    5. Überprüfen ob Aktor Steuerbefehl erhalten hat...
    • DAN78
      DAN78 @AnamCara last edited by DAN78
      @AnamCara Probier mal das Skript. Ich glaube du wolltest das haben
        <variables>
          <variable type="" id="fGkS8jJx-UC*s0yHpdv*">var_neue_Behanghoehe</variable>
          <variable type="" id="Yyk;+Ej*G^q;$$=E8S}l">var_Anzahl_Versuche</variable>
          <variable type="undefined" id="Intervall_weiterer_Versuch">Intervall_weiterer_Versuch</variable>
        </variables>
        <block type="variables_set" id="e8dE+dd:bTXjxgRb9~4?" x="-438" y="37">
          <field name="VAR" id="fGkS8jJx-UC*s0yHpdv*" variabletype="">var_neue_Behanghoehe</field>
            <block type="math_number" id="dj3~OilSG7CKfWwMQOk@">
              <field name="NUM">70</field>
            <block type="schedule" id="TCe,*CJa}b+Jd_3e(#;G">
              <field name="SCHEDULE">49 15 * * *</field>
                <block type="controls_if" id="L$.KI`y*kgR#nR0BX3JJ">
                    <block type="logic_compare" id="Q3A1x?oUTFLHLZ}%{|ux">
                      <field name="OP">NEQ</field>
                        <block type="variables_get" id="X_oyMKvcM,J#8,+-.EqH">
                        <block type="get_value" id="e6n%9(6~|$SO(B-Z#7NM">
                          <field name="OID">hm-rpc.0.PEQ0005311.1.LEVEL</field>
                    <block type="control" id="D|P8C=#ml5QYhj{$EMuR">
                        <block type="variables_get" id="QahG?%RGy:~Q*qb{l,f^">
                        <block type="debug" id="?z|?eaHf-CB^X)WwSmsq">
                          <value name="TEXT">
                            <shadow type="text" id="dNW](`0}~]2aq:]KjY1(">
                              <field name="TEXT">1. Versuch</field>
                            <block type="variables_set" id="gMbk;?$z_[Af8pEA1Mpy">
                              <field name="VAR" id="Yyk;+Ej*G^q;$$=E8S}l" variabletype="">var_Anzahl_Versuche</field>
                                <block type="math_number" id="R(Hl|}rF20EbED5,:?)f">
                                  <field name="NUM">1</field>
                                <block type="timeouts_setinterval" id="26zz;Qjv:Ae:EPjV)},K">
                                  <field name="NAME">Intervall_weiterer_Versuch</field>
                                  <field name="INTERVAL">2</field>
                                    <block type="math_change" id="${[B@86#A~$X%^If(XZ{">
                                      <value name="DELTA">
                                        <shadow type="math_number" id="V,mJT1/f?=TkL*V2!62T">
                                        <block type="controls_if" id="TNQkz1~2HtsEWy]7~gGu">
                                            <block type="logic_operation" id="O2yuL1;z2nk3kkw{+{.^">
                                              <field name="OP">AND</field>
                                                <block type="logic_compare" id="a?hCtQF?1_S(Fqwa*fXa">
                                                  <field name="OP">LTE</field>
                                                    <block type="variables_get" id="Dwq77@qs?FOIPh+]vBn#">
                                                    <block type="math_number" id="_@,w5,-[?Hi))Vs9:?_i">
                                                      <field name="NUM">5</field>
                                                <block type="logic_compare" id="K`|`?6#+WZ:]~378XENY">
                                                    <block type="variables_get" id="eB35z2Gz-9pKG@|rRX]0">
                                                    <block type="get_value" id="|H)xi=7Vc?]F+(}x#fWx">
                                            <block type="control" id="LPoX~di|oNj$[!i{rTPT">
                                                <block type="variables_get" id="x/4L5EMrB=Z]%g^}Eox~">
                                                <block type="debug" id="-o-^OGwdRTOp2[|+Wro.">
                                                  <value name="TEXT">
                                                    <shadow type="text" id=";xPlZCpA^7Asu6v`DK:%">
                                                    <block type="text_join" id="+Y[_X9ky{vf]4ahC-NuS">
                                                      <value name="ADD0">
                                                        <block type="variables_get" id="x8(Q!|R!{:VrD6AK,@D@">
                                                      <value name="ADD1">
                                                        <block type="text" id="/(PHvCiQv)2Q7+XN-ImP">
                                                          <field name="TEXT">. Versuch</field>
                                          <statement name="ELSE">
                                            <block type="timeouts_clearinterval" id="0o,:CCsd[6[VLU4E8#Uz">
                                                <block type="debug" id="s/5zpJ!M@jhY*ib5/g]N">
                                                  <value name="TEXT">
                                                    <shadow type="text" id="D|6rcCb|b@ax^xIM#/fU">
                                                      <field name="TEXT">Rolladen Buero Joerg verzeichnet eine Störung!</field>
                                                    <block type="debug" id="PFQeInC2-=9KZr$hCYea">
                                                      <value name="TEXT">
                                                        <shadow type="text" id="o,uR+N]%2dAY#0--NRZu">
                                                          <field name="TEXT">Intervall/Skript Ende</field>
                <block type="on_ext" id="+.-r#/(bd(1;%iji|@OG">
                  <field name="ACK_CONDITION">true</field>
                  <value name="OID0">
                    <shadow type="field_oid" id="F}2pd5:IApGH#fdP7Kea">
                      <field name="oid">hm-rpc.0.PEQ0005311.1.WORKING</field>
                    <block type="controls_if" id="cI$Iy0K*u5qH)k}4+}5Y">
                        <block type="on_source" id="EY69Ml6`|vHhmrcu{g:e">
                        <block type="debug" id="?W;z^Nfw#ojq2W+b@oID">
                          <value name="TEXT">
                            <shadow type="text" id="h3arA9hGdT|2^mmI|W#N">
                              <field name="TEXT">Rolladen in Aktion</field>
                      <value name="IF1">
                        <block type="logic_operation" id="|nw:k=p~Yn6,8{1`!q9e">
                            <block type="logic_negate" id="g(+XF=#sOL_t5bVJ;.?A">
                              <value name="BOOL">
                                <block type="on_source" id="i;:o=-y%9gA}A-R9p7qR">
                            <block type="logic_compare" id="?n9YB~5~.R2i{pch#0$1">
                              <field name="OP">EQ</field>
                                <block type="variables_get" id="|VUq.Z5l`]Gf#V[e;3xv">
                                <block type="get_value" id="bc.gU,7!}/an!aG1hXFN">
                      <statement name="DO1">
                        <block type="debug" id="n*~m:g:BfTs0_`]=stW~">
                          <value name="TEXT">
                            <shadow type="text" id="*_Y#R].#=_ek)LQ#(s%=">
                              <field name="TEXT">Rolladen ist auf Behanghoehe.</field>
                            <block type="debug" id="M4Zv{r5[qetQXav^BD;5">
                              <value name="TEXT">
                                <shadow type="text" id="5=|n{7v:BacBXfuYT%(L">
      AnamCara 1 Reply Last reply Reply Quote 1
      • AnamCara
        AnamCara @DAN78 last edited by AnamCara
        Dankeschön @DAN78
        nur eine kurze Rückfrage ich habe leider kein .WORKING objekt das ich abfragen kann in HMip oder habe ich etwas übersehen?
        Wenn ich das Skript ausführe, dann laufen gleich alle 1-5 Versuche durch, ich habe deshalb den Intervall von 2 Sek. auf 2 Minuten geändert. Bei mir habe ich dann anstelle von WORKING den ACTIVITY__STATE gewählt. Jetzt kommt im Log dann nur noch folgendes
        javascript.0 2020-04-24 07:57:15.215 info (878) script.js.Test.Pruefung: Rolladen in Aktion
        javascript.0 2020-04-24 07:57:00.213 info (878) script.js.Test.Pruefung: Rolladen in Aktion
        javascript.0 2020-04-24 07:57:00.025 info (878) script.js.Test.Pruefung: 1. Versuch
        Sollte mich der zweite "Rolladen in Aktion" Eintrag stören? 🤔
        DAN78 1 Reply Last reply Reply Quote 0
        • DAN78
          @AnamCara
          Zum zweiten Log-Eintrag:
          Was hast du im Trigger? (Objekt ID geändert oder aktualisiert / anerkannt egal oder update)
          Habe die von HM (ohne IP), kann oder wird sein dass die Datenpunkte nicht identisch sind.
          Activity wird bei HMIP vermutlich dieselbe Funktion haben wie Working und Stop bei HM.
          Du kannt das Ganze evtl auch mit Direction verknüpfen. (states: 0=NONE; 1=UP; 2=DOWN; 3=UNDEFINED)
          Hatte die 2 Sekunden in Intervall um das Blockly zu testen.
          AnamCara 1 Reply Last reply Reply Quote 0
          • AnamCara
            @DAN78 sagte in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
            Ich habe als Trigger "Falls Objekt Rolladen.Buero.Joerg:4.ACTIVITY_STATE wurde geändert".
              <variables>
              </variables>
                    <field name="NUM">100</field>
                    <field name="SCHEDULE">57 7 * * *</field>
                                <field name="OID">hm-rpc.1.00111A49A48768.4.LEVEL</field>
                                <value name="TEXT">
                                                        <value name="TEXT">
                                                            <value name="ADD0">
                                                            <value name="ADD1">
                                                        <value name="TEXT">
                                                            <value name="TEXT">
                            <value name="OID0">
                                <field name="oid">hm-rpc.1.00111A49A48768.4.ACTIVITY_STATE</field>
                                    <value name="TEXT">
                                <value name="IF1">
                                        <value name="BOOL">
                                    <value name="TEXT">
                                        <value name="TEXT">
            Wo kann man eigentlich mal nachlesen, welchen Kanal man wann verwendet und wofür diese gut sind? Ich finde bei eQ3 nicht wirklich eine gute Beschreibung von Aktoren und den Funktionen/Kanälen...
            AnamCara Homoran 2 Replies Last reply Reply Quote 0
            • AnamCara
              AnamCara @AnamCara last edited by
              Nachdem ich nun einfache Verzögerungen (jeweils 5 Sekunden) eingebaut habe ist das Problem nicht mehr aufgetreten.
              @AnamCara sagte in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
                Homoran Global Moderator Administrators @AnamCara last edited by
                bei HomeMatic gibt es ein Programmierhandbuch (Teil4 Datenpunkte) in dem alles sehr asuführlich dokumentiert ist.
                für IP gibt es auch so etwas, das ist schon fast ein Telefonbuch.
                Ansonsten auf der CCU unter Einstellungen - Geräte das entsprechende Gerät aufrufen, dann steht dort üblicherweise zu jedem Kanal zumindest der mehr oder weniger aussagekräftige Bezeichner
                • AnamCara
                  AnamCara @Homoran last edited by AnamCara
                  @Homoran wenn Du das hier meinst? https://www.eq-3.de/Downloads/eq3/download bereich/handbuecher/WebUI_Handbuch_eQ-3.pdf da steht leider nicht alles drin 😞 zum Beispiel fehlen die Rolladenaktoren...
                    Nö - sondern das hier:
                    https://www.eq-3.de/service/downloads.html?id=90
                    • AnamCara
                      @Homoran sagte in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
                      Da sind leider keine HmIP Komponenten drin und die Suche gibt auch keine entsprechenden Ergebnisse. Schade.
                      HM und HmIP haben zum Teil andere Bezeichnungen in den Namen .
                        paul53 @AnamCara last edited by
                        @AnamCara
                        Homematic IP Devices
                        • AnamCara
                          AnamCara @paul53 last edited by
                          @paul53 sagte in Überprüfen ob Aktor Steuerbefehl erhalten hat...:
                          Super - bei einheitlicher Benennung hätte ich es gefunden - so lieben Dank an @paul53 !
                          blockly scenes
                          2141
