    4. Test Adapter time-switch v2.0.x GitHub/Latest
    • Iccube
      Iccube @walli545 last edited by Iccube
      @walli545 ist bei mir genauso wie es @Wolfi beschrieben hat lande auch immer in der Hauptview bei Android geräten Tablet und Handy
      • walli545
        walli545 @liv-in-sky last edited by walli545
        @liv-in-sky hab noch Logging hinzugefügt, bitte nochmal updaten. Falls es nicht geht, kompletten Log schicken und Inhalt des Schedules (Logging Level von Adapter auf debug stellen). Bei mir schaltet es schon 🤔
        @Wolfi @Iccube Kann mir einer von euch davon eine Bildschirmaufnahme machen? Ich kann das bei mir nicht reproduzieren.
        liv-in-sky Iccube 2 Replies Last reply Reply Quote 0
          liv-in-sky @walli545 last edited by
          @walli545
          log - hätte um 17:11 schalten sollen
          time-switch.0	2020-05-03 17:11:58.616	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:58.614	info	(32525) Finished message update-trigger
          time-switch.0	2020-05-03 17:11:58.613	debug	(32525) Scheduling trigger at 17:14 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:11:58.613	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":14,"weekdays":[1,2,3,4,5,6,0],"id":"1","action":{"type":"OnOffStateAction","name":"Off"}}}
          time-switch.0	2020-05-03 17:11:58.613	info	(32525) Received update-trigger
          time-switch.0	2020-05-03 17:11:48.309	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:48.302	info	(32525) Finished message add-trigger
          time-switch.0	2020-05-03 17:11:48.301	debug	(32525) Scheduling trigger at 0:0 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:11:48.300	debug	(32525) Wants OnOffValueAction
          time-switch.0	2020-05-03 17:11:48.300	debug	(32525) Wants TimeTrigger
          time-switch.0	2020-05-03 17:11:48.300	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","triggerType":"TimeTrigger","actionType":"OnOffValueAction","valueType":"boolean","stateIds":["controll-own.0.LEDLampe"]}
          time-switch.0	2020-05-03 17:11:48.300	info	(32525) Received add-trigger
          time-switch.0	2020-05-03 17:11:45.926	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:45.923	info	(32525) Finished message update-trigger
          time-switch.0	2020-05-03 17:11:45.922	debug	(32525) Scheduling trigger at 17:13 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:11:45.921	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":13,"weekdays":[1,2,3,4,5,6,0],"id":"0","action":{"type":"OnOffStateAction","name":"On"}}}
          time-switch.0	2020-05-03 17:11:45.921	info	(32525) Received update-trigger
          time-switch.0	2020-05-03 17:11:35.803	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:35.801	info	(32525) Finished message add-trigger
          time-switch.0	2020-05-03 17:11:35.799	debug	(32525) Scheduling trigger at 0:0 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:11:35.799	debug	(32525) Wants OnOffValueAction
          time-switch.0	2020-05-03 17:11:35.799	debug	(32525) Wants TimeTrigger
          time-switch.0	2020-05-03 17:11:35.799	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","triggerType":"TimeTrigger","actionType":"OnOffValueAction","valueType":"boolean","stateIds":["controll-own.0.LEDLampe"]}
          time-switch.0	2020-05-03 17:11:35.798	info	(32525) Received add-trigger
          time-switch.0	2020-05-03 17:11:34.759	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:34.758	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:34.756	info	(32525) Finished message enable-schedule
          time-switch.0	2020-05-03 17:11:34.756	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:34.756	info	(32525) Received enable-schedule
          time-switch.0	2020-05-03 17:11:34.739	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:34.737	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:34.736	info	(32525) Finished message enable-schedule
          time-switch.0	2020-05-03 17:11:34.735	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:34.735	info	(32525) Received enable-schedule
          time-switch.0	2020-05-03 17:11:26.490	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:26.489	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:26.487	info	(32525) Finished message disable-schedule
          time-switch.0	2020-05-03 17:11:26.487	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:26.487	info	(32525) Received disable-schedule
          time-switch.0	2020-05-03 17:11:26.466	debug	(32525) change from adapter itself for time-switch.0.onoff.0.data
          time-switch.0	2020-05-03 17:11:26.465	debug	(32525) change from adapter itself for time-switch.0.onoff.0.enabled
          time-switch.0	2020-05-03 17:11:26.463	info	(32525) Finished message enable-schedule
          time-switch.0	2020-05-03 17:11:26.462	debug	(32525) {"dataId":"time-switch.0.onoff.0.data"}
          time-switch.0	2020-05-03 17:11:26.462	info	(32525) Received enable-schedule
          time-switch.0	2020-05-03 17:11:20.279	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:20.279	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:20.277	info	(32525) Finished message disable-schedule
          time-switch.0	2020-05-03 17:11:20.276	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:20.276	info	(32525) Received disable-schedule
          time-switch.0	2020-05-03 17:11:19.828	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:19.827	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:19.825	info	(32525) Finished message disable-schedule
          time-switch.0	2020-05-03 17:11:19.824	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:19.824	info	(32525) Received disable-schedule
          time-switch.0	2020-05-03 17:11:19.770	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:19.768	info	(32525) Finished message change-switched-values
          time-switch.0	2020-05-03 17:11:19.767	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","valueType":"boolean","onValue":"true","offValue":"false"}
          time-switch.0	2020-05-03 17:11:19.767	info	(32525) Received change-switched-values
          time-switch.0	2020-05-03 17:11:17.897	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:17.896	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:17.894	info	(32525) Finished message disable-schedule
          time-switch.0	2020-05-03 17:11:17.893	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:17.893	info	(32525) Received disable-schedule
          time-switch.0	2020-05-03 17:11:17.408	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:17.407	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:17.405	info	(32525) Finished message disable-schedule
          time-switch.0	2020-05-03 17:11:17.404	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:17.404	info	(32525) Received disable-schedule
          time-switch.0	2020-05-03 17:11:17.390	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:17.388	info	(32525) Finished message change-switched-values
          time-switch.0	2020-05-03 17:11:17.387	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","valueType":"boolean","offValue":"false"}
          time-switch.0	2020-05-03 17:11:17.387	info	(32525) Received change-switched-values
          time-switch.0	2020-05-03 17:11:11.065	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:11:11.065	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
          time-switch.0	2020-05-03 17:11:11.061	info	(32525) Finished message disable-schedule
          time-switch.0	2020-05-03 17:11:11.060	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
          time-switch.0	2020-05-03 17:11:11.060	info	(32525) Received disable-schedule
          time-switch.0	2020-05-03 17:11:00.006	debug	(32525) Executing trigger with id 1
          time-switch.0	2020-05-03 17:10:15.052	debug	(32525) got state: [object Object]
          time-switch.0	2020-05-03 17:10:15.051	debug	(32525) Scheduling trigger at 17:11 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:10:15.040	debug	(32525) Scheduling trigger at 17:9 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:10:15.035	debug	(32525) got state: [object Object]
          time-switch.0	2020-05-03 17:10:15.015	debug	(32525) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          time-switch.0	2020-05-03 17:10:14.989	debug	(32525) Onoff state 1not found, creating
          time-switch.0	2020-05-03 17:10:14.988	debug	(32525) Found state time-switch.0.onoff.0.data
          time-switch.0	2020-05-03 17:10:14.967	debug	(32525) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          time-switch.0	2020-05-03 17:10:14.948	info	(32525) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.time-switch, node: v10.20.1, js-controller: 3.0.20
          host.iobroker59	2020-05-03 17:10:13.777	info	instance system.adapter.time-switch.0 started with pid 32525
          host.iobroker59	2020-05-03 17:10:11.274	info	instance system.adapter.time-switch.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          time-switch.0	2020-05-03 17:10:10.752	info	(27511) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          time-switch.0	2020-05-03 17:10:10.752	info	(27511) terminating
          time-switch.0	2020-05-03 17:10:10.752	info	(27511) cleaned everything up...
          time-switch.0	2020-05-03 17:10:10.751	info	(27511) Got terminate signal TERMINATE_YOURSELF
          host.iobroker59	2020-05-03 17:10:10.749	info	stopInstance system.adapter.time-switch.0 send kill signal
          host.iobroker59	2020-05-03 17:10:10.748	info	stopInstance system.adapter.time-switch.0 (force=false, process=true)
          time-switch.0	2020-05-03 17:09:56.648	debug	(27511) change from adapter itself for time-switch.0.onoff.0.data
          time-switch.0	2020-05-03 17:09:56.647	debug	(27511) change from adapter itself for time-switch.0.onoff.0.enabled
          time-switch.0	2020-05-03 17:09:56.645	info	(27511) Finished message enable-schedule
          time-switch.0	2020-05-03 17:09:56.645	debug	(27511) {"dataId":"time-switch.0.onoff.0.data"}
          time-switch.0	2020-05-03 17:09:56.644	info	(27511) Received enable-schedule
          host.iobroker59	2020-05-03 17:09:10.059	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          host.iobroker59	2020-05-03 17:09:00.026	info	instance system.adapter.ical.0 started with pid 29171
          time-switch.0	2020-05-03 17:09:00.007	debug	(27511) Executing trigger with id 0
          time-switch.0	2020-05-03 17:08:22.938	debug	(27511) change from adapter itself for time-switch.0.onoff.0.data
          time-switch.0	2020-05-03 17:08:22.934	info	(27511) Finished message update-trigger
          time-switch.0	2020-05-03 17:08:22.931	debug	(27511) Scheduling trigger at 17:11 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:08:22.930	debug	(27511) {"dataId":"time-switch.0.onoff.0.data","trigger":{"type":"TimeTrigger","hour":17,"minute":11,"weekdays":[1,2,3,4,5,6,0],"id":"1","action":{"type":"OnOffStateAction","name":"Off"}}}
          time-switch.0	2020-05-03 17:08:22.930	info	(27511) Received update-trigger
          log - hätte um 17:16 schalten sollen
          time-switch.0	2020-05-03 17:16:00.006	debug	(32525) Executing trigger with id 0
          time-switch.0	2020-05-03 17:14:26.309	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:14:26.306	info	(32525) Finished message update-trigger
          time-switch.0	2020-05-03 17:14:26.305	debug	(32525) Scheduling trigger at 17:17 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:14:26.304	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":17,"weekdays":[1,2,3,4,5,6,0],"id":"1","action":{"type":"OnOffStateAction","name":"Off"}}}
          time-switch.0	2020-05-03 17:14:26.304	info	(32525) Received update-trigger
          time-switch.0	2020-05-03 17:14:21.306	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
          time-switch.0	2020-05-03 17:14:21.304	info	(32525) Finished message update-trigger
          time-switch.0	2020-05-03 17:14:21.303	debug	(32525) Scheduling trigger at 17:16 on 1,2,3,4,5,6,0
          time-switch.0	2020-05-03 17:14:21.303	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":16,"weekdays":[1,2,3,4,5,6,0],"id":"0","action":{"type":"OnOffStateAction","name":"On"}}}
          time-switch.0	2020-05-03 17:14:21.303	info	(32525) Received update-trigger
          time-switch.0	2020-05-03 17:14:00.005	debug	(32525) Executing trigger with id 1
          current value bleibt um 17:16 auf false
          walli545 1 Reply Last reply Reply Quote 0
          • walli545
            @liv-in-sky bewegt sich nur der Schalter nicht oder ändert sich auch der Wert des States nicht? Nicht, dass ich am Falschen Ende suche
              @walli545 datenpunkte ändern sich nicht
              du kannst auch gerne noch warten, ob es einen anderen user gibt, der das selbe problem hat
                @walli545 habe es auch mal mit number getestet - selbes verhalten
                • walli545
                  @liv-in-sky kann es sein, dass du das Widget nicht neu angelegt hast? Und dadurch nie den geschaltenen State konfiguriert hast?
                    liv-in-sky @walli545 last edited by liv-in-sky
                    @walli545
                    instanz stop, widgets wurden gelöscht , objecte gelöscht - instanz gelöscht - update adapter - instanz neu - im setting neu und danach neues widget
                      Wolfi last edited by
                      @walli545 @Iccube
                      Wollte zur Bildschirmaufnahme eine Testumgebung benutzen ( Projekt main ) und siehe da dort lande ich nicht mehr in der Hauptview nein da funktioniert es.
                      Jetzt muss ich rausfinden warum in meinem Projekt das passiert
                        Wolfi last edited by Wolfi
                        @walli545 @Iccube
                        Das hat definitiv nicht mit deinem Adapter/witget zu tun passiert auch mit einem anderen Eingabe Widget aber warum? Das muss ich noch rausfinden.
                        Was löst die Einblendung der Tastatur in der View aus??
                        • walli545
                          @liv-in-sky habs mir gerade nochmal angeschaut, glaube ich habs gefunden. Problem war, dass ich es nicht mit einer frischen Installation ausprobiert hatte 😬 Bitte testen, danke fürs ausprobieren immer 👍
                            @walli545
                            kurze info:
                            JETZT WIRD GESCHALTEN - - teste morgen ausgiebiger weiter
                            • Iccube
                              @walli545 habe den Adapter mal gelöscht und neu aufgespielt dann neuen Schaltplan erstellt jetzt kann ich den Namen nicht mehr ändern und keine Schaltzeiten einfügen folgender fehler im log
                              time-switch.0	2020-05-03 22:46:26.485	error	(13686) Could not handle message:
                              time-switch.0	2020-05-03 22:46:26.485	error	(13686) Error
                              time-switch.0	2020-05-03 22:46:26.484	error	(13686) No schedule found for state undefined
                              time-switch.0	2020-05-03 22:46:26.484	error	at new Promise (<anonymous>)
                              time-switch.0	2020-05-03 22:46:26.484	error	at /opt/iobroker/node_modules/iobroker.time-switch/build/main.js:8:71
                              time-switch.0	2020-05-03 22:46:26.484	error	at Generator.next (<anonymous>)
                              time-switch.0	2020-05-03 22:46:26.484	error	at TimeSwitch.<anonymous> (/opt/iobroker/node_modules/iobroker.time-switch/build/main.js:142:43)
                              time-switch.0	2020-05-03 22:46:26.484	error	at MessageService.handleMessage (/opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:29:16)
                              time-switch.0	2020-05-03 22:46:26.484	error	at __awaiter (/opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:4:12)
                              time-switch.0	2020-05-03 22:46:26.484	error	at /opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:8:71
                              time-switch.0	2020-05-03 22:46:26.484	error	at MessageService.<anonymous> (/opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:40:23)
                              time-switch.0	2020-05-03 22:46:26.484	error	(13686) Error: No schedule found for state undefined
                              time-switch.0	2020-05-03 22:46:26.483	info	(13686) Received disable-schedule
                              • Iccube
                                Iccube last edited by
                                Habe iobroker mal neu gestartet jetzt funktioniert alles wie es soll
                                  @walli545
                                  habe nochmal getestet - bool, string, zahl, mehrere datenpunkte
                                  funktioniert alles
                                  wäre es möglich im json noch das enabled oder disabled wieder einzufügen (ich hoffe, du änderst nicht wieder die json-struktur 😞 )
                                  habe meine tabelle angeglichen (ist mir sonst zu viel platzverbrauch in der vis) - reagiert direkt auf das ändern der datenpunkte (das schalten der dp ist über die tabelle nicht möglich)
                                  • walli545
                                    @liv-in-sky sehr gut danke 👍 Zum Thema enabled: Nein, der wird nicht mehr ins json kommen, zum einen finde ich es in einem eigenen State praktischer, da man so einfach einen Schalter erstellen kann, mit dem man alle ausschaltet, etc. und dafür dann nicht für alle einzeln ins programmier-widget muss. Wenn ich enabled nun wieder in json einbaue, würde sich wie du gesagt hast das json Format wieder ändern und ich muss es an zwei Stellen pflegen, was ich eher unschön finde.
                                      @walli545 sorry - alles gut - den datenpunkt habe ich völlig übersehen- den kann ich auch so einbauen
                                      war voll im json-modus
                                      • walli545
                                        @liv-in-sky kannst dein eigenes Widget ja dann auch hochladen, vielleicht findets jemand ja praktischer 🙂
                                          @walli545 ich habe ja eine ganze sammlung mit diesen tabellen - wenn du sagst, es bleibt so wie es ist, mache ich einen eigenen thread dafür - irgend jemand wird es schon brauchen können
                                          habe datenpunkt enabled integriert
                                          sieht dann so aus
                                          walli545 wendy2702 2 Replies Last reply Reply Quote 0
                                          • walli545
                                            @liv-in-sky denke bis neue Trigger dazu kommen sollte es so bleiben, warte jetzt noch Rückmeldungen ab, dann schaue ich mal, dass ich einen ersten Release in Stable mache
                                            Habe noch eine kleine kosmetische Änderung eingebaut: Beim Einstellen der Uhrzeit wird jetzt der richtige input type verwendet. Dadurch wird auf mobilen Geräten auch ein nativer Dialog zum Auswählen der Uhrzeit angezeigt.
                                            adapter switch test time vis zeitschaltuhr
                                            75
                                            481
                                            114680
