/statement.o
                                    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:
                                    ! ../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ! In file included from ../src/statement.cc:6:0:
                                    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
                                    ! ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ! ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                    ! STATEMENT_BEGIN(Bind);
                                    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:
                                    ! ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                    ! STATEMENT_BEGIN(Get);
                                    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
                                    ! ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                    ! STATEMENT_BEGIN(Run);
                                    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:
                                    ! ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                    ! STATEMENT_BEGIN(All);
                                    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:
                                    ! ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                    ! STATEMENT_BEGIN(Each);
                                    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:
                                    ! ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                    ! STATEMENT_BEGIN(Reset);
                                    ! SOLINK_MODULE(target) Release/obj.target/node_sqlite3.node
                                    ! COPY Release/node_sqlite3.node
                                    ! COPY /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm/node_sqlite3.node
                                    ! TOUCH Release/obj.target/action_after_build.stamp
                                    ! make: Leaving directory '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/build'
                                    ! iobroker.sql@0.2.0 node_modules/iobroker.sql
                                    ! ├── mysql@2.10.2 (bignumber.js@2.1.4, readable-stream@1.1.14)
                                    ! ├── pg@4.5.5 (packet-reader@0.2.0, pg-connection-string@0.1.3, generic-pool@2.1.1, buffer-writer@1.0.1, semver@4.3.6, pg-types@1.11.0, pgpass@0.0.3)
                                    ! ├── sql-client@0.7.0 (argf@0.0.1, optimist@0.6.1, inote-util@0.8.1)
                                    ! ├── mssql@3.2.1 (generic-pool@2.4.2, promise@7.1.1, tedious@1.14.0)
                                    ! └── sqlite3@3.1.3 (nan@2.2.1)
                                    ! sudo npm install https://github.com/ioBroker/ioBroker.hi … all/master --production
                                    ! iobroker.history@0.4.0 node_modules/iobroker.history
                                    ! sudo npm install https://github.com/ioBroker/ioBroker.fl ... all/master --production
                                    ! iobroker.flot@1.2.0 node_modules/iobroker.flot
                                    ! sudo npm install https://github.com/ioBroker/ioBroker.ri ... all/master --production
                                    ! iobroker.rickshaw@0.4.0 node_modules/iobroker.rickshaw
                                    ! sudo chmod 777 * -R
                                    ! node node_modules/iobroker.js-controller/iobroker.js start
                                    ! Starting iobroker controller daemon...
                                    ! iobroker controller daemon started. PID: 961
                                    • Bluefox
                                      @ruhr70:
                                      @Homoran:
                                      siehe auch:
                                      ````funktioniert.
                                      Und Autostart ist mit der Testinstallation nicht aktiv. `
                                      Autostart und die Datei "iobroker" wird nur wenn man mit "npm install iobroker" installiert.
                                      Diese Installation nimmt aber die Versionen von NPM. Und ich will, dass ihr GITHUB testet. 8-)
                                      • derAuge
                                        HAbe nochmal neu installiert.
                                        nun funktioniert die installation
                                        root@RPi2-1:/opt/iobroker#  uname -a && node -v && nodejs -v && npm -v
                                        v4.4.3
                                        v0.10.29
                                        2.15.1
                                        Ein Adapter zickt noch ein wenig:
                                        2016-05-06 16:30:12.045 - info: host.RPi2-1 Restart adapter system.adapter.history.0 because enabled
                                        2016-05-06 16:30:42.074 - info: host.RPi2-1 instance system.adapter.history.0 started with pid 930
                                        2016-05-06 16:30:42.768 - error: host.RPi2-1 instance system.adapter.history.0 terminated with code 1 ()
                                        2016-05-06 16:30:42.769 - info: host.RPi2-1 Restart adapter system.adapter.history.0 because enabled
                                        2016-05-06 16:31:12.802 - info: host.RPi2-1 instance system.adapter.history.0 started with pid 935
                                        2016-05-06 16:31:13.543 - error: host.RPi2-1 instance system.adapter.history.0 terminated with code 1 ()
                                        2016-05-06 16:31:13.545 - info: host.RPi2-1 Restart adapter system.adapter.history.0 because enabled
                                        habe ihn schon mal gelöscht und wieder neu installiert. keine änderung
                                        Jürgen
                                        • Bluefox
                                          @derAuge:
                                          v4.4.3
                                          v0.10.29
                                          2.15.1
                                          Jürgen `
                                          Ich habe history gefixt. Bitte updaten
                                            Heinzelmaennchen last edited by
                                            Hallo BF,
                                            ich habe an dem Testszenario mal heimlich still und leise teilgenommen und die neuen Versionen auf einer Backupmaschine installiert.
                                            nun habe ich das alles ein paar Tage beobachtet bevor ich hier schreibe.
                                            1. Die Installation selbst ging glatt über die Bühne.
                                            Meine Konfiguration ist wie folgt:
                                            Linux castor 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08) i686 GNU/Linux
                                            v0.12.14
                                            2.15.1
                                            1. Ich verwende für die Historisierung der Daten den sql Adapter, der die Daten auf eine getrennte Synology mit mysql schreibt. Auch hier nach der Installation, zumindest glaube ich das, keine Auffälligkeiten.
                                            2. Ich habe nun das logging von Verbrauchsdaten des B-Control Adapters aktiviert, der im 500ms Rhythmus alle Sensoren ausliest.
                                            In der Konfiguration des Logging eines Datenpunktes ->"Table" kann man das auch verfolgen.
                                            1. ABER: Unter "CHART" gibt es leider absolut nichts zu sehen. Auch der Versuch die Datenpunkte über rickcharts oder flot anzuzeigen geht nicht. Es ist, als würden die Daten zwar in die DB geloggt werden, aber der Rückweg zum Anzeigen der Daten nicht funktionieren.
                                            Ich weiss nicht ob das nun ein Bug ist, oder ich einfach etwas übersehen habe zu aktivieren. Bräuchte da mal etwas unterstützung.
                                            7171
