    4. js-controller 3.0/3.1 jetzt im Latest!
      apollon77 @Thisoft last edited by
      @Thisoft ip ist korrekt? Port auch? Es sieht so aus als ob die dB Verbindung geschlossen wird. Sagt das logfile der Datenbank irgendwas?
      Downgrade gern mal auf sql 1.9.x und schau was da passiert. Würde mich aber wundern wenn es da tut.
      Thisoft 1 Reply Last reply Reply Quote 0
        apollon77 @Peoples last edited by
        @Peoples Jupp. So soll es quasi sein.
        • Thisoft
          Thisoft @apollon77 last edited by
          @apollon77 Auch wenn Du's nicht erwartest, aber die Version 1.9.5 funktioniert. Was mir dabei allerdings auffällt, er führt beim Starten automatisch ein Rebuild aus:
          2020-05-03 11:34:26.099 - info: host.ioBroker-Ubuntu Adapter system.adapter.sql.0 needs rebuild and will be restarted afterwards.
          2020-05-03 11:34:26.099 - info: host.ioBroker-Ubuntu system.adapter.sql.0 will be rebuilt
          2020-05-03 11:34:26.099 - warn: host.ioBroker-Ubuntu adapter "sql" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
          2020-05-03 11:34:26.100 - info: host.ioBroker-Ubuntu iobroker rebuild sql --install
          2020-05-03 11:34:26.240 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.sql"
          2020-05-03 11:34:40.150 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: ../deps/libmagic/src/fsmagic.c: In function ‘file_fsmagic’:../deps/libmagic/src/fsmagic.c:223:13: warning: In the GNU C Library, "major" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "major", include directly. If you did not intend to use a system-defined macro "major", you should undefine it after including . COMMA, (long)major(sb->st_rdev), ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:224:13: warning: In the GNU C Library, "minor" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "minor", include directly. If you did not intend to use a system-defined macro "minor", you should undefine it after including . (long)minor(sb->st_rdev)) == -1) ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:258:13: warning: In the GNU C Library, "major" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "major", include directly. If you did not intend to use a system-defined macro "major", you should undefine it after including . COMMA, (long)major(sb->st_rdev), ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:259:13: warning: In the GNU C Library, "minor" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "minor", include directly. If you did not intend to use a system-defined macro "minor", you should undefine it after including . (long)minor(sb->st_rdev)) == -1) ^~~~~~~~~~~~~~~~~~~~~~~~~~~
          2020-05-03 11:34:45.056 - info: host.ioBroker-Ubuntu iobroker npm-rebuild:
          2020-05-03 11:34:45.057 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: Rebuild sql done
          2020-05-03 11:34:46.060 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: exit 0
          2020-05-03 11:34:46.082 - info: host.ioBroker-Ubuntu instance system.adapter.sql.0 started with pid 7239
          Wenn ich wieder auf die 1.12 gehe macht er das nicht - und es funktioniert eben auch nicht...
          Übrigens, ich hab einen MS-SQLServer im Einsatz. Ist der vielleicht zu selten um genug getestet zu sein 😉 ?
            Marty56 @apollon77 last edited by
            @apollon77 Würde ich natürlich machen, aber ich stehe mit dem VIS auf Kriegsfuß und blicke bis heute bei dem Tool nicht durch. Ich habe über die Zeit vermutlich irgendwo in den Verzeichnissen herumgefummelt und ich würde nicht ausschließen, dass ich da Mist gebaut habe und dass die Warnings drauf zurückzuführen sind.
              liv-in-sky @apollon77 last edited by
              @apollon77
              vis alleine ist das nicht
              habe auch von sayit meldungen - leider weiß ich nicht mehr, wo diese dateien herkommen (ob das standard dateien sind oder ob ich kopiert habe) - sayit habe ich schon ewig nicht mehr angesehen - die dateien liegen unter
              readFile	2020-05-03 16:03:35.104	warn	will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
              sayit.0	2020-05-03 16:03:35.103	warn	(423) readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
              readFile	2020-05-03 16:03:35.100	warn	will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
              sayit.0	2020-05-03 16:03:35.064	warn	(423) readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
              muss bei jedem adapter ein git issue angelegt werden ?
              crunchip apollon77 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @liv-in-sky last edited by
                @liv-in-sky hehe, ich schon wieder
                scheinbar standard Dateien, die habe ich auch, habe sie auch bereits gelöscht und werden wieder angelegt
                  liv-in-sky @crunchip last edited by
                  @crunchip bekommst du die warnungen auch im log ?
                    @liv-in-sky ja
                      @crunchip diese files finde ich wenigstens - die anderen von weiter oben finde ich nicht mal - da scheint tatsächlich irgendwo in der vis noch etwas altes zu stehen ???
                        @liv-in-sky welche meinst du?
                          liv-in-sky @crunchip last edited by liv-in-sky
                          @crunchip
                          https://forum.iobroker.net/post/424007
                            crunchip Forum Testing Most Active @liv-in-sky last edited by crunchip
                            @liv-in-sky hat ich doch direkt ein post darunter geschrieben,
                            ah...editiert, ...
                            dazu hab ich leider keine Idee
                              e-i-k-e last edited by e-i-k-e
                              Moin,
                              js.controller läuft auf 3.0.20.
                              Habe soeben ein update von node.js 10 auf 12 gewagt.
                              Bis auf einen Adapter läuft alles.
                              Der SQL-Adapter (Version 1.12.3) steht auf Gelb.
                              Auszug aus dem log.
                              sql.0	2020-05-03 14:39:38.818	error	(12037) TypeError: Cannot read property 'close' of undefined
                              sql.0	2020-05-03 16:39:38.818	error	(12037) TypeError: Cannot read property 'close' of undefined
                              sql.0	2020-05-03 16:37:38.810	error	(12037) TypeError: Cannot read property 'close' of undefined
                              sql.0	2020-05-03 16:37:38.809	error	(12037) Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                              sql.0	2020-05-03 16:37:08.808	error	(12037) TypeError: Cannot read property 'close' of undefined
                              sql.0	2020-05-03 16:37:08.807	error	(12037) Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                              Auch nach einem Downgrade auf 1.9.5 läuft der Adapter nicht.
                              sql.0	2020-05-03 15:13:43.535	error	(5376) TypeError: Cannot read property 'borrow' of undefined
                              sql.0	2020-05-03 15:13:43.534	error	(5376) Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                              sql.0	2020-05-03 15:13:43.498	info	(5376) starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.sql, node: v12.16.3, js-controller: 3.0.20
                              Gibt es dazu Lösungen?
                              Edit: SQL wurde soeben grün. Habe iobroker rebuild sql --install ausgeführt. iobroker rebuild sql brachte keine Besserung.
                              Nachdem ich wieder auf die aktuelle Version 1.12.3 gesprungen bin, war der Adapter wieder gelb. Ein erneutes iobroker rebuild sql --install konnte den Fehler beheben.
                                @Thisoft vor allem der Mssql war in 1.11 kaputt und haben wir mit einigen Usern im Forum getestet. Daher sollte an sich tun.
                                Ich schaue nochmal heute Abend. Bitte mach nochmal die 1.12 und Starterin debug und zeig mal das log davon bitte.
                                  apollon77 @liv-in-sky last edited by
                                  @liv-in-sky sayit schon bekannt.
                                    @liv-in-sky jetzt macht euch keinen Kopf. Die Meldungen fliegen wieder raus in der finalen Version
                                      apollon77 @e-i-k-e last edited by
                                      @e-i-k-e ja klar. Sind verschiedene Versionen von SQLite drin und das will gebaut werden. Ich baue mal noch was ein das das rebuild automatisch passiert.
                                        @apollon77 danke
                                          Slave: (Raspberry/Rasbian) Update von node.js 10 auf 12, js.controller 2.0.30
                                          RPI-Adapter wird zwar Grün, die GPIO lassen sich allerdings nicht steuern.
                                          LOG:
                                          rpi2.3	2020-05-03 17:48:33.112	warn	(11922) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                          rpi2.3	2020-05-03 17:48:33.050	info	(11922) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                          rpi2.3	2020-05-03 17:48:27.832	info	(11412) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          rpi2.3	2020-05-03 17:48:27.830	info	(11412) terminating
                                          rpi2.3	2020-05-03 17:48:27.828	info	(11412) Got terminate signal TERMINATE_YOURSELF
                                          rpi2.3	2020-05-03 17:47:53.595	error	(11412) GPIO is not initialized!
                                          rpi2.3	2020-05-03 17:47:51.593	error	(11412) GPIO is not initialized!
                                          rpi2.3	2020-05-03 17:42:47.016	error	(11412) GPIO is not initialized!
                                          rpi2.3	2020-05-03 17:42:19.480	warn	(11412) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                          rpi2.3	2020-05-03 17:42:19.416	info	(11412) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                          rpi2.3	2020-05-03 17:42:14.061	info	(10753) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          rpi2.3	2020-05-03 17:42:14.059	info	(10753) terminating
                                          rpi2.3	2020-05-03 17:42:14.056	info	(10753) Got terminate signal TERMINATE_YOURSELF
                                          rpi2.3	2020-05-03 17:38:00.253	error	(10753) GPIO is not initialized!
                                          rpi2.3	2020-05-03 17:35:34.761	warn	(10753) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                          rpi2.3	2020-05-03 17:35:34.713	info	(10753) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                          rpi2.3	2020-05-03 17:31:14.638	info	(17396) Got terminate signal TERMINATE_YOURSELF
                                          rpi2.3	2020-05-03 17:31:14.619	info	(17396) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          rpi2.3	2020-05-03 17:02:08.103	error	(17396) read ECONNRESET
                                          Ein Down-/Upgrade des Adapters brachte keine Änderung.
                                          Erst nachdem in den Adapter händisch gelöscht und neu Installiert habe, werden die GPIO angesteuert.
                                          LOG:
                                          rpi2.3	2020-05-03 18:14:07.761	warn	(14278) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                          rpi2.3	2020-05-03 18:14:07.706	info	(14278) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                          rpi2.3	2020-05-03 18:14:02.762	info	(14154) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          rpi2.3	2020-05-03 18:14:02.760	info	(14154) terminating
                                          rpi2.3	2020-05-03 18:14:02.756	info	(14154) Got terminate signal TERMINATE_YOURSELF
                                          rpi2.3	2020-05-03 18:13:08.638	info	(14154) GPIO ports are not configured
                                          rpi2.3	2020-05-03 18:13:08.575	error	(14154) No Value found for cpu_frequency
                                          rpi2.3	2020-05-03 18:13:04.520	warn	(14154) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                          rpi2.3	2020-05-03 18:13:04.443	info	(14154) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                            jhg last edited by
                                            ich habe nach dem Update auf js. 3.0.20 das Problem, dass mein Serialport nicht mehr funktioniert.
                                            Habe von dem Update auf 3.0.20 noch node auf 12.16.3 aktualisiert.
                                            Folgender Fehlermeldung:
                                            prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
                                            gyp ERR! clean error
                                            gyp ERR! stack Error: EACCES: permission denied, unlink 'build/Makefile'
                                            gyp ERR! System Linux 4.19.97-v7+
                                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                            gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                                            gyp ERR! node -v v12.16.3
                                            gyp ERR! node-gyp -v v5.1.0
                                            gyp ERR! not ok
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno 1
                                            npm ERR! serialport@6.2.2 install: prebuild-install || node-gyp rebuild
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the serialport@6.2.2 install script.
                                            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                            Jemand einen Tipp, wie ich das beheben kann.
                                            js-controller
                                            127
                                            1340
                                            433160
