    4. Probleme mit Update auf 3.0.20.0 Note falsch?
    UNSOLVED Probleme mit Update auf 3.0.20.0 Note falsch?
      David16 last edited by
      @Thomas-Braun
      ich wollte heute updaten leider bekomme ich folgende Meldungen. Bevor ich etwas zerstöre, kannst du dir das nochmal anschauen? - Da scheint noch etwas aus unserer letzten Aktion nachzuhängen:
      Update discovery from @2.3.3 to @2.3.5
      NPM version: 6.14.4
      npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
      ../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void void InitAll(Handle<Object> exports) {              ^~~~~~../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token void InitAll(Handle<Object> exports) {                           ^
      ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope void InitAll(Handle<Object> exports) {                             ^~~~~~~In file included from ../src/linux/BluetoothSerialPort.cc:12:0:../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope NODE_MODULE(BluetoothSerialPort, InitAll)                                  ^/home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
      make: *** [Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Fehler 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.9.0-12-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
      gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      Update "system.adapter.discovery.0"
      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      Adapter "discovery" updated
      Adapter "doorbird"       is not installed.
      Adapter "ds18b20"        is not installed.
      Update dwd from @2.4.7 to @2.4.8
      NPM version: 6.14.4
      npm install iobroker.dwd@2.4.8 --loglevel error --prefix "/opt/iobroker" (System call)
        Thomas Braun Most Active @David16 last edited by
        @David16 Als user in /opt/iobroker
        iobroker rebuild discovery --install
        versuchen.
          David16 @Thomas Braun last edited by
          @Thomas-Braun da kommt leider folgende Meldung:
          iobroker@iobroker:/opt/iobroker$ iobroker rebuild discovery --install
          npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.discovery"
          Rebuild discovery done
            @David16 Ja, und? Ist doch ohne Fehlermeldung durchgelaufen.
              @Thomas-Braun okay, ich glaube ich meine etwas anderes.
              Ist denn die Meldung "--loglevel error --prefix "/opt/iobroker" (System call)" normal oder interpretiere ich das falsch?
              J Thomas Braun 2 Replies Last reply Reply Quote 0
                Jan1 @David16 last edited by
                @David16
                Das sagt nur dass das Loglevel auf error steht und somit auch nur Errors geloggt werden 😉
                  @David16 Ja, vollkommen in Ordnung.
                  --loglevel  error
                  bedeutet nur, das der Adapter standardmäßig auf dem Stand 'error' protokolliert.
                  sagt nur, dass der Adapter bzw. die ioBroker-Installation in den passenden Standard-Pfad installiert wird.
                    achso, okay! 😁 😁
                    Sorry!
                      @Thomas-Braun sagte in Probleme mit Update auf 3.0.20.0 Note falsch?:
                      Da wird z. B. ein Symlink auf /usr/local/bin/nodejs gesetzt, den ich nicht nachvollziehen kann. In /usr/local darf eigentlich keine Spur von node oder nodejs zu finden sein.
                      das ist noch ein sehr altes Relikt
                      damals war es tatsächlich nötig, da einige Pakete dort nach nodejs suchten
                      Wenn du meinst ich kann es rausnehmen mache ich das
                        @Homoran
                        Bin ich Archäologe für ioBroker-Frühgeschichte? 🙂
                        Ich war nur verwundert, dass der da so 'nutzlos' rumlag.
                          @Thomas-Braun und ich bin nur ein kleiner Schreiberling und Linux Noob
                          Ich schreibe so was nur wenn man es mir sagt
                          Also:
                          Ist das Kunst oder kann es weg?
                            Thomas Braun Most Active @Homoran last edited by Thomas Braun
                            @Homoran Auf aktuellen Debian-artigen Systemen liegt das von nodesource gepackte Paket da jedenfalls nichts hin. Deswegen muss da meiner Meinung nach auch kein symlink hin. Keine Ahnung, ob es noch Adapter gibt, die da fix hinschauen. Eigentlich dürfte das ja alles im $PATH des users 'iobroker' ablaufen. Und da ist /usr/bin ja drin.
                              @Thomas-Braun Danke für diese Info, dann werde ich das rausnehmen wenn ich es auf node 12 ändere.
                              1.0k
                              errorproblem node update update error
                              2101
