    4. HS100 Adapter Fehlermeldungen
    UNSOLVED HS100 Adapter Fehlermeldungen
      Berchemer @arteck last edited by
      @arteck sagte in HS100 Adapter Fehlermeldungen:
      https://github.com/arteck/ioBroker.hs100
      Test läuft auch hier 🙂
        muckel @arteck last edited by
        @arteck
        Test läuft seit Mittags
        Uuups; war das jetzt ein Ausrutscher?
        Hatte ich mit der .../error Version nicht mehr
        host.SmartHome	2020-05-05 16:55:43.422	info	Restart adapter system.adapter.hs100.0 because enabled
        host.SmartHome	2020-05-05 16:55:43.422	info	instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at TCP.<anonymous> (net.js:672:12)
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at Socket.emit (events.js:310:20)
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at Object.onceWrapper (events.js:417:26)
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: TCP 192.168.0.44:9999 Error: TCP Socket Closed. segment:0 hadError:false
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[2]: at TCP.<anonymous> (net.js:672:12)
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[2]: at Socket.emit (events.js:310:20)
        host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[2]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[2]: TCP 192.168.0.44:9999 Error: TCP Socket Closed. segment:0 hadError:false
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at TCP.<anonymous> (net.js:672:12)
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at Socket.emit (events.js:310:20)
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: TCP 192.168.0.39:9999 Error: TCP Socket Closed. segment:0 hadError:false
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[0]: at TCP.<anonymous> (net.js:672:12)
        host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[0]: at Socket.emit (events.js:310:20)
        host.SmartHome	2020-05-05 16:55:43.420	error	Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
        host.SmartHome	2020-05-05 16:55:43.420	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        host.SmartHome	2020-05-05 16:55:43.418	error	Caught by controller[0]: TCP 192.168.0.45:9999 Error: TCP Socket Closed. segment:0 hadError:false
        hs100.0	2020-05-05 16:55:42.983	error	at TCP.<anonymous> (net.js:672:12)
        hs100.0	2020-05-05 16:55:42.983	error	at Socket.emit (events.js:310:20)
        hs100.0	2020-05-05 16:55:42.983	error	at Object.onceWrapper (events.js:417:26)
        hs100.0	2020-05-05 16:55:42.983	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        hs100.0	2020-05-05 16:55:42.983	error	(28099) Error: TCP Socket Closed. segment:0 hadError:false
        hs100.0	2020-05-05 16:55:42.982	error	(28099) uncaught exception: TCP Socket Closed. segment:0 hadError:false
        hs100.0	2020-05-05 16:55:42.950	error	at TCP.<anonymous> (net.js:672:12)
        hs100.0	2020-05-05 16:55:42.950	error	at Socket.emit (events.js:310:20)
        hs100.0	2020-05-05 16:55:42.950	error	at Object.onceWrapper (events.js:417:26)
        hs100.0	2020-05-05 16:55:42.950	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        hs100.0	2020-05-05 16:55:42.950	error	(28099) Error: TCP Socket Closed. segment:0 hadError:false
        hs100.0	2020-05-05 16:55:42.950	error	(28099) uncaught exception: TCP Socket Closed. segment:0 hadError:false
        hs100.0	2020-05-05 16:55:42.881	info	(28099) Terminated (NO_ERROR): Without reason
        hs100.0	2020-05-05 16:55:42.880	info	(28099) terminating
        hs100.0	2020-05-05 16:55:42.877	error	at TCP.<anonymous> (net.js:672:12)
        hs100.0	2020-05-05 16:55:42.877	error	at Socket.emit (events.js:310:20)
        hs100.0	2020-05-05 16:55:42.877	error	at Object.onceWrapper (events.js:417:26)
        hs100.0	2020-05-05 16:55:42.877	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        hs100.0	2020-05-05 16:55:42.877	error	(28099) Error: TCP Socket Closed. segment:0 hadError:false
        hs100.0	2020-05-05 16:55:42.875	error	(28099) uncaught exception: TCP Socket Closed. segment:0 hadError:false
          skokarl last edited by skokarl
          so,
          vor 17 Stunden Adapter aktualisiert.
          Test bist jetzt :
          NICHTS, KEIN ERROR
          @muckel....den Upload hattest Du gemacht ?
            Berchemer @Berchemer last edited by Berchemer
            @Berchemer sagte in HS100 Adapter Fehlermeldungen:
            Sorry... Hatte vor 9 Stunden von Github installiert, Upload durchgeführt, dann lief es sorgenfrei... Bis vor Kurzem:
            2020-05-05 17:31:42.282 - debug: hs100.0 (32448) HS Plug 192.1.1.132
            2020-05-05 17:31:42.282 - debug: hs100.0 (32448) HS Plug 192.1.1.131
            2020-05-05 17:31:42.467 - debug: hs100.0 (32448) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:31:42
            2020-05-05 17:31:42.548 - debug: hs100.0 (32448) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:31:42
            2020-05-05 17:31:43.720 - debug: hs100.0 (32448) Refresh Data HS110 192.1.1.132
            2020-05-05 17:31:44.581 - debug: hs100.0 (32448) Month value HS110(EU) 192.1.1.132
            2020-05-05 17:31:45.017 - debug: hs100.0 (32448) Day value HS110(EU) 0.32 192.1.1.132
            2020-05-05 17:31:52.469 - error: hs100.0 (32448) uncaught exception: TCP Timeout
            2020-05-05 17:31:52.469 - error: hs100.0 (32448) Error: TCP Timeout
            at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
            at listOnTimeout (internal/timers.js:549:17)
            at processTimers (internal/timers.js:492:7)
            2020-05-05 17:31:52.470 - debug: hs100.0 (32448) Send error setDevState : Error: TCP Timeout
            2020-05-05 17:31:52.472 - info: hs100.0 (32448) terminating
            2020-05-05 17:31:52.472 - info: hs100.0 (32448) Terminated (NO_ERROR): Without reason
            2020-05-05 17:31:52.983 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Timeout
            2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
            2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
            2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[1]: at processTimers (internal/timers.js:492:7)
            2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.131:9999 Error: TCP Timeout
            2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
            2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
            2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: at processTimers (internal/timers.js:492:7)
            2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
            2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
            2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: at processTimers (internal/timers.js:492:7)
            2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.131:9999 Error: TCP Timeout
            2020-05-05 17:31:52.985 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
            2020-05-05 17:31:52.985 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
            2020-05-05 17:32:23.031 - info: host.SERVER instance system.adapter.hs100.0 started with pid 28913
            2020-05-05 17:32:23.223 - debug: hs100.0 (28913) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2020-05-05 17:32:23.232 - debug: hs100.0 (28913) Objects client ready ... initialize now
            2020-05-05 17:32:23.233 - debug: hs100.0 (28913) Objects create System PubSub Client
            2020-05-05 17:32:23.234 - debug: hs100.0 (28913) Objects create User PubSub Client
            2020-05-05 17:32:23.234 - debug: hs100.0 (28913) Objects client initialize lua scripts
            2020-05-05 17:32:23.241 - debug: hs100.0 (28913) Objects connected to redis: 0.0.0.0:9001
            2020-05-05 17:32:23.242 - debug: hs100.0 (28913) objectDB connected
            2020-05-05 17:32:23.243 - debug: hs100.0 (28913) Redis States: Use Redis connection: 0.0.0.0:9000
            2020-05-05 17:32:23.247 - debug: hs100.0 (28913) States create User PubSub Client
            2020-05-05 17:32:23.248 - debug: hs100.0 (28913) States create System PubSub Client
            2020-05-05 17:32:23.254 - debug: hs100.0 (28913) States connected to redis: 0.0.0.0:9000
            2020-05-05 17:32:23.254 - debug: hs100.0 (28913) statesDB connected
            2020-05-05 17:32:23.412 - info: hs100.0 (28913) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
            2020-05-05 17:32:23.424 - debug: hs100.0 (28913) Host = SERVER
            2020-05-05 17:32:23.446 - debug: hs100.0 (28913) undefined generated 192.1.1.131
            2020-05-05 17:32:23.447 - debug: hs100.0 (28913) undefined generated 192.1.1.132
            2020-05-05 17:32:23.700 - debug: hs100.0 (28913) HS Plug 192.1.1.132
            2020-05-05 17:32:23.701 - debug: hs100.0 (28913) HS Plug 192.1.1.131
            2020-05-05 17:32:25.700 - debug: hs100.0 (28913) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:32:25
            2020-05-05 17:32:26.862 - debug: hs100.0 (28913) Refresh Data HS110 192.1.1.132
            2020-05-05 17:32:27.735 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.132
            2020-05-05 17:32:28.169 - debug: hs100.0 (28913) Day value HS110(EU) 0.32 192.1.1.132
            2020-05-05 17:32:30.162 - debug: hs100.0 (28913) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:32:30
            2020-05-05 17:32:30.453 - debug: hs100.0 (28913) Refresh Data HS110 192.1.1.131
            2020-05-05 17:32:30.744 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.131
            2020-05-05 17:32:31.034 - debug: hs100.0 (28913) Day value HS110(EU) 0.438 192.1.1.131
            2020-05-05 17:34:23.703 - debug: hs100.0 (28913) HS Plug 192.1.1.132
            2020-05-05 17:34:23.705 - debug: hs100.0 (28913) HS Plug 192.1.1.131
            2020-05-05 17:34:23.920 - debug: hs100.0 (28913) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:34:23
            2020-05-05 17:34:25.080 - debug: hs100.0 (28913) Refresh Data HS110 192.1.1.132
            2020-05-05 17:34:25.952 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.132
            2020-05-05 17:34:26.182 - debug: hs100.0 (28913) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:34:26
            2020-05-05 17:34:26.390 - debug: hs100.0 (28913) Day value HS110(EU) 0.32 192.1.1.132
            2020-05-05 17:34:32.058 - error: hs100.0 (28913) uncaught exception: TCP Socket Closed. segment:0 hadError:false
            2020-05-05 17:34:32.058 - error: hs100.0 (28913) Error: TCP Socket Closed. segment:0 hadError:false
            at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
            at TCP. (net.js:672:12)
            2020-05-05 17:34:32.059 - debug: hs100.0 (28913) Send error setDevState : Error: TCP Socket Closed. segment:0 hadError:false
            2020-05-05 17:34:32.061 - info: hs100.0 (28913) terminating
            2020-05-05 17:34:32.061 - info: hs100.0 (28913) Terminated (NO_ERROR): Without reason
            2020-05-05 17:34:32.304 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.131
            2020-05-05 17:34:32.576 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
            2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
            2020-05-05 17:34:32.578 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
            2020-05-05 17:34:32.579 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
            2020-05-05 17:35:00.052 - info: host.SERVER instance system.adapter.dwd.0 started with pid 31169
            2020-05-05 17:35:02.620 - info: host.SERVER instance system.adapter.hs100.0 started with pid 31227
            2020-05-05 17:35:02.811 - debug: hs100.0 (31227) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2020-05-05 17:35:02.822 - debug: hs100.0 (31227) Objects client ready ... initialize now
            2020-05-05 17:35:02.823 - debug: hs100.0 (31227) Objects create System PubSub Client
            2020-05-05 17:35:02.823 - debug: hs100.0 (31227) Objects create User PubSub Client
            2020-05-05 17:35:02.824 - debug: hs100.0 (31227) Objects client initialize lua scripts
            2020-05-05 17:35:02.834 - debug: hs100.0 (31227) Objects connected to redis: 0.0.0.0:9001
            2020-05-05 17:35:02.836 - debug: hs100.0 (31227) objectDB connected
            2020-05-05 17:35:02.837 - debug: hs100.0 (31227) Redis States: Use Redis connection: 0.0.0.0:9000
            2020-05-05 17:35:02.842 - debug: hs100.0 (31227) States create User PubSub Client
            2020-05-05 17:35:02.842 - debug: hs100.0 (31227) States create System PubSub Client
            2020-05-05 17:35:02.851 - debug: hs100.0 (31227) States connected to redis: 0.0.0.0:9000
            2020-05-05 17:35:02.851 - debug: hs100.0 (31227) statesDB connected
            2020-05-05 17:35:03.034 - info: hs100.0 (31227) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
            2020-05-05 17:35:03.044 - debug: hs100.0 (31227) Host = SERVER
            2020-05-05 17:35:03.070 - debug: hs100.0 (31227) undefined generated 192.1.1.131
            2020-05-05 17:35:03.114 - debug: hs100.0 (31227) undefined generated 192.1.1.132
            2020-05-05 17:35:03.413 - debug: hs100.0 (31227) HS Plug 192.1.1.132
            2020-05-05 17:35:03.415 - debug: hs100.0 (31227) HS Plug 192.1.1.131
            2020-05-05 17:35:05.443 - debug: hs100.0 (31227) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:35:05
            2020-05-05 17:35:06.605 - debug: hs100.0 (31227) Refresh Data HS110 192.1.1.132
            2020-05-05 17:35:07.476 - debug: hs100.0 (31227) Month value HS110(EU) 192.1.1.132
            2020-05-05 17:35:07.912 - debug: hs100.0 (31227) Day value HS110(EU) 0.32 192.1.1.132
            2020-05-05 17:35:10.191 - debug: hs100.0 (31227) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:35:10
            2020-05-05 17:35:12.684 - debug: hs100.0 (31227) Refresh Data HS110 192.1.1.131
            2020-05-05 17:35:13.529 - debug: hs100.0 (31227) Month value HS110(EU) 192.1.1.131
            2020-05-05 17:35:13.965 - debug: hs100.0 (31227) Day value HS110(EU) 0.44 192.1.1.131
              skokarl @Berchemer last edited by
              @Berchemer
              bei mir seit 17 Std. sauber
                muckel @skokarl last edited by
                @skokarl
                natürlich, hab ja dazugelernt 🙂
                Bis jetzt kam es nicht mehr.
                  skokarl @muckel last edited by
                  @muckel sagte in HS100 Adapter Fehlermeldungen:
                  @skokarl
                  Du hattest doch eben noch von Fehler gesprochen ?
                    @skokarl
                    Siehe Logfile. Das kam einmalig. Seither nichts mehr. Seltsam
                      @skokarl
                      wieder
                      host.SmartHome	2020-05-05 20:04:43.615	error	Caught by controller[0]: at TCP.<anonymous> (net.js:672:12)
                      host.SmartHome	2020-05-05 20:04:43.615	error	Caught by controller[0]: at Socket.emit (events.js:310:20)
                      host.SmartHome	2020-05-05 20:04:43.614	error	Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                      host.SmartHome	2020-05-05 20:04:43.614	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                      host.SmartHome	2020-05-05 20:04:43.612	error	Caught by controller[0]: TCP 192.168.0.42:9999 Error: TCP Socket Closed. segment:0 hadError:false
                      hs100.0	2020-05-05 20:04:43.076	info	(24753) Terminated (NO_ERROR): Without reason
                      hs100.0	2020-05-05 20:04:43.075	info	(24753) terminating
                      hs100.0	2020-05-05 20:04:43.023	error	at TCP.<anonymous> (net.js:672:12)
                      hs100.0	2020-05-05 20:04:43.023	error	at Socket.emit (events.js:310:20)
                      hs100.0	2020-05-05 20:04:43.023	error	at Object.onceWrapper (events.js:417:26)
                      hs100.0	2020-05-05 20:04:43.023	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                      hs100.0	2020-05-05 20:04:43.023	error	(24753) Error: TCP Socket Closed. segment:0 hadError:false
                      hs100.0	2020-05-05 20:04:43.019	error	(24753) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                      • Winni
                        Winni last edited by Winni
                        Sorry, falscher Thread
                          seit 26 Stunden sauber !!!!
                          scheint als wäre ich raus ...😀
                          @arteck sieht gut aus.
                            Nachdem es bei mir über 12 Stunden ohne Fehler lief, habe ich auch mal sicherheitshalber den Adapter gestoppt, den Objekte-Ordner gelöscht und neu gestartet. Mal sehen, wie es jetzt weitergeht 🙂
                              gute Idee, mach ich auch noch
                                Btw. Nachdem ich wegen des Neuanlegens des Objektebaums die Protokollierung durch den SQL-Adapter wieder eingeschaltet habe, wollte ich die Monatscounter als Zähler im sql-Reiter definieren. Der sql-Adapter meckerte daraufhin, dass man string-Datenpunkte nicht als Counter definieren könne und ich stellte fest, dass die Datenpunkte mit Stromstärke, Leistung, Gesamtmenge usw. nicht als number, sondern als string definiert sind.
                                Ich gehe nicht davon aus, dass das das Problem ist, dem wir hier seit Tagen hinterherjagen. Aber sollte man die bei Neuanlage nicht als number statt string definieren? In dem Zusammenhang könnt eman ggf. auch die Unit der Datenpunkte bei Neuanlage mit angeben. Könnte u.a. der automatischen Erkennung durch den Adapter SourceAnalytics helfen, wenn bei den Werte auch Watt oder kwh oder V usw. als Unit stehen würde. Ist sicherlich nichts Dringliches, nur eine Verschönerung 🙂
                                Wer weiß, ob es auch damit zusammenhängen könnte aber ganz nebenbei habe ich auch mal die Firmware der beiden Steckdosen angehoben von
                                1.5.4 Build 180815 Rel 121440
                                auf
                                1.5.6 Build 191125 Rel 083657
                                Vielleicht hilft es ja.
                                Jetzt lasse ich aber den Adapter und die Steckdosen mal wieder in Ruhe damit sie ordentlich weiter laufen und sperre den Steckdosen nach dem Update wieder den Internetzugang 🙂
                                  Lief so schön durch... Über 12 Stunden... Und dann 😖
                                  2020-05-07 09:20:18.669 - debug: hs100.0 (5004) HS Plug 192.1.1.132
                                  2020-05-07 09:20:18.671 - debug: hs100.0 (5004) HS Plug 192.1.1.131
                                  2020-05-07 09:20:18.869 - debug: hs100.0 (5004) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 09:20:18
                                  2020-05-07 09:20:18.875 - debug: hs100.0 (5004) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 09:20:18
                                  2020-05-07 09:20:20.037 - debug: hs100.0 (5004) Refresh Data HS110 192.1.1.131
                                  2020-05-07 09:20:20.045 - debug: hs100.0 (5004) Refresh Data HS110 192.1.1.132
                                  2020-05-07 09:20:20.902 - debug: hs100.0 (5004) Month value HS110(EU) 192.1.1.132
                                  2020-05-07 09:20:20.909 - debug: hs100.0 (5004) Month value HS110(EU) 192.1.1.131
                                  2020-05-07 09:20:21.338 - debug: hs100.0 (5004) Day value HS110(EU) 0.166 192.1.1.132
                                  2020-05-07 09:20:21.352 - debug: hs100.0 (5004) Day value HS110(EU) 0.169 192.1.1.131
                                  2020-05-07 09:22:18.673 - debug: hs100.0 (5004) HS Plug 192.1.1.132
                                  2020-05-07 09:22:18.675 - debug: hs100.0 (5004) HS Plug 192.1.1.131
                                  2020-05-07 09:22:18.833 - debug: hs100.0 (5004) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 09:22:18
                                  2020-05-07 09:22:19.995 - debug: hs100.0 (5004) Refresh Data HS110 192.1.1.132
                                  2020-05-07 09:22:20.867 - debug: hs100.0 (5004) Month value HS110(EU) 192.1.1.132
                                  2020-05-07 09:22:21.302 - debug: hs100.0 (5004) Day value HS110(EU) 0.166 192.1.1.132
                                  2020-05-07 09:22:21.604 - debug: hs100.0 (5004) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 09:22:21
                                  2020-05-07 09:22:27.668 - error: hs100.0 (5004) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                  2020-05-07 09:22:27.669 - error: hs100.0 (5004) Error: TCP Socket Closed. segment:0 hadError:false
                                  2020-05-07 09:22:27.672 - info: hs100.0 (5004) terminating
                                  2020-05-07 09:22:27.672 - info: hs100.0 (5004) Terminated (NO_ERROR): Without reason
                                  2020-05-07 09:22:27.747 - error: hs100.0 (5004) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                  2020-05-07 09:22:27.748 - error: hs100.0 (5004) Error: TCP Socket Closed. segment:0 hadError:false
                                  2020-05-07 09:22:28.034 - debug: hs100.0 (5004) Day value HS110(EU) 0.169 192.1.1.131
                                  2020-05-07 09:22:28.188 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                  2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                  2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                                  2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
                                  2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
                                  2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                  2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                  2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
                                  2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
                                  2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
                                  2020-05-07 09:22:28.191 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                  2020-05-07 09:22:28.191 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                  2020-05-07 09:22:58.208 - info: host.SERVER instance system.adapter.hs100.0 started with pid 7002
                                  2020-05-07 09:22:58.527 - debug: hs100.0 (7002) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  2020-05-07 09:22:58.538 - debug: hs100.0 (7002) Objects client ready ... initialize now
                                  2020-05-07 09:22:58.539 - debug: hs100.0 (7002) Objects create System PubSub Client
                                  2020-05-07 09:22:58.539 - debug: hs100.0 (7002) Objects create User PubSub Client
                                  2020-05-07 09:22:58.540 - debug: hs100.0 (7002) Objects client initialize lua scripts
                                  2020-05-07 09:22:58.548 - debug: hs100.0 (7002) Objects connected to redis: 0.0.0.0:9001
                                  2020-05-07 09:22:58.549 - debug: hs100.0 (7002) objectDB connected
                                  2020-05-07 09:22:58.550 - debug: hs100.0 (7002) Redis States: Use Redis connection: 0.0.0.0:9000
                                  2020-05-07 09:22:58.555 - debug: hs100.0 (7002) States create User PubSub Client
                                  2020-05-07 09:22:58.555 - debug: hs100.0 (7002) States create System PubSub Client
                                  2020-05-07 09:22:58.563 - debug: hs100.0 (7002) States connected to redis: 0.0.0.0:9000
                                  2020-05-07 09:22:58.564 - debug: hs100.0 (7002) statesDB connected
                                  2020-05-07 09:22:58.786 - info: hs100.0 (7002) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                  2020-05-07 09:22:58.794 - debug: hs100.0 (7002) Host = SERVER
                                  2020-05-07 09:22:58.815 - debug: hs100.0 (7002) undefined generated 192.1.1.131
                                  2020-05-07 09:22:58.817 - debug: hs100.0 (7002) undefined generated 192.1.1.132
                                  2020-05-07 09:22:59.100 - debug: hs100.0 (7002) HS Plug 192.1.1.132
                                  2020-05-07 09:22:59.101 - debug: hs100.0 (7002) HS Plug 192.1.1.131
                                  2020-05-07 09:23:00.692 - debug: hs100.0 (7002) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 09:23:00
                                  2020-05-07 09:23:01.128 - debug: hs100.0 (7002) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 09:23:01
                                  2020-05-07 09:23:02.290 - debug: hs100.0 (7002) Refresh Data HS110 192.1.1.132
                                  2020-05-07 09:23:03.162 - debug: hs100.0 (7002) Month value HS110(EU) 192.1.1.132
                                  2020-05-07 09:23:03.173 - debug: hs100.0 (7002) Refresh Data HS110 192.1.1.131
                                  2020-05-07 09:23:03.599 - debug: hs100.0 (7002) Day value HS110(EU) 0.167 192.1.1.132
                                  2020-05-07 09:23:04.480 - debug: hs100.0 (7002) Month value HS110(EU) 192.1.1.131
                                  2020-05-07 09:23:04.916 - debug: hs100.0 (7002) Day value HS110(EU) 0.169 192.1.1.131
                                    Und erneut:
                                    2020-05-07 15:43:41.066 - debug: hs100.0 (13537) HS Plug 192.1.1.132
                                    2020-05-07 15:43:41.066 - debug: hs100.0 (13537) HS Plug 192.1.1.131
                                    2020-05-07 15:43:41.237 - debug: hs100.0 (13537) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:43:41
                                    2020-05-07 15:43:41.299 - debug: hs100.0 (13537) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:43:41
                                    2020-05-07 15:43:42.399 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.132
                                    2020-05-07 15:43:42.461 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.131
                                    2020-05-07 15:43:43.271 - debug: hs100.0 (13537) Month value HS110(EU) 192.1.1.132
                                    2020-05-07 15:43:43.333 - debug: hs100.0 (13537) Month value HS110(EU) 192.1.1.131
                                    2020-05-07 15:43:43.707 - debug: hs100.0 (13537) Day value HS110(EU) 0.332 192.1.1.132
                                    2020-05-07 15:43:43.768 - debug: hs100.0 (13537) Day value HS110(EU) 0.228 192.1.1.131
                                    2020-05-07 15:45:41.068 - debug: hs100.0 (13537) HS Plug 192.1.1.132
                                    2020-05-07 15:45:41.070 - debug: hs100.0 (13537) HS Plug 192.1.1.131
                                    2020-05-07 15:45:41.224 - debug: hs100.0 (13537) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:45:41
                                    2020-05-07 15:45:41.287 - debug: hs100.0 (13537) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:45:41
                                    2020-05-07 15:45:42.345 - error: hs100.0 (13537) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-07 15:45:42.346 - error: hs100.0 (13537) Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-07 15:45:42.348 - info: hs100.0 (13537) terminating
                                    2020-05-07 15:45:42.349 - info: hs100.0 (13537) Terminated (NO_ERROR): Without reason
                                    2020-05-07 15:45:42.450 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.131
                                    2020-05-07 15:45:42.870 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                                    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
                                    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
                                    2020-05-07 15:45:42.871 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                    2020-05-07 15:45:42.871 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                    2020-05-07 15:46:12.886 - info: host.SERVER instance system.adapter.hs100.0 started with pid 5874
                                    2020-05-07 15:46:13.079 - debug: hs100.0 (5874) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                    2020-05-07 15:46:13.090 - debug: hs100.0 (5874) Objects client ready ... initialize now
                                    2020-05-07 15:46:13.091 - debug: hs100.0 (5874) Objects create System PubSub Client
                                    2020-05-07 15:46:13.092 - debug: hs100.0 (5874) Objects create User PubSub Client
                                    2020-05-07 15:46:13.092 - debug: hs100.0 (5874) Objects client initialize lua scripts
                                    2020-05-07 15:46:13.101 - debug: hs100.0 (5874) Objects connected to redis: 0.0.0.0:9001
                                    2020-05-07 15:46:13.102 - debug: hs100.0 (5874) objectDB connected
                                    2020-05-07 15:46:13.103 - debug: hs100.0 (5874) Redis States: Use Redis connection: 0.0.0.0:9000
                                    2020-05-07 15:46:13.109 - debug: hs100.0 (5874) States create User PubSub Client
                                    2020-05-07 15:46:13.110 - debug: hs100.0 (5874) States create System PubSub Client
                                    2020-05-07 15:46:13.117 - debug: hs100.0 (5874) States connected to redis: 0.0.0.0:9000
                                    2020-05-07 15:46:13.118 - debug: hs100.0 (5874) statesDB connected
                                    2020-05-07 15:46:13.294 - info: hs100.0 (5874) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                    2020-05-07 15:46:13.305 - debug: hs100.0 (5874) Host = SERVER
                                    2020-05-07 15:46:13.333 - debug: hs100.0 (5874) undefined generated 192.1.1.131
                                    2020-05-07 15:46:13.375 - debug: hs100.0 (5874) undefined generated 192.1.1.132
                                    2020-05-07 15:46:13.537 - debug: hs100.0 (5874) HS Plug 192.1.1.132
                                    2020-05-07 15:46:13.539 - debug: hs100.0 (5874) HS Plug 192.1.1.131
                                    2020-05-07 15:46:13.873 - debug: hs100.0 (5874) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:46:13
                                    2020-05-07 15:46:15.424 - debug: hs100.0 (5874) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:46:15
                                    2020-05-07 15:46:16.588 - debug: hs100.0 (5874) Refresh Data HS110 192.1.1.131
                                    2020-05-07 15:46:17.458 - debug: hs100.0 (5874) Month value HS110(EU) 192.1.1.131
                                    2020-05-07 15:46:17.824 - debug: hs100.0 (5874) Refresh Data HS110 192.1.1.132
                                    2020-05-07 15:46:17.894 - debug: hs100.0 (5874) Day value HS110(EU) 0.228 192.1.1.131
                                    2020-05-07 15:46:19.132 - debug: hs100.0 (5874) Month value HS110(EU) 192.1.1.132
                                    2020-05-07 15:46:20.438 - debug: hs100.0 (5874) Day value HS110(EU) 0.333 192.1.1.132
                                      version 1.1.5 ist draussen
                                      wenns damit nicht besser ist muss ich ein issue erstellen .. bei tplink-smarthome-api
                                      das ist nicht meine bibliothek.. und hab keine einfluss druff
                                      B 2 Replies Last reply Reply Quote 1
                                        Und wieder fast 24 Stunden später 😬
                                        2020-05-08 15:38:22.814 - debug: hs100.0 (5127) HS Plug 192.1.1.132
                                        2020-05-08 15:38:22.814 - debug: hs100.0 (5127) HS Plug 192.1.1.131
                                        2020-05-08 15:38:23.087 - debug: hs100.0 (5127) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.8 15:38:23
                                        2020-05-08 15:38:23.111 - debug: hs100.0 (5127) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.8 15:38:23
                                        2020-05-08 15:38:24.273 - debug: hs100.0 (5127) Refresh Data HS110 192.1.1.131
                                        2020-05-08 15:38:25.146 - debug: hs100.0 (5127) Month value HS110(EU) 192.1.1.131
                                        2020-05-08 15:38:25.581 - debug: hs100.0 (5127) Day value HS110(EU) 0.262 192.1.1.131
                                        2020-05-08 15:38:29.058 - error: hs100.0 (5127) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.058 - error: hs100.0 (5127) Error: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.059 - debug: hs100.0 (5127) Send error setDevState : Error: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.061 - info: hs100.0 (5127) terminating
                                        2020-05-08 15:38:29.061 - info: hs100.0 (5127) Terminated (NO_ERROR): Without reason
                                        2020-05-08 15:38:29.188 - error: hs100.0 (5127) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.188 - error: hs100.0 (5127) Error: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.475 - debug: hs100.0 (5127) Day value HS110(EU) 0.333 192.1.1.132
                                        2020-05-08 15:38:29.576 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
                                        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
                                        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
                                        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
                                        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Socket.emit (events.js:310:20)
                                        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at TCP. (net.js:672:12)
                                        2020-05-08 15:38:29.578 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                        2020-05-08 15:38:29.578 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                        2020-05-08 15:38:59.591 - info: host.SERVER instance system.adapter.hs100.0 started with pid 11771
                                        2020-05-08 15:38:59.780 - debug: hs100.0 (11771) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                        2020-05-08 15:38:59.790 - debug: hs100.0 (11771) Objects client ready ... initialize now
                                        2020-05-08 15:38:59.791 - debug: hs100.0 (11771) Objects create System PubSub Client
                                        2020-05-08 15:38:59.791 - debug: hs100.0 (11771) Objects create User PubSub Client
                                        2020-05-08 15:38:59.792 - debug: hs100.0 (11771) Objects client initialize lua scripts
                                        2020-05-08 15:38:59.799 - debug: hs100.0 (11771) Objects connected to redis: 0.0.0.0:9001
                                        2020-05-08 15:38:59.800 - debug: hs100.0 (11771) objectDB connected
                                        2020-05-08 15:38:59.801 - debug: hs100.0 (11771) Redis States: Use Redis connection: 0.0.0.0:9000
                                        2020-05-08 15:38:59.806 - debug: hs100.0 (11771) States create User PubSub Client
                                        2020-05-08 15:38:59.807 - debug: hs100.0 (11771) States create System PubSub Client
                                        2020-05-08 15:38:59.813 - debug: hs100.0 (11771) States connected to redis: 0.0.0.0:9000
                                        2020-05-08 15:38:59.814 - debug: hs100.0 (11771) statesDB connected
                                        2020-05-08 15:38:59.984 - info: hs100.0 (11771) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                        2020-05-08 15:38:59.992 - debug: hs100.0 (11771) Host = SERVER
                                        2020-05-08 15:39:00.036 - debug: hs100.0 (11771) undefined generated 192.1.1.131
                                        2020-05-08 15:39:00.078 - debug: hs100.0 (11771) undefined generated 192.1.1.132
                                        2020-05-08 15:39:00.316 - debug: hs100.0 (11771) HS Plug 192.1.1.132
                                        2020-05-08 15:39:00.317 - debug: hs100.0 (11771) HS Plug 192.1.1.131
                                        2020-05-08 15:39:02.320 - debug: hs100.0 (11771) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.8 15:39:02
                                        2020-05-08 15:39:02.324 - debug: hs100.0 (11771) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.8 15:39:02
                                        2020-05-08 15:39:03.482 - debug: hs100.0 (11771) Refresh Data HS110 192.1.1.132
                                        2020-05-08 15:39:03.487 - debug: hs100.0 (11771) Refresh Data HS110 192.1.1.131
                                        2020-05-08 15:39:04.353 - debug: hs100.0 (11771) Month value HS110(EU) 192.1.1.132
                                        2020-05-08 15:39:04.358 - debug: hs100.0 (11771) Month value HS110(EU) 192.1.1.131
                                        2020-05-08 15:39:04.791 - debug: hs100.0 (11771) Day value HS110(EU) 0.333 192.1.1.132
                                        2020-05-08 15:39:04.794 - debug: hs100.0 (11771) Day value HS110(EU) 0.262 192.1.1.131
                                        2020-05-08 15:40:00.015 - info: host.SERVER instance system.adapter.dwd.0 started with pid 12366
                                        2020-05-08 15:40:00.685 - info: dwd.0 (12366) starting. Version 2.4.8 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.0.20
                                        2020-05-08 15:40:01.386 - info: dwd.0 (12366) Terminated (NO_ERROR): Without reason
                                        2020-05-08 15:40:01.893 - info: host.SERVER instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                                          Dann installiere ich erneut 🙂
                                          Btw. Der Beitrag von eben war noch mit der alten Version!
                                            Sorry 😞
                                            Etwas mehr als 21 Stunden hat der Adapter durchgehalten 🙂
                                            Nach "normaler" Installation (Update) des Adapters über den Infotab habe ich sicherheitshalber trotzdem noch einmal upload angeklickt. System danach neu gestartet. Und etwas mehr als 21 Stunden später:
                                            2020-05-09 14:27:02.185 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                            2020-05-09 14:27:02.186 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                            2020-05-09 14:27:02.400 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:27:02
                                            2020-05-09 14:27:03.562 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                            2020-05-09 14:27:04.434 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                            2020-05-09 14:27:04.870 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                            2020-05-09 14:27:05.512 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:27:05
                                            2020-05-09 14:27:06.675 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.131
                                            2020-05-09 14:27:07.547 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.131
                                            2020-05-09 14:27:07.983 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.218 IP : 192.1.1.131
                                            2020-05-09 14:29:02.188 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                            2020-05-09 14:29:02.189 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                            2020-05-09 14:29:02.392 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:29:02
                                            2020-05-09 14:29:02.395 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:29:02
                                            2020-05-09 14:29:03.554 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                            2020-05-09 14:29:03.557 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.131
                                            2020-05-09 14:29:04.429 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                            2020-05-09 14:29:04.439 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.131
                                            2020-05-09 14:29:04.861 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                            2020-05-09 14:29:04.865 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.218 IP : 192.1.1.131
                                            2020-05-09 14:31:02.191 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                            2020-05-09 14:31:02.193 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                            2020-05-09 14:31:03.665 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:31:03
                                            2020-05-09 14:31:04.828 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                            2020-05-09 14:31:05.699 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                            2020-05-09 14:31:06.135 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                            2020-05-09 14:31:12.193 - debug: hs100.0 (12363) IP not found : 192.1.1.131
                                            2020-05-09 14:33:02.194 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                            2020-05-09 14:33:02.194 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                            2020-05-09 14:33:02.462 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:33:02
                                            2020-05-09 14:33:02.754 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                            2020-05-09 14:33:03.043 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                            2020-05-09 14:33:03.332 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                            2020-05-09 14:33:07.852 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:33:07
                                            2020-05-09 14:33:17.854 - error: hs100.0 (12363) uncaught exception: TCP Timeout
                                            2020-05-09 14:33:17.854 - error: hs100.0 (12363) Error: TCP Timeout
                                            2020-05-09 14:33:17.855 - debug: hs100.0 (12363) Error getDevice192.1.1.131
                                            2020-05-09 14:33:17.857 - info: hs100.0 (12363) terminating
                                            2020-05-09 14:33:17.857 - info: hs100.0 (12363) Terminated (NO_ERROR): Without reason
                                            2020-05-09 14:33:18.393 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Timeout
                                            2020-05-09 14:33:18.396 - error: host.SERVER Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                            2020-05-09 14:33:18.396 - error: host.SERVER Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
                                            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[1]: at processTimers (internal/timers.js:492:7)
                                            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.131:9999 Error: TCP Timeout
                                            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
                                            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at processTimers (internal/timers.js:492:7)
                                            2020-05-09 14:33:18.397 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                            2020-05-09 14:33:18.398 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                            2020-05-09 14:33:48.516 - info: host.SERVER instance system.adapter.hs100.0 started with pid 28253
                                            2020-05-09 14:33:48.766 - debug: hs100.0 (28253) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                            2020-05-09 14:33:48.778 - debug: hs100.0 (28253) Objects client ready ... initialize now
                                            2020-05-09 14:33:48.778 - debug: hs100.0 (28253) Objects create System PubSub Client
                                            2020-05-09 14:33:48.779 - debug: hs100.0 (28253) Objects create User PubSub Client
                                            2020-05-09 14:33:48.779 - debug: hs100.0 (28253) Objects client initialize lua scripts
                                            2020-05-09 14:33:48.787 - debug: hs100.0 (28253) Objects connected to redis: 0.0.0.0:9001
                                            2020-05-09 14:33:48.790 - debug: hs100.0 (28253) objectDB connected
                                            2020-05-09 14:33:48.791 - debug: hs100.0 (28253) Redis States: Use Redis connection: 0.0.0.0:9000
                                            2020-05-09 14:33:48.796 - debug: hs100.0 (28253) States create User PubSub Client
                                            2020-05-09 14:33:48.796 - debug: hs100.0 (28253) States create System PubSub Client
                                            2020-05-09 14:33:48.803 - debug: hs100.0 (28253) States connected to redis: 0.0.0.0:9000
                                            2020-05-09 14:33:48.803 - debug: hs100.0 (28253) statesDB connected
                                            2020-05-09 14:33:48.976 - info: hs100.0 (28253) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                            2020-05-09 14:33:48.985 - debug: hs100.0 (28253) Host = SERVER
                                            2020-05-09 14:33:49.007 - debug: hs100.0 (28253) create state
                                            2020-05-09 14:33:49.008 - debug: hs100.0 (28253) undefined generated 192.1.1.131
                                            2020-05-09 14:33:49.050 - debug: hs100.0 (28253) create state
                                            2020-05-09 14:33:49.050 - debug: hs100.0 (28253) undefined generated 192.1.1.132
                                            2020-05-09 14:33:49.352 - debug: hs100.0 (28253) HS Plug 192.1.1.132
                                            2020-05-09 14:33:49.354 - debug: hs100.0 (28253) HS Plug 192.1.1.131
                                            2020-05-09 14:33:51.380 - debug: hs100.0 (28253) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:33:51
                                            2020-05-09 14:33:52.543 - debug: hs100.0 (28253) Refresh Data HS110 192.1.1.132
                                            2020-05-09 14:33:53.449 - debug: hs100.0 (28253) Month value Model : HS110(EU) IP : 192.1.1.132
                                            2020-05-09 14:33:53.884 - debug: hs100.0 (28253) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                            2020-05-09 14:33:56.679 - debug: hs100.0 (28253) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:33:56
                                            2020-05-09 14:33:57.841 - debug: hs100.0 (28253) Refresh Data HS110 192.1.1.131
                                            2020-05-09 14:33:58.713 - debug: hs100.0 (28253) Month value Model : HS110(EU) IP : 192.1.1.131
                                            2020-05-09 14:33:59.153 - debug: hs100.0 (28253) Day value for Model : HS110(EU) Energy : 0.219 IP : 192.1.1.131
                                            fehler im log hs100 adapter
                                            23
                                            190
                                            19704
