    4. deConz Adapter bleibt nach update gelb
    UNSOLVED deConz Adapter bleibt nach update gelb
      monarc last edited by monarc
      Habe gerade den Adapter nochmal deinstalliert und wollte jetzt 1.3.5 neu installieren. Während der Installation kommen auch schon Fehlermeldung. Eine Instanz gibt es nun trotzdem....
      Update: Muss mich korrigieren. Es gibt tatsächlich keine Instanz. Ein Update des Adapters auf 1.3.6 wird mir trotzdem angeboten....
      $ ./iobroker upgrade deconz@1.3.5
      Update deconz from @0.0.0 to @1.3.5
      NPM version: 6.14.4
      npm install iobroker.deconz@1.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
      ERR!
       sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1info sharp Attempting to build from source via node-gyp but this may fail due to the above errorinfo sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
      ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^
      compilation terminated.
      make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
      gyp
      ERR!
       build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.66-v7+gyp
       ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
      upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
      upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
      upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
      Adapter "deconz" updated
      process exited with code 0
      Un hier noch die Ausgabe beim Deinstallieren des Adapters (ohne Instanz). Sah allerdings auch beim erstem mal Deinstallieren ähnlich aus.
      $ ./iobroker del deconz
      Delete adapter "deconz"
      host.raspberrypi Counted 1 meta of deconz
      host.raspberrypi Counted 1 adapter for deconz
      host.raspberrypi Counted 1 objects of deconz
      host.raspberrypi file deconz.admin deleted
      host.raspberrypi object deconz.admin deletedhost.raspberrypi Deleting 3 object(s).
      npm uninstall iobroker.deconz --error --prefix "/opt/iobroker" (System call)
      ERR!
      ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^compilation terminated.
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.66-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      npm
       WARN
       optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        Thomas Braun Most Active @monarc last edited by Thomas Braun
        @monarc said in deConz Adapter bleibt nach update gelb:
        Merkwürdige Versionsnummer.
        Da fehlen vmtl. dev-Pakete (u. a. libvips-dev). Und eine aktuelles node12 evtl. auch.
          monarc @Thomas Braun last edited by
          @Thomas-Braun
          Ist die Neuinstallation, kA ob die Ausgabe dann so zu erwarten ist
          Wie genau installier ich diese dev Pakete denn. Hatte mich da schon mal dran versucht, leider erfolglos.
          Hatte die Meldungen bis vor Kurzem auch noch nie....
            @monarc Okay, dann würde ich aber bei einer Neuinstallation auch nicht upgraden sondern installieren.
            Was für ein System hast du da?
            lsb_release -a
              @Thomas-Braun said in deConz Adapter bleibt nach update gelb:
              lsb_release -a
              pi@raspberrypi:~ $ lsb_release -a
              No LSB modules are available.
              Distributor ID: Raspbian
              Description:    Raspbian GNU/Linux 9.11 (stretch)
              Release:        9.11
              Codename:       stretch
                @monarc Och, stretch... Da müsste man recht viel dran umbauen/selberbauen. Selbst ein buster würde da schon Mühe machen, wenn ich das richtig überflogen habe. Da trau ich mich nicht ran ohne Testsystem.
                  @Thomas-Braun
                  Was wäre denn aktuell zu empfehlen? Bis jetzt galt für mich never touch a running system....
                  Aber ich mein bis zum ersten Upgrade auf 1.3.6 und auch nach dem ersten Downgrade zurück auf 1.3.5 lief ja alles mehr oder weniger gut.
                  Erst nach der aktuellen Meldung (Infosytem), dass man vor dem Upgrade auf 1.3.6 den Deconz adapter deinstallieren soll fing das ganze "Drama" an.....
                    @monarc Dann installier die 1.3.5, wenn die lief.
                    Wenn du ein Backup hast und risikofreudig bist können wir das auch hier probieren. Aber nicht von stretch aus, buster wäre da Minimalvoraussetzung für.
                      Okay 1.3.5 scheint jetzt wieder zu laufen
                      deconz.0	2020-05-07 15:02:26.602	info	(29850) Code 404: Ressource not found get devices: []
                      deconz.0	2020-05-07 15:02:25.832	info	(29850) deConz Version: 2.5.71; API version: 1.16.0
                      deconz.0	2020-05-07 15:02:25.442	info	(29850) starting. Version 1.3.5 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.20
                      Wieso 1.3.6 nicht läuft wäre dann trotzdem noch Interessant.... vielleicht fällt ja noch jemanden was auf?
                        @monarc
                        ldd -version
                          @Thomas-Braun
                          pi@raspberrypi:~ $ ldd --version
                          ldd (Debian GLIBC 2.24-11+deb9u4) 2.24
                            @monarc
                            Das sind jetzt mehrere Abhängigkeiten (dependencies) die da manuell aufgelöst werden müssten.
                            Stretch hat die glibc 2.24 im System, der deconz Adapater benötigt ein Modul 'sharp' was es aber nicht vorkompiliert gibt. Also versucht der Installer sharp zu bauen, scheitert aber, weil sharp auch libvips in einer bestimmten Version braucht. Gibt es aber beides nicht für den ARMV7 Chipsatz mit einer Distribution die auf glibc <= 2.28 baut:
                            The following platforms require compilation of both libvips and sharp from source:
                            Linux ARM64 (glibc <= 2.28, musl)
                            Usw... Da muss ziemlich viel rekompiliert werden. Und mit der alten glibc von stretch macht das keinen Spaß.
                            Auf meinem buster muss ich das mal irgendwann gemacht haben. Kann ich mich aber gar nicht dran erinnern... Jedenfalls hab ich hier sharp in den node-modules liegen.
                              @Thomas-Braun
                              Hmm, versteh ich das richtig, dass der Deconz Adapter (auf einmal ) Sharp benötigt und dieses nicht ARMV7 Chipsatz kompatibel ist und somit nicht auf dem RPi laufen kann?! Oder liegt das alles nur an Stretch?
                                @monarc Das kann man schon bauen.
                                Ich hab das mal irgendwann gemacht, scheint mir.
                                pi@raspberrypi:~ $ ls -la /opt/iobroker/node_modules/sharp/
                                insgesamt 100
                                drwxrwxr-x+   9 iobroker iobroker  4096 Apr 28 21:04 .
                                drwxrwxr-x+ 791 iobroker iobroker 28672 Mai  6 20:46 ..
                                -rw-rwxr--+   1 iobroker iobroker  7245 Okt 26  1985 binding.gyp
                                drwxrwxr-x+   3 iobroker iobroker  4096 Apr 28 21:04 build
                                drwxrwxr-x+   2 iobroker iobroker  4096 Apr 15 07:11 install
                                drwxrwxr-x+   2 iobroker iobroker  4096 Apr 15 07:11 lib
                                -rw-rwxr--+   1 iobroker iobroker 10273 Okt 26  1985 LICENSE
                                drwxrwxr-x+   3 iobroker iobroker  4096 Apr 15 07:11 node-addon-api
                                drwxrwxr-x+   5 iobroker iobroker  4096 Apr 24 07:05 node_modules
                                -rw-rwxr--+   1 iobroker iobroker  8981 Apr 15 07:11 package.json
                                -rw-rwxr--+   1 iobroker iobroker  3238 Okt 26  1985 README.md
                                drwxrwxr-x+   3 iobroker iobroker  4096 Apr 15 07:11 src
                                drwxrwxr-x+   4 iobroker iobroker  4096 Apr 15 07:11 vendor
                                Von buster aus sind die Klimmzüge aber nicht ganz so groß, weil da glibc 2.28 schon läuft.
                                (Und ich sehe, dass mir dabei wohl auch ein Fehler unterlaufen ist. Vermutlich im falschen Verzeichnis gestanden...) 🙂
                                  Naja, dann werd ich demnächst wohl irgendwann mal auf Buster gehen.
                                  Bleibt trotzdem Interessant ob der Deconz Adapter mit einem der nächsten Updates wieder funktioniert.
                                  Vielleicht kann sich zu der Abhängigkeit des Adapters und sharp ja mal jemand melden.
                                  @Jey-Cee Hast du vielleicht eine Idee?
                                  Jey Cee 2 Replies Last reply Reply Quote 0
                                  • Jey Cee
                                    Jey Cee Developer @monarc last edited by
                                    @monarc muss dich Entäuschen ich weis da nix.
                                    • Jey Cee
                                      @monarc so ich hab jetzt nochmal hier Quer gelesen und mal die Abhängigkeiten des Adapters durchsucht, package-lock.json, da taucht sharp auch als indirekte Abhängikeit nicht auf.
                                      Der Fehler kommt aber von gyp und das wiederum wird bei jeder installation eines Paketes aufgerufen wenn Abhängigkeiten im System Kompiliert werden müssen.
                                      Sprich bei jeder Installation wird versucht ausstehende oder Fehlerhafte Abhängigkeiten zu Korrigieren.
                                        Thomas Braun Most Active @Jey Cee last edited by Thomas Braun
                                        @Jey-Cee said in deConz Adapter bleibt nach update gelb:
                                        Ah, okay, das wusste ich so nicht. Da ist also mal irgendwas anderes kleben geblieben. Ich dachte sharp würde evtl. für eine Netzwerkkarte des zigbee-Netzes benötigt. Dann nix für ungut! War ich auf dem Holzweg!
                                          Jemand ne Idee wie ich gyp Fehler beheben kann?
                                          @Jey-Cee Meinst du das Problem (ständige Neustarts des Adapters) von 1.3.6 ist mit 1.3.7 behoben?
                                          • Jey Cee
                                            @monarc Nein das wird bei dir weiterhin auftreten weil deine JS-controller Version das Problem ist. Aktualisiere den auf 3.0.20 und das Problem ist weg.
                                            Hintergrund ist das eine Prüfung eingebaut wurde ob die setState Funktion einen Wert mit übergibt. Nur habe ich wegen Einfachheit, Performance gründen und weil es meiner Meinung nach auch nicht nötig ist keinen Wert übergeben. Nach Rücksprache mit den Core Entwicklern wurde die Änderung wieder raus genommen.
                                            M F 2 Replies Last reply Reply Quote 0
                                            deconz update fehler
                                            2306
