    4. [Tablet Control] Tablet Steuerung möchte getestet werden
      firehero last edited by
      @Issi sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
      https://github.com/xXBJXx/ioBroker.tablet-control
      Hi Issi,
      ich wollte es installieren und testen,
      aber leider kommt bei der Installation folgender Fehler.
      $ ./iobroker url "https://github.com/xXBJXx/ioBroker.tablet-control"
      install https://github.com/xXBJXx/ioBroker.tablet-control/tarball/742798832b5a54498e72acc6c22b74ba0b3ee914
      NPM version: 6.14.5
      npm install https://github.com/xXBJXx/ioBroker.tablet-control/tarball/742798832b5a54498e72acc6c22b74ba0b3ee914 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/graceful-fsnpm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/graceful-fs'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/graceful-fs']npm ERR! stack:npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/graceful-fs'',npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'access',npm ERR! path: '/opt/iobroker/node_modules/graceful-fs' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-05T09_51_38_223Z-debug.log
      ERROR: host.ioBroker-RasPi4 Cannot install https://github.com/xXBJXx/ioBroker.tablet-control/tarball/742798832b5a54498e72acc6c22b74ba0b3ee914: 243
      ERROR: process exited with code 25
      VG Axel
      Issi 1 Reply Last reply Reply Quote 0
      • Issi
        Issi Developer @firehero last edited by
        @firehero Es schaut so aus alls hättest du ein rechte Problem auf deinem System führe bitte den [iobroker fix](curl -sL https://iobroker.net/fix.sh | bash ) in der console durch und probiere es danach noch mal
          liv-in-sky @Issi last edited by
          gute idee - habe eh immer probleme damit - installation hat geklappt und datenpunkte sind da (nur das firetablet will seine adresse nicht im datenpunkt haben) - mein firetablet dreht die brightness immer runter - vielleicht kann ich das mit deinem adapter in den griff bekommen
          jetzt muss ich erstmal meine scripte finden, die das bei mir machen und deaktivieren und dann werd ich mal testen
            skokarl @Issi last edited by
            @Issi
            also erstmal, Tolle Idee !
            Ich benutze Fully seit dem ersten Tag.
            Es gibt zwar schon einen Fully Adapter, sieht bei Dir aber so aus, als hättest Du andere Prioritäten.
            Youtube als Bildschirmschoner klingt schonmal klasse.
            Mein Tablet geht nach einer gewissen Zeit in den Bildschirmschoner, und Motiondetect holt das
            Tablet wieder aus dem Schlaf und macht einen Refresh. ( so ist es aktuell bei mir, ohne Deinen Adapter )
            Bei Deinem Adapter kommt mir jetzt wieder die Idee, dass bisher niemand die Frontkamera benutzt.
            Warum eigentlich nicht ? Könntest Du Dir vorstellen, dass die Frontkamera ein Bild schiesst sobald jemand
            das Tablet mit Motiondetect aus dem Schlaf holt ? Natürlich konfigurierbar. Ich will mich ja nicht ständig selbst
            fotografieren, 😁 , aber vielleicht könnte man dieses Feature dann ich Kombination der Alarmanlage aktivieren.
            Nur so ne Idee, werde den Adapter mal in Ruhe testen.
            Danke.
              A Former User @Issi last edited by
              @Issi Hi, super Idee 👍👍👍👍
              Hab ihn gestern früh installiert, läuft ohne Fehlermeldungen im Log.
              ( Js-controller 3.0.20, node 12.6.3 , Linux system)
              Das Schalten der Steckdose klappt.
              Die Helligkeit ging bei mir nicht, da er wohl nicht auf den Xiaomi Bewegungsmelder reagiert.. muss ich aber nochmal testen, hatte gestern keine Zeit mehr.
              Auf jeden Fall eine sehr gute Ergänzung!!
              • jackblackson
                jackblackson last edited by
                @Issi Sehr coole Idee, diesen Adapter zu bauen. Wäre es vielleicht möglich, die Funktionen von diesem Skript auch in deinen Adapter zu übernehmen? Würde für mich thematisch passen, und wird glaub auch von vielen genutzt:
                https://forum.iobroker.net/topic/20876/vorlage-automatischer-view-wechsel-u-slideshow . Oder möchtest du mit dem Adapter nur Dinge steuern, die über Fully machbar sind?
                • Issi
                  Issi Developer @skokarl last edited by
                  @skokarl
                  Ich habe deine Idee das die Cam ein bild macht sobald Bewegung erkannt wird geprüft und es ist zwar möglich das da ein bild gemacht wird allerdings sehe ich keine Möglichkeit das bild zuspeichern oder direkt zu verschicken da ich nur solch ein Code zurück bekomme
                  6\u0012��H\u0012Dz\u001e�\t4�\f�N�lt.\u0001��36쐁�8���=T�R���=f�y�S~�q�k���\u0016�����\u0017yV�\u0000L�h*(\u0007x@=M(�X�\u0015�-j[,�.�\u0004\u0018�Y\u0006|b@%H!E;H�\f����n���/\u001e�\r��r�8�)v���.���\u0000wR�����\u0010��\r~��ј�Q�[\u0016@1kf�Ä�\u001b\t;�c�r�l\u0007Y\u001e�Tq+��7
                  \-��v�.8��]�-�+��V\u0005Ĕ��$\u0010L����5p�N��1��f�Ǹz�IZ�D��%$!F\u0001�GH\u0003p��UZˆx[\u0016.�zKj\u0004Y�\u0018������.�\-]%��\u001e\u001c)E!Bg��)\u0012�E�1���;\u001c҆3\u0016\u0018�\u0012��\u000b}��!�8\u0000ح\t\n�z���\u001d=y�x���ܶXp\u0000�\b�j�ы8\u000e\u0019�˝P��鸺�]��[���U\u
                  0005j\nmPRF�\u001c�\u0001ڱ?��)�5�=}��.��"۶�\u0019\u0016�˄��W$(��?2�2���$Rr
                  N\u0004���\u000e��r:��J?U#����\u0002�\n��2�7��M��\u0001�\u0012�\n\u0007t��\u001f1Zs�z�k\u001c\u001b\u0017-�{�n���_M��o�p���q��;�\�l�ka%��F꘏Z���0|4ǧ-�o�s�'���\u001b�S\u001b\u0013�\u0013�zT\u0003Ob�\u0000�
                  \u000b%=r\u0012�%\u0007qm��_O�5�o\u001fp<��.-R�)FI����{�.|�� �\ryƽA�\u001eS\f?�2�R<;Uy��+��EW�Z�;�r$�W!|�J=g�>��Z�/!w\bOUMH���A.(�;\u00015Ӕ�4!\u0015�2�\\u0007\u0018%�)V��R+/�'���PM!u�\u0000\fQ<��Gz�Zܥ��w�m\u0015�k�t#+D�\n�ڏ1��\u0007j���"ܕ\u0004�OsP{K�A ��\n���\u0011\u000b߸��
                  !Y6�^�O�dO�G���n��r�\u001ftݭ�\u000f;a�R����L��c��X��ҭ�ʟ�.�⼫R�;����\u0007�\u0015NI�\u001f�5^����V��!J�4�9�p��\b�j���4\u000f\u0011\u001d�]0��?V޾�F�\u001f�y�\b���L��uF���,K�7���҄\u0005,\tI�\u0007�d\u001b�\u0012�W��\u001a�\;moir�Y�l\u0005�|��z� ���w\u0013���/�r����Q}b3ڃ�\u0019�Z�5
                  \u000236/�s%Ĕ�\u0012?� ���$ք�z���f�JJ�xKoL��\u0000�b�o����dY]\u001f��D�\t��[K��VO�6����\u0000\t��\u0016��\u001dތ[+�_�S����٥\u0011wm\u0007r\u0012w�Oq��u�\u0018J=��#p4Nʕ(��4�\u000fw�3;�w��@�\u0012�Va����M͋�)C�7\u001f¡�^���T���\u000f�DngrNաD��k��3\u0013uh��>�n\���6�%m��b\u0003�]ybA�
                  ��M79+\u000b��ae{ql�8�n\u00157\r@�\u0005��Nh!$u��f�p�+�e����\u0000�Ί8�V��fݏ\u0017�Ҕ�\u001f�T�\u0014�\nK���<<ոLվ_Oemp�x琧��!\r��\u00029nj��R\b�\u0004Mf�(}��z3���!�u9l\u0016D9fm��Z�|>F�ڈ�\u0000\u0006@� ���|�1�Ņ�?#d��;��-��\u0005!cЃX���ys+�{g4�)���\u0007nScd�\u001d�2�\u0003�)����Wwr
                  ��T|�ȣ��\u0016$$\u0018�{Rb!JOcK3+\na+$\u0010\u0014\b���_~\n�>�V�����Z�o�T?\u0013Hq~k��\u0003�$���-�:��\u0011�y\u001fҘ���^�6)\~uC��\u000ecc����\rQ�N?\u0019j���L�������\u001f\u0010m���.p����\u0005�\~��$\u0002I��LZܻo�Z���_1�6����zn�������#yyG�4��Ko��3\u001aU|@V\u0007\u0019��8ܢ�6�
                  \u0012
                  m\�,�ޙ���qk+S�V�J2Oֶ/�w�7�\u0005��K�C��͝�̟���}Ԟ�OX��i�~�$͓M(ܺ�h"7\n&#��?���\u0013D�4��\nSeh�^n�\��~���\u001b�f��j��\�{�̓�[jCm(&{n����ދv��Ņ�\u0012 mWF\u001f\u000�W��\u0000ɳ\u0002R�%c�~���\u001c�B���\u000bmb�\n�ay6��;��H����\u0017%�n���'\u0018t��4�gR�9d�O�Z:�Jڱ�q,�\u001fu�6\\f�ǔ\u0016��ˠ\u000f�\u0001�"?�9��~��"��i\u0003�F&��n7@�$�*\f>�N9����#�8]�l�m�))#�Oy+nE\u0000 \u0001]�ĥ�V��#��X�lӸ�a�N%A���3�ԩ/�,�D��\u0014^��\f����\u0012���{�Gj&����#�FԹ0011�?Z���+a��k�87\u001c�\u001f�KBL�\u0015gcy{��k���ʗ�i\u000e.:\u0002��U�CVk;+{\u000f��p�.�|��G�r�\f\u0013����#F�3L|�>\u0013�ʏZ��܋t�GQ�TN���0LH�M<Y]\u0007\u0010C�&\u000fOZH�S%��^\'/!$H\u0004�Kl.�i��\'�ҫ�\u001b�B���=�Mh�B7P��<�Vɓ.�\u001eh#��P>.p�ljx֜\u000e|&Jؒ��D�z��O���\u0007����v7�V�U���\u0007d�E�]�\u000f�:����ǧ��ֹ�ZyT\fA\u0003b)\u0001e%�8��ܴ�Xa�yz�R]j��o\u0012�\u0012\P��\u0000a\u0003�7\nIC�D�g�j�'\u0007h�QRTg��E��b�q\u001a�RZ��V�n-Ck�$�A$\u001f]�\n��\u00194e�Kl���Jҕ\%��T\u001d�ă#�����_\u001cm�\u0015ƺq��-l��բ�!����\u0000��\u000bg���<��X7\u001fdyT�\u00?�g\t�r�QiT���w�[�\t\u0003�\u0015�(�\u0005I$�'a�0o�\u000f\u0000t�7���]5�^5�C�e�g���B�\u000e�4�\u0012�\u0006I�02�R}ұ^�O'�6�?\u0007'��"Q�x�Ýk�N>�Y\u001cb�!��.7r��A�7\u0012}�5��k�,n�ª���)\u0001jB~�duJ���H��6l8oʵ��f��%,8��$�s&I\u0013L�_�W�=ϻ��ߪTavʹC\u000e#���נޮڼ\u0015�}��ō�^A<�\n�\��~���\u001b�f��j��\�{�̓�[jCm(&{n����ދv��Ņ�\u0012 mWF\u001f\u0006\f�ǔ\u0016��ˠ\u000f�\u0001�"?�9��~�u001d%D�������\u0010D-c�\rċ>#a�y2z�Sd\u001dD=�ũ\u0016��\u001e�)@�1�R�"�\u001b-\u001c��ʑ�|j\u0012\u0000'���u�G]�KKOn�5�x)���\u000b�\u0000��}��[���\u001f�2�Y��(�p�d��\u0<Y]\u0007\u0010C�&\u000fOZH�S%��^'/!$H\u0004�Kl.�i��'�ҫ�\u001b�B���=�Mh�B7P��<�Vɓ.�\u001eh#��P>.p�ljx֜\u000e|&J01fZ�m�ٜ;\r��3=�Bv\n�d��ٲ��ӡ\nW�(Q�|^�~��9�kq\u000e�b�q7V�\t����y\u0006?�(�� RAJ=1�'�/��p5<2�\u0002s��\u0001g��\t]dž�t��2�S�sHP\u001d�Q���Á�tv�1_e�ָ\ff��8��9�s6i�r���Bu000bg���<��X7\u001fdyT�\u0002�R}ұ^�O'�6�?\u0007'��"Q�x�Ýk�N>�Y\u001cb�!��.7r��A�7\u0012}�5��k�,n�ª���)\u0001�\u001cI0��m�\u0004\u001e�gҾ5��,$%=\u0005d̹���\u0010���Z���e$�֣\u0019\u0004��]\u0000��S=r���x�p\u001fƢ\u00191���\t�H5�K�~\'���\\���V\u0012���?�:�:H �4�\u001cֶ덀)?�:Z��1c��ʑ�|j\u0012\u0000'���u�G]�KKOn�5�x)���\u000b�\u0000��}��[���\u001f�2�Y��(�p�d��\u001fZ�m�ٜ;\r��3=�Bv\n�d��ٲ>�\u0011\u001fe��ܑ\u0016Y�H%e�ܶ'��PT�\u0013V\u0016��\u0017\u0018�m�G��o\u0003����tA?.a��E�.Ŗm���ql�p�E\X�!��=r�[\u000b��i�֥\r�m\�~B������E�U�C\u0016��Y�I��X�;W�ٴ�i�����gҾ5��,$%=\u0005d̹���\u0010�`��Z���e$�֣\u0019\u0004��]\u0000��S=r���x�p\u001fƢ\u00191���\t�H5�K�~'���\���V� \u0004� �A�;�U\u000f\u00130\u000e�:rv�U�\u0017J幷\u001e^GD�"��_\u0013�<]��_\u001bw��ކ\u001e��n���>ˉq�\u0005��F�$F�F���m�\u0000���R��E�Y��qmn�>\u0013�T�����1W�d��pU�\u001��E�U�C\u0016��Y�I��X�;W�ٴ�i����� \u0004� �A�;�U\u000f\u00130\u000e�:rv�U�\u0017J幷\u001e^GD�"��_\u0013�<]dJ���' }
                  in einem Browser direkt funktioniert es gut allerdings gut nur nicht in einer Adapter.
                    @skokarl
                    LOL, Danke für die Prüfung, schade.
                    • Issi
                      Issi Developer @Guest last edited by
                      Hallo @ilovegym
                      die Helligkeit ist nicht von den Bewegungsmelder abhängig hast du sie über die config Seite eingestellt oder über die manuelle Einstellmöglichkeit in den Dp.
                      Falls du es über die manuelle Einstellmöglichkeit geändert hast sohlte es so aussehen erst den (brightness control mode) auf User also true stehlen ( das sohlte man nicht zu schnell machen da es sonst nicht reagiert ) dann die Helligkeit verändern.
                      es sohlten alle Bewegungsmelder angenommen werden wie oben schon beschrieben sohltest du die Version 1.39 vom Fully Browser haben funktioniert da die Bewegungserkennung nicht (bzw. er schaltet den Screensaver aus aber nicht mehr ein) da im Browser noch ein bug ist dieser wird mit dem nächsten update behoben werden.
                      • Issi
                        Issi Developer @jackblackson last edited by
                        @jackblackson
                        Hi, theoretisch war es nur fürs steuern von den Tablet gedacht gewesen aber dein Vorschlag könnte man noch mit einbauen welche von diesen :
                        1. Automatischer Wechsel auf HomeView nach eingestellter Zeit
                          (Anzeigezeit für jede View separat einstellbar)
                        2. "Slideshow", ausgewählte Views laufen der Reihe nach durch
                          (Anzeigezeit fest oder für jede View separat einstellbar)
                        3. View Wechsel durch Auslöse-Trigger, bspw. Bewegungsmelder -> KameraView
                        4. Screensaver Seitenwechsel
                        sollen den in den Adapter rein?
                        jackblackson 1 Reply Last reply Reply Quote 0
                        • jackblackson
                          jackblackson @Issi last edited by
                          @Issi Hallo! Es ginge um 1., zurück auf Main nach ein paar Minuten damit es wieder auf Default“ ist wenn man zum Tablet geht..aber ja, ich bin mir auch nicht sicher ob es ganz richtig ist in deinem Adapter. Glaub aber das es viele freuen würde.
                          • Issi
                            @jackblackson
                            ok dann werden ich es mal ein bauen
                            • Issi
                              Issi Developer last edited by Issi
                              Die Bewegungsmelder Funktion funktioniert mit der Fully Kiosk Browser Version 1.39.2 wieder
                              es ein eine neue Version 0.1.8 auf GitHub und npm verfügbar:
                              es wurde Automatische Änderung zu HomeView hinzufügen
                              jackblackson 1 Reply Last reply Reply Quote 1
                              • Issi
                                neue Version 0.1.9 auf GitHub verfügbar:
                                Fehler im automatischen Wechsel zum HomeView Widget 8 behoben
                                • jackblackson
                                  jackblackson @Issi last edited by jackblackson
                                  @Issi Servus! Hab grad die 0.1.8 geladen, und der Adapter ist wirklich schon sehr cool! Das "Zurück zu Main" funktioniert bei mir auch. Was mir nur aufgefallen ist, ist das er jedes mal wenn er den View wechselt diese Meldung schmeißt:
                                  PS: Ich hab zum Testen den Zeitraum auf 30 Sekunden gestellt, deshalb die kurzen Zeiträume
                                  PPS: Ok, es scheint nichts mit meinen 30 Sekunden zu tun haben, sondern er loggt das immer, hab den Zeitraum nun auf 10 Minuten für den "Zurück zu Main" gestellt - aber immer noch alle 30 Sekunden den Logeintrag.
                                  Issi 2 Replies Last reply Reply Quote 0
                                  • Issi
                                    @jackblackson diese Meldung hat nicht mit dem View wechselt zutun sondern mit dem laden vom Tablett schau mal wieviel % dein Tablet hat die Meldung sohlte kommen wen das Tablet von unter 18% auf über 18% steigt es
                                    • Issi
                                      Issi Developer @jackblackson last edited by Issi
                                      @jackblackson
                                      hab ne neue Version 0.2.0 auf GitHub hochgeladen hab da die Warnmeldung in eine info umgestellt und ein Limit für die Meldung eingebaut so das sie nur einmal angezeigt wird wen die Bedingung erfüllt ist.
                                      nur noch mal zu Info diese 2 Meldungen gehören zu Lade Funktion von dem Tablett und werden ausgelöst wen der Ladezustand auf 18% fällt und dann wider auf über 18 % steigt.
                                      • Mic
                                        Mic Developer @Issi last edited by
                                        Hey @Issi
                                        sehr cooler Adapter! Ich habe aber noch nicht näher getestet. Jedenfalls tolle Funktionen.
                                        Erstes, frühes Feedback:
                                        1. Der Adapter heißt "Tablet Control", aber geht nur mit dem Fully Browser unter Android. Das verwirrt ggf. die Nutzer von iPads etc. wenn sie "Tablet Control" lesen. Evtl. wäre "Android" oder sogar "Fully" als Namensbestandteil besser.
                                        2. Ich hatte mal ursprünglich das Fully Browser Script entwickelt, das dann @arteck in den Fully Adapter umwandelte. Der Adapter ist ziemlich schlank, warum implementierst du das nicht in den bestehenden Adapter? Oder du übernimmst die Funktionalität (ist wirklich nicht viel, ich weiß das als Autor des ursprünglichen Scripts 😉 ) in deinen neuen Adapter. Denn sonst braucht man mindestens 2 Adapter-Instanzen, z.B. der Fully Adapter verbraucht bei mir aktuell 61,5 MB.
                                        Issi 1 Reply Last reply Reply Quote 2
                                        • Issi
                                          Issi Developer @Mic last edited by Issi
                                          Hey @Mic
                                          das mit dem Namen vom Adapter hab ich mir auch schon überlegt ihn zu ändern hab den Namen in der Version 0.2.2 geändert ( Fully Tablet Control ).
                                          den alten bitte deinstallieren und den neuen von https://github.com/xXBJXx/ioBroker.fully-tablet-control oder npm i iobroker.fully-tablet-control installieren
                                          Und zu der Nr.2 von dir das muss ich mir mal überlegen ob ich alles von dem fully adapter übernehme oder nur einzelne Funktionen da ich finde das im fullybrowser unter Info 60% von den Dp unnötig sind.
                                          Mic 1 Reply Last reply Reply Quote 0
                                          • Mic
                                            Mic Developer @Issi last edited by Mic
                                            Bin absolut deiner Meinung wegen der vielen Info-Datenpunkte. Diese werden vom Script/Adapter automatisch über eine Schleife angelegt, also alles, was die Fully API über die API per cmd=deviceInfo zurückgibt. Sicherlich kann man da vieles rauswerfen/ausfiltern.
                                            Mir persönlich fehlen die Commands-Datenpunkte, um den Fully direkt zu steuern, z.B. screenOn/screenOff, loadStartURL,etc.
                                            adapter fully kiosk browser fullybrowser tablet tablet-control test testen
                                            50
                                            512
                                            80038
