    5. Logik falsch?
    Logik falsch?
    • AnamCara
      AnamCara last edited by
      ich habe eine Frage zu meinem Skript. Obwohl es gestartet ist passiert einfach nichts.
        <variables>
          <variable type="" id="fl:mUtKT4_M[$v0%ib{7">istWochentag</variable>
        </variables>
        <block type="schedule" id="h8UbdefQNT~4R[-,0D-_" x="-2288" y="-3012">
          <field name="SCHEDULE">1 0 * * *</field>
            <block type="controls_if" id="j?mLzH$T77sh#0s/fB#8">
                <block type="logic_negate" id="aP+=+oz:4wCm|n#cMR;-">
                  <value name="BOOL">
                    <block type="get_value" id="..0n@W@aiLD{fgf-C;o@">
                      <field name="OID">feiertage.0.heute.boolean</field>
                <block type="debug" id="`Gqdl_3e@:(0)gL9c=k`">
                  <value name="TEXT">
                    <shadow type="text" id="5,gS[__-B#1aeynHJL13">
                    <block type="text_join" id="6$Bzkt]#@#cg$ItF#w50">
                      <value name="ADD0">
                        <block type="text" id="`tKB}$)?D62`uGJnL$,0">
                          <field name="TEXT">Wert von Feiertag heute: </field>
                      <value name="ADD1">
                        <block type="get_value" id="9@S,-j;Z4$5=G1q]qmt3">
                    <block type="debug" id="2=7hwoMwH2Enu9rs4sk#">
                      <value name="TEXT">
                        <shadow type="text" id="lUc^v76vMsoi6a262/Ca">
                        <block type="text_join" id=".A8/wfPXYFcKT:OA2gpU">
                          <value name="ADD0">
                            <block type="text" id="{dMC:Up}0=p:s]C:E)JV">
                              <field name="TEXT">Wochentagnummer: </field>
                          <value name="ADD1">
                            <block type="time_get" id="2*/}Q[51o=Tyxc|yS[)6">
                              <mutation format="false" language="false"></mutation>
                              <field name="OPTION">wd</field>
                        <block type="controls_if" id="p@^C.`$iT|Pq(37e_ssg">
                            <block type="logic_compare" id="3pt{YG}T**N.:Nsuz~da">
                              <field name="OP">LTE</field>
                                <block type="time_get" id="vNF#NA^D(hv3@Ao`m9fc">
                                <block type="math_number" id="gKv1D=U.T.@z10{R=log">
                                  <field name="NUM">5</field>
                            <block type="variables_set" id="R-{#Ri6=yVdHkldz@9VW">
                              <field name="VAR" id="fl:mUtKT4_M[$v0%ib{7" variabletype="">istWochentag</field>
                                <block type="logic_boolean" id=":,2IH#,]SkA!%d=]4Pld">
                          <statement name="ELSE">
                            <block type="variables_set" id="?_Yh.:|hpD[oX_5%7vK0">
                                <block type="logic_boolean" id="G/Viq$gsR,jB)omk;.,u">
                <block type="variables_set" id="!O#@#Rb!$0J];hJep][(">
                    <block type="logic_boolean" id="ia7X)Pkc+wUWa!E=uh%U">
                <block type="debug" id="ol@Tms6)15haxQ1tu|2y">
                  <value name="TEXT">
                    <shadow type="text" id="q/YwS|iL%s[DdFWKw5LG">
                    <block type="text_join" id="7Z9W;_T{{^A=6k_yCkC^">
                      <value name="ADD0">
                        <block type="text" id="}$-H/!F2hqMMIka[kVj4">
                          <field name="TEXT">Variable istWochentag Wert: </field>
                      <value name="ADD1">
                        <block type="variables_get" id="n#8s[#8{IxIf4]I+^TuW">
                    <block type="controls_if" id="%GllBsSnIY~W-5[hNb{6">
                        <block type="logic_compare" id="#;Mi],J:,msDVYK7pv?8">
                          <field name="OP">EQ</field>
                            <block type="variables_get" id="8rbzFekN1D=xA-2Sbrv2">
                            <block type="logic_boolean" id="s$1IC1.BZw$.Om=H%4ai">
                        <block type="astro" id="u*O6bb(5j07=`]du)Fae">
                          <field name="TYPE">sunrise</field>
                          <field name="OFFSET">0</field>
                            <block type="telegram" id="=|-UgL*C4mlF~tA9Xgzi">
                              <field name="LOG"></field>
                              <value name="MESSAGE">
                                <shadow type="text" id="JO{!a+|*$gVp]1lCq{1S">
                                <block type="text_join" id="F|#58yh`:jT3U4}:S;AJ">
                                  <mutation items="13"></mutation>
                                  <value name="ADD0">
                                    <block type="text" id="]~AKaYOoQyx8zrN4y/B?">
                                      <field name="TEXT">Sonnenaufgang</field>
                                  <value name="ADD1">
                                    <block type="text_newline" id="l`#@:pt3l|6Desx,W@#Z">
                                      <field name="Type">\n</field>
                                  <value name="ADD2">
                                    <block type="text" id="hO~{1$8TeR2Xa%bk%zdb">
                                      <field name="TEXT">Heute ist ein normaler Wochentag:</field>
                                  <value name="ADD3">
                                    <block type="text_newline" id="dH4#fM@]6h-pyhc/P7b%">
                                  <value name="ADD4">
                                    <shadow type="text" id="^KdnQvBodC*#-Vq.E4w-">
                                      <field name="TEXT"></field>
                                    <block type="time_get" id="_yy;)ns4kIi@_oV=o(Xs">
                                      <mutation format="false" language="true"></mutation>
                                      <field name="OPTION">wdt</field>
                                      <field name="LANGUAGE">de</field>
                                  <value name="ADD5">
                                    <block type="text_newline" id=")vN~o-1?r|GlBOtf=L[|">
                                  <value name="ADD6">
                                    <block type="text" id="EVX0B[FH8W4j]Ex+`UtI">
                                      <field name="TEXT">Sonnenaufgang war heute: </field>
                                  <value name="ADD7">
                                    <block type="text_newline" id="wx=L7.3D=er%|[C14Z/k">
                                  <value name="ADD8">
                                    <block type="time_astro" id="X4=8(JGj]~g^;y:?uHze">
                                  <value name="ADD9">
                                    <block type="text_newline" id="C3%4oZZ`#*KP4:(e8meX">
                                  <value name="ADD10">
                                    <block type="text" id="-3CK|Of5@{07tM6U`8d2">
                                      <field name="TEXT">Herzliche Grüße</field>
                                  <value name="ADD11">
                                    <block type="text_newline" id="uz,5n~`mNC.S%=A4cK`e">
                                  <value name="ADD12">
                                    <block type="text" id="(u5//+JC`ojlrT09oeLv">
                                      <field name="TEXT">ioBroker</field>
                            <block type="astro" id="KrcQ89wmJ#-s0ZEV7U)O">
                              <field name="TYPE">sunset</field>
                                <block type="telegram" id="tOvs#J}3=9![~Mb[}QVj">
                                    <shadow type="text" id="wa~^?lUKAn/,lw%9`,]6">
                                    <block type="text_join" id="pr?H($l$gf4oa2GM%wZ6">
                                      <mutation items="17"></mutation>
                                      <value name="ADD0">
                                        <block type="text" id="oPc@44kdjaSCl]_:|)_O">
                                          <field name="TEXT">Sonnenuntergang</field>
                                      <value name="ADD1">
                                        <block type="text_newline" id="957+tB9lh/t$^*]RM23B">
                                      <value name="ADD2">
                                        <block type="text" id="5(WH^8GIA9^fMs|/*Hbi">
                                      <value name="ADD3">
                                        <block type="text_newline" id="`X8HqHYE!w@%RQ5aV|NX">
                                      <value name="ADD4">
                                        <block type="time_get" id="cG6FEhGBfofjC8S3vxhS">
                                      <value name="ADD5">
                                        <block type="text_newline" id="G4ha#k*6)a(5pU#ZV98B">
                                      <value name="ADD6">
                                        <block type="text" id="PR9;SxR8DQd[;ATr{o94">
                                          <field name="TEXT">Sonnenuntergang war heute:</field>
                                      <value name="ADD7">
                                        <block type="text_newline" id="Py^^Q3idI#bva7Ssvh{B">
                                      <value name="ADD8">
                                        <block type="time_astro" id="i6o{0JonW8CMmmBmp8j3">
                                      <value name="ADD9">
                                        <block type="text_newline" id="M*W8[b-P,^Ghu$RFb4L|">
                                        <block type="text" id="SV[fR9c}sP#y:{d$#wwS">
                                          <field name="TEXT">Die Rolläden werden heute geschlossen um:</field>
                                        <block type="text_newline" id="5DHJ9JAZuq5EYnUOc{|T">
                                        <block type="time_astro" id="wBy*R$r50yZXoG!|{{+;">
                                          <field name="TYPE">dusk</field>
                                      <value name="ADD13">
                                        <block type="text_newline" id=":F:NOkQ{ZY0MrJWVx9bE">
                                      <value name="ADD14">
                                        <block type="text" id="]Xt:=J^)1x3tx/W9fPT)">
                                      <value name="ADD15">
                                        <block type="text_newline" id="Cel^A*I:-!%[7nyT$0w!">
                                      <value name="ADD16">
                                        <block type="text" id="+g~[7Jb8BP7qhA$L-1~*">
                        <block type="astro" id="O1Ay07#RTw*qUl~{x}$U">
                            <block type="telegram" id=",n/zL9F$hsM~VC?a~dCz">
                                <shadow type="text" id="=z8,zWDfH?0s)c9LH)0a">
                                <block type="text_join" id="Q)4X|O:X3w=armQA-s)K">
                                  <mutation items="15"></mutation>
                                  <value name="ADD0">
                                    <block type="text" id="b*-dpOER3Yw2?fqCk.E-">
                                  <value name="ADD1">
                                    <block type="text_newline" id="7@@O:c[w{Yks7E/z%yCV">
                                  <value name="ADD2">
                                    <block type="text" id="BCydDCD|#w(;YDeYM{R8">
                                      <field name="TEXT">Heute ist Wochenende oder ein Feiertag:</field>
                                  <value name="ADD3">
                                    <block type="text_newline" id="-,$4|yUU$LfsmOk4FrTp">
                                  <value name="ADD4">
                                    <block type="time_get" id="z7bna9Z)t+DQ2d^)kyl]">
                                  <value name="ADD5">
                                    <block type="text_newline" id="n99(JmGGGSF3tFNjMy,C">
                                  <value name="ADD6">
                                    <block type="get_value" id="QA#ecNMiLHRbO%=Bxw,M">
                                      <field name="OID">feiertage.0.heute.Name</field>
                                  <value name="ADD7">
                                    <shadow type="text" id="?^9u[ieD^uyYAiKk1*x:">
                                    <block type="text_newline" id="O+dW2JH}s]su:+DH=ucC">
                                  <value name="ADD8">
                                    <block type="text" id="@Lyt)=-],#:FJD*@gT!,">
                                      <field name="TEXT">Sonnenaufgang war heute:</field>
                                  <value name="ADD9">
                                    <block type="text_newline" id="4mj)P$C+1^?lNE)(X=Lc">
                                    <block type="time_astro" id="(DXVkqXHPv*UrsUblR3!">
                                    <block type="text_newline" id="TnuEs_AA8;k`}b6EEcha">
                                    <block type="text" id="`G4fwniM)yw0-Nxo7D(C">
                                    <block type="text_newline" id="g_7gU6CD^3jp{d4|OOF,">
                                    <block type="text" id="h#cU~Z9q#1SeD_%K@4qY">
                            <block type="astro" id=".CE`iO=llY*f#jF~H^zE">
                                <block type="telegram" id="R^QZ1^:E.uLX(v{?T+Ys">
                                    <shadow type="text" id="c5FG~g8+KO-ta0XgD#+M">
                                    <block type="text_join" id="oG2eDk1^8,{a-%U}rmo:">
                                      <mutation items="19"></mutation>
                                      <value name="ADD0">
                                        <block type="text" id=";H1,w!Y}IGNlh+ZQbf*/">
                                      <value name="ADD1">
                                        <block type="text_newline" id="%I*dKKn9VM~L^;j)cv5G">
                                      <value name="ADD2">
                                        <block type="text" id="8W(3@gq=Ou^k/dAI]OK!">
                                      <value name="ADD3">
                                        <block type="text_newline" id="mJa^0LdTfp^?IjwCbj2v">
                                      <value name="ADD4">
                                        <shadow type="text" id="NqT+r[uw!`mTw(T@Y.#U">
                                        <block type="time_get" id="m6$|+MHn97gT)($0cO`5">
                                      <value name="ADD5">
                                        <block type="text_newline" id="K~,QT9/M)NWh?3bLt~s~">
                                      <value name="ADD6">
                                        <block type="get_value" id="{Vzl2/.IVoTs]XLP6e6P">
                                      <value name="ADD7">
                                        <block type="text_newline" id="6kd%}:.R#?0=?.kF/n(/">
                                      <value name="ADD8">
                                        <block type="text" id="IIj3YXn{Zkdt]?F{EJ43">
                                          <field name="TEXT">Sonnenuntergang war heute: </field>
                                      <value name="ADD9">
                                        <block type="text_newline" id="neV{*8PTqXxs-:|F0ilp">
                                        <block type="time_astro" id="2gztw77xoNwL$pB#)pJN">
                                        <block type="text_newline" id="Jt~Meau,Jrno|pHb_=+=">
                                        <block type="text" id="u(I5G18^lIz=V*T}SMxT">
                                          <field name="TEXT">Die Rolläden werden heute geschlossen: </field>
                                        <block type="text_newline" id="5wWb/^+SWGtR:.pi`n.O">
                                        <block type="time_astro" id="]^[Bo(al]dau]}_xMij.">
                                        <block type="text_newline" id=",g,,5c?U2u$QP=7/**sK">
                                        <block type="text" id="umRoo=MNjowr(9vHQ#JM">
                                      <value name="ADD17">
                                        <block type="text_newline" id="aQ7)~;ZtA1SPu)OfDzpM">
                                      <value name="ADD18">
                                        <block type="text" id="(k?oN-RROpA$,P-?@}{d">
      Ich habe zu Testzwecken obiges Skript gebaut und wollte mir Morgens und Abends eine Nachricht schicken lassen.
      Zunächst funktionierte es auch bis auf die Tatsache, dass es nicht wirklich richtig bestimmt hat ob ein Wochentag oder ein Feiertag/Wochenendtag vorliegt. Ich hatte dabei das Gefühl, es würden nur nicht die Variablen zurückgesetzt. Deshalb habe ich den Zeitplan außen herum gesetzt um das Skript an jedem neuen Tag neu zu starten - jetzt passiert aber nix mehr. Kann jemand von Euch erkennen woran es liegt?
      Lieben Dank für Eure Hilfe...
      VG
      AnamCara
      paul53 BBTown 2 Replies Last reply Reply Quote 0
      • buggybeast
        buggybeast last edited by
        also ich kapier ehrlich gesagt noch nicht genau, was das Skript machen soll. Aber was meines Wissens nach überhaupt nicht geht, ist einen Trigger in eine "mache" Anweisung zu packen. Dein Astro unten ist ein Trigger. Der muss immer ganz außen/oben stehen. So kann das nicht funktionieren.
        Da ich leider noch nicht verstanden habe, was genau Du erreichen willst, fällt es mir auch schwer, einen Tipp zu geben.
        Aber im 2. Falls-Statement müsstest Du sowas wie: Falls Wochentag=WAHR UND AktuelleZeit=Sonnenaufgang, Mache Telegram-Nachricht.
        Somit wäre der Trigger raus.
        AnamCara 1 Reply Last reply Reply Quote 0
          paul53 @AnamCara last edited by paul53
          @AnamCara sagte:
          Keine Trigger (Astro) innerhalb von Triggern (Zeitplan) verwenden !
          Die Abfrage "istWochentag" muss innerhalb eines jeden Astro-Triggers erfolgen.
          AnamCara 2 Replies Last reply Reply Quote 0
          • BBTown
            BBTown @AnamCara last edited by BBTown
            @AnamCara
            kennst Du eigentlich den Feiertags-Adapter?
            [EDIT]
            Ich habe gerade m Script gesehen, dass Du den bereits einsetzt - da hätte ich auch vorher mal nachschauen kömnen 😎
            • AnamCara
              AnamCara @buggybeast last edited by
              @buggybeast sagte in Logik falsch?:
              Guten Morgen,
              es ist ein Test-Skript, dass mir zum Sonnenaufgang und Sonnenuntergang ein Telegramm zustellen soll.
              Wenn die Zustellungen zuverlässig und so kommen wie gewollt, dann wird darin eine Steuerung eingebaut.
              • AnamCara
                AnamCara @paul53 last edited by
                @paul53 sagte in Logik falsch?:
                Also den Zeitplan, habe ich einfach nur außen herum gelegt, weil mein Skript zwar läuft ohne den Zeitplan, aber leider stimmen die Prüfungen dann nicht mehr wirklich, es ist so als würde das Skript nicht "von oben" her starten und die Variablen neu gesetzt werden? Es kommen also falsche Meldungen (es sei denn meine Logik ist von vornherein falsch).
                Was ich halt möchte mit dem Skript ist zu testen, ob heute ein Feiertag oder ein Wochenendtag ist, falls dem so ist gibt es halt die Wochenend/Feiertagsmeldung, ist ein gewöhnlicher Wochentag die Wochentagsmeldung. In beiden Fällen soll es zum Sonnenaufgang und Sonnenuntergang eine Aktion (Steuerung) geben...
                • AnamCara
                  Okay, will heißen, dass ich zwei Skripte erstellen muss? Oder kann ich zwei Blöcke parallel in ein Skript packen?
                  Wenn dem so ist, nehme ich den Zeitplan einfach wieder heraus, splitte in Wochentag/Feiertag-Aktionen und lege den Block zur Abfrage ob normaler Wochentag (oder nicht) jeweils unter den Astro-Trigger?
                    @AnamCara sagte:
                    Ist das im Bild nicht zu erkennen ?
                    • AnamCara
                      AnamCara @paul53 last edited by AnamCara
                      Ich habe das jetzt mal so umgestellt...
                      Cron wieder raus und jetzt sind es zwei Blöcke (vorher hatte ich den rechten Block unten am ersten angehangen)... jeder hat die Abfrage nach Wochentag/Feier- & Wochenendtag.
                        @AnamCara sagte:
                        Das geht einfacher.
                        AnamCara 1 Reply Last reply Reply Quote 1
                        • AnamCara
                          Das geht einfacher.
                          Okay,
                          jetzt habe ich den Code so angepasst... oder kann ich die Zuweisung der Variable ganz an den Anfang schieben und für beide Blöcke einmal definieren?
                            <variables>
                            </variables>
                            <block type="astro" id="O1Ay07#RTw*qUl~{x}$U" x="-2987" y="-2287">
                                <block type="variables_set" id=";cpOog!4TOp4W1JZF[NL">
                                    <block type="logic_operation" id="tt~i1ofaP|5jn:Y=It@X">
                                      <field name="OP">AND</field>
                                        <block type="logic_compare" id="$.idc#1b^xUe}C5oGT8^">
                                            <block type="time_get" id="XKmmrdb5|QdArIv/c4L6">
                                            <block type="math_number" id="jpgRxS:s-v`o#@iB}-F9">
                                        <block type="logic_negate" id="!NbQ]^)GIS#mUQBNu@d8">
                                          <value name="BOOL">
                                            <block type="get_value" id="FNxuPnrCuEnGjo,8`w.!">
                                    <block type="controls_if" id="B#!uTH`#W$14vH/4;q-d">
                                        <block type="logic_compare" id="?czu3B`6n|ph,zo[xJ#A">
                                            <block type="variables_get" id="F6ncS{D*l*;]hyeDI.Oy">
                                            <block type="logic_boolean" id="S~|+9T8h+lvY8S-jEgi}">
                                              <value name="ADD0">
                                              <value name="ADD1">
                                              <value name="ADD2">
                                              <value name="ADD3">
                                              <value name="ADD4">
                                              <value name="ADD5">
                                              <value name="ADD6">
                                              <value name="ADD7">
                                              <value name="ADD8">
                                              <value name="ADD9">
                                              <value name="ADD0">
                                              <value name="ADD1">
                                              <value name="ADD2">
                                              <value name="ADD3">
                                              <value name="ADD4">
                                              <value name="ADD5">
                                              <value name="ADD6">
                                              <value name="ADD7">
                                              <value name="ADD8">
                                              <value name="ADD9">
                            <block type="astro" id=".CE`iO=llY*f#jF~H^zE" x="-2037" y="-2162">
                                <block type="variables_set" id="^S?U7/F]]EHbvm1sX0#0">
                                    <block type="logic_operation" id="_xBa!c#,RuGf{BJla1-7">
                                        <block type="logic_compare" id="hp]kq{lP2~B9q]V~t^)/">
                                            <block type="time_get" id=":+M(y^6-Go~4A.^/jpAn">
                                            <block type="math_number" id="Ex%@jnv]el%7TL]d!f=y">
                                        <block type="logic_negate" id="n8[q8m$iU{*ja`-e.Mx2">
                                          <value name="BOOL">
                                            <block type="get_value" id="N9R*5hW]|d^/nLBM/bO(">
                                    <block type="controls_if" id="FGP(Q@[/^*VkW#(l!|DE">
                                        <block type="logic_compare" id="9;;85,1~/]=kH|yENM#i">
                                            <block type="variables_get" id="oU.zP79{k|6.TdXurXIm">
                                            <block type="logic_boolean" id="H+f9C9zj?CrJ,bZms7ic">
                                              <value name="ADD0">
                                              <value name="ADD1">
                                              <value name="ADD2">
                                              <value name="ADD3">
                                              <value name="ADD4">
                                              <value name="ADD5">
                                              <value name="ADD6">
                                              <value name="ADD7">
                                              <value name="ADD8">
                                              <value name="ADD9">
                                              <value name="ADD0">
                                              <value name="ADD1">
                                              <value name="ADD2">
                                              <value name="ADD3">
                                              <value name="ADD4">
                                              <value name="ADD5">
                                              <value name="ADD6">
                                              <value name="ADD7">
                                              <value name="ADD8">
                                              <value name="ADD9">
                            @AnamCara sagte:
                            Nein, dann würde die Zuweisung nur einmal bei Script-Start ausgeführt.
                            • AnamCara
                              @paul53 Dankeschön - somit sollte ich jetzt alles korrekt haben - Test läuft 🙂
                              662
