    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    • coyote
      coyote Most Active last edited by
      @Dutchman der Fehler hier ist in 0.4.5 noch nicht behoben, korrekt?
      sourceanalytix.0	2020-04-30 13:00:18.749	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      sourceanalytix.0	2020-04-30 13:00:18.749	error	at Sourceanalytix.initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:394:16)
      sourceanalytix.0	2020-04-30 13:00:18.749	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:736:78)
      sourceanalytix.0	2020-04-30 13:00:18.749	error	(8519) [calculationHandler javascript.0.Gaszaehler.Stand] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie' of undefined
      sourceanalytix.0	2020-04-30 13:00:18.061	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      sourceanalytix.0	2020-04-30 13:00:18.061	error	at Sourceanalytix.initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:394:16)
      sourceanalytix.0	2020-04-30 13:00:18.061	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:736:78)
      sourceanalytix.0	2020-04-30 13:00:18.061	error	(8519) [calculationHandler javascript.0.Gaszaehler.Stand] error: Cannot read property 'cathegorie' of undefined, stack: TypeError: Cannot read property 'cathegorie' of undefined
      Dutchman coyote 2 Replies Last reply Reply Quote 0
      • Dutchman
        Dutchman Developer Most Active Administrators @coyote last edited by
        @coyote sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
        hast du nacht der installation die cat neu gewählt ?!
        • Dutchman
          Dutchman Developer Most Active Administrators @DL7MDX last edited by
          @DL7MDX sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
          Hier mein Problem,
          wenn der neue Tag beginnt und der routinemäßige Neustart ausgeführt wurde, und alle anderen Werte passen, passiert das mit den beiden Steckdosenwerten.
          ok und das passiert nur bei Steckdosen mit watt werten ?
            DL7MDX @Dutchman last edited by
            @Dutchman said in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
            Hier mein Problem,
            ich habe schon den Watt und den Tages kWh wert genommen, passiert mit beiden Werten bei beiden Steckdosen...
            schau mal bitte drüber ob ich alles richtig eingestellt habe, ich bin mir nicht sicher ob in der Zeile "What should be evaluated" das letzte Kästchen den Haken braucht bei Tageswerten...
            • coyote
              coyote Most Active @Dutchman last edited by
              @Dutchman ja habe ich neu gewählt, macht es Sinn wenn ich Mal auf debug schalte und dann das Log poste?
              Oder soll ich mal den Adapter komplett neu installieren?
              • coyote
                @Dutchman habe jetzt nochmal den Datenpunkt neu aktiviert und auch einen neuen Test Datenpunkt erstellt mit Gas und m³, komme aber leider zu dem gleichen Ergebnis wie oben. Log sagt, Kategorie nicht definiert
                  crunchip Forum Testing Most Active @coyote last edited by
                  @coyote das funktioniert in der aktuellen Version leider nicht, hatte den selben Fehler, da liegt noch ein "klitzekleines" Problem mit m3 und m³ vor. Bin daher vorerst wieder zurück
                  • Atifan
                    Atifan last edited by Atifan
                    Kann man schon sagen wann es wieder Werte für die letzten 7 Tage der Woche gibt?
                    Also Montag, Dienstag, Mittwoch, Donnerstag, Freitag, Samstag, Sonntag
                      Berchemer last edited by
                      Sorry, aber ich habe ein seltsames Problem hier.
                      Adapter-Version ist die seinerzeit bei github geladene v0.4.5. Ansonsten ist ioBroker auf Stand "latest" mit allen dazugehörigen Updates, die derzeit vorhanden sind.
                      Abgesehen davon, dass die Ölstands-Werte in Liter über Nacht selbst für den Tagesgebrauch exorbitant gestiegen und ins Minus gerutscht sind... Tagesverbrauch ist eigentlich Restölmenge von dem der tatsächliche Tagesverbrauch abgezogen wurde. Und das Ganze noch mit einem minus versehen 😉
                      Aber meine eigentliches Problem ist ein anderes.
                      Ich wollte im Log mehr sehen. Daher habe ich auf Info statt Warn umgeschaltet.
                      Um mehr Übersicht zu haben wollte ich nun die Protokollierung von Deconz-Stromsensoren in der Objekt-Bearbeitung deaktivieren.
                      Wenn ich im Einstellungsfenster des Objektes von SourceAnalytics bin, etwas geändert habe und auf Save klicken möchte, kann ich dies, aber das Fenster schließt sich nicht mehr. Rausgehen geht nur über Abbrechen und der Abfrage, ob man sich sicher ist, dass man abbrechen möchte. Wenn ich hier die Abfrage mit Ja bestätige, wird das Loggen beendet. Wenn ich die Abfrage cancele, dann schließt sich das Fenster, aber das Loggen wird nicht eingestellt.
                      Wenn ich Änderungen an den z.B. sql-Einstellungen mache und dann sofort auf save gehe, funktioniert dies sofort problemlos. Dies gilt aber anscheinend nur nur für alte Einstellungen des Adapters bei Deconz-Datenpunkten.
                      Habe erneut upload gestartet. Habe Server neu gestartet. Habe den Adapter gestoppt und neugestartet. Hat alles nicht dazu geführt, dass das Problem beseitigt war.
                      Irgendwie habe ich jetzt zwar alle geloggten Datenpunkte vom Logging durch SourceAnalytics ausschließen können.
                      Aber seltsam war es schon...
                      Kann dieses Problem sonst noch Jemand bestätigen?
                        Zu meinem Problem von oben noch eine Ergänzung:
                        Anscheinend betraf es alle Datenpunkte, die vor dem Upgrade von Git schon von SourceAnalytics mitprotokolliert wurden. Also liegt es nicht am Deconz oder so 🙂
                        ostseereiter 1 Reply Last reply Reply Quote 0
                        • TbsJah
                          TbsJah last edited by TbsJah
                          Das Thema wurde bereits angesprochen. Bin mir aber nicht sicher ob ich die Lösung übersehen habe oder ob es noch in Bearbeitung ist.
                          Ich bekomme negative Werte bei dem Tagespunkt
                          Eventuell habe ich etwas falsch eingestellt
                          Edit:
                          Gerade gesehen dass es nur die Werte betrifft, bei denen der aktuelle Verbrauch berechnet wird (Input W Output kWh).
                          Wenn der Wert von einem Zähler kommt sind die Ergebnisse korrekt
                            guergen @TbsJah last edited by
                            @Tobias-Jahnke das selbe Problem habe ich hier auch, jeden Morgen negative Werte, ich hab schon gedacht, dass es an meinem System liegt. Schreibe grade alle Werte kurz vor Tageswechsel in eine Liste..
                            • ostseereiter
                              ostseereiter @Berchemer last edited by
                              @Berchemer ist bei mir auch so momentan ist der nicht zu gebrauchen.
                              Lenny.CB 1 Reply Last reply Reply Quote 0
                              • Lenny.CB
                                Lenny.CB Most Active @ostseereiter last edited by
                                bei mir schaut das neuerdings jeden Morgen so aus:
                                nach dem Neustart des Adapters ist es dann wieder so:
                                ostseereiter crunchip 2 Replies Last reply Reply Quote 0
                                • ostseereiter
                                  ostseereiter @Lenny.CB last edited by
                                  @Lenny-CB genau wie bei mir, dann bin ich ja erst mal beruhigt ich habe den Fehler auf mein System gesucht. ich will nicht lügen aber 4 -5 wochen ist es schon so.
                                    crunchip Forum Testing Most Active @Lenny.CB last edited by
                                    @Lenny-CB @ostseereiter
                                    das Problem ist noch in Bearbeitung, des weiteren gibt es auch noch das ein oder andere UNIT Problem in der aktuellen V0.4.5
                                    Daher läuft bei mir aktuell V0.4.2 und lass den Adapter jede Nacht um 0:10Uhr neu starten.
                                    • ostseereiter
                                      ostseereiter @crunchip last edited by
                                      @crunchip sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                      V0.4.2
                                      na die 0.4,2 läuft bei mir auch.
                                        r.chrisi last edited by
                                        Woher kriege ich die 0.4.2 Danke vorab
                                        • ostseereiter
                                          ostseereiter @r.chrisi last edited by
                                          @r-chrisi wenn du den Iobroker in den Einstellungen auf Latest stellst. Problem ist aber damit auch nicht behoben.
                                            Okay,dann werde ich noch warten ob es Besserung gibt.Danke
                                            81.1k
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            349230
