    3. Entwicklung
    4. Feiertage Adapter
    Feiertage Adapter
    • derAuge
      derAuge last edited by
      in DE hat die Installation ohne probleme funktioniert
      • ruhr70
        ruhr70 last edited by
        @pix:
        Pix `
        Habe noch die Version 0.1.1 aktiv.
        Heute die ioBroker VM neu gestartet und im Log kam folgende Fehler beim Feirtagsadapter:
        ReferenceError:	2016-05-05 08:45:37	error	at feiertag (/opt/iobroker/node_modules/iobroker.feiertage/feiertage.js:103:36)
        ReferenceError:	2016-05-05 08:45:37	error	pfingstsonntag is not defined
        uncaught	2016-05-05 08:45:37	error	exception: pfingstsonntag is not defined
        Und die ganze Meldung:
        host-ubuntu1604server 2016-05-05 08:45:38 error instance system.adapter.feiertage.0 terminated with code 6 (uncaught exception)
        feiertage-0 2016-05-05 08:45:38 info adapter feiertage is unloading
        feiertage-0 2016-05-05 08:45:37 info adapter feiertage is unloading
        ReferenceError: 2016-05-05 08:45:37 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
        ReferenceError: 2016-05-05 08:45:37 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
        ReferenceError: 2016-05-05 08:45:37 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        ReferenceError: 2016-05-05 08:45:37 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
        ReferenceError: 2016-05-05 08:45:37 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
        ReferenceError: 2016-05-05 08:45:37 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:330:29)
        ReferenceError: 2016-05-05 08:45:37 error at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2782:58)
        ReferenceError: 2016-05-05 08:45:37 error at Object.utils.adapter.ready (/opt/iobroker/node_modules/iobroker.feiertage/feiertage.js:27:9)
        ReferenceError: 2016-05-05 08:45:37 error at checkHolidays (/opt/iobroker/node_modules/iobroker.feiertage/feiertage.js:166:23)
        feiertage-0 2016-05-05 08:45:37 info starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.feiertage
        host-ubuntu1604server 2016-05-05 08:45:37 info instance system.adapter.feiertage.0 started with pid 1942
        Laut change-Log hat sich da in den neueren Versionen nichts geändert.
        • coyote
          coyote Most Active last edited by
          Ich bekomme den Adapter einfach nicht mehr zum Laufen. Die 0.1.x funktionierte noch, dann hab ich die 0.3.0 installiert und ich bekomme im Log den Fehler: cannot find start File. Habe jetzt schon zig mal neu installiert, auch die Instanz vorher gelöscht. Beim neu installieren über git bzw beim aktivieren kommt der Fehler und es sind keine Datenpunkte mit Daten gefüllt.
          Wie kann ich den Fehler finden?
          Gesendet von meinem SM-T700 mit Tapatalk
            pix last edited by
            Hallo coyote,
            lösch mal den ganzen Adapter, statt nur der Instanz.
            Also im Reiter Adapter unter Zeitplanung den Adapter "Deutsche Feiertage" suchen und in der Zeil gaaanz rechts auf den Papierkorb klicken. Danach kannst du ihn über github wieder neu installieren.
            Pix
            • coyote
              Vielleicht hab ich mich falsch ausgedrückt 🙂 aber ich hab ihn ja schon mindestens 3 mal neu installiert, nicht nur die Instanz gelöscht
              • eric2905
                eric2905 last edited by
                Ich habe das gleiche Problem mit der 0.3.0
                Instanz gelöscht und neu angelegt => "startInstance feiertage.0: cannot find start file!"
                Adapter gelöscht und aus Git neu installiert, usw. => "startInstance feiertage.0: cannot find start file!"
                Das gleiche habe ich nochmal wiederholt, ohne die Feiertags-Konfig anzupassen => "startInstance feiertage.0: cannot find start file!"
                Irgendwas klemmt da.
                Gruß,
                Eric
                • derAuge
                  gerade getestet.
                  der Adapter lies sich problemlos installieren
                  Jürgen
                  • eric2905
                    Resterte ihn mal und schau dann ins Log.
                    Hast Du da keine entspr. Meldung?
                      pix last edited by
                      Habe den Adapter komplett gelöscht!
                      ! 2016-05-07 12:33:22.662 - info: iobroker del feiertage 2016-05-07 12:33:23.572 - info: iobroker host.MacMini-Ethernet.fritz.box delete /Users/pix/Documents/iobroker/node_modules/iobroker.feiertage 2016-05-07 12:33:23.905 - info: iobroker host.MacMini-Ethernet.fritz.box Counted 1 instances of feiertage 2016-05-07 12:33:23.916 - info: iobroker host.MacMini-Ethernet.fritz.box Counted 9 states (io.feiertage.*) from states 2016-05-07 12:33:24.257 - info: iobroker host.MacMini-Ethernet.fritz.box Counted 9 states (feiertage.*) from stateshost.MacMini-Ethernet.fritz.box Counted 7 states (system.adapter.feiertage.*) from states host.MacMini-Ethernet.fritz.box Counted 1 adapters for feiertage host.MacMini-Ethernet.fritz.box Counted 4 channels of feiertage ! 2016-05-07 12:33:24.478 - info: iobroker host.MacMini-Ethernet.fritz.box Counted 16 states of feiertagehost.MacMini-Ethernet.fritz.box Deleting 22 object(s). ! 2016-05-07 12:33:24.700 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.feiertage.0 2016-05-07 12:33:24.700 - info: host.MacMini-Ethernet.fritz.box object deleted system.adapter.feiertage.0 2016-05-07 12:33:24.888 - info: iobroker exit 0 2016-05-07 12:34:03.124 - info: iobroker url "https://github.com/Pix---/ioBroker.feiertage" 2016-05-07 12:34:03.748 - info: iobroker install https://github.com/Pix---/ioBroker.feiertage/tarball/master 2016-05-07 12:34:03.892 - info: iobroker npm install https://github.com/Pix---/ioBroker.feiertage/tarball/master --production --prefix "/Users/pix/Documents/iobroker" (System call) 2016-05-07 12:34:38.955 - info: iobroker exit 0 2016-05-07 12:34:39.160 - info: host.MacMini-Ethernet.fritz.box Update repository "online" under "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json" !
                      Und dann von github neu installiert:
                      ! 2016-05-07 12:35:43.581 - info: iobroker add feiertage 2016-05-07 12:35:44.222 - info: iobroker host.MacMini-Ethernet.fritz.box install adapter feiertage 2016-05-07 12:35:44.250 - info: iobroker got /Users/pix/Documents/iobroker/node_modules/iobroker.feiertage/admin 2016-05-07 12:35:44.280 - info: iobroker upload [2] feiertage.admin /Users/pix/Documents/iobroker/node_modules/iobroker.feiertage/admin/index.html index.html text/html 2016-05-07 12:35:44.360 - info: iobroker upload [1] feiertage.admin /Users/pix/Documents/iobroker/node_modules/iobroker.feiertage/admin/holidays.js holidays.js application/javascript 2016-05-07 12:35:44.429 - info: iobroker upload [0] feiertage.admin /Users/pix/Documents/iobroker/node_modules/iobroker.feiertage/admin/feiertage.png feiertage.png image/png 2016-05-07 12:35:44.522 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage created 2016-05-07 12:35:44.628 - info: iobroker host.MacMini-Ethernet.fritz.box create instance feiertage 2016-05-07 12:35:44.637 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.next.duration created 2016-05-07 12:35:44.673 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.next.date created 2016-05-07 12:35:44.709 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.next.name created 2016-05-07 12:35:44.742 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.next created 2016-05-07 12:35:44.798 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.aftertomorrow.boolean created 2016-05-07 12:35:44.832 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.aftertomorrow.name created 2016-05-07 12:35:44.867 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.aftertomorrow created 2016-05-07 12:35:44.902 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.tomorrow.boolean created 2016-05-07 12:35:44.937 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.tomorrow.name created 2016-05-07 12:35:44.969 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.tomorrow created 2016-05-07 12:35:45.005 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.today.boolean created 2016-05-07 12:35:45.040 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.today.name created 2016-05-07 12:35:45.074 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.today created 2016-05-07 12:35:45.113 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.naechster.Dauer created 2016-05-07 12:35:45.149 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.naechster.Datum created 2016-05-07 12:35:45.189 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.naechster.Name created 2016-05-07 12:35:45.222 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.naechster created 2016-05-07 12:35:45.253 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.uebermorgen.boolean created 2016-05-07 12:35:45.290 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.uebermorgen.Name created 2016-05-07 12:35:45.328 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.uebermorgen created 2016-05-07 12:35:45.359 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.morgen.boolean created 2016-05-07 12:35:45.391 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.morgen.Name created 2016-05-07 12:35:45.425 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.morgen created 2016-05-07 12:35:45.458 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.heute.boolean created 2016-05-07 12:35:45.492 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.heute.Name created 2016-05-07 12:35:45.528 - info: iobroker host.MacMini-Ethernet.fritz.box object feiertage.0.heute created 2016-05-07 12:35:45.565 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage.0.uptime created 2016-05-07 12:35:45.601 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage.0.memRss created 2016-05-07 12:35:45.636 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage.0.memHeapTotal created 2016-05-07 12:35:45.669 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage.0.memHeapUsed created 2016-05-07 12:35:45.702 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage.0.connected created 2016-05-07 12:35:45.734 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage.0.alive created 2016-05-07 12:35:45.765 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.feiertage.0 2016-05-07 12:35:45.770 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.feiertage.0 created 2016-05-07 12:35:45.777 - info: iobroker exit 0 2016-05-07 12:35:51.077 - warn: host.MacMini-Ethernet.fritz.box some hosts are offline 2016-05-07 12:36:18.240 - info: history.0 moving 961 entries from system.adapter.admin.0.memHeapTotal to file 2016-05-07 12:36:51.701 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.feiertage.0 2016-05-07 12:36:51.704 - error: host.MacMini-Ethernet.fritz.box startInstance feiertage.0: cannot find start file! !
                      Und da ist der Fehler 😢
                      Datenpunkte werden nicht gefüllt.
                      Danke für den Hinweis!
                      Pix
                        pix last edited by
                        habe eine neue Version 0.3.1 auf Github geladen. Bitte vorher sicherheitshalber den alten Adapter komplett löschen. Auch wenn das Update von npm angezeigt wird, macht es bitte mal ausnahmsweise von Github.
                        Falls nach dem Installieren von Github noch Probleme bestehen (hohe CPU Last des Adapters oder nicht gefüllte Datenpunkte), bitte die Adapter-Einstellungen einmal ändern (irgendwo Haken weg, wo einer war oder umgekehrt) und abspeichern. Danach Instanz neu starten (geht ja automatisch).
                        Warte auf Berichte!
                        Pix
                        • eric2905
                          Die Last ist geringfügig angestiegen (laut TOP habe ich 2 PIDs laufen, die jeweils zwischen 60% und 98% pendeln (auch wenn ich die Instanz im Admin stoppe ?).
                          Die Systemlast (average load) ist von 2,6 auf 3,1 angestiegen
                          Das wichtigste ist aber, das wieder Daten kommen!
                          Gruß,
                          Eric
                          • derAuge
                            hat funktioniert.
                            Adapter gelöscht und neu installiert
                            	feiertage.0
                            	aftertomorrow	channel		channel	day
                            	boolean	state	Holiday in the day after tomorrow?	state	state			false
                            	name	state	Holiday after tomorrow - Name	state	state
                            	heute	channel		channel	day
                            	Name	state	Feiertag heute - Name	state
                            	boolean	state	Feiertag heute?	state				false
                            	morgen	channel		channel	day
                            	Name	state	Feiertag morgen - Name	state
                            	boolean	state	Feiertag morgen?	state				false
                            	naechster	channel		channel	day
                            	Datum	state	Naechster Feiertag - Datum?	state	value.date			15.05.2016
                            	Dauer	state	Naechster Feiertag - Dauer bis dahin	state	value.interval.days			7 Tage
                            	Name	state	naechster Feiertag - Name	state				Pfingstsonntag
                            	next	channel		channel	day
                            	date	state	Next holiday - date?	state	value.date			15.05.2016
                            	duration	state	Duration till next holiday	state	value.interval.days			7 days
                            	name	state	Next holiday - Name	state	state			Pfingstsonntag
                            	today	channel		channel	day
                            	boolean	state	Holiday today?	state	state			false
                            	name	state	Holiday today - Name	state	state
                            	boolean	state	Holiday tomorrow?	state	state			false
                            	name	state	Holiday tomorrow - Name	state	state
                            	uebermorgen	channel		channel	day
                            	Name	state	Feiertag übermorgen - Name	state
                            	boolean	state	Feiertag übermorgen?	state				false
                            Datenpunkte wurden angelegt und gefüllt
                            Jürgen
                              …und doch!
                              wie bereits auf dem HM-Treffen diskutiert lügt der Adapter doch! :mrgreen:
                              Oder werden hier nur die noch zu wartenden ganze Tage gezählt?
                              Also Mo, Di. Mi. (=3) und dann ist Feiertag???
                              ich hätte hier eine 4 erwartet
                              Rainer
                                Der Adapter läuft bei mir jetzt schon ne ganze Weile recht problemlos! 😄
                                Dieses Jahr ist ja, der nicht so oft, aber doch immer wieder auftretende Fall, dass der 4.Advent und Heiligabend auf einen Tag fallen. Ist es möglich das in <u>einem</u> Adapter abzubilden (ich habe die Möglickeit der zweiten Instanz probiert, das würde notfalls auch gehen!)? Momentan wird mir als nächster Feiertag ja nur der 4. Advent angezeigt, aber eben nicht Heiligabend. :? Ich weiß, das sind "Luxusprobleme"! :roll:
                                Enrico
                                  pix last edited by
                                  hast recht, ist ein Luxusproblem. Oder vielleicht doch nicht? Denn der 4. Advent ist - wie immer - ein Sonntag und deshalb eigentlich nicht unbedingt im Adapter als Feiertag zu markieren. Wer das doch tut, muss damit rechnen, andere Feiertage zu übersteuern.
                                  Falls jemand jetzt sagt, der 4. Advent ist aber doch ein Feiertag, dann argumentiere ich einfach andersherum: Heilig Abend ist keiner! :lol:
                                  Pix
                                    …man da hatte ich mir aber eine konstruktivere Antwort gewünscht! :lol:
                                    Mit den Feiertagen hast du natürlich Recht, aber wenn ich davon ausgehe, dass du auch die Tage ausgesucht hast, die als "Feiertage" angezeigt werden können, hättest du ja auch schon mal drauf stoßen können, dass solch ein "Problem" entstehen kann! 😄
                                    Nee. wie gesagt, ich werde mir da was mit einer zweiten Instanz basteln, damit mir unter dem Datum auch beide "Feiertage" angezeigt werden. Hätte aber eben auch sein können, dass dir sofort ne Lösung dafür eingefallen wäre.
                                    In diesem Sinne: Einen schönen 4.Advent und schöne Weihnachten! 😄
                                    Enrico
                                      pix last edited by
                                      Hallo Enrico,
                                      der Adapter ist mittlerweile eine Gemeinschaftsproduktion mehrerer Entwickler. Zuletzt wurden auch regionale Feiertage und besondere Tage aufgenommen.
                                      Kannst du mir kurz deine Anwendung beschreiben? Reicht es, die Tage kommasepariert im Objekt zu speichern? Das sollte sich machen lassen. Weiß aber nicht, ob ich das morgen hinbekomme. Danach wird das Testen schwierig…
                                      Pix
                                        mir persönlich würde es reichen, wenn die Tage, mit Komma getrennt, als Wert erscheinen. Wie schon geschrieben, habe ich auf meinem Wandtablet unter der Datums- und Uhrzeitanzeige ein Feld, dass nur erscheint, wenn ein besonderer Tag ist. Diese besonderen Tage kommen eben aus dem Feiertage-Adapter. 🙂
                                        Das mit dem Testen ist so ne Sache, aber wie gesagt das wäre ja auch mit zwei Feiertage-Instanzen machbar, dann würde ich den Heiligabend nur in der zweiten Instanz abfragen und das dann gemeinsam anzeigen lassen. Der andere Test wäre ja erst wieder in ein paar Jahren möglich, vielleicht habe ich bis dahin das "Problem" schon wieder vergessen! :lol:
                                        Enrico
                                        • cash
                                          ich habe heute mal den Adapter installiert. Vielen Dank für den tollen Adapter.
                                          Ist es normal das alle Variablen (oder wie nennt man die?) nun zweimal da sind einmal auf deutsch und einmal auf englisch?
                                          Ich habe also jetzt einen Feiertag heute und einen Holiday today oder Naechster Feiertag - Dauer bis dahin und Duration till next holiday
                                          Beide werden jeweils auf den ersten Blick richtig gefüllt. (Leider noch 77 Tage bis zum nächsten Feiertag)
                                            Is bei mir auch so, soll wohl auch.
                                            Enrico
                                            1.2k
                                            115
                                            23318
