    4. Test Adapter time-switch v2.0.x GitHub/Latest
      liv-in-sky @walli545 last edited by
      @walli545
      log - hätte um 17:11 schalten sollen
      time-switch.0	2020-05-03 17:11:58.616	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:58.614	info	(32525) Finished message update-trigger
      time-switch.0	2020-05-03 17:11:58.613	debug	(32525) Scheduling trigger at 17:14 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:11:58.613	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":14,"weekdays":[1,2,3,4,5,6,0],"id":"1","action":{"type":"OnOffStateAction","name":"Off"}}}
      time-switch.0	2020-05-03 17:11:58.613	info	(32525) Received update-trigger
      time-switch.0	2020-05-03 17:11:48.309	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:48.302	info	(32525) Finished message add-trigger
      time-switch.0	2020-05-03 17:11:48.301	debug	(32525) Scheduling trigger at 0:0 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:11:48.300	debug	(32525) Wants OnOffValueAction
      time-switch.0	2020-05-03 17:11:48.300	debug	(32525) Wants TimeTrigger
      time-switch.0	2020-05-03 17:11:48.300	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","triggerType":"TimeTrigger","actionType":"OnOffValueAction","valueType":"boolean","stateIds":["controll-own.0.LEDLampe"]}
      time-switch.0	2020-05-03 17:11:48.300	info	(32525) Received add-trigger
      time-switch.0	2020-05-03 17:11:45.926	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:45.923	info	(32525) Finished message update-trigger
      time-switch.0	2020-05-03 17:11:45.922	debug	(32525) Scheduling trigger at 17:13 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:11:45.921	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":13,"weekdays":[1,2,3,4,5,6,0],"id":"0","action":{"type":"OnOffStateAction","name":"On"}}}
      time-switch.0	2020-05-03 17:11:45.921	info	(32525) Received update-trigger
      time-switch.0	2020-05-03 17:11:35.803	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:35.801	info	(32525) Finished message add-trigger
      time-switch.0	2020-05-03 17:11:35.799	debug	(32525) Scheduling trigger at 0:0 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:11:35.799	debug	(32525) Wants OnOffValueAction
      time-switch.0	2020-05-03 17:11:35.799	debug	(32525) Wants TimeTrigger
      time-switch.0	2020-05-03 17:11:35.799	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","triggerType":"TimeTrigger","actionType":"OnOffValueAction","valueType":"boolean","stateIds":["controll-own.0.LEDLampe"]}
      time-switch.0	2020-05-03 17:11:35.798	info	(32525) Received add-trigger
      time-switch.0	2020-05-03 17:11:34.759	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:34.758	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:34.756	info	(32525) Finished message enable-schedule
      time-switch.0	2020-05-03 17:11:34.756	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:34.756	info	(32525) Received enable-schedule
      time-switch.0	2020-05-03 17:11:34.739	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:34.737	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:34.736	info	(32525) Finished message enable-schedule
      time-switch.0	2020-05-03 17:11:34.735	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:34.735	info	(32525) Received enable-schedule
      time-switch.0	2020-05-03 17:11:26.490	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:26.489	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:26.487	info	(32525) Finished message disable-schedule
      time-switch.0	2020-05-03 17:11:26.487	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:26.487	info	(32525) Received disable-schedule
      time-switch.0	2020-05-03 17:11:26.466	debug	(32525) change from adapter itself for time-switch.0.onoff.0.data
      time-switch.0	2020-05-03 17:11:26.465	debug	(32525) change from adapter itself for time-switch.0.onoff.0.enabled
      time-switch.0	2020-05-03 17:11:26.463	info	(32525) Finished message enable-schedule
      time-switch.0	2020-05-03 17:11:26.462	debug	(32525) {"dataId":"time-switch.0.onoff.0.data"}
      time-switch.0	2020-05-03 17:11:26.462	info	(32525) Received enable-schedule
      time-switch.0	2020-05-03 17:11:20.279	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:20.279	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:20.277	info	(32525) Finished message disable-schedule
      time-switch.0	2020-05-03 17:11:20.276	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:20.276	info	(32525) Received disable-schedule
      time-switch.0	2020-05-03 17:11:19.828	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:19.827	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:19.825	info	(32525) Finished message disable-schedule
      time-switch.0	2020-05-03 17:11:19.824	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:19.824	info	(32525) Received disable-schedule
      time-switch.0	2020-05-03 17:11:19.770	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:19.768	info	(32525) Finished message change-switched-values
      time-switch.0	2020-05-03 17:11:19.767	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","valueType":"boolean","onValue":"true","offValue":"false"}
      time-switch.0	2020-05-03 17:11:19.767	info	(32525) Received change-switched-values
      time-switch.0	2020-05-03 17:11:17.897	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:17.896	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:17.894	info	(32525) Finished message disable-schedule
      time-switch.0	2020-05-03 17:11:17.893	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:17.893	info	(32525) Received disable-schedule
      time-switch.0	2020-05-03 17:11:17.408	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:17.407	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:17.405	info	(32525) Finished message disable-schedule
      time-switch.0	2020-05-03 17:11:17.404	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:17.404	info	(32525) Received disable-schedule
      time-switch.0	2020-05-03 17:11:17.390	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:17.388	info	(32525) Finished message change-switched-values
      time-switch.0	2020-05-03 17:11:17.387	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","valueType":"boolean","offValue":"false"}
      time-switch.0	2020-05-03 17:11:17.387	info	(32525) Received change-switched-values
      time-switch.0	2020-05-03 17:11:11.065	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:11:11.065	debug	(32525) change from adapter itself for time-switch.0.onoff.1.enabled
      time-switch.0	2020-05-03 17:11:11.061	info	(32525) Finished message disable-schedule
      time-switch.0	2020-05-03 17:11:11.060	debug	(32525) {"dataId":"time-switch.0.onoff.1.data"}
      time-switch.0	2020-05-03 17:11:11.060	info	(32525) Received disable-schedule
      time-switch.0	2020-05-03 17:11:00.006	debug	(32525) Executing trigger with id 1
      time-switch.0	2020-05-03 17:10:15.052	debug	(32525) got state: [object Object]
      time-switch.0	2020-05-03 17:10:15.051	debug	(32525) Scheduling trigger at 17:11 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:10:15.040	debug	(32525) Scheduling trigger at 17:9 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:10:15.035	debug	(32525) got state: [object Object]
      time-switch.0	2020-05-03 17:10:15.015	debug	(32525) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      time-switch.0	2020-05-03 17:10:14.989	debug	(32525) Onoff state 1not found, creating
      time-switch.0	2020-05-03 17:10:14.988	debug	(32525) Found state time-switch.0.onoff.0.data
      time-switch.0	2020-05-03 17:10:14.967	debug	(32525) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      time-switch.0	2020-05-03 17:10:14.948	info	(32525) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.time-switch, node: v10.20.1, js-controller: 3.0.20
      host.iobroker59	2020-05-03 17:10:13.777	info	instance system.adapter.time-switch.0 started with pid 32525
      host.iobroker59	2020-05-03 17:10:11.274	info	instance system.adapter.time-switch.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      time-switch.0	2020-05-03 17:10:10.752	info	(27511) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      time-switch.0	2020-05-03 17:10:10.752	info	(27511) terminating
      time-switch.0	2020-05-03 17:10:10.752	info	(27511) cleaned everything up...
      time-switch.0	2020-05-03 17:10:10.751	info	(27511) Got terminate signal TERMINATE_YOURSELF
      host.iobroker59	2020-05-03 17:10:10.749	info	stopInstance system.adapter.time-switch.0 send kill signal
      host.iobroker59	2020-05-03 17:10:10.748	info	stopInstance system.adapter.time-switch.0 (force=false, process=true)
      time-switch.0	2020-05-03 17:09:56.648	debug	(27511) change from adapter itself for time-switch.0.onoff.0.data
      time-switch.0	2020-05-03 17:09:56.647	debug	(27511) change from adapter itself for time-switch.0.onoff.0.enabled
      time-switch.0	2020-05-03 17:09:56.645	info	(27511) Finished message enable-schedule
      time-switch.0	2020-05-03 17:09:56.645	debug	(27511) {"dataId":"time-switch.0.onoff.0.data"}
      time-switch.0	2020-05-03 17:09:56.644	info	(27511) Received enable-schedule
      host.iobroker59	2020-05-03 17:09:10.059	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      host.iobroker59	2020-05-03 17:09:00.026	info	instance system.adapter.ical.0 started with pid 29171
      time-switch.0	2020-05-03 17:09:00.007	debug	(27511) Executing trigger with id 0
      time-switch.0	2020-05-03 17:08:22.938	debug	(27511) change from adapter itself for time-switch.0.onoff.0.data
      time-switch.0	2020-05-03 17:08:22.934	info	(27511) Finished message update-trigger
      time-switch.0	2020-05-03 17:08:22.931	debug	(27511) Scheduling trigger at 17:11 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:08:22.930	debug	(27511) {"dataId":"time-switch.0.onoff.0.data","trigger":{"type":"TimeTrigger","hour":17,"minute":11,"weekdays":[1,2,3,4,5,6,0],"id":"1","action":{"type":"OnOffStateAction","name":"Off"}}}
      time-switch.0	2020-05-03 17:08:22.930	info	(27511) Received update-trigger
      log - hätte um 17:16 schalten sollen
      time-switch.0	2020-05-03 17:16:00.006	debug	(32525) Executing trigger with id 0
      time-switch.0	2020-05-03 17:14:26.309	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:14:26.306	info	(32525) Finished message update-trigger
      time-switch.0	2020-05-03 17:14:26.305	debug	(32525) Scheduling trigger at 17:17 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:14:26.304	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":17,"weekdays":[1,2,3,4,5,6,0],"id":"1","action":{"type":"OnOffStateAction","name":"Off"}}}
      time-switch.0	2020-05-03 17:14:26.304	info	(32525) Received update-trigger
      time-switch.0	2020-05-03 17:14:21.306	debug	(32525) change from adapter itself for time-switch.0.onoff.1.data
      time-switch.0	2020-05-03 17:14:21.304	info	(32525) Finished message update-trigger
      time-switch.0	2020-05-03 17:14:21.303	debug	(32525) Scheduling trigger at 17:16 on 1,2,3,4,5,6,0
      time-switch.0	2020-05-03 17:14:21.303	debug	(32525) {"dataId":"time-switch.0.onoff.1.data","trigger":{"type":"TimeTrigger","hour":17,"minute":16,"weekdays":[1,2,3,4,5,6,0],"id":"0","action":{"type":"OnOffStateAction","name":"On"}}}
      time-switch.0	2020-05-03 17:14:21.303	info	(32525) Received update-trigger
      time-switch.0	2020-05-03 17:14:00.005	debug	(32525) Executing trigger with id 1
      current value bleibt um 17:16 auf false
      walli545 1 Reply Last reply Reply Quote 0
      • walli545
        walli545 @liv-in-sky last edited by
        @liv-in-sky bewegt sich nur der Schalter nicht oder ändert sich auch der Wert des States nicht? Nicht, dass ich am Falschen Ende suche
          @walli545 datenpunkte ändern sich nicht
          du kannst auch gerne noch warten, ob es einen anderen user gibt, der das selbe problem hat
            @walli545 habe es auch mal mit number getestet - selbes verhalten
            • walli545
              walli545 @liv-in-sky last edited by walli545
              @liv-in-sky kann es sein, dass du das Widget nicht neu angelegt hast? Und dadurch nie den geschaltenen State konfiguriert hast?
                liv-in-sky @walli545 last edited by liv-in-sky
                @walli545
                instanz stop, widgets wurden gelöscht , objecte gelöscht - instanz gelöscht - update adapter - instanz neu - im setting neu und danach neues widget
                  Wolfi last edited by
                  @walli545 @Iccube
                  Wollte zur Bildschirmaufnahme eine Testumgebung benutzen ( Projekt main ) und siehe da dort lande ich nicht mehr in der Hauptview nein da funktioniert es.
                  Jetzt muss ich rausfinden warum in meinem Projekt das passiert
                    Wolfi last edited by Wolfi
                    @walli545 @Iccube
                    Das hat definitiv nicht mit deinem Adapter/witget zu tun passiert auch mit einem anderen Eingabe Widget aber warum? Das muss ich noch rausfinden.
                    Was löst die Einblendung der Tastatur in der View aus??
                    • walli545
                      @liv-in-sky habs mir gerade nochmal angeschaut, glaube ich habs gefunden. Problem war, dass ich es nicht mit einer frischen Installation ausprobiert hatte 😬 Bitte testen, danke fürs ausprobieren immer 👍
                        @walli545
                        kurze info:
                        JETZT WIRD GESCHALTEN - - teste morgen ausgiebiger weiter
                        • Iccube
                          Iccube @walli545 last edited by
                          @walli545 habe den Adapter mal gelöscht und neu aufgespielt dann neuen Schaltplan erstellt jetzt kann ich den Namen nicht mehr ändern und keine Schaltzeiten einfügen folgender fehler im log
                          time-switch.0	2020-05-03 22:46:26.485	error	(13686) Could not handle message:
                          time-switch.0	2020-05-03 22:46:26.485	error	(13686) Error
                          time-switch.0	2020-05-03 22:46:26.484	error	(13686) No schedule found for state undefined
                          time-switch.0	2020-05-03 22:46:26.484	error	at new Promise (<anonymous>)
                          time-switch.0	2020-05-03 22:46:26.484	error	at /opt/iobroker/node_modules/iobroker.time-switch/build/main.js:8:71
                          time-switch.0	2020-05-03 22:46:26.484	error	at Generator.next (<anonymous>)
                          time-switch.0	2020-05-03 22:46:26.484	error	at TimeSwitch.<anonymous> (/opt/iobroker/node_modules/iobroker.time-switch/build/main.js:142:43)
                          time-switch.0	2020-05-03 22:46:26.484	error	at MessageService.handleMessage (/opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:29:16)
                          time-switch.0	2020-05-03 22:46:26.484	error	at __awaiter (/opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:4:12)
                          time-switch.0	2020-05-03 22:46:26.484	error	at /opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:8:71
                          time-switch.0	2020-05-03 22:46:26.484	error	at MessageService.<anonymous> (/opt/iobroker/node_modules/iobroker.time-switch/build/services/MessageService.js:40:23)
                          time-switch.0	2020-05-03 22:46:26.484	error	(13686) Error: No schedule found for state undefined
                          time-switch.0	2020-05-03 22:46:26.483	info	(13686) Received disable-schedule
                          • Iccube
                            Iccube last edited by
                            Habe iobroker mal neu gestartet jetzt funktioniert alles wie es soll
                              @walli545
                              habe nochmal getestet - bool, string, zahl, mehrere datenpunkte
                              funktioniert alles
                              wäre es möglich im json noch das enabled oder disabled wieder einzufügen (ich hoffe, du änderst nicht wieder die json-struktur 😞 )
                              habe meine tabelle angeglichen (ist mir sonst zu viel platzverbrauch in der vis) - reagiert direkt auf das ändern der datenpunkte (das schalten der dp ist über die tabelle nicht möglich)
                              • walli545
                                @liv-in-sky sehr gut danke 👍 Zum Thema enabled: Nein, der wird nicht mehr ins json kommen, zum einen finde ich es in einem eigenen State praktischer, da man so einfach einen Schalter erstellen kann, mit dem man alle ausschaltet, etc. und dafür dann nicht für alle einzeln ins programmier-widget muss. Wenn ich enabled nun wieder in json einbaue, würde sich wie du gesagt hast das json Format wieder ändern und ich muss es an zwei Stellen pflegen, was ich eher unschön finde.
                                  @walli545 sorry - alles gut - den datenpunkt habe ich völlig übersehen- den kann ich auch so einbauen
                                  war voll im json-modus
                                  • walli545
                                    @liv-in-sky kannst dein eigenes Widget ja dann auch hochladen, vielleicht findets jemand ja praktischer 🙂
                                      @walli545 ich habe ja eine ganze sammlung mit diesen tabellen - wenn du sagst, es bleibt so wie es ist, mache ich einen eigenen thread dafür - irgend jemand wird es schon brauchen können
                                      habe datenpunkt enabled integriert
                                      sieht dann so aus
                                      walli545 wendy2702 2 Replies Last reply Reply Quote 0
                                      • walli545
                                        @liv-in-sky denke bis neue Trigger dazu kommen sollte es so bleiben, warte jetzt noch Rückmeldungen ab, dann schaue ich mal, dass ich einen ersten Release in Stable mache
                                        Habe noch eine kleine kosmetische Änderung eingebaut: Beim Einstellen der Uhrzeit wird jetzt der richtige input type verwendet. Dadurch wird auf mobilen Geräten auch ein nativer Dialog zum Auswählen der Uhrzeit angezeigt.
                                          arteck Developer Most Active @walli545 last edited by
                                          @walli545 machst ein merge bitte auf ein release
                                            @walli545
                                            Was ist bitte schön der aktuelle Ordner Neue Version?
                                            adapter switch test time vis zeitschaltuhr
                                            75
                                            481
                                            114659
