    4. JavaScript
    5. [gelöst] on{... , change: "any"} läuft immer 2x mal
      paul53 @mickym last edited by paul53
      @mickym sagte:
      aber einmal ist doch der Value FALSE und einmal TRUE
      Nein, das ist der oldState.val. Interessant wäre gleichzeitig der state.val.
        Dado last edited by
        Da kann ich helfen 😉
        Das hier ...
        on({id: sourceIDs , change: "any", ack: true}, function (obj) {
           log("oldState.val: "  + JSON.stringify(obj.oldState.val), "warn");
           log("newState.ack: "  + JSON.stringify(obj.newState.ack), "warn");
           log("state.val: "  + JSON.stringify(obj.state.val), "warn");
        //    light_control(obj.id);
        ...ergibt bei einmal durch den Sensor laufen
        4.5.2020, 15:23:23.868	[info ]: javascript.0 (689) Stop script script.js.common.Light.motion-light1
        4.5.2020, 15:23:23.958	[info ]: javascript.0 (689) Start javascript script.js.common.Light.motion-light1
        4.5.2020, 15:23:23.962	[info ]: javascript.0 (689) script.js.common.Light.motion-light1: Subcribe folgende source IDs: ["deconz.0.Sensors.24.presence","deconz.0.Sensors.3.open"]
        4.5.2020, 15:23:23.962	[info ]: javascript.0 (689) script.js.common.Light.motion-light1: subscribe: {"pattern":{"id":"deconz.0.Sensors.24.presence","change":"any","ack":true,"q":0},"name":"script.js.common.Light.motion-light1"}
        4.5.2020, 15:23:23.962	[info ]: javascript.0 (689) script.js.common.Light.motion-light1: subscribe: {"pattern":{"id":"deconz.0.Sensors.3.open","change":"any","ack":true,"q":0},"name":"script.js.common.Light.motion-light1"}
        4.5.2020, 15:23:23.963	[info ]: javascript.0 (689) script.js.common.Light.motion-light1: registered 2 subscriptions and 0 schedules
        4.5.2020, 15:23:34.165	[warn ]: javascript.0 (689) script.js.common.Light.motion-light1: oldState.val: false
        4.5.2020, 15:23:34.165	[warn ]: javascript.0 (689) script.js.common.Light.motion-light1: newState.ack: true
        4.5.2020, 15:23:34.166	[warn ]: javascript.0 (689) script.js.common.Light.motion-light1: state.val: true
        4.5.2020, 15:23:34.168	[warn ]: javascript.0 (689) script.js.common.Light.motion-light1: oldState.val: true
        4.5.2020, 15:23:34.171	[warn ]: javascript.0 (689) script.js.common.Light.motion-light1: newState.ack: true
        4.5.2020, 15:23:34.172	[warn ]: javascript.0 (689) script.js.common.Light.motion-light1: state.val: true
        J.A.R.V.I.S. paul53 2 Replies Last reply Reply Quote 0
        • J.A.R.V.I.S.
          J.A.R.V.I.S. Developer @Dado last edited by
          @Dado du könntest 'change' in 'ne' ändern, dann wird er nur getriggert, wenn der Wert ungleich des alten Wertes ist.
          Bleibt der Wert eine gewisse Zeit auf true oder geht er danach wieder auf false?
            paul53 @Dado last edited by paul53
            @Dado
            Offenbar ist es eine Eigenheit des Deconz-Adapters, dass unmittelbar nach einer Wertänderung nochmal aktualisiert wird. Triggern auf change: "ne" sollte das Problem beheben.
              Dado @J.A.R.V.I.S. last edited by
              @J-A-R-V-I-S
              Der Wert bleibt auf true stehen und geht nach 90 Sekunden wieder auf false...
              Was etwas seltsam ist, da ist das Teil so modifiziert habe, dass er nur noch eine Totzeit von 5 Sekunden hat (Standard sind 2 Min)
              mickym J.A.R.V.I.S. 2 Replies Last reply Reply Quote 0
              • mickym
                mickym Most Active @Dado last edited by
                @Dado Ich habe die Dinger auch. Meines Erachtens sind das 2 verschiedene Paar Stiefel - das Löten heißt nur, dass er den Status mit einem minimalen Zeitpunkt von 5 Sek. auflöst.
                Die 90s kommen, wenn Du in occupancy_timeout nichts eingetragen hast. Trag da einfach mal einen Wert ein, aber ich würde den nicht zu klein wählen
                  Dado @paul53 last edited by
                  Ja und nein...
                  Ja, ich bekomme nur noch einmal getriggert
                  Nein, jetzt triggert er nur noch bei Flankenwechsel (was bei != ja auch erwartbar ist)
                  Das ist bei einem Bewegungsmelder aber ein "schwieriges" Verhalten oder anders ausgedrückt, der WAF ist dann gleich Null 😉
                    @Dado sagte:
                    Dann verwende "entprellen".
                    var timer;
                    on({id: sourceIDs}, function(dp) {
                        if(!timer) {
                            timer = setTimeout(function() {
                                timer = null;
                            }, 100);
                            // Aktionen
                    • J.A.R.V.I.S.
                      J.A.R.V.I.S. Developer @Dado last edited by J.A.R.V.I.S.
                      @Dado die Frage ist, möchtest du, wenn du in der Zeit noch einmal den Bewegungsmelder triggerst, das Skript nochmal ausführen? Das wäre mit "ne" dann nicht möglich. Dann müsstest du "any" und dann den Timestamp prüfen, ob z.B. größer eine Sekunde zum letzten mal.
                        Stand da nicht gerade noch was mit Suche im Forum? 🙂
                        Ja, sowas hatte ich gerade im Forum gefunden. Aber danke nochmal fürs Rein'paste'n!
                        Das hilft mir weiter. Werde beizeiten noch mal Rückmeldung geben, ob das dann wie gewüscht funktioniert
                        Danke!
                          @J-A-R-V-I-S
                          Brauche zweiteres. Das Licht soll ja länger anbleiben, wenn man im Sensorbereich steht. Werde diese Idee mal mit dem Snippet von paul angehen.
                          Danke!
                            Dado last edited by
                            Sieht gut aus! Eine (eventuell dumme) Frage hätte ich noch:
                            Das Skript soll ja auf verschiedene Sensoren reagieren. Wenn jetzt 2 verschiedene Sensoren innerhalb des Timeout Fensters triggern, dann würde der 2. nicht ausgeführt, oder?
                            Macht es Sinn, dass dann ggf. so zu modifizieren (und timer als array zu initialisieren)?
                                if(!timer[obj.id]) {
                                    timer[obj.id] = setTimeout(function() {timer[obj.id] = null;}, 100);
                              @Dado sagte:
                              Richtig. Wie wahrscheinlich ist es ? Man kann sicherlich auch die Sperrzeit verringern (z.B. 20 ms) , um die Wahrscheinlichkeit weiter zu verringern.
                                Vermutlich weit weniger wahrscheinlich, als ich denke... Ist ja jetzt nicht so, dass ich damit ein komplettes Hochhaus steuere. 😉
                                Danke für den Realitätscheck.
                                Werde ggf mal den Timeout zart reduzieren und stelle das hier mal auf "gelöst"
                                  ticaki last edited by ticaki
                                  Würde gerne noch etwas einbringen. Soweit ich sehe verwendest du obj.state.val nicht. Dann könntest du val:true benutzen.
                                  Ob das mit dem timer[obj.id] Sinn macht. Ja ist doch kaum Arbeit. Ich würde es dann aber eher so lösen:
                                  var devices = {};
                                  on(...(obj)=> {
                                   devices[obj.id] = true;
                                   //hier entprellen
                                   setTimeout(meineFunktion,100);
                                  function meineFunktion() {
                                   for (let dev in devices){...}
                                   devices = {};
                                  Kann Syntaxfehler enthalten. 🙂
                                  javascript
                                  1245
